There are also Python fronts ends for OpenSCAD for people who prefer to
describe objects in Python.
On Fri, 8 May 2020 at 19:53, arnholm@arnholm.org wrote:
On 2020-05-08 20:00, Jordan Brown wrote:
There are two distinct questions there:
* Could there be a language similar to OpenSCAD that has more
"conventional" behavior?
Yes, AngelCAD is like that, using AngelScript.
https://arnholm.github.io/angelcad-docs/
Thanks Jordan, that's very interesting! maybe I will read up more on
chldren:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules#Children
I'm pretty sure I'll be able to build whatever shape i want now. Also i
think adding while loops is probably counter productive; I think I was just
stuck in the wrong mind frame.
I like the new release(2019.05)! Everything is better-than-ever(once i
figured out how to turn off sound notifications and mouse centric zoom)! ;)
On Fri, May 8, 2020 at 2:01 PM Jordan Brown openscad@jordan.maileater.net
On 5/8/2020 4:58 AM, Rob Ward wrote:
If it is possible to set up increments/assignments in For loops, why not
for other variables?
First, I have to note that I know nothing of the internals of OpenSCAD.
However, I have done some black-box exploration of its behavior.
- Could there be a language similar to OpenSCAD that has more
- How hard would it be to change OpenSCAD to behave like such a
language?
I think the answer to the first is clearly "yes". One can readily imagine
languages that behave more conventionally. Most likely, one would just
build a CSG library for some existing language like Python or JavaScript.
The answer to the second question is much trickier. Again, I'm not
familiar with the internals of OpenSCAD, but black-box testing shows that
its behavior is even further from "conventional" than it first appears.
Consider:
x = echo("1") 0;
echo("2");
y = echo("3") 0;
Simple enough, right?
ECHO: "1"
ECHO: "3"
ECHO: "2"
Or the behavior of children():
module x() {
children(0);
children(0);
children(2);
x() {
echo("0");
echo("1");
echo("2");
It's not terribly unobvious, but doesn't bear much resemblance to a
conventional language:
ECHO: "0"
ECHO: "0"
ECHO: "2"
Speaking of children, how do assignments and children interact?
module x() {
a = echo("a") 0;
children(0);
b = echo("b") 0;
x() {
c = echo("c") 0;
echo("0");
echo("1");
echo("2");
d = echo("d") 0;
Did you expect this?
ECHO: "c"
ECHO: "d"
ECHO: "a"
ECHO: "b"
ECHO: "0"
Net, the execution flow in OpenSCAD doesn't look much like what you would
expect from a conventional language. Could a language have the same goals
and be more conventional? Sure. But it's clear that the internal plumbing
of OpenSCAD is very, very different from a conventional language and it
would require a substantial overhaul to become more conventional.
And I suppose there's a third question:
- Could OpenSCAD be changed to be more conventional, while retaining
compatibility with its current behavior?
Technically, no. One can readily write OpenSCAD programs that would
execute differently in a more conventional language.
One such case is the fact that assignments are processed before module
invocations:
echo(x);
x = 1;
Another is the fact that assigning a value inside a scope creates a new
symbol visible only inside that scope:
x = 1;
if (1 == 1) {
x = 2;
echo(x);
echo(x);
yields
ECHO: 2
ECHO: 1
And the fact that when you define an OpenSCAD symbol, the value of the
same-named symbol from the enclosing scope is still visible:
x = 1;
for (i = [0:1]) {
x = x + 1;
echo(x);
yields:
ECHO: 2
ECHO: 2
Do people actually use these ... interesting ... cases? I don't know.
But they clearly could, and so true compatibility would not be possible.
Somebody asked how to classify OpenSCAD. My personal model is largely
that it is a macro processing language, that executing an OpenSCAD program
consists of expanding the various macros to form the resulting tree.
