Re: openscad stopped working on Centos7
Sun, May 9, 2021 1:18 AM
$ openscad-nightly
/snap/openscad-nightly/2576/usr/bin/openscad-nightly: error while
loading shared libraries: libQt5Core.so.5: cannot open shared
object file: No such file or directory
I don't know what's going on, but that's not how snaps should
start. Those need to run inside the container which brings
everything including the matching Qt library.
Try starting via /snap/bin/openscad-nightly that should bring
up the application running inside the snap environment.
> $ openscad-nightly > /snap/openscad-nightly/2576/usr/bin/openscad-nightly: error while > loading shared libraries: libQt5Core.so.5: cannot open shared > object file: No such file or directory I don't know what's going on, but that's not how snaps should start. Those need to run inside the container which brings everything including the matching Qt library. Try starting via /snap/bin/openscad-nightly that should bring up the application running inside the snap environment. ciao, Torsten.
Ron Wheeler
Sun, May 9, 2021 1:53 AM
Thanks for the quick response
Is this what you are suggesting?
$ /snap/bin/openscad-nightly
loading shared libraries: libQt5Core.so.5: cannot open shared object
I did some other looking about
$ which openscad-nightly
/var/lib/snapd/snap/bin/openscad-nightly
$ls -lad /snap/bin/*
lrwxrwxrwx. 1 root root 13 May  8 19:34 /snap/bin/openscad-nightly ->
/usr/bin/snap
$ls -lad /usr/bin/snap
-rwxr-xr-x. 1 root root 14742768 Feb 17 10:09 /usr/bin/snap
$ ls -lad /var/snap/openscad-nightly/*
drwxr-xr-x. 2 root root 6 May  8 19:34 /var/snap/openscad-nightly/2576
drwxr-xr-x. 2 root root 6 May  8 19:34 /var/snap/openscad-nightly/common
lrwxrwxrwx. 1 root root 4 May  8 19:34
/var/snap/openscad-nightly/current -> 2576
[rwheeler@workstation1 snap]$ df -v
Filesystem                           1K-blocks      Used Available Use%
Mounted on
/dev/mapper/centos_workstation1-root  52403200  38538980  13864220 74% /
/dev/loop2                              101632    101632         0 100%
/var/lib/snapd/snap/core/10908
/dev/loop3                               63232     63232         0 100%
/var/lib/snapd/snap/core20/975
/dev/loop4                              101632    101632         0 100%
/var/lib/snapd/snap/core/10958
/dev/loop5                               63232     63232         0 100%
/var/lib/snapd/snap/core20/904
/dev/sda2                              1038336    294972    743364 29% /boot
/dev/sda1                               204580     11636    192944 6%
/boot/efi
/dev/mapper/centos_workstation1-home 524097172 111696352 412400820 22% /home
/dev/mapper/backup-rwheeler_backup   769006328 598363372 131556468 82%
/backup/rwheeler
/dev/mapper/backup-system_backup     192152460  23488788 158879764 13%
/backup/system
/dev/loop0                              123904    123904         0 100%
/var/lib/snapd/snap/openscad-nightly/2576
$ du --max-depth=2 /var/lib/snapd/snap/openscad-nightly/
21    /var/lib/snapd/snap/openscad-nightly/2576/bin
162    /var/lib/snapd/snap/openscad-nightly/2576/etc
133    /var/lib/snapd/snap/openscad-nightly/2576/lib
46    /var/lib/snapd/snap/openscad-nightly/2576/meta
52    /var/lib/snapd/snap/openscad-nightly/2576/snap
592524    /var/lib/snapd/snap/openscad-nightly/2576/usr
592937    /var/lib/snapd/snap/openscad-nightly/2576
If there anything else that I can look at?
On 2021-05-08 9:18 p.m., Torsten Paul wrote:
$ openscad-nightly
Ron Wheeler
Artifact Software
438-345-3369
Thanks for the quick response Is this what you are suggesting? $ /snap/bin/openscad-nightly /snap/openscad-nightly/2576/usr/bin/openscad-nightly: error while loading shared libraries: libQt5Core.so.5: cannot open shared object file: No such file or directory I did some other looking about $ which openscad-nightly /var/lib/snapd/snap/bin/openscad-nightly $ls -lad /snap/bin/* lrwxrwxrwx. 1 root root 13 May  8 19:34 /snap/bin/openscad-nightly -> /usr/bin/snap $ls -lad /usr/bin/snap -rwxr-xr-x. 1 root root 14742768 Feb 17 10:09 /usr/bin/snap $ ls -lad /var/snap/openscad-nightly/* drwxr-xr-x. 2 root root 6 May  8 19:34 /var/snap/openscad-nightly/2576 drwxr-xr-x. 2 root root 6 May  8 19:34 /var/snap/openscad-nightly/common lrwxrwxrwx. 1 root root 4 May  8 19:34 /var/snap/openscad-nightly/current -> 2576 [rwheeler@workstation1 snap]$ df -v Filesystem                           1K-blocks      Used Available Use% Mounted on /dev/mapper/centos_workstation1-root  52403200  38538980  13864220 74% / /dev/loop2                              101632    101632         0 100% /var/lib/snapd/snap/core/10908 /dev/loop3                               63232     63232         0 100% /var/lib/snapd/snap/core20/975 /dev/loop4                              101632    101632         0 100% /var/lib/snapd/snap/core/10958 /dev/loop5                               63232     63232         0 100% /var/lib/snapd/snap/core20/904 /dev/sda2                              1038336    294972    743364 29% /boot /dev/sda1                               204580     11636    192944 6% /boot/efi /dev/mapper/centos_workstation1-home 524097172 111696352 412400820 22% /home /dev/mapper/backup-rwheeler_backup   769006328 598363372 131556468 82% /backup/rwheeler /dev/mapper/backup-system_backup     192152460  23488788 158879764 13% /backup/system /dev/loop0                              123904    123904         0 100% /var/lib/snapd/snap/openscad-nightly/2576 $ du --max-depth=2 /var/lib/snapd/snap/openscad-nightly/ 21    /var/lib/snapd/snap/openscad-nightly/2576/bin 162    /var/lib/snapd/snap/openscad-nightly/2576/etc 133    /var/lib/snapd/snap/openscad-nightly/2576/lib 46    /var/lib/snapd/snap/openscad-nightly/2576/meta 52    /var/lib/snapd/snap/openscad-nightly/2576/snap 592524    /var/lib/snapd/snap/openscad-nightly/2576/usr 592937    /var/lib/snapd/snap/openscad-nightly/2576 592937    /var/lib/snapd/snap/openscad-nightly/ If there anything else that I can look at? On 2021-05-08 9:18 p.m., Torsten Paul wrote: >> $ openscad-nightly >> /snap/openscad-nightly/2576/usr/bin/openscad-nightly: error while >> loading shared libraries: libQt5Core.so.5: cannot open shared >> object file: No such file or directory > I don't know what's going on, but that's not how snaps should > start. Those need to run inside the container which brings > everything including the matching Qt library. > > Try starting via /snap/bin/openscad-nightly that should bring > up the application running inside the snap environment. > > ciao, > Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- Ron Wheeler Artifact Software 438-345-3369 rwheeler@artifact-software.com
Ron Wheeler
Sun, May 9, 2021 2:00 AM
Where should the Qt5 library be located?
