Making adjustments to an STL in OpenSCAD?
Terry
Mon, Jul 17, 2023 10:56 AM
This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty
well a few months ago, and I made a couple in anticipation of future
use.
But I'd now like to quickly make two small adjustments before printing
another in Cura:
  1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now
    have a way of making the rectangular hole in the project case with
    sufficient accuracy to allow such a tiny overlap; we'll see!
  2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm.
    A couple broke when I tried to push-fit, and I used hot glue. The change
    will probably need trial/error. (Unless I can improvise something. I'm
    thinking maybe a tightly folded cylinder of sandpaper?)
No SCAD file was available so I imported the STL (an excellent feature
of OpenSCAD). But is there some way to get the STL converted to SCAD
code?
I know I can Add, Difference, Translate, etc, but apparently not
directly change dimensions of the existing objects?
Terry
This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty well a few months ago, and I made a couple in anticipation of future use. But I'd now like to quickly make two small adjustments before printing another in Cura: 1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now have a way of making the rectangular hole in the project case with sufficient accuracy to allow such a tiny overlap; we'll see! 2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm. A couple broke when I tried to push-fit, and I used hot glue. The change will probably need trial/error. (Unless I can improvise something. I'm thinking maybe a tightly folded cylinder of sandpaper?) No SCAD file was available so I imported the STL (an excellent feature of OpenSCAD). But is there some way to get the STL converted to SCAD code? I know I can Add, Difference, Translate, etc, but apparently not directly change dimensions of the existing objects? Terry
Mon, Jul 17, 2023 11:06 AM
You can scale or resize it in any axis but apart from that no, you can't
change an arbitrary dimension. I think there are programs that will convert
an STL to a polyhedron but that would be hard to find the right numbers to
tweak.
use.
another in Cura:
code?
Terry
You can scale or resize it in any axis but apart from that no, you can't change an arbitrary dimension. I think there are programs that will convert an STL to a polyhedron but that would be hard to find the right numbers to tweak. On Mon, 17 Jul 2023 at 11:57, Terry <terrypingm@gmail.com> wrote: > This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty > well a few months ago, and I made a couple in anticipation of future > use. > > But I'd now like to quickly make two small adjustments before printing > another in Cura: > > 1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now > have a way of making the rectangular hole in the project case with > sufficient accuracy to allow such a tiny overlap; we'll see! > > 2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm. > A couple broke when I tried to push-fit, and I used hot glue. The change > will probably need trial/error. (Unless I can improvise something. I'm > thinking maybe a tightly folded cylinder of sandpaper?) > > No SCAD file was available so I imported the STL (an excellent feature > of OpenSCAD). But is there some way to get the STL converted to SCAD > code? > > I know I can Add, Difference, Translate, etc, but apparently not > directly change dimensions of the existing objects? > > Terry > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Mon, Jul 17, 2023 12:20 PM
use.
another in Cura:
code?
No you can't. Or actually you can, but it doesn't help you.
The STL file is nothing else than a list of points, and then a list of
triangles between those points. So say a cube would consist of 8 points
and 12 triangles (two for each face).
So that cylinder that you wanted to change in size is a whole lot of
points.
What I do in such a situation is to just reconstruct the openscad code
myzelf. I start out overlaying them with the STL and tweaking the
positions and sizes until I get them the same as in the STL.
On Mon, Jul 17, 2023 at 11:56:54AM +0100, Terry wrote: > This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty > well a few months ago, and I made a couple in anticipation of future > use. > > But I'd now like to quickly make two small adjustments before printing > another in Cura: > > 1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now > have a way of making the rectangular hole in the project case with > sufficient accuracy to allow such a tiny overlap; we'll see! > > 2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm. > A couple broke when I tried to push-fit, and I used hot glue. The change > will probably need trial/error. (Unless I can improvise something. I'm > thinking maybe a tightly folded cylinder of sandpaper?) > > No SCAD file was available so I imported the STL (an excellent feature > of OpenSCAD). But is there some way to get the STL converted to SCAD > code? No you can't. Or actually you can, but it doesn't help you. The STL file is nothing else than a list of points, and then a list of triangles between those points. So say a cube would consist of 8 points and 12 triangles (two for each face). So that cylinder that you wanted to change in size is a whole lot of points. What I do in such a situation is to just reconstruct the openscad code myzelf. I start out overlaying them with the STL and tweaking the positions and sizes until I get them the same as in the STL. Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
terrypingm (at) gmail.com
Mon, Jul 17, 2023 12:51 PM
Thanks both, appreciate those fast replies.
