I think Mr.Jordan's solution is the most simple and best in this case .
On Fri, 14 Oct, 2022, 9:44 am Jordan Brown, openscad@jordan.maileater.net
Here's another simple answer.
module pie(a) {
polygon([
[0,0],
for (i=[0:a]) [cos(i), sin(i)]
pie(360*$t);
Left for the reader:
- Extending to larger than unit.
- Extending to 3D.
- Handling a=0.
- Handling a=360.
While I appreciate the hat-tip, no, Whosawhatsis's is better for the 3D
case that I think he really wanted.
$fn=50;
module pie(a) {
rotate_extrude(angle=a) square();
pie(360*$t);
Note that the "active ingredient" is just one line.
Yes
In case the shape is not a cylinder, then probably a few more lines to be
written and difference( ) command would be required here.
On Fri, 14 Oct, 2022, 10:56 am Jordan Brown, openscad@jordan.maileater.net
$fn=50;
module pie(a) {
pie(360*$t);
Here's yet another answer: build the polyhedron on your own.
module pie(a) {
// Approximately one side per degree.
n = ceil(a);
// Return indexes into the point list for the specified
// index into the bottom or top.
function bottom(i) = 2+i;
function top(i) = 2+n+1+i;
if (a > 0) {
points = [
[0,0,0],
[0,0,1],
for (z=[0,1], i=[0:n]) [cos(i/n*a), sin(i/n*a), z]
faces = [
// Bottom
for (i=[0:n-1]) [0, bottom(i), bottom(i+1)],
// Top
for (i=[0:n-1]) [1, top(i+1), top(i)],
// Triangles pointing up
for (i=[0:n-1]) [bottom(i+1), bottom(i), top(i)],
// Triangles pointing down
for (i=[0:n-1]) [top(i), top(i+1), bottom(i+1)],
// Sides
[ 0, top(0), bottom(0) ],
[ 0, 1, top(0) ],
[ 0, bottom(n), 1],
[ 1, bottom(n), top(n)],
polyhedron(points=points, faces=faces);
pie($t*360);
This answer is, of course, enormously more complex than any of the
others. However, learning the techniques involved in algorithmically
building polyhedra will let you do lots of interesting things - and
generally the performance is excellent.
My version is just an intersection between a circle and a four triangle fan.
//! A sector of a circle between two angles.
include <../utils/core/core.scad>
module sector(r, start_angle, end_angle) { //! Create specified sector
given radius r, start_angle and end_angle
R = r * sqrt(2) + 1;
if(end_angle > start_angle)
circle4n(r);
// A 4 triangle fan
polygon([[0, 0],
for(i = [0 : 4], a = start_angle + i * (end_angle -
start_angle) / 4) R * [cos(a), sin(a)] ]);
On Fri, 14 Oct 2022 at 07:35, Jordan Brown openscad@jordan.maileater.net
module pie(a) {
n = ceil(a);
if (a > 0) {
points = [
[0,0,0],
[0,0,1],
for (z=[0,1], i=[0:n]) [cos(i/na), sin(i/na), z]
faces = [
// Bottom
// Top
// Sides
[ 0, 1, top(0) ],
[ 0, bottom(n), 1],
pie($t*360);
This is simpler, and renders much faster:
h=50;
d=300;
a=34;
rotate_extrude(angle = 360-a) square([d/2,h]);
// if you want the slice instead of the pie, use angle = a instead of 360-a
On 10/13/2022 7:48 PM, Raymond West wrote:
This'll work, if you are not too greedy 😉
module pie(){
cylinder(h=h,d=d);
module slice(){
translate([0,0,-h])
linear_extrude (3h)
polygon(points=[[0,0],[0,d2],[sin(a)2d,cos(a)2d]]);
pie();
slice();
h=50;
d=300;
a=34;
leaves the rest of the pie. If you want the slice, intersection not
difference.
On 13/10/2022 23:58, Bryan Lee wrote:
I need a method to cut a wedge out of a cylinder (or other shape).
Think of it like cutting a slice of pie at a specific angle.
module wedge(cutangle){
// returns a wedge of the specified angle
I thought I had a solution that used the intersection of 2 cubes, but
then
my brain broke. I was able to accomplish the goal by differencing
out the
negative using 3 cubes, but this became a difference() in a
difference() in
a difference() and there the preview render can get ugly.
I would really like a solid shape that I can intersect instead.
Any thoughts?
