I have a problem with this http://www.thingiverse.com/thing:140343 project
when rendering in openscad. The logo is extruded out from the surface, but
does not go into the surface to make the negative on the other side of the
hinge. Can someone help me?
Before rendering:
http://forum.openscad.org/file/n14953/ska.png
After rendering:
http://forum.openscad.org/file/n14953/Sk%C3%A6rmbillede_2015-12-05_kl.png
"code"
// preview[view:south, tilt:top]
/* [Global] */
// Load a 100x100 pixel image.(images will be stretched to fit) Simple, high
contrast images work best. Make sure to click the Invert Colors checkbox!
image_file = "cp.dat"; // [image_surface:100x100]
// Where would you like the hinge in relation to your image?
hinge_placement = 1; // [1:top,2:left,3:bottom,4:right]
// What height would you like for the embossed area (mm)?
emboss_height = 1.5;
/* [Hidden] */
$fa = 6;
$fs = 1.5;
image_width = 40;
image_length = 40;
image_padding = 4;
handle_width = image_width + image_padding*2;
handle_length = 70;
handle_height = emboss_height+2.5;
nub = 3; // hinge size
tol = 0.4; // spacing between hinge pieces
assembly();
module assembly() {
stamp_top(90hinge_placement);
stamp_bottom(90hinge_placement);
module stamp_top(rot=90) {
translate([1,0,0])
difference () {
translate([handle_length + nub + tol, -handle_width/2, 0])
rotate([0,0,90]) handle();
translate([handle_length-image_length/2+nub+tol,0,handle_height])
rotate([0,180,rot]) plate();
// hinge
translate([-1,handle_width/2-2*nub,handle_height]) hinge_m();
mirror([0,1,0]) translate([-1,handle_width/2-2*nub,handle_height])
hinge_m();
translate([-1,-nub,handle_height]) hinge_m();
mirror([0,1,0]) translate([-1,-nub,handle_height]) hinge_m();
module stamp_bottom(rot=90) {
translate([-1,0,0])
translate([-handle_length + image_length/2-nub-tol,0,handle_height])
rotate([0,0,-rot]) plate();
mirror([1,0,0]) translate([handle_length + nub + tol,
// hinge
translate([1,-nub-tol,handle_height]) hinge_f();
mirror([0,1,0]) translate([1,-nub-tol,handle_height]) hinge_f();
module handle() {
hull() {
cube([handle_width, handle_length, handle_height]);
translate([image_padding,0,0]) cylinder(r=image_padding,
h=handle_height);
translate([handle_width-image_padding,0,0])
cylinder(r=image_padding, h=handle_height);
guide();
module guide() {
translate([image_padding,0,-.5])
cube([image_width, image_length, 1]);
translate([1,1,-0.5]) cube([image_width-2, image_length-2, 2]);
module hinge_m() {
difference () {
rotate([0,45,0]) union(){
translate([0,0,-nub]) cube ([nub3,nub2, nub2]);
rotate([90,0,0]) {
translate([0,0,-2nub]) cylinder(r=nub,h=2nub);
cylinder(r1=nub,r2=0,h=nub);
translate([-nub,-nub/2,-handle_height-nub5]) cube([nub5, nub3,
nub*5]);
module hinge_f() {
len = handle_width/2 - 3nub - 2tol;
rotate([90,-45,0])
cylinder(r=nub, h=len);
translate([-3*nub,-nub,0]) cube([nub*3,nub*2,len]);
translate([0,0,-0.1]) cylinder(r1=nub+tol,r2=0,h=nub);
translate([0,0,len-nub+0.1]) cylinder(r1=0,r2=nub+tol,h=nub);
translate([-nub*4,-len-nub/2,-handle_height-nub*5]) cube([nub*5,
len+nub, nub*5]);
module plate() {
scale([(image_width)/100,(image_length)/100,emboss_height])
surface(file=image_file, center=true, convexity=5);
View this message in context: http://forum.openscad.org/Problem-in-openscad-script-from-Thingiverse-tp14953.html
Can you upload the cp.dat file you are using.
View this message in context: http://forum.openscad.org/Problem-in-openscad-script-from-Thingiverse-tp14953p14971.html
Hi Michael
Here is the file. https://www.dropbox.com/s/umqyfgg2wv63bq3/cp.dat?dl=0
I am also getting the same error with the other .dat's in the project.
View this message in context: http://forum.openscad.org/Problem-in-openscad-script-from-Thingiverse-tp14953p14978.html
Well some error has slithered into later releases...
I get the same error, but not in 2013.06, I'll try some other versions and
see if I can drill down to the root cause.
http://forum.openscad.org/file/n14983/2013-0_v_2015-10-17.jpg
If your project is urgent you can find 2013.06 here
http://files.openscad.org/
View this message in context: http://forum.openscad.org/Problem-in-openscad-script-from-Thingiverse-tp14953p14983.html
2014.03 is also OK.
View this message in context: http://forum.openscad.org/Problem-in-openscad-script-from-Thingiverse-tp14953p14984.html
This did the trick Michael, thank you so much for your valuable help! It has
helped me a lot!
Best regards
Anders, Denmark
View this message in context: http://forum.openscad.org/Problem-in-openscad-script-from-Thingiverse-tp14953p14986.html
Seems to be an issue with scale() and surface().
Issue 1512 raised https://github.com/openscad/openscad/issues/1512
View this message in context: http://forum.openscad.org/Problem-in-openscad-script-from-Thingiverse-tp14953p15002.html
I found that if you remove the coincident faces the problem goes away.
In the translate() before the two plate() calls, change the z to
handle_height+0.01.
View this message in context: http://forum.openscad.org/Problem-in-openscad-script-from-Thingiverse-tp14953p15529.html
