Pyr3x
Thu, Nov 10, 2016 6:05 PM
Excuse me for asking what might be a stupid question but if assign is being
phased out what would be the better option for me in the case of the code
below:
module Curve(p1, p2, cursor, steps = 5, filled = true)
stepsize1 = (cursor - p1) / steps;
stepsize2 = (p2 - cursor) / steps;
for (i = [0:steps - 1])
assign(point1 = p1 + stepsize1 * i)
assign(point2 = cursor + stepsize2 * i)
assign(point3 = p1 + stepsize1 * (i + 1))
assign(point4 = cursor + stepsize2 * (i + 1))
assign(bpoint1 = point1 + (point2 - point1) * (i / steps))
assign(bpoint2 = point3 + (point4 - point3) * ((i + 1) / steps))
polygon(points = [bpoint1, bpoint2, filled ? p1 : cursor]);
View this message in context: http://forum.openscad.org/Assign-Depreciated-Then-tp19018.html
below:
Pyr3x
Thu, Nov 10, 2016 6:10 PM
Never mind I am an idiot... Sorry
point1 = p1 + stepsize1 * i;
point2 = cursor + stepsize2 * i;
point3 = p1 + stepsize1 * (i + 1);
point4 = cursor + stepsize2 * (i + 1);
bpoint1 = point1 + (point2 - point1) * (i / steps);
bpoint2 = point3 + (point4 - point3) * ((i + 1) / steps);
View this message in context: http://forum.openscad.org/Assign-Depreciated-Then-tp19018p19019.html
Thu, Nov 10, 2016 6:51 PM
steps);
cursor]);
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Variables
2016-11-10 16:10 GMT-02:00 Pyr3x <pyrex@xploit.ninja>:
> steps);
> cursor]);
Thu, Nov 10, 2016 8:06 PM
Problem is not all braces create a new scope so I have to use for(var =
value) instead of assign(var = value) in the odd place.
On 10 November 2016 at 18:51, Ronaldo Persiano rcmpersiano@gmail.com
steps);
steps);
cursor]);
On 10 November 2016 at 18:51, Ronaldo Persiano <rcmpersiano@gmail.com>
>> steps);
>> steps);
>> cursor]);
Thu, Nov 10, 2016 9:43 PM
nophead, it would be nice to have a note on this in the Manual.
2016-11-10 18:06 GMT-02:00 nop head nop.head@gmail.com:
steps);
/ steps);
: cursor]);
2016-11-10 18:06 GMT-02:00 nop head <nop.head@gmail.com>:
>>> steps);
>>> / steps);
>>> : cursor]);
Thu, Nov 10, 2016 10:15 PM
Well in my mind deprecating assign was a mistake unless all braces create a
new scope but some people objected to that as they used braces to fold
things in their editor.
On 10 November 2016 at 21:43, Ronaldo Persiano rcmpersiano@gmail.com
steps);
/ steps);
: cursor]);
On 10 November 2016 at 21:43, Ronaldo Persiano <rcmpersiano@gmail.com>
>>>> steps);
>>>> / steps);
>>>> : cursor]);
Thu, Nov 10, 2016 10:52 PM
On Nov 10, 2016, at 17:15, nop head nop.head@gmail.com wrote:
Well in my mind deprecating assign was a mistake unless all braces create a new scope but some people objected to that as they used braces to fold things in their editor.
That’s a bit hard to enforce without breaking old designs.
Perhaps we should deprecate that behavior as well (unscoped braces). Just not sure how to best deal with backwards compatibility.
Thu, Nov 10, 2016 11:00 PM
Replace assign() with let()? [I don't know where let() came from]
View this message in context: http://forum.openscad.org/Assign-Depreciated-Then-tp19018p19025.html
Thu, Nov 10, 2016 11:42 PM
I don't think that forcing people to replace assign() with for() is
acceptable. Because you are encouraging people to exploit a bug in for()
[which I think should be fixed] in order to work around the fact that
assign() prints a deprecation warning.
The easiest way out is to undeprecate assign(), as Nop Head suggested.
If you want people to use {} in preference to assign(), then fix it so that
it works correctly. This means fixing the "unscoped braces" bug, even
though there is a person or maybe some people who have started exploiting
the bug in their own code. And yeah, fixing language bugs usually raises
backward compatibility issues in OpenSCAD. Maybe a broader discussion needs
to occur around this issue of fixing bugs and backwards compatibility.
> -Marius
Fri, Nov 11, 2016 12:13 AM
My guess would be using braces to collapse assignments in an editor must be
a pretty obscure use case. Is there more than one person that does this?
that it works correctly. This means fixing the "unscoped braces" bug, even
>> -Marius
