I came across this model of a "melted" or "wilting" gear... (Think Dali's
clocks.)
https://www.thingiverse.com/thing:2872162
http://forum.openscad.org/file/t1632/a22b1cd568ea8d3a6547ed46a6a10119_preview_featured.jpg
Can anyone think of a good way to recreate this in OpenSCAD?
Let's assume you are completely modeling in OpenSCAD so could re-write the
code for the gear generation.
Objective is to curve a flat object around a "pipe" of a certain diameter.
Could you multiple the object (i.e. the mesh of all the points of the
object) by a transform matrix, which effects the radial transformation?
Kevin
clocks.)
http://forum.openscad.org/file/t1632/a22b1cd568ea8d3a6547ed46a6a10119_preview_featured.jpg>
Kevin Toppenberg says:
Could you multiple the object (i.e. the mesh of all the points of the object) by a transform matrix, which effects the radial transformation?
I don't think so. This requires a non-affine transformation, which can't be represented by a transformation matrix.
My 3D modelling language, Curv, supports non-affine transformations, which are represented by functions that map 3D points onto other 3D points, not matrices. I've implemented several 'bend' operators that do this kind of transformation.
In OpenSCAD, it's not so easy. I bet somebody on the list has a better answer, though.
Doug Moen.
Kevin
clocks.)
I've implemented bend functionality by taking slices of the original shape
and placing them in position, and unioning it together. It tends to be slow
though
transformation.
answer, though.
Doug Moen.
Kevin
clocks.)
OpenSCAD doesn't have native support for plastic transformations or for
userland geometry. I would recommend using something else.
If you're really determined, it's possible to write a geometry engine within
OPENScad, and then implement plastic transforms by subdividing triangles,
but it's a bunch of work and OPENScad isn't well-suited to a task like that.
This is "extruded" and "bent" in OpenSCAD, but I had to scrape the geometry
for the letters from postscript.
http://forum.openscad.org/file/t2140/cylindertext.stl
clocks.)
There is no way in OpenSCAD to take an exiting flat object and "melt" it
into something like your example. This is because you cannot access and
transform individual coordinates in an OpenSCAD object.
In AngelCAD you can do it for an imported object as shown here
https://gist.github.com/arnholm/af72c7d0790bb3d72e6bdf29c7aac1ed
There is one requirement in addition to being able to change coordinates
of existing objects, and that is that the discretization of the object
mesh is fine enough to allow the melting/morphing. The link above shows
the difference (use the wirefame options).
I suppose it's a somewhat advanced effort, but I don't think it would be
particularly hard to write a "bent_sweep" module that would take a polygon
expressed as a series of point coordinates and a second "destination"
polygon also as a series of points. You could project the first polygon
onto the second one and then build it up to the desired thickness (in the
normal direction), constructing the vertices and faces of the necessary
polyhedron.
be
polygon
polygon
polyhedron.
A polygon in OpenSCAD is a 2d object with only (x,y) coordinates, so the
"destination" cannot exist anywhere but in the (x,y) plane. I think you
would "be on your own" having to write such from scratch using lists of
3d coordinates. Possible perhaps, but somewhat inconvenient. However,
sweeping is not the same as "melting" (or morphing rather). In a sweep
you start with a 2d shape and create a 3d object by sweeping the (rigid)
2d shape along a path to get a 3d object. OpenSCAD linear_extrude is a
special case of this. A slightly different case is
https://gist.github.com/arnholm/931bba4633ca344a3ffe0698b945395f
The melting/morphing case is quite different, it begins with an existing
valid 3d model created using any method. Usually keeping the topology of
the model fixed, the shape of the 3d model is modified. If the model
is represented as a polyhedron mesh, either explicitly modeled as such
or the result of mesh based boolean operations, changing the shape
translates to transforming the polyhedron vertex coordinates, using
different transformations for different vertices (i.e. "non-affine
transformation" of the model).
Here's my quick and dirty code based on my library
https://github.com/JustinSDK/dotSCAD .
include <shape_starburst.scad>;
include <bend_extrude.scad>;
gear_r = 30;
thickness = 2;
angle = 75;
frags = 24;
module gear() {
rotate(1) difference() {
polygon(shape_starburst(gear_r, 25, 24));
circle(5);
for(i = [0:5]) {
rotate(60 * i) translate([15, 0, 0]) circle(5);
rotate([0, -angle / frags, 0])
translate([gear_r / frags / 2, -gear_r, gear_r * 180 / (angle *
3.14159)])
rotate([90, 0, 0])
bend_extrude([gear_r, gear_r * 2], thickness, angle, frags)
translate([0, gear_r, 0]) gear();
linear_extrude(thickness)
translate([-gear_r / 2, 0, 0])
gear();
bend_extrude is not documented currently, however, it's already in the
repository.
<http://forum.openscad.org/file/t1825/melting_gear.jpg>
square([gear_r, gear_r * 2], center = true);
gear_r = 30;
thickness = 2;
angle = 75;
frags = 24;
module gear() {
circle(5);
for(i = [0:5]) {
3.14159)])
rotate([90, 0, 0])
gear();
repository.
http://forum.openscad.org/file/t1825/melting_gear2.jpg
