missing parts on review (f5), but correct on render (f6)
KB
kornelis bijker
Wed, Nov 30, 2022 12:43 PM
Hi there,
I have constructed a polygon, which I extrude and then a build an object
from it by rotation. I then difference a cylinder to construct a pneumatic
cylinder body.
Upon f5, it leaves out weird surfaces all over the place, but on f6 it is a
solid.
I tried convexity, but it seems to do nothing, or maybe I used it in the
wrong place(s).
Anybody, can this be resolved since it is a pain in the neck when you are
constructing visually to see if things will fit, but you have to render
every time? Can take very long with large part counts.
my code:
$fn=64;
polygon_points
=[[-38,-35],[-35,-38],[-21,-38],[-20,-37],[-9,-37],[-9,-35],[-10,-35],[-10,-34],[-1,-34],[-1,-37],[1,-37],[1,-34],[10,-34],[10,-35],[9,-35],[9,-37],[20,-37],[21,-38],[35,-38],[38,-35],[38,-22.5],[-38,-22.5],[-38,-35]];
module
upright_side(){linear_extrude(56)polygon(polygon_points,convexity=20);
difference(){union(){
upright_side();
rotate([0,0,180])upright_side();
rotate([0,0,90])upright_side();
rotate([0,0,270])upright_side();
translate([0,0,-0.5])cylinder(h=57,d=65);
I would like some of the longer standing members to have a look, and
explain to me how to improve on this. I also noticed this with certain
imported stl files. Convexity can sort most of them but sometimes after a
difference the whole import stl disappears, also annoying and I have some
feeling it has to do with the same issue.
Kind regards and thanks,
Kees "3dcase" Bijker
Hi there, I have constructed a polygon, which I extrude and then a build an object from it by rotation. I then difference a cylinder to construct a pneumatic cylinder body. Upon f5, it leaves out weird surfaces all over the place, but on f6 it is a solid. I tried convexity, but it seems to do nothing, or maybe I used it in the wrong place(s). Anybody, can this be resolved since it is a pain in the neck when you are constructing visually to see if things will fit, but you have to render every time? Can take very long with large part counts. my code: $fn=64; polygon_points =[[-38,-35],[-35,-38],[-21,-38],[-20,-37],[-9,-37],[-9,-35],[-10,-35],[-10,-34],[-1,-34],[-1,-37],[1,-37],[1,-34],[10,-34],[10,-35],[9,-35],[9,-37],[20,-37],[21,-38],[35,-38],[38,-35],[38,-22.5],[-38,-22.5],[-38,-35]]; module upright_side(){linear_extrude(56)polygon(polygon_points,convexity=20); } difference(){union(){ upright_side(); rotate([0,0,180])upright_side(); rotate([0,0,90])upright_side(); rotate([0,0,270])upright_side(); } translate([0,0,-0.5])cylinder(h=57,d=65); } I would like some of the longer standing members to have a look, and explain to me how to improve on this. I also noticed this with certain imported stl files. Convexity can sort most of them but sometimes after a difference the whole import stl disappears, also annoying and I have some feeling it has to do with the same issue. Kind regards and thanks, Kees "3dcase" Bijker
Wed, Nov 30, 2022 2:22 PM
Add the convexity parameter to linear_extrude().
On Wed, 30 Nov 2022 at 12:44, kornelis bijker kornelis030465@gmail.com
Hi there,
cylinder body.
a solid.
wrong place(s).