$ du --max-depth=15 /var/lib/snapd/snap/openscad-nightly/
1    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11/Xreset.d
1    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11/Xresources
9    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11/Xsession.d
0    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11/xkb
33    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11
102 /var/lib/snapd/snap/openscad-nightly/2576/etc/fonts/conf.avail
1    /var/lib/snapd/snap/openscad-nightly/2576/etc/fonts/conf.d
106    /var/lib/snapd/snap/openscad-nightly/2576/etc/fonts
0 /var/lib/snapd/snap/openscad-nightly/2576/etc/glvnd/egl_vendor.d
3    /var/lib/snapd/snap/openscad-nightly/2576/etc/init.d
0 /var/lib/snapd/snap/openscad-nightly/2576/etc/pulse/client.conf.d
2    /var/lib/snapd/snap/openscad-nightly/2576/etc/pulse
0    /var/lib/snapd/snap/openscad-nightly/2576/etc/sensors.d
0 /var/lib/snapd/snap/openscad-nightly/2576/etc/vulkan/explicit_layer.d
0    /var/lib/snapd/snap/openscad-nightly/2576/etc/vulkan/icd.d
0 /var/lib/snapd/snap/openscad-nightly/2576/etc/vulkan/implicit_layer.d
1    /var/lib/snapd/snap/openscad-nightly/2576/etc/xdg/autostart
1    /var/lib/snapd/snap/openscad-nightly/2576/etc/xdg/qtchooser
3    /var/lib/snapd/snap/openscad-nightly/2576/etc/xdg
77    /var/lib/snapd/snap/openscad-nightly/2576/lib/udev/rules.d
133    /var/lib/snapd/snap/openscad-nightly/2576/lib/udev
44    /var/lib/snapd/snap/openscad-nightly/2576/meta/gui
1    /var/lib/snapd/snap/openscad-nightly/2576/snap/command-chain
10486    /var/lib/snapd/snap/openscad-nightly/2576/usr/bin
738
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Algebraic_kernel_d
24
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Algebraic_kernel_for_circles
57
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Algebraic_kernel_for_spheres
24
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Apollonius_graph_2/uncertain
257
88
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Approximate_min_ellipsoid_d
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arithmetic_kernel
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_geometry_traits/IO
599
564
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_point_location
153 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_rat_arc
76
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_spherical_gaussian_map_3
194
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_topology_traits
538 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arrangement_2
104
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Barycentric_coordinates_2
248
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Boolean_set_operations_2
34
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Box_intersection_d
155 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/CORE/poly
463 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/CORE
337 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Cartesian
188
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Circular_kernel_2
205
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Circular_kernel_3
33 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Circulator
42
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/ETHZ/internal/random-forest
48
60
57
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/Feature
11
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/OpenCV
38
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/TensorFlow
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/internal
353
33
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Cone_spanners_2
104
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Convex_decomposition_3
70 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Convex_hull_2
75
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Convex_hull_3/dual
75 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Convex_hull_3
185
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Curved_kernel_via_analysis_2/gfx
37
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Curved_kernel_via_analysis_2/test
567
54 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Envelope_2
246 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Envelope_3
19
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Filtered_bbox_circular_kernel_2
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Filtered_kernel
132 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/GMP
30
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Heat_method_3/internal
65 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Heat_method_3
354 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Homogeneous
756 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/IO
436 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/ImageIO
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Interpolation/internal
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Interpolation
28
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Intersections_2/internal
182
290
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Intersections_3/internal
365
306 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Kernel
352 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Kernel_d
106 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Mesh_2
63
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Mesh_3/experimental
1021 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Mesh_3
34 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Meshes
30 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Min_circle_2
44 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Min_ellipse_2
20 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Min_sphere_d
42
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Min_sphere_of_spheres_d
210
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Minkowski_sum_2
66
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Minkowski_sum_3
8
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Modular_arithmetic
333 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Nef_2
866 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Nef_3
372 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Nef_S2
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d/LA_eigen
42
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d/Types
62
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d/Vector
38
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d/Wrapper
369 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Number_types
52 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/OTR_2
32 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/OpenGR
53 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/OpenNL
32
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Optimal_bounding_box/internal
54
42 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Optimisation
222 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Partition_2
14
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Periodic_3_mesh_3/IO
129
34 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Point_set_3
14
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Point_set_processing_3/internal/Voronoi_covariance_3
50
50
77 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_2
337
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Corefinement
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Hole_filling/experimental
62
72
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Isotropic_remeshing
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Polygon_mesh_slicer
14
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Side_of_triangle_mesh
47
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Smoothing
104
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Snapping
699
1812
39
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polyline_simplification_2
265 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polynomial
415 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/QP_solver
173 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/RS
31 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Regularization
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Scale_space_reconstruction_3/internal
65
451
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Segment_Delaunay_graph_2
659
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Segment_Delaunay_graph_Linf_2
25
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Set_movable_separability_2/Single_mold_translational_casting
20
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Set_movable_separability_2/internal
45
162
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Efficient_RANSAC
45
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Region_growing/Region_growing_on_point_set
27
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Region_growing/Region_growing_on_polygon_mesh
11
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Region_growing/internal
94
35
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/deprecated
293
82 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Sqrt_extension
141
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Straight_skeleton_2
23
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Subdivision_method_3/internal
69
26
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh/IO
165 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh
24
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_approximation
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_parameterization/IO
34
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_parameterization/internal
341
16
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_shortest_path/internal
166
36
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_simplification/Policies/Edge_collapse/internal
85
85
49
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_simplification/internal
142
167
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_topology/internal
167
178
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesher
421
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_sweep_2
224
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Tetrahedral_remeshing/internal
235
120 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Three
10 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Tools
103
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Triangulation_2/internal
107
15 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Visibility_2
158
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Voronoi_diagram_2
19 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/auto_link
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/bimap
18
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/graph/METIS
71
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/graph/internal
889 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/graph
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/iterator
898 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost
81 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/constructions
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/export
39
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/AABB_tree
21 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/AFSR
30
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Mesh_3
195
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Static_filters
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Surface_mesh_deformation
108
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Surface_mesh_segmentation
24
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Surface_mesh_skeletonization
14 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/TDS_2
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Triangulation
57
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/auxiliary
15 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/boost
1300 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal
35
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/license/Polygon_mesh_processing
237 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/license
47 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/pointmatcher
94 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/predicates
36348 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL
20 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/Math
12 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/Mesh
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/MeshExport
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/MeshImport
25
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/MeshInformation
20 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/OPC
84 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/Platform
231 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common
324 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/COM
83 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Classes
18
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader/BeamLattice1702
23
/var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader/Slice1507
44 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader/v093
51 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader/v100
165 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader
9 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Writer/v100
30 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Writer
602    /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model
0    /var/lib/snapd/snap/openscad-nightly/2576/usr/include/X11
37193    /var/lib/snapd/snap/openscad-nightly/2576/usr/include
0    /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/X11
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_DJ/LC_MESSAGES
315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_DJ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_DJ.utf8/LC_MESSAGES
2868 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_DJ.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ER/LC_MESSAGES
351 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ER
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ER@saaho/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ER@saaho
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ET/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ET
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/af_ZA/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/af_ZA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/af_ZA.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/af_ZA.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/agr_PE/LC_MESSAGES
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/agr_PE
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ak_GH/LC_MESSAGES
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ak_GH
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/am_ET/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/am_ET
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/an_ES/LC_MESSAGES
316 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/an_ES
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/an_ES.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/an_ES.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/anp_IN/LC_MESSAGES
343 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/anp_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_AE/LC_MESSAGES
312 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_AE
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_AE.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_AE.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_BH/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_BH
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_BH.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_BH.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_DZ/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_DZ
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_DZ.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_DZ.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_EG/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_EG
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_EG.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_EG.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IN/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IN
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IQ/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IQ
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IQ.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IQ.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_JO/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_JO
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_JO.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_JO.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_KW/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_KW
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_KW.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_KW.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LB/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LB
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LB.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LB.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LY/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LY
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LY.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LY.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_MA/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_MA
