TR
Thomas Richter
Fri, Jun 19, 2026 10:09 AM
I am not sure if this is possible at all, I didn't even know exactly how to name the question.
Let's say we have the following example(!) code:
cube([50, 5, 10]);
translate([20, -20, 0]) rotate([0, 0, 75]) cube([50, 5, 10]);
I know that the union() is not absolutely necessary here but read on...
Is there any possibility to identify the edges or the vertices created by the "intersection" of the two cubes and to store them into variables? I know that this is not an intersection in the OpenSCAD sense but I didn't know how to name it better.
Why would I want to do this? Sometimes I have quite complex models where the orientation of certain elements is - for the sake of my laziness - found by trial-and-error instead of analytically calculating it. Nonetheless, sometimes I need the exact coordinates of the edges / vertices / surfaces to place / orient further elements or to calculate distances and angles.
In short, I'd like to be able to query the engine for specific coordinates that are the result of union / difference / intersection operations.
cube([50, 5, 10]);
Fri, Jun 19, 2026 11:40 AM
Not possible in openscad, not sure about in bosl2/whatever. For the
general case, the problem is in defining what you want. I think you want
these points?
Selected points:
[20.1826, 0, 10], // (mesh 0, vertex 7 | OBJ index 8)
[21.5223, 5, 10], // (mesh 0, vertex 11 | OBJ index 12)
[26.6987, 5, 10], // (mesh 0, vertex 20 | OBJ index 21)
[25.359, 0, 10], // (mesh 0, vertex 14 | OBJ index 15)
[21.5223, 5, 0], // (mesh 0, vertex 9 | OBJ index 10)
[26.6987, 5, 0], // (mesh 0, vertex 16 | OBJ index 17)
[25.359, 0, 0], // (mesh 0, vertex 12 | OBJ index 13)
[20.1826, 0, 0], // (mesh 0, vertex 3 | OBJ index 4)
I would be interested to know if, when you get a definitive reply,if
those values are correct
Best wishes,
Ray
cube([50, 5, 10]);
these points?
Selected points:
Best wishes,
Ray
> union() {
> cube([50, 5, 10]);
Fri, Jun 19, 2026 11:49 AM
Here's the polyhedron for your shape, so you get the tris if you want.
polyhedron(points=[[0,0,0],[15.1704,-18.7059,0],[20,-20,0],[20.1826,0,0],[0,0,10],[15.1704,-18.7059,10],[20,-20,10],[20.1826,0,10],[0,5,0],[21.5223,5,0],[0,5,10],[21.5223,5,10],[25.359,0,0],[50,0,0],[25.359,0,10],[50,0,10],[26.6987,5,0],[28.1113,29.5904,0],[32.941,28.2963,0],[50,5,0],[26.6987,5,10],[28.1113,29.5904,10],[32.941,28.2963,10],[50,5,10]],
faces=[[0,8,3],[0,10,8],[8,12,3],[8,9,13],[0,3,7],[0,4,10],[0,7,4],[4,7,10],[10,7,14],[10,15,11],[8,10,9],[10,11,9],[8,13,12],[13,9,16],[16,19,13],[13,15,12],[13,19,15],[15,14,12],[14,15,10],[15,20,11],[15,19,23],[15,23,20],[19,16,20],[19,20,23],[2,1,3],[2,5,1],[2,12,6],[2,3,12],[1,7,3],[2,6,5],[1,5,7],[6,14,5],[6,12,14],[5,14,7],[21,9,11],[17,16,9],[18,20,16],[18,16,17],[17,9,21],[18,17,22],[22,11,20],[18,22,20],[22,17,21],[22,21,11]]);
-------- Forwarded Message --------
Subject: Re: [OpenSCAD] Storing information derived from the geometry
into variables
Date: Fri, 19 Jun 2026 12:40:02 +0100
To: Thomas Richter via Discuss discuss@lists.openscad.org
these points?
Selected points:
Best wishes,
Ray
cube([50, 5, 10]);
operations.
into variables
To: Thomas Richter via Discuss <discuss@lists.openscad.org>
these points?
Selected points:
Best wishes,
Ray
> union() {
> cube([50, 5, 10]);
> operations.
TR
Thomas Richter
Fri, Jun 19, 2026 11:54 AM
Dear Ray,
thank you. Please don't put any further effort into solving it for this particular code. I put an exclamation mark behind "example" in my text to make clear this is not the real problem I try to solve. Sorry for misleading you.