Ok, understood. So, focusing on  the first of those changes, what I’m trying is to Difference() the import with something that will preserve everything except say 2.0 mm of all edges. Struggling with the ‘something’. Haven’t given up but any help would be much welcomed.
Haven’t done any OpenSCAD for ages, so I’m very rusty. But if that works maybe I could take the same differencing approach with the four pillars?
Terry
use.
another in Cura:
code?
points.
Thanks both, appreciate those fast replies. Ok, understood. So, focusing on the first of those changes, what I’m trying is to Difference() the import with something that will preserve everything except say 2.0 mm of all edges. Struggling with the ‘something’. Haven’t given up but any help would be much welcomed. Haven’t done any OpenSCAD for ages, so I’m very rusty. But if that works maybe I could take the same differencing approach with the four pillars? -- Terry On 17 Jul 2023, at 13:20, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: On Mon, Jul 17, 2023 at 11:56:54AM +0100, Terry wrote: > This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty > well a few months ago, and I made a couple in anticipation of future > use. > > But I'd now like to quickly make two small adjustments before printing > another in Cura: > > 1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now > have a way of making the rectangular hole in the project case with > sufficient accuracy to allow such a tiny overlap; we'll see! > > 2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm. > A couple broke when I tried to push-fit, and I used hot glue. The change > will probably need trial/error. (Unless I can improvise something. I'm > thinking maybe a tightly folded cylinder of sandpaper?) > > No SCAD file was available so I imported the STL (an excellent feature > of OpenSCAD). But is there some way to get the STL converted to SCAD > code? No you can't. Or actually you can, but it doesn't help you. The STL file is nothing else than a list of points, and then a list of triangles between those points. So say a cube would consist of 8 points and 12 triangles (two for each face). So that cylinder that you wanted to change in size is a whole lot of points. What I do in such a situation is to just reconstruct the openscad code myzelf. I start out overlaying them with the STL and tweaking the positions and sizes until I get them the same as in the STL. Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle. _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
Mon, Jul 17, 2023 1:05 PM
welcomed.
on the sides you want to take something off just difference with a cube.
if your object is something roughly like
module theobject () { cube ([100,30,8]);}
and you want to take 2mm off the right you do
difference () {
theobject ();
translate ([100-2, -1,-1]) cube ([10,40,40]);
Note that the "40" for Z is "way" too big. I didn't want to
think about of the smaller one went in Y or Z position.
the four pillars?
for the pillars you difference with a cylinder-with-thickness.
module cylinder_hollow (id, wt, h)
difference () {
cylinder (d=id+2*wt, h=h);
translate ([0,0,-1]) cylinder (d=id, h = h+2);
and you position that on the old pillar with id= new diameter, and
wt thick enough to take away all the extra material in the old one.
(Trick: If you make wt so small that you JUST take away all the
material you can verify that you're spot-on with the location. Then
increase wt a bit.).
Terry
use.
another in Cura:
code?
points.
