mixing 2D and 3D
Sat, Jun 25, 2016 9:58 PM
I'm playing around with moldings.  I thought I was careful to keep all
of the 2D stuff together and all of the 3D stuff together, but I guess I
was wrong.
  1. if I do a hull() on 2D objects, don't I get a 2D object as a result?
  2. can a module() return a 2D object?
  3. sure would be nice if the error messages gave even a HINT about where
    the problem was.  I doubt that I am the first to whine about this.
Thanks
$fn = 100;
eps = 0.1;
module RoundedSquare(x, y) {
hull() {
translate([0,    1]) square(1);
translate([x-4, y-4]) circle(4);
translate([x-1,  1]) square(1);
translate([0,  y-1]) square(1);
module CrossSection1()
square([10, 20]);
translate([10, 3])
circle(2);
translate([10, 15])
circle(2);
CrossSection1();
translate([0, 30, 0])
CrossSection2();
module CrossSection2()
RoundedSquare(10, 20);
translate([10, 12])
circle(2);
translate([10, 5])
circle(2);
translate([80, 0, 0])
rotate([0, -90, 0])
linear_extrude(height = 50)
CrossSection1();
translate([80, 30, 0])
rotate([0, -90, 0])
CrossSection2();
translate([-50, 50 + 15, 0])
rotate([0, -90, 90])
CrossSection2();
translate([-50, 0, -eps])
rotate([0, -90, 0])
CrossSection2();
I'm playing around with moldings. I thought I was careful to keep all of the 2D stuff together and all of the 3D stuff together, but I guess I was wrong. 1) if I do a hull() on 2D objects, don't I get a 2D object as a result? 2) can a module() return a 2D object? 3) sure would be nice if the error messages gave even a HINT about where the problem was. I doubt that I am the first to whine about this. Thanks Jon --- $fn = 100; eps = 0.1; module RoundedSquare(x, y) { hull() { translate([0, 1]) square(1); translate([x-4, y-4]) circle(4); translate([x-1, 1]) square(1); translate([0, y-1]) square(1); } } module CrossSection1() difference() { union() { square([10, 20]); translate([10, 3]) circle(2); } translate([10, 15]) circle(2); } CrossSection1(); translate([0, 30, 0]) CrossSection2(); module CrossSection2() difference() { union() { RoundedSquare(10, 20); translate([10, 12]) circle(2); } translate([10, 5]) circle(2); } translate([80, 0, 0]) rotate([0, -90, 0]) linear_extrude(height = 50) CrossSection1(); translate([80, 30, 0]) rotate([0, -90, 0]) linear_extrude(height = 50) CrossSection2(); difference() { translate([-50, 50 + 15, 0]) rotate([0, -90, 90]) linear_extrude(height = 50) CrossSection2(); translate([-50, 0, -eps]) rotate([0, -90, 0]) linear_extrude(height = 50) CrossSection2(); }
Sat, Jun 25, 2016 10:17 PM
Your model has 2 2D objects and 3 3D objects at the top level. This is
clearly visible in F5 preview.
You can't export a mixture of 2D and 3D objects, we don't support any file
formats where this makes sense, and the F6 render fails for this reason.
If you want to export to STL, you'll need to disable the 2D objects before
doing F6 and Export. Likewise, if you want to export to DXF, you'll need to
disable the 3D objects before doing F6 and Export.
wrong.
