Absolute newbie - looking for advice on how to apply a chamfer
S
SUggy62
Fri, Feb 7, 2020 6:54 PM
Hi All,
I'm trying to design a display for some Poker Chips. Due to the
manufacturing tolerances of the chips and of my printer, some chips fit
snugly and some are loose.
To get round this I'd like a chamfer on the edge where the chip is inserted
to make it easier to insert the chip into a tight recess, but am clueless as
to how to achieve this
My current code is ;
$fn=64;
ChipBase=44;
x=3 ;
y=3;
module Chip() {
cube([ChipBase,ChipBase,5]);
translate ([ChipBase/2,ChipBase/2,1.7])cylinder (r=20.30,h=4);
translate([ChipBase/2, ChipBase/2, -0.5]) cylinder (r=10, h=3);
for(i = [0:ChipBase:(xChipBase)-1]){
for(j = [0:ChipBase:(y
ChipBase)-1]){
translate([i,j,0]) Chip();
Hope this makes sense and any suggestions gratefully received
Hi All, I'm trying to design a display for some Poker Chips. Due to the manufacturing tolerances of the chips and of my printer, some chips fit snugly and some are loose. To get round this I'd like a chamfer on the edge where the chip is inserted to make it easier to insert the chip into a tight recess, but am clueless as to how to achieve this My current code is ; $fn=64; ChipBase=44; x=3 ; y=3; module Chip() { difference() { cube([ChipBase,ChipBase,5]); translate ([ChipBase/2,ChipBase/2,1.7])cylinder (r=20.30,h=4); translate([ChipBase/2, ChipBase/2, -0.5]) cylinder (r=10, h=3); } } for(i = [0:ChipBase:(x*ChipBase)-1]){ for(j = [0:ChipBase:(y*ChipBase)-1]){ translate([i,j,0]) Chip(); } } Hope this makes sense and any suggestions gratefully received -- Sent from: http://forum.openscad.org/
Fri, Feb 7, 2020 10:41 PM
I personally would do it using the BOSL2 library, which provides chamfered
cylinders.  Or you could write your own chamfered cylinder if you want to
work more.
https://github.com/revarbat/BOSL2/wiki
include<BOSL2/std.scad>
$fn=64;
ChipBase=44;
x=3 ;
y=3;
module Chip() {
//translate ([ChipBase/2,ChipBase/2,1.7])
translate([ChipBase/2,ChipBase/2,1.7])cyl(r=20.30,h=4,chamfer2=-2,anchor=BOTTOM);
ChipBase)-1]){
SUggy62 wrote
Hi All,
inserted
as
$fn=64;
ChipBase=44;
x=3 ;
y=3;
module Chip() {
ChipBase)-1]){
Discuss@.openscad
I personally would do it using the BOSL2 library, which provides chamfered cylinders. Or you could write your own chamfered cylinder if you want to work more. https://github.com/revarbat/BOSL2/wiki include<BOSL2/std.scad> $fn=64; ChipBase=44; x=3 ; y=3; module Chip() { difference() { cube([ChipBase,ChipBase,5]); //translate ([ChipBase/2,ChipBase/2,1.7]) translate([ChipBase/2,ChipBase/2,1.7])cyl(r=20.30,h=4,chamfer2=-2,anchor=BOTTOM); translate([ChipBase/2, ChipBase/2, -0.5]) cylinder (r=10, h=3); } } for(i = [0:ChipBase:(x*ChipBase)-1]){ for(j = [0:ChipBase:(y*ChipBase)-1]){ translate([i,j,0]) Chip(); } } SUggy62 wrote > Hi All, > > I'm trying to design a display for some Poker Chips. Due to the > manufacturing tolerances of the chips and of my printer, some chips fit > snugly and some are loose. > > To get round this I'd like a chamfer on the edge where the chip is > inserted > to make it easier to insert the chip into a tight recess, but am clueless > as > to how to achieve this > > My current code is ; > > $fn=64; > > ChipBase=44; > x=3 ; > y=3; > > module Chip() { > difference() { > cube([ChipBase,ChipBase,5]); > translate ([ChipBase/2,ChipBase/2,1.7])cylinder (r=20.30,h=4); > translate([ChipBase/2, ChipBase/2, -0.5]) cylinder (r=10, h=3); > } > } > > > for(i = [0:ChipBase:(x*ChipBase)-1]){ > for(j = [0:ChipBase:(y*ChipBase)-1]){ > translate([i,j,0]) Chip(); > } > } > > Hope this makes sense and any suggestions gratefully received > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@.openscad > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- Sent from: http://forum.openscad.org/
lar3ry
Sat, Feb 8, 2020 4:50 AM
Being reluctant to dig out and learn chamfers in BOSL2, I just did a bit of a
brute force thing,
$fn=64;
ChipBase=44;
x=3 ;
y=3;
module Chip() {
translate ([22,22,1.5])
chamfer();
module chamfer() {
rotate_extrude(convexity = 10)
translate([20,4, 0])
circle(r = 2,$fn=3);
ChipBase)-1]){
Being reluctant to dig out and learn chamfers in BOSL2, I just did a bit of a brute force thing, $fn=64; ChipBase=44; x=3 ; y=3; module Chip() { difference() { cube([ChipBase,ChipBase,5]); translate ([ChipBase/2,ChipBase/2,1.7]) cylinder (r=20.30,h=4); translate([ChipBase/2, ChipBase/2, -0.5]) cylinder (r=10, h=3); translate ([22,22,1.5]) chamfer(); } } module chamfer() { rotate_extrude(convexity = 10) translate([20,4, 0]) circle(r = 2,$fn=3); } for(i = [0:ChipBase:(x*ChipBase)-1]){ for(j = [0:ChipBase:(y*ChipBase)-1]){ translate([i,j,0]) Chip(); } } -- Sent from: http://forum.openscad.org/
Sat, Feb 8, 2020 5:20 AM
brute force thing,
Yep, though I thought in terms of a cone rather than a rotate_extrude of
a triangle.
Also I couldn't resist factoring the translate-to-center out.  Nor could
I resist extracting all of the variables out.  Note that we don't need
separate variables for the thickness of the negative cylinders, because
they only have to reach above the base; the thickness of the base (+2
for the through hole) is plenty.
$fn=64;
ChipBase=44;
x=3;
y=3;
thickness = 5;      // Base thickness
thickness2 = 1.7;  // thickness inside chip hole
chip_r = 20.3;      // Outer hole
hole_r = 10;        // Inner hole
cham_h = 1;        // Height of the chamfer
cham_r = 1;        // Radius (in addition to the hole) of the chamfer
module Chip() {
cube([ChipBase, ChipBase, thickness]);
translate([ChipBase/2, ChipBase/2, 0]) {
translate ([0, 0, thickness2])
cylinder (r=chip_r,h=thickness);
// -1 and +2 are to avoid Z-fighting.
translate([0, 0, -1])
cylinder (r=hole_r, h=thickness+2);
translate ([0, 0, thickness])
chamfer();
// z=0 is at the top of the hole, so we generate a chamfer down from that.
// Note that this module controls all of the geometry of the chamfer.
module chamfer() {
translate([0,0,-cham_h]) {
// cham_h2 gets us out of Z-fighting.  cham_r2 keeps the
// angles the same.
cylinder(h=cham_h2, r1=chip_r, r2=chip_r + cham_r2);
ChipBase)-1]){
On 2/7/2020 8:50 PM, lar3ry wrote: > Being reluctant to dig out and learn chamfers in BOSL2, I just did a bit of a > brute force thing, Yep, though I thought in terms of a cone rather than a rotate_extrude of a triangle. Also I couldn't resist factoring the translate-to-center out.  Nor could I resist extracting all of the variables out.  Note that we don't need separate variables for the thickness of the negative cylinders, because they only have to reach above the base; the thickness of the base (+2 for the through hole) is plenty. $fn=64; ChipBase=44; x=3; y=3; thickness = 5; // Base thickness thickness2 = 1.7; // thickness inside chip hole chip_r = 20.3; // Outer hole hole_r = 10; // Inner hole cham_h = 1; // Height of the chamfer cham_r = 1; // Radius (in addition to the hole) of the chamfer module Chip() { difference() { cube([ChipBase, ChipBase, thickness]); translate([ChipBase/2, ChipBase/2, 0]) { translate ([0, 0, thickness2]) cylinder (r=chip_r,h=thickness); // -1 and +2 are to avoid Z-fighting. translate([0, 0, -1]) cylinder (r=hole_r, h=thickness+2); translate ([0, 0, thickness]) chamfer(); } } } // z=0 is at the top of the hole, so we generate a chamfer down from that. // Note that this module controls all of the geometry of the chamfer. module chamfer() { translate([0,0,-cham_h]) { // cham_h*2 gets us out of Z-fighting. cham_r*2 keeps the // angles the same. cylinder(h=cham_h*2, r1=chip_r, r2=chip_r + cham_r*2); } } for(i = [0:ChipBase:(x*ChipBase)-1]){ for(j = [0:ChipBase:(y*ChipBase)-1]){ translate([i,j,0]) Chip(); } }
S
SUggy62
Sat, Feb 8, 2020 8:08 AM
Fantastic, That's been really helpful and informative.
I'm going to have a play with all three methods
TY
Fantastic, That's been really helpful and informative. I'm going to have a play with all three methods TY -- Sent from: http://forum.openscad.org/
Sat, Feb 8, 2020 1:03 PM
I usually don't bother with the adjustments by making the
cylinder big enough:
cylinder(r = hole_r, h = thickness * 3, center = true);
On 08.02.20 06:20, Jordan Brown wrote: > // -1 and +2 are to avoid Z-fighting. > translate([0, 0, -1]) > cylinder (r=hole_r, h=thickness+2); I usually don't bother with the adjustments by making the cylinder big enough: cylinder(r = hole_r, h = thickness * 3, center = true); ciao, Torsten.
Sat, Feb 8, 2020 11:49 PM
Chamfers in BOSL2 are actually fairly convenient in this case.  A cyl() with a negative chamfer2= value makes an external top chamfer mask.
$fn=64;
x=3;
y=3;
ChipBase=44;
grid2d(spacing=ChipBase, cols=x, rows=y) {
cube([ChipBase+0.01,ChipBase+0.01,thickness], anchor=BOT);
up(thickness2) cyl(r=chip_r, h=thickness-thickness2+0.01, chamfer2=-cham_h, anchor=BOT);
cyl(r=hole_r, h=thickness*3);
brute force thing,
$fn=64;
ChipBase=44;
x=3 ;
y=3;
module Chip() {
chamfer();
module chamfer() {
ChipBase)-1]){
Chamfers in BOSL2 are actually fairly convenient in this case. A cyl() with a negative chamfer2= value makes an external top chamfer mask. include <BOSL2/std.scad> $fn=64; x=3; y=3; ChipBase=44; thickness = 5; // Base thickness thickness2 = 1.7; // thickness inside chip hole chip_r = 20.3; // Outer hole hole_r = 10; // Inner hole cham_h = 1; // Height of the chamfer grid2d(spacing=ChipBase, cols=x, rows=y) { difference() { cube([ChipBase+0.01,ChipBase+0.01,thickness], anchor=BOT); up(thickness2) cyl(r=chip_r, h=thickness-thickness2+0.01, chamfer2=-cham_h, anchor=BOT); cyl(r=hole_r, h=thickness*3); } } > On Feb 7, 2020, at 8:50 PM, lar3ry <lar3ry@sasktel.net> wrote: > > Being reluctant to dig out and learn chamfers in BOSL2, I just did a bit of a > brute force thing, > > $fn=64; > > ChipBase=44; > x=3 ; > y=3; > > module Chip() { > difference() { > cube([ChipBase,ChipBase,5]); > translate ([ChipBase/2,ChipBase/2,1.7]) > cylinder (r=20.30,h=4); > translate([ChipBase/2, ChipBase/2, -0.5]) > cylinder (r=10, h=3); > translate ([22,22,1.5]) > chamfer(); > } > } > > module chamfer() { > rotate_extrude(convexity = 10) > translate([20,4, 0]) > circle(r = 2,$fn=3); > } > > for(i = [0:ChipBase:(x*ChipBase)-1]){ > for(j = [0:ChipBase:(y*ChipBase)-1]){ > translate([i,j,0]) Chip(); > } > } > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
lar3ry
Sun, Feb 9, 2020 5:15 AM
$fn=64;
x=3;
y=3;
ChipBase=44;
Tried that, and got:
ERROR: Assertion 'false' failed: "Bad arguments." in file
../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/vectors.scad, line 120
TRACE: called by 'vector_angle', in file
../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/coords.scad, line 151.
TRACE: called by 'rotate_points3d', in file
../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/attachments.scad, line
156.
TRACE: called by 'find_anchor', in file
253.
TRACE: called by 'orient_and_anchor', in file
../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/transforms.scad, line
1053.
TRACE: called by 'if', in file
1052.
1033.
TRACE: called by 'grid2d', in file OpenSCAD, line 13.
