Openscad and SolidPython
SQ
Sam Quintanar
Mon, Sep 11, 2017 11:30 PM
Does anyone here know if I can install SolidPython on windows (and if so, how?!)  I'd like to generate dome Openscad code with it.I downloaded the zip file from the github page and when I unzipped and clicked on setup.py...a console window appeared and then quickly disappeared.
squint
Does anyone here know if I can install SolidPython on windows (and if so, how?!)  I'd like to generate dome Openscad code with it.I downloaded the zip file from the github page and when I unzipped and clicked on setup.py...a console window appeared and then quickly disappeared. squint
S
stonysmith
Tue, Sep 12, 2017 11:17 PM
You have two options:
  1. Drop to a command line, and simply type in "python"... see what happens.
    You may get any one of several messages to the effect that some thing is not
    found and/or is missing.
Then, exit from python, change to the folder where your setup.py is, and
type in "python setup.py"... this time, the window won't just disappear.
or...
2) search your Python installation and find the program "Idle.bat". It
should be in ... \python\Lib\idlelib
Idle (a GUI interface) will open in a new window.. you can then open
setup.py and select run on it.
You have two options: 1) Drop to a command line, and simply type in "python"... see what happens. You may get any one of several messages to the effect that some thing is not found and/or is missing. Then, exit from python, change to the folder where your setup.py is, and type in "python setup.py"... this time, the window won't just disappear. or... 2) search your Python installation and find the program "Idle.bat". It should be in ... \python\Lib\idlelib Idle (a GUI interface) will open in a new window.. you can then open setup.py and select run on it. -- Sent from: http://forum.openscad.org/