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_MA.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_MA.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_OM/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_OM
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_OM.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_OM.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_QA/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_QA
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_QA.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_QA.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SA/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SA
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SA.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SA.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SD/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SD
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SD.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SD.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SS/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SS
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SY/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SY
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SY.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SY.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_TN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_TN
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_TN.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_TN.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_YE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_YE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_YE.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_YE.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/as_IN/LC_MESSAGES
343 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/as_IN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ast_ES/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ast_ES
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ast_ES.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ast_ES.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ayc_PE/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ayc_PE
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/az_AZ/LC_MESSAGES
2739 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/az_AZ
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/az_IR/LC_MESSAGES
2874 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/az_IR
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY/LC_MESSAGES
318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY@latin/LC_MESSAGES
298 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY@latin
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bem_ZM/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bem_ZM
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ber_DZ/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ber_DZ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ber_MA/LC_MESSAGES
2529 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ber_MA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bg_BG/LC_MESSAGES
31 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bg_BG
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bg_BG.utf8/LC_MESSAGES
2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bg_BG.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bhb_IN.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bhb_IN.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bho_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bho_IN
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bho_NP/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bho_NP
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bi_VU/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bi_VU
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bn_BD/LC_MESSAGES
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bn_BD
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bn_IN/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bn_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bo_CN/LC_MESSAGES
2596 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bo_CN
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bo_IN/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bo_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR/LC_MESSAGES
29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR.utf8/LC_MESSAGES
2535 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR@euro/LC_MESSAGES
30 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR@euro
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/brx_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/brx_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bs_BA/LC_MESSAGES
318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bs_BA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bs_BA.utf8/LC_MESSAGES
2535 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bs_BA.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/byn_ER/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/byn_ER
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_AD/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_AD
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_AD.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_AD.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES/LC_MESSAGES
29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES.utf8/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES@euro/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES@euro
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES@valencia/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES@valencia
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_FR/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_FR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_FR.utf8/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_FR.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_IT/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_IT
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_IT.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_IT.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ce_RU/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ce_RU
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/chr_US/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/chr_US
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ckb_IQ/LC_MESSAGES
24 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ckb_IQ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cmn_TW/LC_MESSAGES
5036 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cmn_TW
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/crh_UA/LC_MESSAGES
2739 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/crh_UA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cs_CZ/LC_MESSAGES
30 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cs_CZ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cs_CZ.utf8/LC_MESSAGES
2535 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cs_CZ.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/csb_PL/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/csb_PL
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cv_RU/LC_MESSAGES
2531 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cv_RU
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cy_GB/LC_MESSAGES
322 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cy_GB
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cy_GB.utf8/LC_MESSAGES
2537 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cy_GB.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/da_DK/LC_MESSAGES
313 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/da_DK
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/da_DK.utf8/LC_MESSAGES
2866 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/da_DK.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT/LC_MESSAGES
292 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT.utf8/LC_MESSAGES
340 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT@euro/LC_MESSAGES
314 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE@euro/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_CH/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_CH
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_CH.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_CH.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE@euro/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_IT/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_IT
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_IT.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_IT.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LI.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LI.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU@euro/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU@euro
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/doi_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/doi_IN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dsb_DE/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dsb_DE
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dv_MV/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dv_MV
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dz_BT/LC_MESSAGES
9 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dz_BT
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_CY/LC_MESSAGES
317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_CY
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_CY.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_CY.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR@euro/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR@euro
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AG/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AG
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AU/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AU
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AU.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AU.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_BW/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_BW
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_BW.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_BW.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_CA/LC_MESSAGES
28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_CA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_CA.utf8/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_CA.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK.iso885915/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK.iso885915
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB.iso885915/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB.iso885915
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_HK/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_HK
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_HK.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_HK.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE@euro/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IL/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IL
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IN/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IN
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NG/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NG
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NZ/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NZ
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NZ.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NZ.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_PH/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_PH
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_PH.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_PH.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SC.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SC.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SG/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SG
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SG.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SG.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US.iso885915/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US.iso885915
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZA/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZA
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZA.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZA.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZM/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZM
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZW/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZW
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZW.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZW.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eo/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eo
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eo_US.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eo_US.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_AR/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_AR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_AR.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_AR.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_BO/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_BO
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_BO.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_BO.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CL/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CL
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CL.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CL.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CO/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CO
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CO.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CO.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CR/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CR.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CR.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CU/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CU
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_DO/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_DO
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_DO.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_DO.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_EC/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_EC
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_EC.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_EC.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES@euro/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_GT/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_GT
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_GT.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_GT.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_HN/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_HN
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_HN.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_HN.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_MX/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_MX
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_MX.utf8/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_MX.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_NI/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_NI
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_NI.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_NI.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PA/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PA
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PA.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PA.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PE.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PE.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PR/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PR.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PR.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PY/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PY
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PY.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PY.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_SV/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_SV
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_SV.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_SV.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_US/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_US
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_US.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_US.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_UY/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_UY
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_UY.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_UY.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_VE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_VE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_VE.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_VE.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE/LC_MESSAGES
27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE.iso885915/LC_MESSAGES
29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE.iso885915
