Hello,
I want to build a simple 3D form who look like a bridge.
Description :
I want than the middle of this bridge are more narrow than begin and end.
What the prefered way for doing that ?
Thanks
I have find this about the global 3D form :
https://www.mathcurve.com/courbes2d.gb/croixdemalte/croixdemalte.shtml
And i wan't this like a bridge.
Who could i do that ?
Like this?
http://forum.openscad.org/file/t1309/arch.jpg
The shape of a Bezier curve follows its control point specifications. What
is the header (name and arguments) of the Bezier function you are using and
what are the arguments you set for the upper arc of the bridge? I could
give you some suggestions based on them.
2017-11-24 12:23 GMT-02:00 ashuan laurent.sass@gmail.com:
Hello,
Description :
Thanks
I did this to show a simple bridge.
$fn = 120;
db = 200; // diameter of bridge -- higher is flatter
dw = 35; // width of bridge -- higher is wider
do = 1.1; // offset of either side in the middle
module bridge()
intersection()
rotate([0,90,0]) translate([db/2,0,0]) cylinder(d=db, h=dw,
center=true);
rotate([0,90,0]) translate([db/2*do,0,0]) cylinder(d=db, h=dw+10,
center=true);
translate([-db/2*do,0,0]) cylinder(d=db, h=dw, center=true);
mirror([1,0,0]) translate([-db/2*do,0,0]) cylinder(d=db, h=dw,
center=true);
cube([dw,200,10], center=true);
bridge();
translate([0,0,-2]) scale([1.25, 1, 0.95]) bridge();
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
On Fri, Nov 24, 2017 at 10:43 AM, Ronaldo Persiano rcmpersiano@gmail.com
Hello,
Description :
Thanks
Thanks, yes, it's seem ok.
I have just a problematic point :
Is it possible with your proposal ?
Thanks for this code, it's exactly look like what i want.
I have look for my ideal parameters.
I have change those like that :
db = 20; // diameter of bridge -- higher is flatter
dw = 40; // width of bridge -- higher is wider
do = 1.2; // offset of either side in the middle
I have a little bug (screenshot).
I try to understand your code proposal :
http://forum.openscad.org/file/t2049/2017-11-27_1243.png
If my understand are exact, i have just to change the compute of left &
right cylinder.
Yes, just difference two more cylinders.
http://forum.openscad.org/file/t1309/arch2.jpg
Thanks a lot, it's perfect.
I have change your code like following.
Now, i just have to destroy (if possible) the x, y, z correction
and applicate my parameter like shape_Length, shape_Width, shape_Height,
bridge_Width, bridge_Height.
Thanks again.
shapeColorTop = "red";
shapeColorLeft = "red";
shapeColorRight = "red";
shapeColorDown = "red";
shapePos_x = 10 - 75; // true value, correction
shapePos_y = 10 + 45; // true value, correction
shapePos_z = 00 - 10; // true value, correction
shape_Length = 110; // Longeur
shape_Width = 40; // Largeur
shape_Height = 30; // Hauteur
bridge_Width = 15; // Taille étroite du pont
bridge_Height = 05; // Hauteur étroite du pont
translate([shapePos_x,shapePos_y,shapePos_z]) {
choiceColor(shapeColorTop) {
rotate([90,0,0])
translate([0,-25,0])
cylinder(h=50, r1=65, r2=65, center=false, $fa=2);
choiceColor(shapeColorDown) {
rotate([90,0,0])
translate([0,-11,0])
cylinder(h=100, r1=50, r2=50, center=false, $fa=2);
// remove the lower portion
choiceColor(shapeColorLeft) {
translate([-75,-75,-90])
cube(size=[150,100,100], center=false);
// make arch more narrow in center
choiceColor(shapeColorRight) {
translate([0,80,0])
cylinder(h=100,r1=100,r2=100,center=false,$fa=2);
translate([0,-130,0])
// color gesture
module choiceColor(couleur)
if (couleur == "default") orange() children();
if (couleur == "green") green() children();
if (couleur == "blue") blue() children();
if (couleur == "orange") orange() children();
if (couleur == "violet") violet() children();
if (couleur == "red") red() children();
if (couleur == "postit") postit() children();
if (couleur == "marron") marron() children();
if (couleur == "black") black() children();
if (couleur == "white") white() children();
if (couleur == "human") human() children();
module green() color("LimeGreen", 0.5) children();
module orange() color("Gold", 1) children();
module blue() color("SteelBlue", 0.5) children();
module violet() color("DarkOrchid", 1) children();
module red() color("FireBrick", 0.8) children();
module postit() color("Cornsilk", 0.8) children();
module marron() color("Peru", 0.8) children();
module black() color("Black", 0.7) children();
module white() color("White", 1) children();
module human() color("SteelBlue", 0.9) children();