my code:
$fn=64;
polygon_points
module
upright_side();
Add the convexity parameter to linear_extrude(). On Wed, 30 Nov 2022 at 12:44, kornelis bijker <kornelis030465@gmail.com> wrote: > Hi there, > I have constructed a polygon, which I extrude and then a build an object > from it by rotation. I then difference a cylinder to construct a pneumatic > cylinder body. > Upon f5, it leaves out weird surfaces all over the place, but on f6 it is > a solid. > I tried convexity, but it seems to do nothing, or maybe I used it in the > wrong place(s). > > Anybody, can this be resolved since it is a pain in the neck when you are > constructing visually to see if things will fit, but you have to render > every time? Can take very long with large part counts. > my code: > $fn=64; > polygon_points > =[[-38,-35],[-35,-38],[-21,-38],[-20,-37],[-9,-37],[-9,-35],[-10,-35],[-10,-34],[-1,-34],[-1,-37],[1,-37],[1,-34],[10,-34],[10,-35],[9,-35],[9,-37],[20,-37],[21,-38],[35,-38],[38,-35],[38,-22.5],[-38,-22.5],[-38,-35]]; > module > upright_side(){linear_extrude(56)polygon(polygon_points,convexity=20); > } > difference(){union(){ > upright_side(); > rotate([0,0,180])upright_side(); > rotate([0,0,90])upright_side(); > rotate([0,0,270])upright_side(); > } > translate([0,0,-0.5])cylinder(h=57,d=65); > } > > I would like some of the longer standing members to have a look, and > explain to me how to improve on this. I also noticed this with certain > imported stl files. Convexity can sort most of them but sometimes after a > difference the whole import stl disappears, also annoying and I have some > feeling it has to do with the same issue. > > Kind regards and thanks, > Kees "3dcase" Bijker > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Thu, Dec 1, 2022 2:45 AM
Mr. nop head's answer is the most appropriate in your case.
Also the way you are calculating the points seems to be quite complicated.
In such cases I found moving in a relative reference would be much easier
than the absolute reference e.g. to create a square of 5x5
absolute reference : [[0,0],[5,0],[5,5],[0,5]]
but if you write a function to calculate cumulative sum of points
you can write in relative reference:
some_function([[0,0],[5,0],[0,5],[-5,0]])
On Wed, 30 Nov 2022 at 18:14, kornelis bijker kornelis030465@gmail.com
Hi there,
cylinder body.
a solid.
wrong place(s).
my code:
$fn=64;
polygon_points
module
upright_side();
Mr. nop head's answer is the most appropriate in your case. Also the way you are calculating the points seems to be quite complicated. In such cases I found moving in a relative reference would be much easier than the absolute reference e.g. to create a square of 5x5 absolute reference : [[0,0],[5,0],[5,5],[0,5]] but if you write a function to calculate cumulative sum of points you can write in relative reference: some_function([[0,0],[5,0],[0,5],[-5,0]]) On Wed, 30 Nov 2022 at 18:14, kornelis bijker <kornelis030465@gmail.com> wrote: > Hi there, > I have constructed a polygon, which I extrude and then a build an object > from it by rotation. I then difference a cylinder to construct a pneumatic > cylinder body. > Upon f5, it leaves out weird surfaces all over the place, but on f6 it is > a solid. > I tried convexity, but it seems to do nothing, or maybe I used it in the > wrong place(s). > > Anybody, can this be resolved since it is a pain in the neck when you are > constructing visually to see if things will fit, but you have to render > every time? Can take very long with large part counts. > my code: > $fn=64; > polygon_points > =[[-38,-35],[-35,-38],[-21,-38],[-20,-37],[-9,-37],[-9,-35],[-10,-35],[-10,-34],[-1,-34],[-1,-37],[1,-37],[1,-34],[10,-34],[10,-35],[9,-35],[9,-37],[20,-37],[21,-38],[35,-38],[38,-35],[38,-22.5],[-38,-22.5],[-38,-35]]; > module > upright_side(){linear_extrude(56)polygon(polygon_points,convexity=20); > } > difference(){union(){ > upright_side(); > rotate([0,0,180])upright_side(); > rotate([0,0,90])upright_side(); > rotate([0,0,270])upright_side(); > } > translate([0,0,-0.5])cylinder(h=57,d=65); > } > > I would like some of the longer standing members to have a look, and > explain to me how to improve on this. I also noticed this with certain > imported stl files. Convexity can sort most of them but sometimes after a > difference the whole import stl disappears, also annoying and I have some > feeling it has to do with the same issue. > > Kind regards and thanks, > Kees "3dcase" Bijker > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
