To rotate around an arbitrary point, center, you do
translate(center)rotate(.....)translate(-center). The BOSL2 library
has a rot() function that accepts a centerpoint argument, so you can
do it there with rot(...., cp=center).
On Sat, Mar 12, 2022 at 7:29 AM Jan Öhman via Discuss
To: "discuss@lists.openscad.org" discuss@lists.openscad.org
Cc:
Bcc:
Date: Sat, 12 Mar 2022 12:30:01 +0000 (UTC)
Subject: [OpenSCAD] Rotate some objects around a selected point
Assume the following (a slightly simplified example)
There are two axles (one long and one short) with a knot (sphere) between them.
On the short one, a wheel is placed.
This code below puts these parts together.
but
My wish is to turn the wheel and the short axle (and maybe the knot) for example 20 degrees (right / left), around the knot.
(not at the center of the wheel and short axle)
$fn=100;
// axle1 (the long one)
length1 = 10;
width1 = 3;
x1=10;
y1=10;
z1= 0;
// axle2 (the short one)
length2 = 3;
width2 = 3;
// The "knot"
knot = width1 + 2;
// wheel
wheelDiam = 20;
wheelWidth = 8;
x2=x1+length2;
y2=y1;
z2=z1;
// Create the Axle1
translate([x1, y1, z1])
rotate([0,-90,0]) cylinder(h=length1, d=width1);
// Create the Axle2
rotate([0,90,0]) cylinder(h=length2, d=width2);
// Mount the "knot"
translate([x1, y1, z1]) sphere(d=knot);
// Mount the Wheel
translate([x2, y2, z2])
rotate([0,90,0]) cylinder(d=wheelDiam, h=wheelWidth);
From: "Jan Öhman via Discuss" discuss@lists.openscad.org
Cc: "Jan Öhman" jan_ohman@yahoo.com
Bcc:
I have made few changes in your code to achieve what you are looking for
(if i understand correctly)
$fn=100;
length1 = 10;
width1 = 3;
x1=10;
y1=10;
z1= 0;
length2 = 3;
width2 = 3;
// The "knot"
knot = width1 + 2;
// wheel
wheelDiam = 20;
wheelWidth = 8;
x2=x1+length2;
y2=y1;
z2=z1;
// Create the Axle1
rotate([0,0,-20])
union(){
// Create the Axle2
// Mount the "knot"
sphere(d=knot);
// Mount the Wheel
translate([length2, 0, 0])
rotate([0,90,0]) cylinder(d=wheelDiam, h=wheelWidth);}
Cc:
Bcc:
between them.
but
$fn=100;
length1 = 10;
width1 = 3;
x1=10;
y1=10;
z1= 0;
length2 = 3;
width2 = 3;
// The "knot"
knot = width1 + 2;
// wheel
wheelDiam = 20;
wheelWidth = 8;
x2=x1+length2;
y2=y1;
z2=z1;
// Create the Axle1
// Create the Axle2
// Mount the "knot"
// Mount the Wheel
Bcc:
