Yes I should. I only live here in Tenerife in the winter. I was probably
running a more recent version in the UK.
On Tue, 3 Dec 2024, 08:54 Chun Kit LAM via Discuss, <
Why not update? It is already about a year old, and manifold changed a lot.
On 12/3/24 15:51, nop head via Discuss wrote:
I am using a version from January so, yes it is due to the massive cube in
the below module. Removing a zero fixes it.
module below(bh=1,ht=25){
intersection(){translate([0,0,-1000+ht])
cube([1000,1000,2000],true);
children();}
On Tue, 3 Dec 2024 at 07:42, Chun Kit LAM via Discuss <
Which version are you using? I don't get any issue with the latest
master. Manifold was using single precision floating point and can cause
issue for this kind of models, but it was changed a few months ago.
On 12/3/24 15:31, nop head via Discuss wrote:
Regardless of the code, why does Manifold get the wrong result?
On Tue, 3 Dec 2024 at 01:45, Caddiy via Discuss <
Hey!
With offset() you even get nicely chamfered rounded corners!
$fn=100;
ch=1; // chamfer height = width
sqx=5; // side x
sqy=10; // side y
linear_extrude(+ch, scale=[(1-2/sqx), (1-2/sqy)])
offset(2)
square([sqx, sqy], center=true);
BTW is this exercise just about experimenting with simple bevel modules
or does it have a deeper purpose?
Thanks to all of you for the replies. Glad I was not alone. (fwiw, I
found that fast csg gave errors, but normal csg was OK, if restarted,
but that would be too slow for where I intended to use this). This
stemmed from trying an earlier post '[OpenSCAD] making a round container
with the help of rotate (?)' by FPA. Part of the the solution I posted
used Minkowski, which was very slow in rounding the top of the
partitions and tray. Since I think we are only concerned with 3d
printing, by choosing steps of 0.1mm, then the bevel top gives a good
result. (In any case, for fdm, chamfers are better than rounding). This
solution, that I posted, was intended to be a generic solution to that
sort of chamfering. It produces suitable results far faster than
Minkowski, but is obviously restricted to flat sections of the solid.
I chose a large cube for the intersection, since, as yet, I do not have
an fdm printer with a bed of that size, and i needed to allow for the
model being offset.
I'll update my version, and see how it goes.
Best wishes,
Ray
lot.
cube in the below module. Removing a zero fixes it.
children();}
latest master. Manifold was using single precision floating point
and can cause issue for this kind of models, but it was changed a
few months ago.
Hey!
|$fn=100;|
|ch=1; // chamfer height = width|
|sqx=5; // side x|
|sqy=10; // side y|
|linear_extrude(+ch, scale=[(1-2/sqx), (1-2/sqy)])|
|offset(2)|
|square([sqx, sqy], center=true);|
bevel modules or does it have a deeper purpose?
I've installed the build for last night. There is no problem with
Manifold, nor fast csg, since they, or much else of the earlier
features, are listed in the new features. Anyway, it works. i guess
manifold was a test situation.
There is a problem with this, in as such, now I can produce working
scripts, that will not run on earlier versions. Not a problem for me,
but obviously could be for others.
Best wishes,
Ray
container with the help of rotate (?)' by FPA. Part of the the
solution I posted used Minkowski, which was very slow in rounding the
top of the partitions and tray. Since I think we are only concerned
with 3d printing, by choosing steps of 0.1mm, then the bevel top gives
a good result. (In any case, for fdm, chamfers are better than
rounding). This solution, that I posted, was intended to be a generic
solution to that sort of chamfering. It produces suitable results far
faster than Minkowski, but is obviously restricted to flat sections of
the solid.
have an fdm printer with a bed of that size, and i needed to allow for
the model being offset.
Best wishes,
Ray
a lot.
children();}
point and can cause issue for this kind of models, but it was
Hey!
|$fn=100;|
|sqx=5; // side x|
|sqy=10; // side y|
|offset(2)|
I think i may revert to my earlier version. The latest, without
manifold, is far, far too slow.
Here is the console output for the February version using manifold.
ECHO: 0.7, 56, 102.857
Rendering Polygon Mesh using Manifold...
Geometries in cache: 86
Geometry cache size in bytes: 3013408
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
Total rendering time: 0:00:00.374
Facets: 31732
Rendering finished.
and for the latest version
Geometries in cache: 632
Geometry cache size in bytes: 4620624
CGAL Polyhedrons in cache: 101
CGAL cache size in bytes: 216265592
Total rendering time: 0:01:30.395
Top level object is a 3D object (Nef polyhedron):
Simple: no
Vertices: 16240
Halfedges: 49032
Edges: 24516
Halffacets: 16562
Facets: 8281
Volumes: 4
WARNING: Object may not be a valid 2-manifold and may need repair!
Rendering finished.
The above results were for exactly the same script, and only a
relatively small part of the project. The fact that the cgi version
threw a warning, does not matter in this case, since the slicer did not
bulk at the stl file produced by the manifold version.
For anything useful to me, the cgi rendering is now far too slow. I
recollect someone mentioning it would be removed, a while back, but If
it gave a problem, then there was the option of re-rendering in the cgi
engine.
Are there any newer settings to speed it up a bit?
Best wishes,
Ray
gives a good result. (In any case, for fdm, chamfers are better than
of the solid.
for the model being offset.
Best wishes,
Ray
a lot.
children();}
Hey!
|$fn=100;|
|sqx=5; // side x|
|sqy=10; // side y|
|offset(2)|
I suggest you turn on Manifold in the newer version:
Preferences-->Advanced-->3D Rendering-->Backend
Dan
On Tue, Dec 3, 2024 at 6:53 PM Raymond West via Discuss <
I think i may revert to my earlier version. The latest, without manifold,
Facets: 31732
Rendering finished.
Simple: no
Vertices: 16240
Halfedges: 49032
Edges: 24516
Halffacets: 16562
Facets: 8281
Volumes: 4
Rendering finished.
The above results were for exactly the same script, and only a relatively
small part of the project. The fact that the cgi version threw a warning,
does not matter in this case, since the slicer did not bulk at the stl file
recollect someone mentioning it would be removed, a while back, but If it
engine.
Manifold, nor fast csg, since they, or much else of the earlier features,
are listed in the new features. Anyway, it works. i guess manifold was a
test situation.
scripts, that will not run on earlier versions. Not a problem for me, but
Best wishes,
Ray
Thanks to all of you for the replies. Glad I was not alone. (fwiw, I found
that fast csg gave errors, but normal csg was OK, if restarted, but that
would be too slow for where I intended to use this). This stemmed from
trying an earlier post '[OpenSCAD] making a round container with the help
of rotate (?)' by FPA. Part of the the solution I posted used Minkowski,
which was very slow in rounding the top of the partitions and tray. Since I
think we are only concerned with 3d printing, by choosing steps of 0.1mm,
then the bevel top gives a good result. (In any case, for fdm, chamfers
are better than rounding). This solution, that I posted, was intended to be
a generic solution to that sort of chamfering. It produces suitable results
far faster than Minkowski, but is obviously restricted to flat sections of
the solid.
an fdm printer with a bed of that size, and i needed to allow for the model
being offset.
Best wishes,
Ray
children();}
Hey!
$fn=100;
sqx=5; // side x
sqy=10; // side y
offset(2)
You can also do this in the command line by adding the flag --backend Manifold.
A backend selection mechanism was added recently and manifold is no
longer treated the same as the other experimental features.
Dan
Facets: 31732
Rendering finished.
Simple: no
Vertices: 16240
Halfedges: 49032
Edges: 24516
Halffacets: 16562
Facets: 8281
Volumes: 4
Rendering finished.
version threw a warning, does not matter in this case, since the
slicer did not bulk at the stl file produced by the manifold version.
slow. I recollect someone mentioning it would be removed, a while
back, but If it gave a problem, then there was the option of
re-rendering in the cgi engine.
guess manifold was a test situation.
working scripts, that will not run on earlier versions. Not a
problem for me, but obviously could be for others.
Best wishes,
Ray
(fwiw, I found that fast csg gave errors, but normal csg was OK,
if restarted, but that would be too slow for where I intended to
use this). This stemmed from trying an earlier post '[OpenSCAD]
making a round container with the help of rotate (?)' by FPA.
Part of the the solution I posted used Minkowski, which was very
of 0.1mm, then the bevel top gives a good result. (In any case,
for fdm, chamfers are better than rounding). This solution, that
I posted, was intended to be a generic solution to that sort of
solid.
not have an fdm printer with a bed of that size, and i needed to
allow for the model being offset.
Best wishes,
Ray
changed a lot.
massive cube in the below module. Removing a zero fixes it.
children();}
the latest master. Manifold was using single precision
floating point and can cause issue for this kind of
result?
Hey!
corners!
|$fn=100;|
|sqx=5; // side x|
|sqy=10; // side y|
|offset(2)|
simple bevel modules or does it have a deeper purpose?
I guess 'change the location to confuse the enemy.' 😳
Total rendering time: 0:00:00.152
thanks
Dan
Facets: 31732
Rendering finished.
Simple: no
Vertices: 16240
Halfedges: 49032
Edges: 24516
Halffacets: 16562
Facets: 8281
Volumes: 4
Rendering finished.
Best wishes,
Ray
solid.
Best wishes,
Ray
changed a lot.
children();}
result?
Hey!
corners!
|$fn=100;|
|sqx=5; // side x|
|sqy=10; // side y|
|offset(2)|
Here is my latest complete bevel code. I'm happy with what it does. At
the moment, it only works with vertical, straight sided objects. Useful
for open-topped boxes, and they can easily be made stackable. The 0.1
resolution is good enough for current fdm printers. Note that the
bevels (really the are chamfers) are subtractive, as they are in the
machinist's world.
module myshape(){
$fn=100;
union(){cylinder(d=18,h=25);
cube(25);}
translate([8,8,-8]) cylinder(d=10,h=60);
ht=14; // height of top of object
bh=1.55; // height of top bevel
bb=2; // height of bottom bevel
bt=4; // height of bottom of object
bevelobj(ht,bh,bb,bt)myshape();
module beveltop(bh=1,ht=25){ // bh = bevel height, ht = height to top
of bevel
translate([0,0,ht-bh-0.1])
for (j=[0:0.1:bh-0.1]){
translate([0,0,j])
linear_extrude(0.2)
offset(delta=-1*j)
projection(cut=true)
translate([0,0,-ht])
module bevelbot(bb=2,bt=0){ //bt= bottom of bevel, bb= bevel height
translate([0,0,bt+bb])
for (j=[0:0.1:bb]){
translate([0,0,-j])
linear_extrude(0.2)
offset(delta=-1*j)
translate([0,0,-bt])
myshape();
module middle(ht=10,bh=1,bb=2,bt=2){
intersection(){
translate([-5000,-5000,bt+bb])
cube([10000,10000,ht-bh-(bt+bb)]);
module bevelobj(ht,bh,bb,bt){
middle(ht,bh,bb,bt)children();
beveltop(bh,ht)children();
bevelbot(bb,bt)children();
thanks
Dan
Facets: 31732
Rendering finished.
Simple: no
Vertices: 16240
Halfedges: 49032
Edges: 24516
Halffacets: 16562
Facets: 8281
Volumes: 4
Rendering finished.
version.
while back, but If it gave a problem, then there was the option
of re-rendering in the cgi engine.
with Manifold, nor fast csg, since they, or much else of the
earlier features, are listed in the new features. Anyway, it
works. i guess manifold was a test situation.
Best wishes,
Ray
OK, if restarted, but that would be too slow for where I
intended to use this). This stemmed from trying an earlier post
'[OpenSCAD] making a round container with the help of rotate
tray. Since I think we are only concerned with 3d printing, by
suitable results far faster than Minkowski, but is obviously
to allow for the model being offset.
Best wishes,
Ray
changed a lot.
children();}
result?
Hey!
corners!
|$fn=100;|
|sqx=5; // side x|
|sqy=10; // side y|
|offset(2)|
The two modules below simply add a vertical section, and it now renders
for sloping sided objects too, so replace the previous two 'same named
modules' with these. If you have an stl that prints with an 'elephant's
foot', then you can now bevel the base to remove it.
of bevel
translate([0,0,j])
linear_extrude(0.2)
offset(delta=-1*j)
translate([0,0,-ht+bh])
for (j=[0:0.1:bb]){
translate([0,0,-j])
linear_extrude(0.2)
offset(delta=-1*j)
translate([0,0,-bt-bb])
myshape();
Useful for open-topped boxes, and they can easily be made stackable.
The 0.1 resolution is good enough for current fdm printers. Note that
the bevels (really the are chamfers) are subtractive, as they are in
the machinist's world.
module myshape(){
$fn=100;
cube(25);}
of bevel
translate([0,0,j])
linear_extrude(0.2)
offset(delta=-1*j)
for (j=[0:0.1:bb]){
translate([0,0,-j])
linear_extrude(0.2)
offset(delta=-1*j)
myshape();
intersection(){
thanks
Dan
Facets: 31732
Rendering finished.
Simple: no
Vertices: 16240
Halfedges: 49032
Edges: 24516
Halffacets: 16562
Facets: 8281
Volumes: 4
Rendering finished.
version.
Best wishes,
Ray
post '[OpenSCAD] making a round container with the help of
intended to be a generic solution to that sort of chamfering.
It produces suitable results far faster than Minkowski, but is
do not have an fdm printer with a bed of that size, and i
needed to allow for the model being offset.
Best wishes,
Ray
changed a lot.
children();}
result?
Hey!
corners!
|$fn=100;|
|sqx=5; // side x|
|sqy=10; // side y|
|offset(2)|
