Hello. I'm trying to write a module that will perform an operation on subsets
of its children. I tried using children() with an index, but this still
seems to give me all of the children. I'm seeing this behavior both with
2013.01+dfsg-2.2 (the latest binary in the Ubuntu 14.04 repo) and a build I
did myself from git commit 0dd3f004dd66798faef42ab4edaa72c12dc0ad66.
Here's a simplified version of what I'm trying that illustrates the problem:
module first() {
child(0);
first() {
for(i=[0:20:120]) {
rotate([0,0,i]) translate([10,0,0]) cylinder();
The for loop generates 7 cylinders in an arc. I would expect the "first"
module to then ignore all of them except the first, so I expect to see only
one cylinder. Instead I see all 7.
I have tried using children() instead of child() and I have also tried using
index=0 instead of just 0 as the parameter. Either way, the result is the
same (except some don't compile on the older OpenSCAD binary).
Any ideas what I'm doing wrong?
View this message in context: http://forum.openscad.org/How-to-get-at-individual-children-tp11738.html
You ar enot doing anything wrong, there is an implicit union()
happening after for().
See the note here:
http://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Conditional_and_Iterator_Functions#Intersection_For_Loop
And see this: https://github.com/openscad/openscad/issues/350
Miro Hrončok
Telefon: +420777974800
2015-02-24 0:02 GMT+01:00 xenomachina from-openscad@xenomachina.com:
module first() {
child(0);
first() {
for(i=[0:20:120]) {
The problem is for always unions it children so there is only ever one
child of first() and that is the for() node.
On 23 February 2015 at 23:02, xenomachina from-openscad@xenomachina.com
subsets
problem:
module first() {
child(0);
first() {
for(i=[0:20:120]) {
using
Ah, I see. Thanks.
Is there any workaround for this behavior? I tried rebuilding OpenSCAD in
the issue350 branch and running it with the --enable=lazy-union flag, but
it still gives me 7 cylinders.
On Mon, Feb 23, 2015 at 3:07 PM, Miro Hrončok [via OpenSCAD] <
See the note here:
Miro Hrončok
2015-02-24 0:02 GMT+01:00 xenomachina <[hidden email]
http:///user/SendEmail.jtp?type=node&node=11739&i=0>:
subsets
build I
problem:
module first() {
child(0);
first() {
for(i=[0:20:120]) {
only
using
[hidden email] http:///user/SendEmail.jtp?type=node&node=11739&i=1
[hidden email] http:///user/SendEmail.jtp?type=node&node=11739&i=2
below:
http://forum.openscad.org/How-to-get-at-individual-children-tp11738p11739.html
To unsubscribe from How to get at individual children?, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=11738&code=ZnJvbS1vcGVuc2NhZEB4ZW5vbWFjaGluYS5jb218MTE3Mzh8MjA2MDM4NDcyNA==
NAML
View this message in context: http://forum.openscad.org/How-to-get-at-individual-children-tp11738p11748.html
No because children are not individual 3D objects, They are child nodes in
the syntax tree.
E.g.
child(1) {
a();
b();
c();
will select b(), which could generate many objects.
On 24 February 2015 at 20:53, xenomachina from-openscad@xenomachina.com
Ah, I see. Thanks.
On Mon, Feb 23, 2015 at 3:07 PM, Miro Hrončok [via OpenSCAD] <[hidden
See the note here:
Miro Hrončok
Telefon: <a href="tel:%2B420777974800" value="+420777974800" target="_blank">+420777974800
subsets
with
build I
problem:
module first() {
child(0);
first() {
for(i=[0:20:120]) {
"first"
only
using
discussion below:
To unsubscribe from How to get at individual children?, click here.
NAML
View this message in context: Re: How to get at individual children?
at Nabble.com.
Yes, get that that's the behavior of for, though I honestly don't see how
the implicit union is desirable, except for backward compatibility.
What I'm asking is: how can I create a sequence of 3D objects in a loop,
and then iterate through them individually in a separate module? For
example, is there a way to get at the individual children of a union?
Here's a more concrete example of what I'd like to be able to do:
module hull_join() {
for_without_a_union (i=[0:$children - 2]) {
hull() {
children(index=i);
children(index=i+1);
hull_join() {
for_without_a_union(i=[0:20:120]) {
If for_without_a_union existed, then this would create a set of cylinders
in an arc and then hull_join would union together the hulls of each
adjacent pair producing a round arc path. See this combined screenshot:
https://imgur.com/MJjDlcY
To generate the left half of that screenshot I ended up manually unrolling
the loop, but I'm hoping there's a way to use/implement hull_join that
doesn't require unrolling loops, inlining the caller, or other sorts of
special-casing.
On Tue, Feb 24, 2015 at 12:59 PM, nophead [via OpenSCAD] <
the syntax tree.
E.g.
child(1) {
a();
b();
c();
On 24 February 2015 at 20:53, xenomachina <[hidden email]
http:///user/SendEmail.jtp?type=node&node=11749&i=0> wrote:
Ah, I see. Thanks.
See the note here:
Miro Hrončok
Telefon: <a href="tel:%2B420777974800" value="<a
+420777974800" target="_blank"><a href="tel:%2B420777974800" value="
subsets
still
with
build I
problem:
module first() {
child(0);
first() {
for(i=[0:20:120]) {
"first"
only
using
discussion below:
NAML
at Nabble.com.
[hidden email] http:///user/SendEmail.jtp?type=node&node=11749&i=1
[hidden email] http:///user/SendEmail.jtp?type=node&node=11749&i=2
below:
http://forum.openscad.org/How-to-get-at-individual-children-tp11738p11749.html
NAML
View this message in context: http://forum.openscad.org/How-to-get-at-individual-children-tp11738p11750.html
Have you considered recursion? (I haven't for your particular issue, brain
not awake yet)
View this message in context: http://forum.openscad.org/How-to-get-at-individual-children-tp11738p11751.html
That's an interesting idea!
I just tried this...
module segment(i, step, last) {
if (i < last) segment(i + step, step, last);
hull_join() {
segment(0, 20, 120);
... and I still end up with something that looks a like the right image.
Something still seems to be making an implicit union. Is there some other
approach that could avoid this?
On Tue, Feb 24, 2015 at 2:27 PM, MichaelAtOz [via OpenSCAD] <
not awake yet)
Public Domain; To the extent possible under law, I have waived all
copyright and related or neighbouring rights to this work. This work is
published globally via the internet. :)
Inclusion of works of previous authors is not included in the above.
http://www.ourfairdeal.org/
below:
NAML
View this message in context: http://forum.openscad.org/How-to-get-at-individual-children-tp11738p11752.html
hull_join() {
This doesn't work with arbitrary 3D objects, but will do what you want from one
child and a series of transformations:
use <scad-utils/transformations.scad>
module hull_join (transformations)
for (i = [0 : len (transformations) - 2])
hull () {
multmatrix (transformations[i])
children ();
multmatrix (transformations[i + 1])
children ();
Kind regards,
Loong Jin
Also worth looking at is generalized extrusion along path:
Kind regards,
Loong Jin