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES@euro/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR.utf8/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR@euro/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR@euro
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fa_IR/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fa_IR
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ff_SN/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ff_SN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI/LC_MESSAGES
27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI.utf8/LC_MESSAGES
2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI@euro/LC_MESSAGES
28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI@euro
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fil_PH/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fil_PH
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fo_FO/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fo_FO
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fo_FO.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fo_FO.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE@euro/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE@euro
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CA/LC_MESSAGES
27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CA.utf8/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CA.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CH/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CH
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CH.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CH.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR/LC_MESSAGES
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR.utf8/LC_MESSAGES
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR@euro/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU@euro/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU@euro
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fur_IT/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fur_IT
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fy_DE/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fy_DE
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fy_NL/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fy_NL
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE@euro/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE@euro
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gd_GB/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gd_GB
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gd_GB.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gd_GB.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ER/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ER
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ER@abegede/LC_MESSAGES
2528 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ER@abegede
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ET/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ET
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ET@abegede/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ET@abegede
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES@euro/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES@euro
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gu_IN/LC_MESSAGES
342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gu_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gv_GB/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gv_GB
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gv_GB.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gv_GB.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ha_NG/LC_MESSAGES
2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ha_NG
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hak_TW/LC_MESSAGES
299 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hak_TW
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/he_IL/LC_MESSAGES
314 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/he_IL
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/he_IL.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/he_IL.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hi_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hi_IN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hif_FJ/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hif_FJ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hne_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hne_IN
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hr_HR/LC_MESSAGES
292 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hr_HR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hr_HR.utf8/LC_MESSAGES
339 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hr_HR.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hsb_DE/LC_MESSAGES
315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hsb_DE
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hsb_DE.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hsb_DE.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ht_HT/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ht_HT
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hu_HU/LC_MESSAGES
328 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hu_HU
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hu_HU.utf8/LC_MESSAGES
2881 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hu_HU.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hy_AM/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hy_AM
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hy_AM.armscii8/LC_MESSAGES
315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hy_AM.armscii8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ia_FR/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ia_FR
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/id_ID/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/id_ID
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/id_ID.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/id_ID.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ig_NG/LC_MESSAGES
2537 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ig_NG
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ik_CA/LC_MESSAGES
2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ik_CA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/is_IS/LC_MESSAGES
27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/is_IS
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/is_IS.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/is_IS.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_CH/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_CH
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_CH.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_CH.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT@euro/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT@euro
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/iu_CA/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/iu_CA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ja_JP.eucjp/LC_MESSAGES
984 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ja_JP.eucjp
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ja_JP.utf8/LC_MESSAGES
1037 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ja_JP.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ka_GE/LC_MESSAGES
318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ka_GE
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ka_GE.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ka_GE.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kab_DZ/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kab_DZ
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ/LC_MESSAGES
317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ.rk1048/LC_MESSAGES
318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ.rk1048
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kl_GL/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kl_GL
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kl_GL.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kl_GL.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/km_KH/LC_MESSAGES
37 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/km_KH
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kn_IN/LC_MESSAGES
342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kn_IN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ko_KR.euckr/LC_MESSAGES
1139 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ko_KR.euckr
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ko_KR.utf8/LC_MESSAGES
1303 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ko_KR.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kok_IN/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kok_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ks_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ks_IN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ks_IN@devanagari/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ks_IN@devanagari
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ku_TR/LC_MESSAGES
199 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ku_TR
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ku_TR.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ku_TR.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kw_GB/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kw_GB
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kw_GB.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kw_GB.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ky_KG/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ky_KG
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lb_LU/LC_MESSAGES
339 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lb_LU
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lg_UG/LC_MESSAGES
317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lg_UG
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lg_UG.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lg_UG.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/li_BE/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/li_BE
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/li_NL/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/li_NL
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lij_IT/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lij_IT
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ln_CD/LC_MESSAGES
2535 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ln_CD
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lo_LA/LC_MESSAGES
43 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lo_LA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lt_LT/LC_MESSAGES
317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lt_LT
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lt_LT.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lt_LT.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lv_LV/LC_MESSAGES
29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lv_LV
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lv_LV.utf8/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lv_LV.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lzh_TW/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lzh_TW
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mag_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mag_IN
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mai_IN/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mai_IN
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mai_NP/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mai_NP
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mfe_MU/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mfe_MU
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mg_MG/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mg_MG
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mg_MG.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mg_MG.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mhr_RU/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mhr_RU
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mi_NZ/LC_MESSAGES
31 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mi_NZ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mi_NZ.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mi_NZ.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/miq_NI/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/miq_NI
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mjw_IN/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mjw_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mk_MK/LC_MESSAGES
315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mk_MK
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mk_MK.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mk_MK.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ml_IN/LC_MESSAGES
2871 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ml_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mn_MN/LC_MESSAGES
344 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mn_MN
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mni_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mni_IN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mnw_MM/LC_MESSAGES
304 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mnw_MM
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mr_IN/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mr_IN
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ms_MY/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ms_MY
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ms_MY.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ms_MY.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mt_MT/LC_MESSAGES
317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mt_MT
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mt_MT.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mt_MT.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/my_MM/LC_MESSAGES
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/my_MM
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nan_TW/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nan_TW
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nan_TW@latin/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nan_TW@latin
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nb_NO/LC_MESSAGES
28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nb_NO
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nb_NO.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nb_NO.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nds_DE/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nds_DE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nds_NL/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nds_NL
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ne_NP/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ne_NP
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nhn_MX/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nhn_MX
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/niu_NU/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/niu_NU
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/niu_NZ/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/niu_NZ
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_AW/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_AW
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE@euro/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL@euro/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nn_NO/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nn_NO
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nn_NO.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nn_NO.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nr_ZA/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nr_ZA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nso_ZA/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nso_ZA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/oc_FR/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/oc_FR
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/oc_FR.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/oc_FR.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_ET/LC_MESSAGES
2536 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_ET
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_KE/LC_MESSAGES
31 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_KE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_KE.utf8/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_KE.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/or_IN/LC_MESSAGES
363 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/or_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/os_RU/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/os_RU
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pa_IN/LC_MESSAGES
341 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pa_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pa_PK/LC_MESSAGES
339 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pa_PK
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pap_AW/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pap_AW
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pap_CW/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pap_CW
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pl_PL/LC_MESSAGES
29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pl_PL
