Hi everyone,
I just want to show my parametric fan duct design, which I have been working
on for a little while. It is made for my 3d printer design, but it is highly
parametric so could easily be adapted for use elsewhere.
My goal was to achieve a data-driven design, where a few data points define
the air flow path.
I've used splines in combination with sweep/skin to interpolate both the
flow path and the shape of the fan duct tubes.
Thanks to Parkinbot for his great nSpline library!
I've also used a few other interesting functions, such as a "headered" array
approach w/helper functions that allow you to index into the array without
hardcoding columns.
https://github.com/oysteinkrog/kmax1/blob/master/fanduct.scad
The data that generates the duct blades for these images is as simple as
this:
// data for duct geometry
// ss parameter is initial size of duct (e.g. for fan throat/output)
// returned data has a header row
// warning, don't set r to 0 or rendering breaks!
function gen_data(ss) = [
[ "Tx","Ty","Tz", "Sx", "Sy", "Rx", "Ry", "r"],
[ ss.x/4, -27, 55, ss.x/2, ss.y, 13, 0, .01],
[ 2.5+ss.x/4, -25, 49, 5+ss.x/2, 1+ss.y, 13, 0, .1 ],
[ 15, -18, 40, 11, 20, 13, 0, .4 ],
[ 17, -8, 20, 11, 17, 11, -10, .5 ],
[ 14, -3, 10, 8, 15, 8, -25, .7 ],
[ 11, 0, 4, 6, 13, 0, -45, .8 ],
http://forum.openscad.org/file/t1826/fanduct1.png
http://forum.openscad.org/file/t1826/fanduct2.png
