compiling
D
David
Fri, Oct 9, 2020 10:55 AM
Is it possible to compile and run OpenSCAD on an RPi and/or a Jetson
Nano/Xavier?
Thanks,
David
Is it possible to compile and run OpenSCAD on an RPi and/or a Jetson Nano/Xavier? Thanks, David
Fri, Oct 9, 2020 11:04 AM
Yes, if Qt is available with Desktop OpenGL support.
That's by default the case for most arm64 system, e.g. latest
(still beta?) version of Raspberry Pi OS 64-bit.
Otherwise it's still possible but requires a custom Qt build
which is shown to work on an old 32bit Chromebook via Software
Rendering.
See also ARM64 AppImage on the download page
https://www.openscad.org/downloads.html#snapshots
On 09.10.20 12:55, David wrote: > Is it possible to compile and run OpenSCAD on an RPi and/or > a Jetson Nano/Xavier? Yes, if Qt is available with Desktop OpenGL support. That's by default the case for most arm64 system, e.g. latest (still beta?) version of Raspberry Pi OS 64-bit. Otherwise it's still possible but requires a custom Qt build which is shown to work on an old 32bit Chromebook via Software Rendering. See also ARM64 AppImage on the download page https://www.openscad.org/downloads.html#snapshots ciao, Torsten.
CA
Fri, Oct 9, 2020 8:51 PM
Rendering.
If you have an OpenSCAD RPI executable for Raspberry PI4 you could try
this example for n=2 to n=16
module manyballs(n)
$fn=25;
delta = 45;
for(i=[0:1:n-1]) {
x = idelta;
for(j=[0:1:n-1]) {
y = j
delta;
for(k=[0:1:n-1]) {
z = k*delta;
translate([x,y,z])sphere(25);
manyballs(n=7);
Just for the fun of it I built https://github.com/arnholm/xcsg to 32bit
raspbian for RPI4 and ran the equivalent "manyballs" samples with xcsg
for n=2 to n=16.
It worked for n up to 9 and failed for higher values, probably because
of 32bit memory addressing limitations (not sure).
timings
xcsg, manyballs(n=9), RPI4 32bit raspbian 1m 47.75s
xcsg, manyballs(n=9), Ubuntu 18.04 64bit  0m 42.659s
So the Ubuntu/64bit workstation runs only about 2.5 times faster than my
RPI4/Raspbian/32bit for this kind of problem. Actually an interesting
result.
Comparing OpenSCAD 2020.10.05.nightly, and xcsg for n=7 case
openscad  manyballs(n=7), Ubuntu 18.04 64bit 12m 59.87s
xcsg,    manyballs(n=7), Ubuntu 18.04 64bit  0m 12.50s
xcsg,    manyballs(n=7), RPI4 32bit raspbian 0m 48.72s
On 09.10.2020 13:04, Torsten Paul wrote: > On 09.10.20 12:55, David wrote: >> Is it possible to compile and run OpenSCAD on an RPi and/or >> a Jetson Nano/Xavier? > > Yes, if Qt is available with Desktop OpenGL support. > > That's by default the case for most arm64 system, e.g. latest > (still beta?) version of Raspberry Pi OS 64-bit. > > Otherwise it's still possible but requires a custom Qt build > which is shown to work on an old 32bit Chromebook via Software > Rendering. > > See also ARM64 AppImage on the download page > https://www.openscad.org/downloads.html#snapshots If you have an OpenSCAD RPI executable for Raspberry PI4 you could try this example for n=2 to n=16 module manyballs(n) { $fn=25; delta = 45; for(i=[0:1:n-1]) { x = i*delta; for(j=[0:1:n-1]) { y = j*delta; for(k=[0:1:n-1]) { z = k*delta; translate([x,y,z])sphere(25); } } } } manyballs(n=7); Just for the fun of it I built https://github.com/arnholm/xcsg to 32bit raspbian for RPI4 and ran the equivalent "manyballs" samples with xcsg for n=2 to n=16. It worked for n up to 9 and failed for higher values, probably because of 32bit memory addressing limitations (not sure). timings xcsg, manyballs(n=9), RPI4 32bit raspbian 1m 47.75s xcsg, manyballs(n=9), Ubuntu 18.04 64bit 0m 42.659s So the Ubuntu/64bit workstation runs only about 2.5 times faster than my RPI4/Raspbian/32bit for this kind of problem. Actually an interesting result. Comparing OpenSCAD 2020.10.05.nightly, and xcsg for n=7 case openscad manyballs(n=7), Ubuntu 18.04 64bit 12m 59.87s xcsg, manyballs(n=7), Ubuntu 18.04 64bit 0m 12.50s xcsg, manyballs(n=7), RPI4 32bit raspbian 0m 48.72s Carsten Arnholm
