Dear OpenSCAD users,
I am trying to design a bottle lid with air channels from the center to the outer diameter. It is a piece for a musical instrument. The code is attached. The shape could be simplified as
rotate_extrude() polygon();
for( i=[0:30] ) {
hull(){
translate() sphere();
I suffer from a three issues:
(1) Warnings while compiling:
WARNING: Normalized tree is growing past 18000000 elements. Aborting normalization.
WARNING: CSG normalization resulted in an empty tree
I found
Edit -> Preferences -> Advanced -> 3D Preview (OpenCSG) -> Turn off rendering at $fixnum elements
but that did not reenable preview for me.
(2) an empty preview
(3) Wireframe not shown:
What settings may I want to adjust?
May there be a regression in the manifold backend regarding the wireframe display?
Cheers,
Marcus
I think the essence is that preview really hates intersection, and
you're doing a fair number of them. I think the complexity of one of
the internal data structures is in some way an exponential function of
the number of intersections.
Here's a table of segmente_anzahl versus size of the normalized tree:
1
12
2
32
3
80
4
192
5
448
6
1024
10
24576
However... you're doing something like
for (...) {
rotate(...) luftrohr();
... a cylinder ...
which is equivalent to
... a cylinder ...
for (...) {
only the first does about thirty intersections, while the second only
does one.
There is a relevant FAQ entry which somewhat explains the situation:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_the_preview_so_slow
One quick fix is to wrap the intersection in your luftrohr module with a
render() instantiation:
module luftrohr(){
render() intersection(){...
This effectively collapses that CSG subtree and avoids the explosion in CSG
product terms.
On Mon, Oct 14, 2024 at 6:47 PM Jordan Brown via Discuss <
I think the essence is that preview really hates intersection, and you're
doing a fair number of them. I think the complexity of one of the internal
data structures is in some way an exponential function of the number of
intersections.
1
12
2
32
3
80
4
192
5
448
6
1024
10
24576
for (...) {
... a cylinder ...
... a cylinder ...
for (...) {
only the first does about thirty intersections, while the second only does
one.
That was an interesting read and boils it down to a well known workaround.
module luftrohr(){
product terms.
Works great. :-)
Thank you,
Marcus
1
12
2
32
3
80
4
192
5
448
6
1024
10
24576
for (...) {
... a cylinder ...
... a cylinder ...
for (...) {
That is a very educative way to highlight my problem.
It works equally nice as Hans solution, thank you!
Cheers,
Marcus
I applied Hans solution (making use of the cache by a render()-directive) und would like to highlight my second issue:
cgal-backend can display a wireframe.
manifold-backend cannot.
As manifold is officially stable, I would consider that a regression bug.
Code is attached. Test with:
./OpenSCAD-2024.10.09.ai20850-x86_64.AppImage --backend=manifold 0.23.2_360labium.scad
./OpenSCAD-2024.10.09.ai20850-x86_64.AppImage --backend=cgal 0.23.2_360labium.scad
Cheers,
Marcus
Known issue.
https://github.com/openscad/openscad/issues/4825
The sixth (top-level) item:
Support wireframe rendering of Manifold geometries
