I really have not understood the behaviour of nested use and include as
expressed in the wiki Manual. And does not understand the outcomes of the
following three codes:
// file test1
VAR = 1;
function f(a) = VAR;
// file test2.scad
include
<test1.scad>
function g(a) = f(a);
// file test3.scad
include
<test1.scad>
use
<test2.scad>
function f(a) = a*VAR;
echo(g(5));
I would expect an output ECHO: 5 from running test3.scad. However, the
redefinition of f() in test3.scad does not override the test1.scad
definition. If, instead of use, I include test2.scad in test3.scad I get the
wanted overriding but at the expenses of an unwanted additional echo.
View this message in context: http://forum.openscad.org/Usage-of-use-and-include-tp17850.html
AFAIK
include <> basically brings the text inline to the main file. Hence global
scope/context applies.
The internals of a use<>'ed file operates in its own context.
Thus, with use<> the f(a) defining g() in test2.scad will always be the f(a)
in test2.scad
With include<> the f(a) defining g() in test2.scad will be the f(a) in
scope, i.e. the redefined one in test3.scad.
use<> has similar issues if you want to override local variables, you can't.
IMO it is better practice to utilise include<> without executable code, than
use<>.
View this message in context: http://forum.openscad.org/Usage-of-use-and-include-tp17850p17852.html
p.s. What 'unwanted additional echo'?
View this message in context: http://forum.openscad.org/Usage-of-use-and-include-tp17850p17853.html