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pl_PL.utf8/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pl_PL.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ps_AF/LC_MESSAGES
2830 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ps_AF
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_BR/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_BR
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_BR.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_BR.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT@euro/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT@euro
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/quz_PE/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/quz_PE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/raj_IN/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/raj_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ro_RO/LC_MESSAGES
315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ro_RO
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ro_RO.utf8/LC_MESSAGES
2866 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ro_RO.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.cp1251/LC_MESSAGES
30 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.cp1251
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.koi8r/LC_MESSAGES
318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.koi8r
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_UA/LC_MESSAGES
319 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_UA
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_UA.utf8/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_UA.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/rw_RW/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/rw_RW
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sa_IN/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sa_IN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sah_RU/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sah_RU
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sat_IN/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sat_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sc_IT/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sc_IT
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_IN
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_IN@devanagari/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_IN@devanagari
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_PK/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_PK
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/se_NO/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/se_NO
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sgs_LT/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sgs_LT
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/shn_MM/LC_MESSAGES
346 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/shn_MM
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/shs_CA/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/shs_CA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/si_LK/LC_MESSAGES
2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/si_LK
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sid_ET/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sid_ET
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sk_SK/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sk_SK
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sk_SK.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sk_SK.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sl_SI/LC_MESSAGES
29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sl_SI
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sl_SI.utf8/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sl_SI.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sm_WS/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sm_WS
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_DJ/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_DJ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_DJ.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_DJ.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_ET/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_ET
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_KE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_KE
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_KE.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_KE.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_SO/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_SO
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_SO.utf8/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_SO.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_AL/LC_MESSAGES
32 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_AL
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_AL.utf8/LC_MESSAGES
2537 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_AL.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_MK/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_MK
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_ME/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_ME
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_RS/LC_MESSAGES
341 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_RS
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_RS@latin/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_RS@latin
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ss_ZA/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ss_ZA
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/st_ZA/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/st_ZA
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/st_ZA.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/st_ZA.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI/LC_MESSAGES
26 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI.utf8/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI@euro/LC_MESSAGES
313 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI@euro
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE.iso885915/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE.iso885915
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sw_KE/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sw_KE
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sw_TZ/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sw_TZ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/szl_PL/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/szl_PL
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ta_IN/LC_MESSAGES
342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ta_IN
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ta_LK/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ta_LK
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tcy_IN.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tcy_IN.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/te_IN/LC_MESSAGES
342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/te_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tg_TJ/LC_MESSAGES
316 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tg_TJ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tg_TJ.utf8/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tg_TJ.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/th_TH/LC_MESSAGES
335 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/th_TH
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/th_TH.utf8/LC_MESSAGES
50 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/th_TH.utf8
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/the_NP/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/the_NP
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ti_ER/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ti_ER
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ti_ET/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ti_ET
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tig_ER/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tig_ER
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tk_TM/LC_MESSAGES
2868 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tk_TM
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tl_PH/LC_MESSAGES
27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tl_PH
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tl_PH.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tl_PH.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tn_ZA/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tn_ZA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/to_TO/LC_MESSAGES
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/to_TO
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tpi_PG/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tpi_PG
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_CY/LC_MESSAGES
28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_CY
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_CY.utf8/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_CY.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_TR/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_TR
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_TR.utf8/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_TR.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ts_ZA/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ts_ZA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tt_RU/LC_MESSAGES
2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tt_RU
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tt_RU@iqtelif/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tt_RU@iqtelif
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ug_CN/LC_MESSAGES
2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ug_CN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ug_CN@latin/LC_MESSAGES
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ug_CN@latin
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uk_UA/LC_MESSAGES
280 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uk_UA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uk_UA.utf8/LC_MESSAGES
2827 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uk_UA.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/unm_US/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/unm_US
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ur_IN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ur_IN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ur_PK/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ur_PK
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ/LC_MESSAGES
317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ.utf8/LC_MESSAGES
2870 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ@cyrillic/LC_MESSAGES
341 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ@cyrillic
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ve_ZA/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ve_ZA
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/vi_VN/LC_MESSAGES
2867 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/vi_VN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE/LC_MESSAGES
291 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE.utf8/LC_MESSAGES
339 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE.utf8
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE@euro/LC_MESSAGES
291 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE@euro
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wae_CH/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wae_CH
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wal_ET/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wal_ET
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wo_SN/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wo_SN
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/xh_ZA/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/xh_ZA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/xh_ZA.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/xh_ZA.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yi_US/LC_MESSAGES
319 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yi_US
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yi_US.utf8/LC_MESSAGES
2867 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yi_US.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yo_NG/LC_MESSAGES
2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yo_NG
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yue_HK/LC_MESSAGES
338 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yue_HK
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yuw_PG/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yuw_PG
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN/LC_MESSAGES
743 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.gb18030/LC_MESSAGES
2809 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.gb18030
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.gbk/LC_MESSAGES
1167 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.gbk
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.utf8/LC_MESSAGES
2741 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_HK/LC_MESSAGES
1092 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_HK
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_HK.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_HK.utf8
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG/LC_MESSAGES
426 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG.gbk/LC_MESSAGES
878 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG.gbk
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG.utf8/LC_MESSAGES
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW/LC_MESSAGES
924 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW.euctw/LC_MESSAGES
1197 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW.euctw
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW.utf8/LC_MESSAGES
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW.utf8
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zu_ZA/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zu_ZA
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zu_ZA.utf8/LC_MESSAGES
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zu_ZA.utf8
215940    /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale
16 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/avahi
30
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/Help
28
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/config/support
18
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/config/testfiles
47
35
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/demo/icons
29
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/demo/resources
63
394
394 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake
36042 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/dri
454 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/fcitx
327
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders
327
342
316
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines
316
316
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/pkgconfig
515
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/pulseaudio
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt-default/qtchooser
0
580
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer
399
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/egldeviceintegrations
96
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/gamepads
422
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/generic
40
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/iconengines
141
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats
359
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts
1544
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms
88
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/printsupport
36
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/wayland-decoration-client
250
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/wayland-graphics-integration-client
436
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/wayland-graphics-integration-server
301
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/wayland-shell-integration
156
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/xcbglintegrations
4844
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/qml/QtQml
66
4910 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5
229052 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu
451481    /var/lib/snapd/snap/openscad-nightly/2576/usr/lib
1    /var/lib/snapd/snap/openscad-nightly/2576/usr/sbin
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/C
17
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/am_ET.UTF-8
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/armscii-8
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/cs_CZ.UTF-8
123
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/el_GR.UTF-8
566
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/en_US.UTF-8
36
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/fi_FI.UTF-8
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/georgian-academy
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/georgian-ps
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ibm-cp1133
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iscii-dev
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/isiri-3342
22 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-1
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-10
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-11
23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-13
23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-14
21 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-15