On Mon, Jul 17, 2023 at 01:51:07PM +0100, terrypingm@gmail.com wrote: > Thanks both, appreciate those fast replies. > > Ok, understood. So, focusing on the first of those changes, what > I’m trying is to Difference() the import with something that will > preserve everything except say 2.0 mm of all edges. Struggling with > the ‘something’. Haven’t given up but any help would be much > welcomed. on the sides you want to take something off just difference with a cube. if your object is something roughly like module theobject () { cube ([100,30,8]);} and you want to take 2mm off the right you do difference () { theobject (); translate ([100-2, -1,-1]) cube ([10,40,40]); } Note that the "40" for Z is "way" too big. I didn't want to think about of the smaller one went in Y or Z position. > Haven’t done any OpenSCAD for ages, so I’m very rusty. But if > that works maybe I could take the same differencing approach with > the four pillars? for the pillars you difference with a cylinder-with-thickness. module cylinder_hollow (id, wt, h) { difference () { cylinder (d=id+2*wt, h=h); translate ([0,0,-1]) cylinder (d=id, h = h+2); } } and you position that on the old pillar with id= new diameter, and wt thick enough to take away all the extra material in the old one. (Trick: If you make wt so small that you JUST take away all the material you can verify that you're spot-on with the location. Then increase wt a bit.). Roger. > -- > Terry > > On 17 Jul 2023, at 13:20, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > > On Mon, Jul 17, 2023 at 11:56:54AM +0100, Terry wrote: > > This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty > > well a few months ago, and I made a couple in anticipation of future > > use. > > > > But I'd now like to quickly make two small adjustments before printing > > another in Cura: > > > > 1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now > > have a way of making the rectangular hole in the project case with > > sufficient accuracy to allow such a tiny overlap; we'll see! > > > > 2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm. > > A couple broke when I tried to push-fit, and I used hot glue. The change > > will probably need trial/error. (Unless I can improvise something. I'm > > thinking maybe a tightly folded cylinder of sandpaper?) > > > > No SCAD file was available so I imported the STL (an excellent feature > > of OpenSCAD). But is there some way to get the STL converted to SCAD > > code? > > No you can't. Or actually you can, but it doesn't help you. > > The STL file is nothing else than a list of points, and then a list of > triangles between those points. So say a cube would consist of 8 points > and 12 triangles (two for each face). > > So that cylinder that you wanted to change in size is a whole lot of > points. > > What I do in such a situation is to just reconstruct the openscad code > myzelf. I start out overlaying them with the STL and tweaking the > positions and sizes until I get them the same as in the STL. > > Roger. > > -- > ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** > ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** > f equals m times a. When your f is steady, and your m is going down > your a is going up. -- Chris Hadfield about flying up the space shuttle. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
Terry
Mon, Jul 17, 2023 2:20 PM
Thanks Roger, glad to see I'm on the right track. I'll edit it having
seen your post, but here is what I had so far. I'm essentially trying to
work in 2D so your cubes are my squares. Wish I'd gone straight for this
'crude but intuitive' approach an hour or so ago, instead of trying to
create a 'difference of two squares' as my subtraction object.
translate([-24.25, 2.75, 0])
import("C:/Users/terry/Dropbox/3D
Printer/PROJECTS/1602_LCD_Bezel_3459425/files/1602_LCD_Bezel.stl"  );
#translate([0,51,0])
square ([100,60],center = true);
#translate([0,-51,0])
#translate([93,0,0])
#translate([-93,0,0])
I may try printing that soon, as the pillars are less important.
Arguably a dab of hot glue is preferable to a push fit.
welcomed.
difference () {
theobject ();
the four pillars?
difference () {
Terry
use.
another in Cura:
code?
points.