I am looking for a general way to achieve what I was asking for since I expect to face more problems of this kind in the future.
Best,
Thomas
Am 19.06.2026 um 13:49 schrieb Raymond West via Discuss discuss@lists.openscad.org:
polyhedron(points=[[0,0,0],[15.1704,-18.7059,0],[20,-20,0],[20.1826,0,0],[0,0,10],[15.1704,-18.7059,10],[20,-20,10],[20.1826,0,10],[0,5,0],[21.5223,5,0],[0,5,10],[21.5223,5,10],[25.359,0,0],[50,0,0],[25.359,0,10],[50,0,10],[26.6987,5,0],[28.1113,29.5904,0],[32.941,28.2963,0],[50,5,0],[26.6987,5,10],[28.1113,29.5904,10],[32.941,28.2963,10],[50,5,10]], faces=[[0,8,3],[0,10,8],[8,12,3],[8,9,13],[0,3,7],[0,4,10],[0,7,4],[4,7,10],[10,7,14],[10,15,11],[8,10,9],[10,11,9],[8,13,12],[13,9,16],[16,19,13],[13,15,12],[13,19,15],[15,14,12],[14,15,10],[15,20,11],[15,19,23],[15,23,20],[19,16,20],[19,20,23],[2,1,3],[2,5,1],[2,12,6],[2,3,12],[1,7,3],[2,6,5],[1,5,7],[6,14,5],[6,12,14],[5,14,7],[21,9,11],[17,16,9],[18,20,16],[18,16,17],[17,9,21],[18,17,22],[22,11,20],[18,22,20],[22,17,21],[22,21,11]]);
-------- Forwarded Message -------- Subject: Re: [OpenSCAD] Storing information derived from the geometry into variables Date: Fri, 19 Jun 2026 12:40:02 +0100 From: Raymond West raywest@raywest.com To: Thomas Richter via Discuss discuss@lists.openscad.org
Not possible in openscad, not sure about in bosl2/whatever. For the general case, the problem is in defining what you want. I think you want these points?
Selected points:
I would be interested to know if, when you get a definitive reply,if those values are correct
Best wishes,
Ray
cube([50, 5, 10]);
Dear Ray,
Best,
Thomas
> Am 19.06.2026 um 13:49 schrieb Raymond West via Discuss <discuss@lists.openscad.org>:
> -------- Forwarded Message -------- Subject: Re: [OpenSCAD] Storing information derived from the geometry into variables Date: Fri, 19 Jun 2026 12:40:02 +0100 From: Raymond West <raywest@raywest.com> To: Thomas Richter via Discuss <discuss@lists.openscad.org>
> Selected points:
> Best wishes,
> Ray
>> union() {
>> cube([50, 5, 10]);
GS
Guenther Sohler
Fri, Jun 19, 2026 12:22 PM
Dear Ray,
misleading you.
Best,
Thomas
these points?
Selected points:
Best wishes,
Ray
cube([50, 5, 10]);
angles.
operations.
You might look into
https://pythonscad.org/tutorial/python_specialities/
PythonSCAD is a superset of OpenSCAD and in python mode you can store
everything to variables.
cheers
On Fri, Jun 19, 2026 at 1:55 PM Thomas Richter via Discuss <
> Dear Ray,
> misleading you.
> Best,
> Thomas
> these points?
> > Selected points:
> > Best wishes,
> > Ray
> >> union() {
> >> cube([50, 5, 10]);
> angles.
> operations.
John David
Fri, Jun 19, 2026 1:36 PM
It has been awhile since I came across an example of someone doing this in
OpenSCAD or PythonSCAD, but others have does exactly the same thing. Yes,
it would be nice if we could label geometry features, such as your
geometric or part intersection/boundary (or whatever terms we choose to
label them).
Does anyone else remember the example (probably a year or three ago) where
someone needed to know the line where two shapes met? I seam to remember
that one of the shapes was complex like a NURB surface...
EBo --
On Fri, Jun 19, 2026 at 8:23 AM Guenther Sohler via Discuss <
Dear Ray,
misleading you.
Best,
Thomas
these points?
Selected points:
Best wishes,
Ray
cube([50, 5, 10]);
angles.
operations.
label them).
EBo --
> You might look into
> cheers
> discuss@lists.openscad.org> wrote:
>> Dear Ray,
>> misleading you.