One thing that I do wonder is how isolated the language processing is,
inside OpenSCAD. Hypothetically, it seems like the language processing
could be a black box that takes source text as input and returns a geometry
tree as output. If it is such a black box, then perhaps it would be
practical to make it a plug-in, so that one could type Python into the
editor, with an appropriate Python library, and have the results end up in
the viewing window. One could even imagine cross-language calls that
passed parameters and returned geometry.
Let me be clear: that's just a fantasy. I'm not asking the developers to
work on such a thing.
By the way, perhaps people might be curious about what I'm actually trying
to fabricate(it's face masks): https://www.thingiverse.com/thing:4345994
chldren:
language?
imagine languages that behave more conventionally. Most likely, one would
just build a CSG library for some existing language like Python or
JavaScript.
Consider:
x = echo("1") 0;
echo("2");
y = echo("3") 0;
ECHO: "1"
ECHO: "3"
ECHO: "2"
module x() {
children(0);
children(0);
children(2);
x() {
echo("0");
echo("1");
echo("2");
ECHO: "0"
ECHO: "0"
ECHO: "2"
module x() {
a = echo("a") 0;
children(0);
b = echo("b") 0;
x() {
c = echo("c") 0;
echo("0");
echo("1");
echo("2");
d = echo("d") 0;
ECHO: "c"
ECHO: "d"
ECHO: "a"
ECHO: "b"
ECHO: "0"
invocations:
echo(x);
x = 1;
x = 1;
if (1 == 1) {
x = 2;
echo(x);
echo(x);
yields
ECHO: 2
ECHO: 1
x = 1;
for (i = [0:1]) {
x = x + 1;
echo(x);
yields:
ECHO: 2
ECHO: 2
to work on such a thing.
Please remove my email from all discussions
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of Rob Ward
Sent: Friday, May 8, 2020 6:59 AM
To: OpenSCAD general discussion; nop head
Subject: Re: [OpenSCAD] 2D SVG concat(points, [point]) no output, loops&conditionals, vector declarations
I think that sums up the OpenSCAD variable dilemma.
"It is also like maths in that x = x +1 does not make sense."
as a static equation, as NopHead says it does make sense mathematically, I agree.
But to see it as a powerful programming concept of a calculation followed by an assignment means it is a very, very sad omission in OpenSCAD.
My limited understanding of OpenSCAD is that it was thrown together to generate .stl files to make 3-D printer parts. This maybe mythological garbage I have accumulated from somewhere, or maybe true. If that is true, it has succeeded in that sense and in many other fantastic designs.
I have found OpenSCAD immensely useful and inspiring in its current incarnation. I am indebted to its authors. But it seems to me that the long term users of it have so much code they don't want to see broken, and they are the ones most qualified to change it, that nothing is going to change soon.
Call OpenSCAD whatever type of programming you like, if it is unable to implement a simple accumulator increment, then it simply appears a mysterious orphan, cast off from the very architecture that actually makes it possible. Very curious.
If it is possible to set up increments/assignments in For loops, why not for other variables?
Rob
On 8 May 2020 8:31:38 pm AEST, nop head nop.head@gmail.com wrote:
Another way to think of it is that OpenSCAD script is not a program, it is a description of some geometric objects. When you describe something static nothing about it changes during the description, so no variables are needed.
On Fri, 8 May 2020 at 11:21, Max Bond max.o.bond@gmail.com wrote:
I would place OpenSCAD solidly in the functional camp.
t helps to understand that OpenSCAD is actually a fairly thin layer over OpenCSG; if you take a look at some "compiled" code using Design -> Display CSG Tree, you'll see that OpenSCAD's output is a static structure in an "assembly language" not too different from OpenSCAD itself. OpenCSG doesn't have any concept of variables or of mutating state. Those quirks propagate up the stack into OpenSCAD.
It can take a big adjustment to learn to think in OpenSCAD, but I've found that programming in this environment forces me to have a discipline that's made me a better programmer in other languages.
