Hi, I made an object, and then wanted to see what happened if I did a
Minkowski sum of the object with a small sphere. Since Minkowski is like
black magic to me I just wanted to see what happened, hoping for the corners
of my object being rounded.
The result was crashing OpenSCAD most of the times, and the other times I
got lots of these errors:
CGAL error in CGALUtils::applyBinaryOperator union: CGAL ERROR: assertion
violation!
Expr: G.mark(v1,0)==G.mark(v2,0)&& G.mark(v1,1)==G.mark(v2,1)
File:
/data/OpenSCAD/libraries-mingw64-master/mxe-w64/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_S2/SM_overlayer.h
Line: 287
violation!
Expr: itl != it->second.end()
File:
/data/OpenSCAD/libraries-mingw64-master/mxe-w64/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1102
The code used is:
depth=20;
height=43;
width=60;
outerhole=20;
innerhole=10;
minkowski() {
cube([depth, width, height], center=true);
translate([0,0,height/10]) rotate([0,90, 0]) cylinder(d=outerhole,
h=depth*2, center=true);
translate([0, -width/2+(width/8.1), height/2.75]) cube([depth+1,
width/4, height/3], center=true);
translate([0, width/2-(width/8.1), height/2.75]) cube([depth+1,
for (x = [-4,12])
for (y = [-22,22])
rotate([0,90,0]) translate([x,y,0]) cylinder(d=5.5,
h=depth+1, center=true);
translate([0,-width/2+8,0]) cylinder(d=6.6, h=height+1,
center=true);
mirror([0,1,0]) translate([0,-width/2+8,0]) cylinder(d=6.6,
h=height+1, center=true);
sphere(2);
Worth investigating? (Using 2014.12.18 on Win64 )
View this message in context: http://forum.openscad.org/Crash-when-using-minkowski-on-my-object-tp10668.html
You're lucky, it crashed OpenSCAD on my system. (OpenSCAD 2014.12.18, W7/64)
View this message in context: http://forum.openscad.org/Crash-when-using-minkowski-on-my-object-tp10668p10670.html
When I do F5/F6 it just hangs. This is because minkowski is a really slow
module(). Setting $fn=3; gave me a result after a while.
version 2014.12.04 x64 windows
View this message in context: http://forum.openscad.org/Crash-when-using-minkowski-on-my-object-tp10668p10671.html
Probably same as issue 947 https://github.com/openscad/openscad/issues/947
View this message in context: http://forum.openscad.org/Crash-when-using-minkowski-on-my-object-tp10668p10672.html
Strike that.
I'm not sure if minkowski is designed for something with a hole in it.
depth=20;
height=43;
width=60;
outerhole=20;
innerhole=10;
minkowski()
cube([depth-4, width-4, height-4], center=true);
sphere(2);
cylinder(d=outerhole, h=depth*2, center=true);
cube([depth+1, width/4, height/3], center=true);
for (x = [-4,12])
for (y = [-22,22])
translate([0,-width/2+8,-0.5]) cylinder(d=6.6, h=height+1,
center=true);
mirror([0,1,0]) translate([0,-width/2+8,-0.5]) cylinder(d=6.6,
Doesn't round the cut-outs tho.
View this message in context: http://forum.openscad.org/Crash-when-using-minkowski-on-my-object-tp10668p10673.html
I hope I do not cause offense when I make mention of this, but I’ll risk it anyway.
OpenSCAD is a tool. As such it is intended to be used by someone with a reasonable amount of skill in the trade for which the tool is applied. This means using the tool within normal limits or pushing those limits somewhat if only to understand what they are.
Lately I have been seeing a lot of posts on the topic of “I used my knife as a screwdriver and it broke” followed by “should we fix this issue?”. The answer is “No, never use a knife as a screwdriver.”.
I hope you will pardon my attempt at humor and get my point which is: I use the tool properly and have none of these issues. You should too.
Les
On Dec 20, 2014, at 6:57 PM, MichaelAtOz oz.at.michael@gmail.com wrote:
Strike that.
depth=20;
height=43;
width=60;
outerhole=20;
innerhole=10;
minkowski()
sphere(2);
for (x = [-4,12])
for (y = [-22,22])
center=true);
it anyway.
Les
Les, no offense is taken :) I understand your point, but let me also make
mine.
Lets change your analagy a bit - OpenSCAD is a workshop. It has a workbench,
some powertools and some materials. I just picked up the minkowski-powertool
that I haven't really used before, used it on a block of wood, and suddenly
my entire workshop burned to the ground. I think we can all agree that
anything that causes the workshop to go up in flames deserves to be looked
at.
I would either have expected the result to look really weird, or perhaps
take a long time to compute, but certainly not kill the application.
Yes, I agree that I'm most likely misusing the tool. I also hinted at that
in the initial post. Your argument of "Just use the tool properly" assumes
that one knows how the tool works. A common way of figuring out how a
certain tool works is "lets just try it and see what happens". Trial and
error. I've read the documentation for minkowski(), and the definition of
the minkowski algorithm, but I will still need to just "take it for a spin"
before I see all the usecases where it is suitable to use.
I find OpenSCAD a very interresting application, with a good community
spirit. Marius and Torsten do a fantastic job of listening to the users, and
I've seen several examples where feedback from users have been implemented
by them within minutes. My thought when sharing the crash-situation was that
they might see an issue that should be fixed, even though I admittely did
write funky code.
View this message in context: http://forum.openscad.org/Crash-when-using-minkowski-on-my-object-tp10668p10677.html
Michael, here is a simple example that has a hole in it, and where I think
minkowski serves a purpose.
minkowski() {
cube([20,20,2]);
translate([10,10,-1]) cylinder(h=30, r=5);
sphere(1);
View this message in context: http://forum.openscad.org/Crash-when-using-minkowski-on-my-object-tp10668p10678.html
Software should never crash, regardless of misuse.
View this message in context: http://forum.openscad.org/Crash-when-using-minkowski-on-my-object-tp10668p10679.html
I like your workshop analogy. You got out a power tool and it hurt you. There’s a saying “Power tools maim”, and it is a warning and a reminder that we must be very careful when using such tools. You’re not being careful, you’ve got a circular saw in your hands and you cut the cord with it. Of course it broke. The shop didn’t burn down, you can run OpenSCAD again, it just quit working cause you used it improperly.
OK, silly analogies aside, I’ve noticed there are two kinds of computer users: those who try to make software work and those who try to break it and then complain that it broke. Which one are you?
Just my perspective…
Les
On Dec 21, 2014, at 4:52 AM, Scalpel78 frode@lillerud.no wrote:
it anyway.
Les
mine.
at.
write funky code.