25 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-2
24 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-3
18 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-4
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-5
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-6
12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-7
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-8
23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-9
24 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-9e
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ja
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ja.JIS
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ja.SJIS
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ja_JP.UTF-8
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/km_KH.UTF-8
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ko
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ko_KR.UTF-8
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/koi8-c
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/koi8-r
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/koi8-u
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/microsoft-cp1251
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/microsoft-cp1255
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/microsoft-cp1256
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/mulelao-1
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/nokhchi-1
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/pt_BR.UTF-8
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/pt_PT.UTF-8
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ru_RU.UTF-8
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/sr_CS.UTF-8
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/tatar-cyr
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/th_TH
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/th_TH.UTF-8
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/tscii-0
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/vi_VN.tcvn
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/vi_VN.viscii
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_CN
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_CN.UTF-8
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_CN.gb18030
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_CN.gbk
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_HK.UTF-8
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_HK.big5
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_HK.big5hkscs
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_TW
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_TW.UTF-8
11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_TW.big5
1260 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale
27 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/compat
39
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/geometry/digital_vndr
41
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/geometry/sgi_vndr
350 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/geometry
12
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/keycodes/digital_vndr
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/keycodes/sgi_vndr
76 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/keycodes
716 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/rules
25
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/digital_vndr
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/fujitsu_vndr
4
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/hp_vndr
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/jolla_vndr
49
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/macintosh_vndr
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/nec_vndr
113
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/nokia_vndr
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/sgi_vndr
11
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/sharp_vndr
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/sony_vndr
161
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/sun_vndr
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/xfree68_vndr
2022 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols
29 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/types
3218 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb
4520    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/applications
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/apport/package-hooks
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libegl-mesa0
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libegl1
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libgbm1
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libgl1
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libgl1-mesa-dri
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libglapi-mesa
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libglvnd0
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libglx-mesa0
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libglx0
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libopengl0
8    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug
292 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/CGAL
93
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/adwaita-icon-theme
23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/dmz-cursor-theme
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fcitx-frontend-qt5
9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fcitx-module-dbus
11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fcitx-modules
174 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fontconfig
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fontconfig-config
73 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fonts-dejavu-core
41 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fonts-ubuntu
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gnome-themes-extra
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gnome-themes-extra-data
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gnome-themes-standard
41
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gtk-update-icon-cache
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gtk2-engines-murrine
17
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gtk2-engines-pixbuf
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/hicolor-icon-theme
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/humanity-icon-theme
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libasyncns0
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libavahi-client3
22
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libavahi-common-data
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libavahi-common3
1921
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libboost-filesystem1.71.0
1921
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libboost-program-options1.71.0
1921
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libboost-regex1.71.0
1921
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libboost-system1.71.0
28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libcairo-gobject2
133 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libcairo2
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libcups2/examples
15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libcups2
9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdatrie1
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdouble-conversion3
16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-amdgpu1
17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-common
16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-intel1
16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-nouveau2
16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-radeon1
17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm2
14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libegl-mesa0
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libegl1
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libevdev2
11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libflac8
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libfontconfig1
37 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libfreetype6
10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libfribidi0
15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgbm1
19
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgdk-pixbuf2.0-0
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgdk-pixbuf2.0-common
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgl1
14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgl1-mesa-dri
15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglapi-mesa
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglew2.1
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglu1-mesa
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglvnd0
14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglx-mesa0
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglx0
12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgraphite2-3
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgudev-1.0-0
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libharfbuzz0b
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libice6
9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libicu66
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libinput-bin
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libinput10
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libjbig0
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libjpeg-turbo8
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libjpeg8
10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libllvm11
34 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libmpfr6
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libmtdev1
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libogg0
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libopengl0
56 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpango-1.0-0
12
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpangocairo-1.0-0
12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpangoft2-1.0-0
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpciaccess0
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpcre2-16-0
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpixman-1-0
92 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpng16-16
10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpresage-data
32 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpresage1v5
32 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpulse0
11
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqscintilla2-qt5-15
10
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqscintilla2-qt5-l10n
127 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5core5a
125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5dbus5
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5gamepad5
125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5gui5
11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5multimedia5
125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5network5
125
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5printsupport5
61 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5qml5
59 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5quick5
10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5svg5
16
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5waylandclient5
16
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5waylandcompositor5
125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5widgets5
43 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/librsvg2-2
15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/librsvg2-common
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libsensors-config
6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libsensors5
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libsm6
13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libsndfile1
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libthai-data
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libthai0
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libtiff5
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libtinyxml2.6.2v5
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libvorbis0a
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libvorbisenc2
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libvulkan1
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwacom-common
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwacom2
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwayland-client0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwayland-cursor0
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwayland-egl1
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwayland-server0
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwebp6
53 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libx11-6
48 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libx11-data
48 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libx11-xcb1
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxau6
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-dri2-0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-dri3-0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-glx0
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-icccm4
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-image0
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-keysyms1
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-present0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-randr0
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-render-util0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-render0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-shape0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-shm0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-sync1
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-util1
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-xfixes0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-xinerama0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-xinput0
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-xkb1
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb1
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcomposite1
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxdamage1
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxdmcp6
12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxext6
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxfixes3
4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxkbcommon-x11-0
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxkbcommon0
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxml2
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxrender1
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxshmfence1
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxxf86vm1
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libzip5
17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/light-themes
28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/locales-all
14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/qtwayland5
59
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/shared-mime-info/shared-mime-info-spec.html
228 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/shared-mime-info
28
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/ttf-ubuntu-font-family
19 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/ubuntu-mono
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/x11-common
5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/xdg-user-dirs
15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/xkb-data
11094    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc
3    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc-base
35    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/drirc.d
21 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/addon
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/configdesc
46
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/data/quickphrase.d
3816 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/data
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/dbus
1368 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/spell
5215    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx
2806
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/fonts/truetype/dejavu
4279
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/fonts/truetype/ubuntu
7085 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fonts/truetype
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/glvnd/egl_vendor.d
63 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/gtk-engines
16
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/actions
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/apps
10
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/devices
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/emblems
11
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/emotes
89
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/legacy
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/mimetypes
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/status
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/ui
147 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16
4
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/devices
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/emblems
