I downloaded into w10, unzipped, put the five scad files into a library
(possibly only two needed), and all work fine. looks useful, but the
link to the pdf is not valid.
On 22/10/2021 23:28, timhoffner@gmail.com wrote:
Thanks Larry,
I will try dl the individual .scad files again as neither of the
archives have any .scad files. I did do this but was getting errors
when trying to open any of them - in particular a line that is
something like <!DOCTYPE html>
Tim
Thanks - the archives I got from the web page did not seem to have any - is
that where you got the archive? David sent me a link to "master.zip" which
I think may have been somewhere else that I was not seeing. anyway, I have
it and it's working, thank you for your reply!
Tim
(possibly only two needed), and all work fine. looks useful, but the link
Thanks Larry,
I will try dl the individual .scad files again as neither of the archives
have any .scad files. I did do this but was getting errors when trying to
open any of them - in particular a line that is something like <!DOCTYPE
html>
Tim
https://mseminatore.github.io/mdsSpurGear then selected 'mdsSpurGear'
link at bottom of page then select 'code' then 'download zip' was what
I did.
On Fri, Oct 22, 2021 at 5:58 PM Ray West <raywest@raywest.com
library (possibly only two needed), and all work fine. looks
useful, but the link to the pdf is not valid.
<mailto:timhoffner@gmail.com> wrote:
Thanks Larry,
errors when trying to open any of them - in particular a line
that is something like <!DOCTYPE html>
Tim
To unsubscribe send an email todiscuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>
weird. that worked. previously I tried "download .zip" and "download
.tar" and got archive with some .pngs, .css but no .scad. Oh well. thanks
for confirming!
Tim
link at bottom of page then select 'code' then 'download zip' was what I
did.
is that where you got the archive? David sent me a link to "master.zip"
which I think may have been somewhere else that I was not seeing. anyway,
I have it and it's working, thank you for your reply!
Tim
Thanks Larry,
html>
Tim