RevarBat wrote > Chamfers in BOSL2 are actually fairly convenient in this case. A cyl() > with a negative chamfer2= value makes an external top chamfer mask. > > include &lt;BOSL2/std.scad&gt; > > $fn=64; > x=3; > y=3; > ChipBase=44; > thickness = 5; // Base thickness > thickness2 = 1.7; // thickness inside chip hole > chip_r = 20.3; // Outer hole > hole_r = 10; // Inner hole > cham_h = 1; // Height of the chamfer > > grid2d(spacing=ChipBase, cols=x, rows=y) { > difference() { > cube([ChipBase+0.01,ChipBase+0.01,thickness], anchor=BOT); > up(thickness2) cyl(r=chip_r, h=thickness-thickness2+0.01, > chamfer2=-cham_h, anchor=BOT); > cyl(r=hole_r, h=thickness*3); > } > } Tried that, and got: ERROR: Assertion 'false' failed: "Bad arguments." in file ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/vectors.scad, line 120 TRACE: called by 'vector_angle', in file ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/coords.scad, line 151. TRACE: called by 'rotate_points3d', in file ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/attachments.scad, line 156. TRACE: called by 'find_anchor', in file ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/attachments.scad, line 253. TRACE: called by 'orient_and_anchor', in file ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/transforms.scad, line 1053. TRACE: called by 'if', in file ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/transforms.scad, line 1052. TRACE: called by 'if', in file ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/transforms.scad, line 1033. TRACE: called by 'grid2d', in file OpenSCAD, line 13. -- Sent from: http://forum.openscad.org/
Sun, Feb 9, 2020 10:12 AM
It's possible that you have an old version of BOSL2.  It's still alpha code, and I've been actively reworking it for months now. I suppose I shouldn't really be referencing it yet, but it's already so much nicer than BOSL1 that I just don't use BOSL1 anymore.
  • Revar
$fn=64;
x=3;
y=3;
ChipBase=44;
156.
253.
1053.
1052.
1033.
It's possible that you have an old version of BOSL2. It's still alpha code, and I've been actively reworking it for months now. I suppose I shouldn't really be referencing it yet, but it's already so much nicer than BOSL1 that I just don't use BOSL1 anymore. - Revar > On Feb 8, 2020, at 9:15 PM, lar3ry <lar3ry@sasktel.net> wrote: > > RevarBat wrote >> Chamfers in BOSL2 are actually fairly convenient in this case. A cyl() >> with a negative chamfer2= value makes an external top chamfer mask. >> >> include &lt;BOSL2/std.scad&gt; >> >> $fn=64; >> x=3; >> y=3; >> ChipBase=44; >> thickness = 5; // Base thickness >> thickness2 = 1.7; // thickness inside chip hole >> chip_r = 20.3; // Outer hole >> hole_r = 10; // Inner hole >> cham_h = 1; // Height of the chamfer >> >> grid2d(spacing=ChipBase, cols=x, rows=y) { >> difference() { >> cube([ChipBase+0.01,ChipBase+0.01,thickness], anchor=BOT); >> up(thickness2) cyl(r=chip_r, h=thickness-thickness2+0.01, >> chamfer2=-cham_h, anchor=BOT); >> cyl(r=hole_r, h=thickness*3); >> } >> } > > Tried that, and got: > > ERROR: Assertion 'false' failed: "Bad arguments." in file > ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/vectors.scad, line 120 > TRACE: called by 'vector_angle', in file > ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/coords.scad, line 151. > TRACE: called by 'rotate_points3d', in file > ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/attachments.scad, line > 156. > TRACE: called by 'find_anchor', in file > ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/attachments.scad, line > 253. > TRACE: called by 'orient_and_anchor', in file > ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/transforms.scad, line > 1053. > TRACE: called by 'if', in file > ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/transforms.scad, line > 1052. > TRACE: called by 'if', in file > ../Users/Admin/Documents/OpenSCAD/libraries/BOSL2/transforms.scad, line > 1033. > TRACE: called by 'grid2d', in file OpenSCAD, line 13. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
TLC123
Wed, Nov 18, 2020 5:37 PM
check out the latest pull request on this upcoming feature
Implement offset_extrude
https://github.com/openscad/openscad/pull/2079
check out the latest pull request on this upcoming feature Implement offset_extrude https://github.com/openscad/openscad/pull/2079 -- Sent from: http://forum.openscad.org/