125
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/legacy
4
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/mimetypes
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/status
135 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22
16
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/actions
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/apps
10
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/devices
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/emblems
12
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/emotes
123
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/legacy
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/mimetypes
10
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/status
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/ui
183 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24
2053
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/256x256/legacy
2053
16
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/actions
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/apps
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/devices
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/emblems
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/emotes
195
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/legacy
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/mimetypes
10
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/status
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/ui
259 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32
18
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/actions
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/apps
18
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/devices
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/emblems
23
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/emotes
306
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/legacy
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/mimetypes
14
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/status
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/ui
398 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48
130
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/devices
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/emblems
46
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/legacy
30
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/mimetypes
12
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/status
229
20
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/actions
8
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/apps
11
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/devices
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/emblems
24
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/emotes
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/legacy
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/mimetypes
15
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/status
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/ui
90 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/8x8/emblems
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/8x8/legacy
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/8x8
26
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/actions
11
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/apps
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/devices
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/emblems
37
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/emotes
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/legacy
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/mimetypes
21
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/status
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/ui
121 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96
163
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/actions
61
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/apps
26
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/categories
67
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/devices
10
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/emblems
22
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/emotes
17
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/legacy
29
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/mimetypes
18
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/places
264
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/status
22
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/ui
696
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable-up-to-32/status
3
4321 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita
1699
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/DMZ-Black/cursors
1701 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/DMZ-Black
1699
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/DMZ-White/cursors
1701 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/DMZ-White
100
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/128
341
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/16
445
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/22
548
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/24
132
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/32
486
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/48
80
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/64
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/symbolic
2133
4
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/16
45
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/22
47
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/24
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/32
168
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/48
270
147
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/128
231
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/16
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/192
405
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/22
767
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/24
313
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/32
766
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/48
126
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/64
2757 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps
10
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/128
43
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/16
56
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/22
210
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/24
139
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/32
782
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/48
178
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/64
1416
42
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/128
82
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/16
100
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/22
159
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/24
58
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/32
462
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/48
57
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/64
960
45
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/16
43
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/22
66
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/24
106
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/32
152
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/48
410
272
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/128
148
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/16
203
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/22
245
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/24
246
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/256
149
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/32
765
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/48
35
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/64
2062
25
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/128
127
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/16
254
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/22
285
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/24
218
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/32
294
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/48
286
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/64
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/scalable
1494
22
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/128
223
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/16
291
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/22
304
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/24
37
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/32
530
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/48
21
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/64
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/scalable
1427
29
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/16
27
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/22
28
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/24
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/32
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/48
95 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock
13051 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/actions/16
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/actions/22
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/actions/24
3
4
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps/16
134
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps/22
121
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps/24
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps/48
265
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/devices/16
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/devices/22
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/devices/24
2
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/16
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/22
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/24
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/32
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/48
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/64
13
160
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status/16
205
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status/22
211
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status/24
438
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status/48
1013
1316 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/16
34
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/22
34
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/24
27
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/48
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/64
98 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/default
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/animations
16
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/text
0
16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/animations
44
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/text
0
44 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/animations
11
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/text
0
11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/animations
103
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/text
0
103
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/animations
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/text
0
7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/actions
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/animations
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/apps
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/categories
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/devices
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/emblems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/emotes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/filesystems
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/intl
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/mimetypes
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/places
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/status
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/chart
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/code
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/data
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/form
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/image
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/io
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/media
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/navigation
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/net
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/object
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/table
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/text
0
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/symbolic/apps
0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/symbolic
234 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/actions/16
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/actions/22
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/actions/24
24
72
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/animations/22
72
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/animations/24
143
12
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps/16
39
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps/22
34
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps/24
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps/48
84
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/categories/22
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/categories/24
10
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/mimes/16
8
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/mimes/22
8
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/mimes/24
22
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/16
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/22
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/24
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/32
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/48
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/64
38
483
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/status/16
572
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/status/22
301
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/status/24
1355
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/128
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/16
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/22
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/24
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/32
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/48
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/64
3
1678
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/actions/16
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/actions/22
6
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/actions/24
24
72
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/animations/22
72
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/animations/24
143
12
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps/16
39
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps/22
34
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps/24
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps/48
84
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/categories/22
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/categories/24
10
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/mimes/16
8
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/mimes/22
8
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/mimes/24
22
5
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/16
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/22
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/24
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/32
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/48
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/64
38
499
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/status/16
844
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/status/22
544
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/status/24
1886
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/128
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/16
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/22
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/24
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/32
0
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/48
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/64
4
2210
26309    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons
8    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libdrm
33    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libinput
566    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libthai
299 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libwacom/layouts
502 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libwacom
17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/lintian/overrides
