packing objects in 2 space
Sun, Feb 13, 2022 12:17 AM
On 2/12/2022 3:49 PM, Father Horton wrote:
Interesting. If you randomly permute the list of objects, how widely
spread are the results? If there’s a considerable range, and if you
need to minimize the total area, that could be something to try.
Performance definitely varies widely with similar (not the same)
inputs.  Another run for 100 blocks on a 60x60 space ran in 18m57s and
at the end had 2.6M entries on the free list.
This algorithm doesn't try to minimize the total area, and in fact does
an awful job at minimizing the bounding box.  It tends to walk up the
left side of the area, and then walk to the right, and then fill in from
the top down.  I don't yet fully understand the behavior, but I think
that it's dominated by the fact that, given a free block that can hold
the block to be placed, it uses the lower-left corner of that free block.
To minimize the bounding box, I think you'd want to sort of build out
from the origin, placing new blocks along the perimeter of the existing
blocks.
A related problem is to pack as many blocks as possible into a given
area.  That's where randomly permuting the inputs to this function might
be useful.  Probably you would make it stop and return what it has when
it's not able to place a block - and if it was able to place all of the
blocks, you could try placing more.
On 2/12/2022 3:49 PM, Father Horton wrote: > Interesting. If you randomly permute the list of objects, how widely > spread are the results? If there’s a considerable range, and if you > need to minimize the total area, that could be something to try.  Performance definitely varies widely with similar (not the same) inputs.  Another run for 100 blocks on a 60x60 space ran in 18m57s and at the end had 2.6M entries on the free list. This algorithm doesn't try to minimize the total area, and in fact does an awful job at minimizing the bounding box.  It tends to walk up the left side of the area, and then walk to the right, and then fill in from the top down.  I don't yet fully understand the behavior, but I think that it's dominated by the fact that, given a free block that can hold the block to be placed, it uses the lower-left corner of that free block. To minimize the bounding box, I think you'd want to sort of build out from the origin, placing new blocks along the perimeter of the existing blocks. A related problem is to pack as many blocks as possible into a given area.  That's where randomly permuting the inputs to this function might be useful.  Probably you would make it stop and return what it has when it's not able to place a block - and if it was able to place all of the blocks, you could try placing more.
Sun, Feb 13, 2022 5:37 PM
On 2/12/2022 4:08 PM, jon wrote:
Wow.  I can't even begin to comprehend what you did.  But I am
grateful!   I hope this helps others going forward
It was an interesting puzzle.
But conceptually it's really not that complex.
Start with an area
ABCDE
FGHIJ
KLMNO
PQRST
UVWXY
Let's place, oh, a [2,3] block.  That's easy:
ABCDE
FGHIJ
**MNO
**RST
**WXY
We've placed our first block.  What space do we have left?  We have the
area above that block:
ABCDE   call this block 1
FGHIJ
and the area to the right:
..CDE    call this block 2
..HIJ
..MNO
..RST
..WXY
left.  Now let's place a [4,1] block.  That fits in block 1:
ABCDE
****J
and splits block 1 into:
ABCDE   call this block 3
and
....E   call this block 4
....J
It also overlaps block 2.  It's chopping out the HI, so splits it into
the block above:
..CDE    call this block 5
the block to the right:
....E    call this block 6
....J
....O
....T
....Y
and the block below:
.....    call this block 7
..MNO
..RST
..WXY
Now we're placed two blocks:
2222.
11...
11...
11...
and have this free space:
ABCDE
....J
..MNO
..RST
..WXY
The free space is recorded in the form of five overlapping blocks -
blocks 3, 4, 5, 6, and 7.
3      4      5      6      7
ABCDE  ....E  ..CDE  ....E  .....
.....  ....J  .....  ....J  .....
.....  .....  .....  ....O  ..MNO
.....  .....  .....  ....T  ..RST
.....  .....  .....  ....Y  ..WXY
(Note:  this illustrates what I mean about the potential for
deduplication.  Block 5 (CDE) is entirely enclosed by block 3 (ABCDE)
and so could be dropped.  Similarly, block 4 (EJ) is entirely enclosed
by block 6 (EJOTY).)
We continue this process until we've placed all of the blocks, or until
we can't fit a block into an available space.
The implementation uses some slightly tricky OpenSCAD stuff like list
comprehensions (to find a free space to put a block, and to break up
free blocks when we place a block) and recursion (to process all of the
blocks to be placed), but with an idea of how it works maybe you can
understand the implementation better.
I don't claim that this is the best algorithm available for the
problem.  In particular, I suspect that it could be relatively easily
improved by looking for the smallest block that the new block will fit
into, rather than the first one found.  But it was what I came up with,
and it seems to sort of work...
