For accurate holes you want a single outline, or make sure the outer ones
(inner in holes) are done first. When you stack extrusions next to each
other the exact width depends on the viscosity of the plastic, which the
slicer doesn't know about.
On Wed, 14 Apr 2021 at 14:13, Terrypin via Discuss <
Cc:
Bcc:
Date: Wed, 14 Apr 2021 06:13:11 -0700 (MST)
Subject: [OpenSCAD] Re: Polyhole tester: unexpected result after printing
Thanks for those three helpful posts mondo. I guess we’re OT now but...I
swapped the original springs for the improved (stiffer?) ones and did spend
a lot of time on bed levelling. But clearly don’t yet have it 100% sorted!
P.S. How do I edit a post? Using ‘Edit this page’ plainly isn’t the way.
at Nabble.com.
From: Terrypin via Discuss discuss@lists.openscad.org
Cc: Terrypin T.pinnell@btinternet.com
Bcc:
Bed leveling is pretty essential, but the z-offset is what controls
adhesion in general. If you are leveling manually, use thinner paper or at
least set it up to grab the paper more strongly , if you are using ABL, set
the z-offset lower. I usually print a 25mm square patch, one layer thick,
and if it has a smooth surface with no gaps, it is probably about right.
Gaps or actual loose strings of filament is too high, and a rough surface
usually means too low
Cc:
Bcc:
at Nabble.com.
Bcc:
