Import stl files with Openscad on mac
G
Gianpaolo
Thu, Mar 29, 2018 10:44 AM
Hello,
how can I import STL files with a Mac?
import(“User:/my name/Desktop/miocubo.stl”);
WARNING: Can’t open import file ‘”User:/my name/Desktop/miocubo.stl”‘.
Con surface(“User:/may name/Desktop/miocubo.stl”);
WARNING: Can’t open DAT file
‘/Users/paolopuggioni/Desktop/mioimport/User:/my name/Desktop/miocubo.stl’.
WARNING: PolySet has degenerate polygons
Thank you
Import stl files with Openscad on mac Hello, how can I import STL files with a Mac? import(“User:/my name/Desktop/miocubo.stl”); WARNING: Can’t open import file ‘”User:/my name/Desktop/miocubo.stl”‘. Con surface(“User:/may name/Desktop/miocubo.stl”); WARNING: Can’t open DAT file ‘/Users/paolopuggioni/Desktop/mioimport/User:/my name/Desktop/miocubo.stl’. WARNING: PolySet has degenerate polygons Thank you -- Sent from: http://forum.openscad.org/
Thu, Mar 29, 2018 1:37 PM
I don't know why your file name starts with "User:". I don't think that
works on a Mac.
Try
import("/Users/paolopuggioni/Desktop/miocubo.stl”);
Hello,
Thank you
I don't know why your file name starts with "User:". I don't think that works on a Mac. Try import("/Users/paolopuggioni/Desktop/miocubo.stl”); On 29 March 2018 at 06:44, Gianpaolo <gpau@ticino.com> wrote: > Import stl files with Openscad on mac > Hello, > how can I import STL files with a Mac? > > import(“User:/my name/Desktop/miocubo.stl”); > WARNING: Can’t open import file ‘”User:/my name/Desktop/miocubo.stl”‘. > > Con surface(“User:/may name/Desktop/miocubo.stl”); > WARNING: Can’t open DAT file > ‘/Users/paolopuggioni/Desktop/mioimport/User:/my > name/Desktop/miocubo.stl’. > WARNING: PolySet has degenerate polygons > > Thank you > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
G
Gianpaolo
Thu, Mar 29, 2018 2:08 PM
I inserted the search into openscad, but it gave me error
import ( "/ Users / paolopuggioni / Desktop / miocubo.stl");
ERROR: Parser error in line 3: syntax error
ERROR: Compilation failed!
I inserted the search into openscad, but it gave me error import ( "/ Users / paolopuggioni / Desktop / miocubo.stl"); ERROR: Parser error in line 3: syntax error ERROR: Compilation failed! -- Sent from: http://forum.openscad.org/
Thu, Mar 29, 2018 2:25 PM
You are not showing the entire script, only a single line of the script.
This line by itself does not produce a parser error. The syntax error is on
line 3, so the script must have at least 3 lines.
You are not showing the entire script, only a single line of the script. This line by itself does not produce a parser error. The syntax error is on line 3, so the script must have at least 3 lines. On 29 March 2018 at 10:08, Gianpaolo <gpau@ticino.com> wrote: > I inserted the search into openscad, but it gave me error > > import ( "/ Users / paolopuggioni / Desktop / miocubo.stl"); > > ERROR: Parser error in line 3: syntax error > ERROR: Compilation failed! > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
G
Gianpaolo
Thu, Mar 29, 2018 2:50 PM
What should I write more to have three lines?
What should I write more to have three lines? -- Sent from: http://forum.openscad.org/
HJ
Hugo Jackson
Thu, Mar 29, 2018 3:13 PM
If you’re unsure about the syntax of how to load a specific STL file into OpenSCAD, drag and drop the STL file onto the OpenSCAD program.
OpenSCAD will create a new window whose sole content is the STL import statement. You can then copy and paste that line into your own program.
e.g.:
import("/Users/me/Downloads/epoxy_spatula.stl”);
Looking at some of the samples you’ve provided I would note that
  1. There should be no colon “:” after “User”
    should be:
    import(“User/myname/Desktop/miocubo.stl”);
2)It looks like you’re adding spaces in the path, where there should be none
import ( "/ Users / paolopuggioni / Desktop / miocubo.stl”);
should be:
import ( "/Users/paolopuggioni/Desktop/miocubo.stl");
If you’re unsure about the syntax of how to load a specific STL file into OpenSCAD, drag and drop the STL file onto the OpenSCAD program. OpenSCAD will create a new window whose sole content is the STL import statement. You can then copy and paste that line into your own program. e.g.: import("/Users/me/Downloads/epoxy_spatula.stl”); Looking at some of the samples you’ve provided I would note that 1) There should be no colon “:” after “User” import(“User:/my name/Desktop/miocubo.stl”); should be: import(“User/myname/Desktop/miocubo.stl”); 2)It looks like you’re adding spaces in the path, where there should be none import ( "/ Users / paolopuggioni / Desktop / miocubo.stl”); should be: import ( "/Users/paolopuggioni/Desktop/miocubo.stl"); > On Mar 29, 2018, at 7:50 AM, Gianpaolo <gpau@ticino.com> wrote: > > What should I write more to have three lines? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
G
Gianpaolo
Thu, Mar 29, 2018 3:39 PM
If it was really useful, I never thought it would be enough to transport the
file in openscad.
Thanks so much
If it was really useful, I never thought it would be enough to transport the file in openscad. Thanks so much -- Sent from: http://forum.openscad.org/
G
Gianpaolo
Thu, Mar 29, 2018 3:56 PM
Ok, the problem of importing files is solved, but it is not possible to see
the script of the file?
Or is it possible how is it done?
Ok, the problem of importing files is solved, but it is not possible to see the script of the file? Or is it possible how is it done? -- Sent from: http://forum.openscad.org/
Apres
Thu, Mar 29, 2018 4:16 PM
STL files are NOT scripts... they are static objects... so you can’t revise them directly
STL files are NOT scripts... they are static objects... so you can’t revise them directly > On Mar 29, 2018, at 8:56 AM, Gianpaolo <gpau@ticino.com> wrote: > > Ok, the problem of importing files is solved, but it is not possible to see > the script of the file? > Or is it possible how is it done? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
G
Gianpaolo
Thu, Mar 29, 2018 4:35 PM
Ok, thanks
Ok, thanks -- Sent from: http://forum.openscad.org/