On 2/12/2022 4:08 PM, jon wrote: > > Wow.  I can't even begin to comprehend what you did.  But I am > grateful!   I hope this helps others going forward > It was an interesting puzzle. But conceptually it's really not that complex. Start with an area ABCDE FGHIJ KLMNO PQRST UVWXY Let's place, oh, a [2,3] block.  That's easy: ABCDE FGHIJ **MNO **RST **WXY We've placed our first block.  What space do we have left?  We have the area above that block: ABCDE call this block 1 FGHIJ ..... ..... ..... and the area to the right: ..CDE call this block 2 ..HIJ ..MNO ..RST ..WXY left.  Now let's place a [4,1] block.  That fits in block 1: ABCDE ****J ..... ..... ..... and splits block 1 into: ABCDE call this block 3 ..... ..... ..... ..... and ....E call this block 4 ....J ..... ..... ..... It also overlaps block 2.  It's chopping out the HI, so splits it into the block above: ..CDE call this block 5 ..... ..... ..... ..... the block to the right: ....E call this block 6 ....J ....O ....T ....Y and the block below: ..... call this block 7 ..... ..MNO ..RST ..WXY Now we're placed two blocks: ..... 2222. 11... 11... 11... and have this free space: ABCDE ....J ..MNO ..RST ..WXY The free space is recorded in the form of five overlapping blocks - blocks 3, 4, 5, 6, and 7. 3 4 5 6 7 ABCDE ....E ..CDE ....E ..... ..... ....J ..... ....J ..... ..... ..... ..... ....O ..MNO ..... ..... ..... ....T ..RST ..... ..... ..... ....Y ..WXY (Note:  this illustrates what I mean about the potential for deduplication.  Block 5 (CDE) is entirely enclosed by block 3 (ABCDE) and so could be dropped.  Similarly, block 4 (EJ) is entirely enclosed by block 6 (EJOTY).) We continue this process until we've placed all of the blocks, or until we can't fit a block into an available space. The implementation uses some slightly tricky OpenSCAD stuff like list comprehensions (to find a free space to put a block, and to break up free blocks when we place a block) and recursion (to process all of the blocks to be placed), but with an idea of how it works maybe you can understand the implementation better. I don't claim that this is the best algorithm available for the problem.  In particular, I suspect that it could be relatively easily improved by looking for the smallest block that the new block will fit into, rather than the first one found.  But it was what I came up with, and it seems to sort of work...
Sun, Feb 13, 2022 5:45 PM
On Sat, Feb 12, 2022 at 11:40:45PM +0000, Jordan Brown wrote:
It uses a "first fit" scheme; a "best fit" scheme might yield better
results.
In computer-science, I remember that for memory allocation, first-fit
and best fit perform very similar. That's because "best fit" is more
likely to leave very small remaining areas that end up never being
useful again. This might apply here too.
On Sat, Feb 12, 2022 at 11:40:45PM +0000, Jordan Brown wrote: > It uses a "first fit" scheme; a "best fit" scheme might yield better > results. In computer-science, I remember that for memory allocation, first-fit and best fit perform very similar. That's because "best fit" is more likely to leave very small remaining areas that end up never being useful again. This might apply here too. Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
Sun, Feb 13, 2022 5:47 PM
On 2/13/2022 9:37 AM, Jordan Brown wrote:
 3      4      5      6      7
Note that although the free list tends to grow rather explosively, it
does occasionally shrink.  If we now place a [1,5] block, it will fit
into block 6 and totally consume blocks 4 and 6, leaving:
8      9      10
ABCD.  ..CD.  .....
.....  .....  ..MN.
.....  .....  ..RS.
.....  .....  ..WX.
On 2/13/2022 9:37 AM, Jordan Brown wrote: > > 3 4 5 6 7 > ABCDE ....E ..CDE ....E ..... > ..... ....J ..... ....J ..... > ..... ..... ..... ....O ..MNO > ..... ..... ..... ....T ..RST > ..... ..... ..... ....Y ..WXY > Note that although the free list tends to grow rather explosively, it does occasionally shrink.  If we now place a [1,5] block, it will fit into block 6 and totally consume blocks 4 and 6, leaving: 8 9 10 ABCD. ..CD. ..... ..... ..... ..... ..... ..... ..MN. ..... ..... ..RS. ..... ..... ..WX.
Sun, Feb 13, 2022 6:07 PM
Would it help if you sorted by size so that you placed the largest
objects first?
<snip>
Would it help if you sorted by size so that you placed the largest objects first? On 2/13/2022 12:37 PM, Jordan Brown wrote: > It was an interesting puzzle. > > But conceptually it's really not that complex. > > <snip> > > We continue this process until we've placed all of the blocks, or > until we can't fit a block into an available space. > > The implementation uses some slightly tricky OpenSCAD stuff like list > comprehensions (to find a free space to put a block, and to break up > free blocks when we place a block) and recursion (to process all of > the blocks to be placed), but with an idea of how it works maybe you > can understand the implementation better. > > I don't claim that this is the best algorithm available for the > problem.  In particular, I suspect that it could be relatively easily > improved by looking for the smallest block that the new block will fit > into, rather than the first one found.  But it was what I came up > with, and it seems to sort of work... >
Sun, Feb 13, 2022 6:16 PM
objects first?
Don't know, maybe.  Sounds likely.
On 2/13/2022 10:07 AM, jon wrote: > > Would it help if you sorted by size so that you placed the largest > objects first? > Don't know, maybe.  Sounds likely.