Thanks Roger, glad to see I'm on the right track. I'll edit it having seen your post, but here is what I had so far. I'm essentially trying to work in 2D so your cubes are my squares. Wish I'd gone straight for this 'crude but intuitive' approach an hour or so ago, instead of trying to create a 'difference of two squares' as my subtraction object. difference() { translate([-24.25, 2.75, 0]) import("C:/Users/terry/Dropbox/3D Printer/PROJECTS/1602_LCD_Bezel_3459425/files/1602_LCD_Bezel.stl" ); #translate([0,51,0]) square ([100,60],center = true); #translate([0,-51,0]) square ([100,60],center = true); #translate([93,0,0]) square ([100,60],center = true); #translate([-93,0,0]) square ([100,60],center = true); } I may try printing that soon, as the pillars are less important. Arguably a dab of hot glue is preferable to a push fit. On Mon, 17 Jul 2023 15:05:41 +0200, you wrote: >On Mon, Jul 17, 2023 at 01:51:07PM +0100, terrypingm@gmail.com wrote: >> Thanks both, appreciate those fast replies. >> > >> Ok, understood. So, focusing on the first of those changes, what >> I’m trying is to Difference() the import with something that will >> preserve everything except say 2.0 mm of all edges. Struggling with >> the ‘something’. Haven’t given up but any help would be much >> welcomed. > >on the sides you want to take something off just difference with a cube. > >if your object is something roughly like > > module theobject () { cube ([100,30,8]);} > >and you want to take 2mm off the right you do > > difference () { > theobject (); > translate ([100-2, -1,-1]) cube ([10,40,40]); > } > >Note that the "40" for Z is "way" too big. I didn't want to >think about of the smaller one went in Y or Z position. > >> Haven’t done any OpenSCAD for ages, so I’m very rusty. But if >> that works maybe I could take the same differencing approach with >> the four pillars? > >for the pillars you difference with a cylinder-with-thickness. > >module cylinder_hollow (id, wt, h) >{ > difference () { > cylinder (d=id+2*wt, h=h); > translate ([0,0,-1]) cylinder (d=id, h = h+2); > } >} > >and you position that on the old pillar with id= new diameter, and >wt thick enough to take away all the extra material in the old one. > >(Trick: If you make wt so small that you JUST take away all the >material you can verify that you're spot-on with the location. Then >increase wt a bit.). > > Roger. > >> -- >> Terry >> >> On 17 Jul 2023, at 13:20, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: >> >> ?On Mon, Jul 17, 2023 at 11:56:54AM +0100, Terry wrote: >> > This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty >> > well a few months ago, and I made a couple in anticipation of future >> > use. >> > >> > But I'd now like to quickly make two small adjustments before printing >> > another in Cura: >> > >> > 1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now >> > have a way of making the rectangular hole in the project case with >> > sufficient accuracy to allow such a tiny overlap; we'll see! >> > >> > 2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm. >> > A couple broke when I tried to push-fit, and I used hot glue. The change >> > will probably need trial/error. (Unless I can improvise something. I'm >> > thinking maybe a tightly folded cylinder of sandpaper?) >> > >> > No SCAD file was available so I imported the STL (an excellent feature >> > of OpenSCAD). But is there some way to get the STL converted to SCAD >> > code? >> >> No you can't. Or actually you can, but it doesn't help you. >> >> The STL file is nothing else than a list of points, and then a list of >> triangles between those points. So say a cube would consist of 8 points >> and 12 triangles (two for each face). >> >> So that cylinder that you wanted to change in size is a whole lot of >> points. >> >> What I do in such a situation is to just reconstruct the openscad code >> myzelf. I start out overlaying them with the STL and tweaking the >> positions and sizes until I get them the same as in the STL. >> >> Roger. >> >> -- >> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** >> ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** >> f equals m times a. When your f is steady, and your m is going down >> your a is going up. -- Chris Hadfield about flying up the space shuttle. >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org
Terry
Mon, Jul 17, 2023 2:34 PM
Hmm, something wrong there. On closer inspection it looks the same size
as the original. Good job I spotted it before hitting the Ender's Print
command!
welcomed.
difference () {
theobject ();
the four pillars?
difference () {
Terry
use.
another in Cura:
code?
points.
Hmm, something wrong there. On closer inspection it looks the same size as the original. Good job I spotted it before hitting the Ender's Print command! On Mon, 17 Jul 2023 15:20:34 +0100, I wrote: >Thanks Roger, glad to see I'm on the right track. I'll edit it having >seen your post, but here is what I had so far. I'm essentially trying to >work in 2D so your cubes are my squares. Wish I'd gone straight for this >'crude but intuitive' approach an hour or so ago, instead of trying to >create a 'difference of two squares' as my subtraction object. > > >difference() >{ >translate([-24.25, 2.75, 0]) >import("C:/Users/terry/Dropbox/3D >Printer/PROJECTS/1602_LCD_Bezel_3459425/files/1602_LCD_Bezel.stl" ); > > >#translate([0,51,0]) >square ([100,60],center = true); > >#translate([0,-51,0]) >square ([100,60],center = true); > >#translate([93,0,0]) >square ([100,60],center = true); > >#translate([-93,0,0]) >square ([100,60],center = true); > >} > >I may try printing that soon, as the pillars are less important. >Arguably a dab of hot glue is preferable to a push fit. > > > > > > > >On Mon, 17 Jul 2023 15:05:41 +0200, you wrote: > >>On Mon, Jul 17, 2023 at 01:51:07PM +0100, terrypingm@gmail.com wrote: >>> Thanks both, appreciate those fast replies. >>> >> >>> Ok, understood. So, focusing on the first of those changes, what >>> I’m trying is to Difference() the import with something that will >>> preserve everything except say 2.0 mm of all edges. Struggling with >>> the ‘something’. Haven’t given up but any help would be much >>> welcomed. >> >>on the sides you want to take something off just difference with a cube. >> >>if your object is something roughly like >> >> module theobject () { cube ([100,30,8]);} >> >>and you want to take 2mm off the right you do >> >> difference () { >> theobject (); >> translate ([100-2, -1,-1]) cube ([10,40,40]); >> } >> >>Note that the "40" for Z is "way" too big. I didn't want to >>think about of the smaller one went in Y or Z position. >> >>> Haven’t done any OpenSCAD for ages, so I’m very rusty. But if >>> that works maybe I could take the same differencing approach with >>> the four pillars? >> >>for the pillars you difference with a cylinder-with-thickness. >> >>module cylinder_hollow (id, wt, h) >>{ >> difference () { >> cylinder (d=id+2*wt, h=h); >> translate ([0,0,-1]) cylinder (d=id, h = h+2); >> } >>} >> >>and you position that on the old pillar with id= new diameter, and >>wt thick enough to take away all the extra material in the old one. >> >>(Trick: If you make wt so small that you JUST take away all the >>material you can verify that you're spot-on with the location. Then >>increase wt a bit.). >> >> Roger. >> >>> -- >>> Terry >>> >>> On 17 Jul 2023, at 13:20, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: >>> >>> ?On Mon, Jul 17, 2023 at 11:56:54AM +0100, Terry wrote: >>> > This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty >>> > well a few months ago, and I made a couple in anticipation of future >>> > use. > > > >>> > >>> > But I'd now like to quickly make two small adjustments before printing >>> > another in Cura: >>> > >>> > 1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now >>> > have a way of making the rectangular hole in the project case with >>> > sufficient accuracy to allow such a tiny overlap; we'll see! >>> > >>> > 2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm. >>> > A couple broke when I tried to push-fit, and I used hot glue. The change >>> > will probably need trial/error. (Unless I can improvise something. I'm >>> > thinking maybe a tightly folded cylinder of sandpaper?) >>> > >>> > No SCAD file was available so I imported the STL (an excellent feature >>> > of OpenSCAD). But is there some way to get the STL converted to SCAD >>> > code? >>> >>> No you can't. Or actually you can, but it doesn't help you. >>> >>> The STL file is nothing else than a list of points, and then a list of >>> triangles between those points. So say a cube would consist of 8 points >>> and 12 triangles (two for each face). >>> >>> So that cylinder that you wanted to change in size is a whole lot of >>> points. >>> >>> What I do in such a situation is to just reconstruct the openscad code >>> myzelf. I start out overlaying them with the STL and tweaking the >>> positions and sizes until I get them the same as in the STL. >>> >>> Roger. >>> >>> -- >>> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** >>> ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** >>> f equals m times a. When your f is steady, and your m is going down >>> your a is going up. -- Chris Hadfield about flying up the space shuttle. >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org
Mon, Jul 17, 2023 9:04 PM
Sorted. Main mistake was that I had got the subtraction reversed.
Printed correctly. But I’d been too brave in reducing the size of the rim to a mere 1.5 mm, as the Dremel hole cutting wasn’t quite accurate enough. Still looking for a really reliable way to cut rectangles in plastic cases.
A good learning exercise though. Turns out quite a lot of changes can be made even without access to the  original OpenSCAD CODE.
Terry
command!
welcomed.
difference () {
theobject ();
the four pillars?
difference () {
Terry
use.
another in Cura:
code?
points.