Thanks
$fn = 100;
eps = 0.1;
hull() {
square([10, 20]);
translate([10, 3])
circle(2);
translate([10, 15])
circle(2);
CrossSection1();
CrossSection2();
translate([10, 12])
circle(2);
translate([10, 5])
circle(2);
rotate([0, -90, 0])
CrossSection1();
rotate([0, -90, 0])
CrossSection2();
CrossSection2();
rotate([0, -90, 0])
CrossSection2();
Your model has 2 2D objects and 3 3D objects at the top level. This is clearly visible in F5 preview. You can't export a mixture of 2D and 3D objects, we don't support any file formats where this makes sense, and the F6 render fails for this reason. If you want to export to STL, you'll need to disable the 2D objects before doing F6 and Export. Likewise, if you want to export to DXF, you'll need to disable the 3D objects before doing F6 and Export. On 25 June 2016 at 17:58, jon <jon@jonbondy.com> wrote: > I'm playing around with moldings. I thought I was careful to keep all of > the 2D stuff together and all of the 3D stuff together, but I guess I was > wrong. > > 1) if I do a hull() on 2D objects, don't I get a 2D object as a result? > > 2) can a module() return a 2D object? > > 3) sure would be nice if the error messages gave even a HINT about where > the problem was. I doubt that I am the first to whine about this. > > Thanks > > Jon > > --- > > $fn = 100; > eps = 0.1; > > module RoundedSquare(x, y) { > hull() { > translate([0, 1]) square(1); > translate([x-4, y-4]) circle(4); > translate([x-1, 1]) square(1); > translate([0, y-1]) square(1); > } > } > > module CrossSection1() > difference() { > union() { > square([10, 20]); > translate([10, 3]) > circle(2); > } > translate([10, 15]) > circle(2); > } > > CrossSection1(); > > translate([0, 30, 0]) > CrossSection2(); > > module CrossSection2() > difference() { > union() { > RoundedSquare(10, 20); > translate([10, 12]) > circle(2); > } > translate([10, 5]) > circle(2); > } > > translate([80, 0, 0]) > rotate([0, -90, 0]) > linear_extrude(height = 50) > CrossSection1(); > > translate([80, 30, 0]) > rotate([0, -90, 0]) > linear_extrude(height = 50) > CrossSection2(); > > difference() { > translate([-50, 50 + 15, 0]) > rotate([0, -90, 90]) > linear_extrude(height = 50) > CrossSection2(); > translate([-50, 0, -eps]) > rotate([0, -90, 0]) > linear_extrude(height = 50) > CrossSection2(); > } > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Sat, Jun 25, 2016 10:24 PM
Ah.  Not "mixed within a statement" or "mixed within a module" but
"mixed across the entire set of objects".
Thank you.  I "fixed" it by doing a tiny linear_extrude() of the 2D objects.
reason.
 result?
 this.
 Thanks
 $fn = 100;
 eps = 0.1;
     hull() {
             square([10, 20]);
             translate([10, 3])
                 circle(2);
         translate([10, 15])
             circle(2);
 CrossSection1();
     CrossSection2();
             translate([10, 12])
                 circle(2);
         translate([10, 5])
             circle(2);
     rotate([0, -90, 0])
             CrossSection1();
     rotate([0, -90, 0])
             CrossSection2();
                 CrossSection2();
         rotate([0, -90, 0])
                 CrossSection2();
Checked by AVG - www.avg.com http://www.avg.com
Version: 2016.0.7640 / Virus Database: 4604/12488 - Release Date: 06/25/16
Ah. Not "mixed within a statement" or "mixed within a module" but "mixed across the entire set of objects". Thank you. I "fixed" it by doing a tiny linear_extrude() of the 2D objects. Jon On 6/25/2016 6:17 PM, doug moen wrote: > Your model has 2 2D objects and 3 3D objects at the top level. This is > clearly visible in F5 preview. > > You can't export a mixture of 2D and 3D objects, we don't support any > file formats where this makes sense, and the F6 render fails for this > reason. > > If you want to export to STL, you'll need to disable the 2D objects > before doing F6 and Export. Likewise, if you want to export to DXF, > you'll need to disable the 3D objects before doing F6 and Export. > > On 25 June 2016 at 17:58, jon <jon@jonbondy.com > <mailto:jon@jonbondy.com>> wrote: > > I'm playing around with moldings. I thought I was careful to keep > all of the 2D stuff together and all of the 3D stuff together, but > I guess I was wrong. > > 1) if I do a hull() on 2D objects, don't I get a 2D object as a > result? > > 2) can a module() return a 2D object? > > 3) sure would be nice if the error messages gave even a HINT about > where the problem was. I doubt that I am the first to whine about > this. > > Thanks > > Jon > > --- > > $fn = 100; > eps = 0.1; > > module RoundedSquare(x, y) { > hull() { > translate([0, 1]) square(1); > translate([x-4, y-4]) circle(4); > translate([x-1, 1]) square(1); > translate([0, y-1]) square(1); > } > } > > module CrossSection1() > difference() { > union() { > square([10, 20]); > translate([10, 3]) > circle(2); > } > translate([10, 15]) > circle(2); > } > > CrossSection1(); > > translate([0, 30, 0]) > CrossSection2(); > > module CrossSection2() > difference() { > union() { > RoundedSquare(10, 20); > translate([10, 12]) > circle(2); > } > translate([10, 5]) > circle(2); > } > > translate([80, 0, 0]) > rotate([0, -90, 0]) > linear_extrude(height = 50) > CrossSection1(); > > translate([80, 30, 0]) > rotate([0, -90, 0]) > linear_extrude(height = 50) > CrossSection2(); > > difference() { > translate([-50, 50 + 15, 0]) > rotate([0, -90, 90]) > linear_extrude(height = 50) > CrossSection2(); > translate([-50, 0, -eps]) > rotate([0, -90, 0]) > linear_extrude(height = 50) > CrossSection2(); > } > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > Version: 2016.0.7640 / Virus Database: 4604/12488 - Release Date: 06/25/16 >
