Running openscad with Mesa (OpenGL) on azure windws Server 2012
loskiorama
Fri, Feb 20, 2015 6:14 PM
I've been trying to run openscad export png function on an azure windows
Server Virtual machine. The problem is that azure virtual machines have very
basic openGL support so I tried using Mesa as explained on the last lines
here
http://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows
After running $ pacman -S mingw-w64-x86_64-mesa on MSYS2 I tried both
copying opengl32.dll to System32 and and copying it to the same folder as
openscad.exe but keep getting the same as error as before when running png
export:
Framebuffer Object extension not found by GLEW.
Can't create OpenGL OffscreenView. Code: -1.
How could I run openscad on top of Mesa?
View this message in context: http://forum.openscad.org/Running-openscad-with-Mesa-OpenGL-on-azure-windws-Server-2012-tp11678.html
I've been trying to run openscad export png function on an azure windows Server Virtual machine. The problem is that azure virtual machines have very basic openGL support so I tried using Mesa as explained on the last lines here <http://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows> After running $ pacman -S mingw-w64-x86_64-mesa on MSYS2 I tried both copying opengl32.dll to System32 and and copying it to the same folder as openscad.exe but keep getting the same as error as before when running png export: Framebuffer Object extension not found by GLEW. Can't create OpenGL OffscreenView. Code: -1. How could I run openscad on top of Mesa? -- View this message in context: http://forum.openscad.org/Running-openscad-with-Mesa-OpenGL-on-azure-windws-Server-2012-tp11678.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Fri, Feb 20, 2015 7:06 PM
I would strongly recommend running on a Linux VM instead, as the chance of getting community help would be a lot higher.
However, if you do figure this out, it would be very appreciated if you could update the documentation, or post an email to the list with your experiences.
..and there’s always the option of going to the source: Ask Azure customer support for OpenGL 2 support.
Cheers,
On Feb 20, 2015, at 13:14 PM, loskiorama <alejandro@sur3d.com> wrote: > > How could I run openscad on top of Mesa? > I would strongly recommend running on a Linux VM instead, as the chance of getting community help would be a lot higher. However, if you do figure this out, it would be very appreciated if you could update the documentation, or post an email to the list with your experiences. ..and there’s always the option of going to the source: Ask Azure customer support for OpenGL 2 support. Cheers, -Marius
Sat, Feb 21, 2015 3:21 PM
Can you open the GUI at all? If yes, can you please post the
text from the Help->Library Info window?
This would include the OpenGL driver the GUI application found.
Are you running the 64bit OpenSCAD binary?
On 02/20/2015 07:14 PM, loskiorama wrote: > How could I run openscad on top of Mesa? > Can you open the GUI at all? If yes, can you please post the text from the Help->Library Info window? This would include the OpenGL driver the GUI application found. Are you running the 64bit OpenSCAD binary? ciao, Torsten.