>> Best,
>> Thomas
>> these points?
>> > Selected points:
>> > Best wishes,
>> > Ray
>> >> union() {
>> >> cube([50, 5, 10]);
>> angles.
>> operations.
LD
lee.deraud (at) roadrunner.com
Fri, Jun 19, 2026 2:33 PM
Watching with interest. My use case is similar (I think), except some or all
of the shapes in question are imported STLs from scans.
Example 1: precisely aligning/combining two scanned shapes. The scanner app
can do this, but it requires parts that overlap significantly. Not to
mention that the resulting lump is a bit unwieldy, and I still need to be
able to manipulate the two pieces separately.
Example 2: deriving the intersection edge between two scans, or a scan and a
OpenSCAD-generated object. Think car fender (scanned) and wheelwell flare
(generated): determining the cut-line where the two pieces would join
together.
I'm vaguely doubtful OpenSCAD/BOSL2 is the right tool for either job, but
it's generally easier to deal with than homegrown Python code using the
open3d library.
From: Thomas Richter via Discuss discuss@lists.openscad.org
Sent: Friday, June 19, 2026 3:10 AM
Cc: Thomas Richter tomselektropost@googlemail.com
Subject: [OpenSCAD] Storing information derived from the geometry into
variables
name the question.
cube([50, 5, 10]);
translate([20, -20, 0]) rotate([0, 0, 75]) cube([50, 5, 10]); }
to name it better.
together.
open3d library.
From: Thomas Richter via Discuss <discuss@lists.openscad.org>
To: OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org>
Cc: Thomas Richter <tomselektropost@googlemail.com>
variables
name the question.
cube([50, 5, 10]);
to name it better.
Fri, Jun 19, 2026 3:27 PM
The fundamental problem, is that if openscad could do what you want, you
would have to describe what you want to openscad. since it does not
except interactive input from a pointing device, other than in measuring
between points or edges. Then your specification becomes complicated for
a general purpose solution. A similar simple problem, say is being able
to select maybe five edges of a cube to be bevelled. (A cube would be
relatively easy to specify edges, but hopefully you get to what I'm
alluding.) Raw Openscad, does not allow much in the way of interactive
design, if any. Therefore, in principal, openscad, as it stands, is the
wrong tool for doing that sort of thing.
together.
open3d library.
variables
name the question.
cube([50, 5, 10]);
to name it better.
> together.
> open3d library.
> -----Original Message-----
> variables
> name the question.
> union() {
> cube([50, 5, 10]);
> to name it better.
Fri, Jun 19, 2026 3:42 PM
Slightly off topic...
I have used Cloud Compare to align two point clouds coming from my scanner
together.
open3d library.
variables
name the question.
cube([50, 5, 10]);
to name it better.
> together.
> open3d library.
> variables
> name the question.
> union() {
> cube([50, 5, 10]);
> to name it better.
LD
Fri, Jun 19, 2026 5:32 PM
Yeah, merging overlapping scans is a relatively simple brute-force
operation. Aligning things that touch but don't overlap, not so much.
(It doesn't help a bit that the point clouds out of the scanner app are not
aligned with the coordinate axes, even though it can "see" the surface the
scanned object was sitting on.)
Most of the apps I've looked at assume overlap, not adjacency, so two parts
that fit together end up smashed into a blob.
From: Jon Bondy via Discuss discuss@lists.openscad.org
Sent: Friday, June 19, 2026 8:42 AM
Cc: lee.deraud@roadrunner.com; Jon Bondy jon@jonbondy.com
Subject: [OpenSCAD] Re: Storing information derived from the geometry into
variables
or all of the shapes in question are imported STLs from scans.
scanner app can do this, but it requires parts that overlap
significantly. Not to mention that the resulting lump is a bit
unwieldy, and I still need to be able to manipulate the two pieces
and a OpenSCAD-generated object. Think car fender (scanned) and
wheelwell flare
together.
but it's generally easier to deal with than homegrown Python code
using the open3d library.
variables
cube([50, 5, 10]);
From: Jon Bondy via Discuss <discuss@lists.openscad.org>
Cc: lee.deraud@roadrunner.com; Jon Bondy <jon@jonbondy.com>
variables
separately.
> wheelwell flare
> together.
> variables
> union() {
> cube([50, 5, 10]);
operations.