Best of luck!
On Fri, May 8, 2020 at 1:04 AM kipple bits kipplebits@gmail.com wrote:
...Right, Thank! ...I think I was actually already doing this subconsciously, although I guess I was working a little outside of my comfort zone, and got turned around. ...Also probably didn't help that I was using a 3 year old build.(up to date now!) ...i guess the problem in my example was related to scope then; I think in most programing languages(c++, java) a for loop carries the same scope as it's surroundings... ...also vectors/arrays are not static... ...kind of a curveball ;P
OpenSCAD is sort of strange if you are used to c++ or java. how would you classify OpenSCAD as a programing language? what other language would you say it is most like? https://en.wikipedia.org/wiki/List_of_programming_languages_by_type#Pure ...Haskell?
Anyway I think I'm straightened out now, Thanks! hopefully I won't decide to import code snips into my scad files again.
On Thu, May 7, 2020 at 6:46 PM Torsten Paul Torsten.Paul@gmx.de wrote:
You can't modify already assigned vectors, but you can
declare them using multiple expression and function
calls, e.g:
function right() = [ for (a = [20:-5:-20]) [18 + abs(a%10), a] ];
points = [
// top
for (a = [0:5:360]) [a / 10 - 18, 5 * sin(a) + 20],
// right
each right(),
// bottom
for (a = [360:-5:0]) [a / 10 - 18, 2 * sin(5 * a) - 20],
// left
[-20, -20],
[-15, 0],
[-20, 20]
polygon(points);
For more details, see List Comprehensions topic in the manual
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/List_Comprehensions
For the 2D angle there are a number of other tools to try/consider:
- Processing - Nodebox - Metapost (and its derivatives such as TikZ, Asymptote, &c.) - Maker.js -- this is oriented towards CAM
another successor tool would (eventually?) be RapCAD.
A newer tool I'm investigating is CADquery.
That said, I'm kind of wedded to OpenSCAD since I really like the BlockSCAD environment --- OpenJSCAD has a similar one though.
I posted my little scad file: https://www.thingiverse.com/thing:4354587
It's not very complex, but then it's kind of a pain if you mess up and
overshoot, so maybe it could be helpful to someone.
width = 34;
length = 48;
xremainder = 4;
yremainder = 5;
//either horizontal
for(i=[0:2:length-1]){
translate(v = [0, i10, 0]){
square(size = [width10, 10], center = true/false);
//or vertical
for(i=[0:2:width-1]){
translate(v = [i10, 0, 0]){
square(size = [10, length10], center = true/false);
//perimeter nearest cm
//square(size = [10width, 10length]);
// full perimeter nearest mm
//square(size = [10width+xremainder, 10length+yremainder]);
//full area offset for safety check
translate(v = [0, 0, -10]) {
//scale/numbers
translate([i*10+1, 10, 0]) {text(str(i));}
translate([10, i*10+1, 0]) {text(str(i));
lasergrbl had some troubles importing svg, so I ended up converting to
black&white png, using GIMP. I'll have to check out some of William's
suggestions, although I'm really just looking for an efficient way to
convert to b&w; maybe batch-mode or gimp-scripting/automated-editing...?
...or maybe there's something to be done as far as lasergrbl svg support?
...anyway, the latest build of openSCAD is working well for me, keep up the
good work!
although I'm really just looking for an efficient way to convert to b&w;
I'm not sure what you're doing, but you know you can do custom Color
Schemes?
you know you can do custom Color Schemes?
doesn't change the output color in the svg, although you did give me an
idea to edit the line in my svg stroke="black" fill="lightgrey"
stroke-width="0.5"
i changed it to simply fill="black", then open in gimp, upsize DPI, remove
alpha-channel,(and perhaps index to black&white), and it actually looks
pretty good! it's still a few clicks, although much better than add 2 new
layers and path to selection fill b&w then merge layers. ;D
