Hypoid gear modelling - been done in OpenSCAD?
AG
Alex Gibson
Thu, Feb 20, 2020 3:13 PM
I would like to model a car differential gear set for a personal project.
This uses Hypoid gear drive - similar to this:
https://www.thingiverse.com/thing:1888576
The Hypoid gear goes a bit beyond the usual spiral bevel gear libraries, as
there's an offset shaft as well as curved teeth.
I've found a few examples of people having done this in Blender, showing
their working, and there are online calculators, so eventually I imagine I
could recreate these - but would be brilliant if this already exists in
OpenSCAD - anybody seen this please?
Cheers,
Alex Gibson
admg consulting
edumaker limited
.        Project management
.        Operations & Process improvement
.        3D Printing
I would like to model a car differential gear set for a personal project. This uses Hypoid gear drive - similar to this: https://www.thingiverse.com/thing:1888576 The Hypoid gear goes a bit beyond the usual spiral bevel gear libraries, as there's an offset shaft as well as curved teeth. I've found a few examples of people having done this in Blender, showing their working, and there are online calculators, so eventually I imagine I could recreate these - but would be brilliant if this already exists in OpenSCAD - anybody seen this please? Cheers, Alex Gibson admg consulting edumaker limited . Project management . Operations & Process improvement . 3D Printing
N
NateTG
Thu, Feb 20, 2020 6:53 PM
I tried to generate hypoid gears years ago, but my gear theory was bad at the
time.  Maybe I should take another crack at it.
I tried to generate hypoid gears years ago, but my gear theory was bad at the time. Maybe I should take another crack at it. -- Sent from: http://forum.openscad.org/
AG
Alex Gibson
Thu, Feb 20, 2020 7:27 PM
I could only encourage this :)
Some research aids!
This is a true hypoid already created as I mentioned already:
This actually comes with a full tutorial for creating it in Blender - and
even better from the maker, an online calculator:
http://www.otvinta.com/hypoid.html
Here are a few already good OpenSCAD gear libraries, it would be great to
build on one of these to give any new function maximum reach - one that is
referenced by a lot of extruder designs:
https://www.thingiverse.com/thing:3752
...and another which is very comprehensive and includes planetary gearboxes,
herringbone bevel gears, in German but I could help with anything Google
Translate doesn't make sense of!
https://www.thingiverse.com/thing:1604369
(apparently sometimes this generates non-manifold issues but I've not yet
had that issue...
Here is an unfinished library that contains good stuff too:
https://www.thingiverse.com/thing:881568
Alex Gibson
admg consulting
edumaker limited
. 3D Printing
NateTG
Sent: 20 February 2020 18:53
Subject: Re: [OpenSCAD] Hypoid gear modelling - been done in OpenSCAD?
I could only encourage this :) Some research aids! This is a true hypoid already created as I mentioned already: https://www.thingiverse.com/thing:1888576 This actually comes with a full tutorial for creating it in Blender - and even better from the maker, an online calculator: http://www.otvinta.com/hypoid.html Here are a few already good OpenSCAD gear libraries, it would be great to build on one of these to give any new function maximum reach - one that is referenced by a lot of extruder designs: https://www.thingiverse.com/thing:3752 ...and another which is very comprehensive and includes planetary gearboxes, herringbone bevel gears, in German but I could help with anything Google Translate doesn't make sense of! https://www.thingiverse.com/thing:1604369 (apparently sometimes this generates non-manifold issues but I've not yet had that issue... Here is an unfinished library that contains good stuff too: https://www.thingiverse.com/thing:881568 Alex Gibson admg consulting edumaker limited . Project management . Operations & Process improvement . 3D Printing -----Original Message----- From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of NateTG Sent: 20 February 2020 18:53 To: discuss@lists.openscad.org Subject: Re: [OpenSCAD] Hypoid gear modelling - been done in OpenSCAD? I tried to generate hypoid gears years ago, but my gear theory was bad at the time. Maybe I should take another crack at it. -- Sent from: http://forum.openscad.org/ _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- This email has been checked for viruses by AVG. https://www.avg.com
JC
Juan C.Cilleruelo
Fri, Feb 21, 2020 7:17 AM
See this: https://www.thingiverse.com/thing:1604369
Some research aids!
had that issue...
Alex Gibson
admg consulting
edumaker limited
. 3D Printing
NateTG
See this: https://www.thingiverse.com/thing:1604369 On 20/02/2020 20:27, Alex Gibson wrote: > I could only encourage this :) > > Some research aids! > > This is a true hypoid already created as I mentioned already: > https://www.thingiverse.com/thing:1888576 > This actually comes with a full tutorial for creating it in Blender - and > even better from the maker, an online calculator: > http://www.otvinta.com/hypoid.html > > Here are a few already good OpenSCAD gear libraries, it would be great to > build on one of these to give any new function maximum reach - one that is > referenced by a lot of extruder designs: > https://www.thingiverse.com/thing:3752 > > ...and another which is very comprehensive and includes planetary gearboxes, > herringbone bevel gears, in German but I could help with anything Google > Translate doesn't make sense of! > https://www.thingiverse.com/thing:1604369 > (apparently sometimes this generates non-manifold issues but I've not yet > had that issue... > > Here is an unfinished library that contains good stuff too: > https://www.thingiverse.com/thing:881568 > > > Alex Gibson > > admg consulting > > edumaker limited > > . Project management > . Operations & Process improvement > . 3D Printing > > > -----Original Message----- > From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of > NateTG > Sent: 20 February 2020 18:53 > To: discuss@lists.openscad.org > Subject: Re: [OpenSCAD] Hypoid gear modelling - been done in OpenSCAD? > > I tried to generate hypoid gears years ago, but my gear theory was bad at > the > time. Maybe I should take another crack at it. > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