Sorted. Main mistake was that I had got the subtraction reversed. Printed correctly. But I’d been too brave in reducing the size of the rim to a mere 1.5 mm, as the Dremel hole cutting wasn’t quite accurate enough. Still looking for a really reliable way to cut rectangles in plastic cases. A good learning exercise though. Turns out quite a lot of changes can be made even without access to the original OpenSCAD CODE. -- Terry On 17 Jul 2023, at 15:34, Terry <terrypingm@gmail.com> wrote: Hmm, something wrong there. On closer inspection it looks the same size as the original. Good job I spotted it before hitting the Ender's Print command! On Mon, 17 Jul 2023 15:20:34 +0100, I wrote: > Thanks Roger, glad to see I'm on the right track. I'll edit it having > seen your post, but here is what I had so far. I'm essentially trying to > work in 2D so your cubes are my squares. Wish I'd gone straight for this > 'crude but intuitive' approach an hour or so ago, instead of trying to > create a 'difference of two squares' as my subtraction object. > > > difference() > { > translate([-24.25, 2.75, 0]) > import("C:/Users/terry/Dropbox/3D > Printer/PROJECTS/1602_LCD_Bezel_3459425/files/1602_LCD_Bezel.stl" ); > > > #translate([0,51,0]) > square ([100,60],center = true); > > #translate([0,-51,0]) > square ([100,60],center = true); > > #translate([93,0,0]) > square ([100,60],center = true); > > #translate([-93,0,0]) > square ([100,60],center = true); > > } > > I may try printing that soon, as the pillars are less important. > Arguably a dab of hot glue is preferable to a push fit. > > > > > > > > On Mon, 17 Jul 2023 15:05:41 +0200, you wrote: > >> On Mon, Jul 17, 2023 at 01:51:07PM +0100, terrypingm@gmail.com wrote: >>> Thanks both, appreciate those fast replies. >>> >> >>> Ok, understood. So, focusing on the first of those changes, what >>> I’m trying is to Difference() the import with something that will >>> preserve everything except say 2.0 mm of all edges. Struggling with >>> the ‘something’. Haven’t given up but any help would be much >>> welcomed. >> >> on the sides you want to take something off just difference with a cube. >> >> if your object is something roughly like >> >> module theobject () { cube ([100,30,8]);} >> >> and you want to take 2mm off the right you do >> >> difference () { >> theobject (); >> translate ([100-2, -1,-1]) cube ([10,40,40]); >> } >> >> Note that the "40" for Z is "way" too big. I didn't want to >> think about of the smaller one went in Y or Z position. >> >>> Haven’t done any OpenSCAD for ages, so I’m very rusty. But if >>> that works maybe I could take the same differencing approach with >>> the four pillars? >> >> for the pillars you difference with a cylinder-with-thickness. >> >> module cylinder_hollow (id, wt, h) >> { >> difference () { >> cylinder (d=id+2*wt, h=h); >> translate ([0,0,-1]) cylinder (d=id, h = h+2); >> } >> } >> >> and you position that on the old pillar with id= new diameter, and >> wt thick enough to take away all the extra material in the old one. >> >> (Trick: If you make wt so small that you JUST take away all the >> material you can verify that you're spot-on with the location. Then >> increase wt a bit.). >> >> Roger. >> >>> -- >>> Terry >>> >>> On 17 Jul 2023, at 13:20, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: >>> >>> ?On Mon, Jul 17, 2023 at 11:56:54AM +0100, Terry wrote: >>>> This 16x2 1602A LCD bezel from Thingiverse printed and fitted pretty >>>> well a few months ago, and I made a couple in anticipation of future >>>> use. > > > >>>> >>>> But I'd now like to quickly make two small adjustments before printing >>>> another in Cura: >>>> >>>> 1. Reduce the 'lip' from 4 to 2 mm. After much experiment I think I now >>>> have a way of making the rectangular hole in the project case with >>>> sufficient accuracy to allow such a tiny overlap; we'll see! >>>> >>>> 2. Reduce the diameters of the four tiny push-fit pillars by say 0.1 mm. >>>> A couple broke when I tried to push-fit, and I used hot glue. The change >>>> will probably need trial/error. (Unless I can improvise something. I'm >>>> thinking maybe a tightly folded cylinder of sandpaper?) >>>> >>>> No SCAD file was available so I imported the STL (an excellent feature >>>> of OpenSCAD). But is there some way to get the STL converted to SCAD >>>> code? >>> >>> No you can't. Or actually you can, but it doesn't help you. >>> >>> The STL file is nothing else than a list of points, and then a list of >>> triangles between those points. So say a cube would consist of 8 points >>> and 12 triangles (two for each face). >>> >>> So that cylinder that you wanted to change in size is a whole lot of >>> points. >>> >>> What I do in such a situation is to just reconstruct the openscad code >>> myzelf. I start out overlaying them with the STL and tweaking the >>> positions and sizes until I get them the same as in the STL. >>> >>> Roger. >>> >>> -- >>> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** >>> ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** >>> f equals m times a. When your f is steady, and your m is going down >>> your a is going up. -- Chris Hadfield about flying up the space shuttle. >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org