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/aa/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ace/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/af/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/am/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/an/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ar/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/as/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ast/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/az/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/be/LC_MESSAGES
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/be@latin/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/be@latin
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bg/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bn/LC_MESSAGES
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bn_IN/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bn_IN
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bo/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/br/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bs/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ca/LC_MESSAGES
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ca@valencia/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ca@valencia
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ce/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/chr/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ckb/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/crh/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cs/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/csb/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cv/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cy/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/da/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/de/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/dv/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/el/LC_MESSAGES
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_AU/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_AU
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_CA/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_CA
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_GB/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_GB
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/eo/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/es/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/et/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/eu/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fa/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fi/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fo/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fr/LC_MESSAGES
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fr_CA/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fr_CA
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fur/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fy/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ga/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gd/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gl/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gu/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/he/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hi/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hr/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ht/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hu/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hy/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ia/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/id/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/is/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/it/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ja/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/jv/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ka/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kk/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/km/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kn/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ko/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ku/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kw/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ky/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ln/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/lt/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/lv/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mi/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mk/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ml/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mr/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ms/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/my/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nb/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nds/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ne/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nl/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nn/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/oc/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/om/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/or/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pa/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pl/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ps/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pt/LC_MESSAGES
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pt_BR/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pt_BR
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ro/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ru/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sa/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sd/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/se/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/shn/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/si/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sk/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sl/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sq/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sr/LC_MESSAGES
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sr@Latn/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sr@Latn
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sv/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sw/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ta/LC_MESSAGES
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ta_LK/LC_MESSAGES
3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ta_LK
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/te/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/tg/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/th/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/tr/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ug/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/uk/LC_MESSAGES
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ur/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/vec/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/vi/LC_MESSAGES
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_CN/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_CN
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_HK/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_HK
2
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_TW/LC_MESSAGES
2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_TW
218    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale
23    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man/man1
24    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man/man5
12    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man/man7
1    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man/man8
59    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man
4    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/metainfo
2251 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/mime/packages
13
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/color-schemes/editor
10
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/color-schemes/render
24
20
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Advanced
732
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Basics
9
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Functions
167
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Old
8
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Parametric
943
3981
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/fonts/Liberation-2.00.1/ttf
3990
3991
28
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/libraries/MCAD/bitmap
243
243
15
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/cs/LC_MESSAGES
15
34
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/de/LC_MESSAGES
34
15
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/es/LC_MESSAGES
15
30
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/fr/LC_MESSAGES
30
35
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/hy/LC_MESSAGES
35
25
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/pl/LC_MESSAGES
25
35
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/ru/LC_MESSAGES
35
26
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/uk/LC_MESSAGES
26
29
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/zh_CN/LC_MESSAGES
29
28
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/zh_TW/LC_MESSAGES
28
270
3
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/templates
5472 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly
2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/pkgconfig
12162 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/presage
303 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/qt5/translations
87
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita/gtk-2.0/assets
153
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita/gtk-3.0
158 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita
87
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita-dark/gtk-2.0/assets
153
1
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita-dark/gtk-3.0
157 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita-dark
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-2.0/apps
26
40
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-3.0/apps
15725
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-3.0/assets
15867
41
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-3.20/apps
197
62
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/metacity-1
295
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/unity
16446 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance
7
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-2.0/apps
26
23
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-3.0/apps
134
25
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-3.20/apps
189
62
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/metacity-1
256
/var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/unity
666 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance
17426 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes
1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/thumbnailers
8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/xml/fontconfig
93364    /var/lib/snapd/snap/openscad-nightly/2576/usr/share
592524    /var/lib/snapd/snap/openscad-nightly/2576/usr
592937    /var/lib/snapd/snap/openscad-nightly/2576
On 2021-05-08 9:18 p.m., Torsten Paul wrote:
$ openscad-nightly
/snap/openscad-nightly/2576/usr/bin/openscad-nightly: error while
loading shared libraries: libQt5Core.so.5: cannot open shared
object file: No such file or directory
I don't know what's going on, but that's not how snaps should
start. Those need to run inside the container which brings
everything including the matching Qt library.
Try starting via /snap/bin/openscad-nightly that should bring
up the application running inside the snap environment.
Ron Wheeler
Artifact Software
438-345-3369
Where should the Qt5 library be located? $ du --max-depth=15 /var/lib/snapd/snap/openscad-nightly/ 21    /var/lib/snapd/snap/openscad-nightly/2576/bin 1    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11/Xreset.d 1    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11/Xresources 9    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11/Xsession.d 0    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11/xkb 33    /var/lib/snapd/snap/openscad-nightly/2576/etc/X11 102 /var/lib/snapd/snap/openscad-nightly/2576/etc/fonts/conf.avail 1    /var/lib/snapd/snap/openscad-nightly/2576/etc/fonts/conf.d 106    /var/lib/snapd/snap/openscad-nightly/2576/etc/fonts 0 /var/lib/snapd/snap/openscad-nightly/2576/etc/glvnd/egl_vendor.d 0    /var/lib/snapd/snap/openscad-nightly/2576/etc/glvnd 3    /var/lib/snapd/snap/openscad-nightly/2576/etc/init.d 0 /var/lib/snapd/snap/openscad-nightly/2576/etc/pulse/client.conf.d 2    /var/lib/snapd/snap/openscad-nightly/2576/etc/pulse 0    /var/lib/snapd/snap/openscad-nightly/2576/etc/sensors.d 0 /var/lib/snapd/snap/openscad-nightly/2576/etc/vulkan/explicit_layer.d 0    /var/lib/snapd/snap/openscad-nightly/2576/etc/vulkan/icd.d 0 /var/lib/snapd/snap/openscad-nightly/2576/etc/vulkan/implicit_layer.d 0    /var/lib/snapd/snap/openscad-nightly/2576/etc/vulkan 1    /var/lib/snapd/snap/openscad-nightly/2576/etc/xdg/autostart 1    /var/lib/snapd/snap/openscad-nightly/2576/etc/xdg/qtchooser 3    /var/lib/snapd/snap/openscad-nightly/2576/etc/xdg 162    /var/lib/snapd/snap/openscad-nightly/2576/etc 77    /var/lib/snapd/snap/openscad-nightly/2576/lib/udev/rules.d 133    /var/lib/snapd/snap/openscad-nightly/2576/lib/udev 133    /var/lib/snapd/snap/openscad-nightly/2576/lib 44    /var/lib/snapd/snap/openscad-nightly/2576/meta/gui 46    /var/lib/snapd/snap/openscad-nightly/2576/meta 1    /var/lib/snapd/snap/openscad-nightly/2576/snap/command-chain 52    /var/lib/snapd/snap/openscad-nightly/2576/snap 10486    /var/lib/snapd/snap/openscad-nightly/2576/usr/bin 738 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Algebraic_kernel_d 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Algebraic_kernel_for_circles 57 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Algebraic_kernel_for_spheres 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Apollonius_graph_2/uncertain 257 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Apollonius_graph_2 88 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Approximate_min_ellipsoid_d 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arithmetic_kernel 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_geometry_traits/IO 599 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_geometry_traits 564 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_point_location 153 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_rat_arc 76 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_spherical_gaussian_map_3 194 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arr_topology_traits 538 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Arrangement_2 104 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Barycentric_coordinates_2 248 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Boolean_set_operations_2 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Box_intersection_d 155 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/CORE/poly 463 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/CORE 337 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Cartesian 188 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Circular_kernel_2 205 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Circular_kernel_3 33 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Circulator 42 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/ETHZ/internal/random-forest 48 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/ETHZ/internal 60 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/ETHZ 57 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/Feature 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/OpenCV 38 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/TensorFlow 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification/internal 353 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Classification 33 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Cone_spanners_2 104 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Convex_decomposition_3 70 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Convex_hull_2 75 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Convex_hull_3/dual 75 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Convex_hull_3 185 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Curved_kernel_via_analysis_2/gfx 37 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Curved_kernel_via_analysis_2/test 567 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Curved_kernel_via_analysis_2 54 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Envelope_2 246 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Envelope_3 19 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Filtered_bbox_circular_kernel_2 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Filtered_kernel 132 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/GMP 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Heat_method_3/internal 65 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Heat_method_3 354 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Homogeneous 756 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/IO 436 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/ImageIO 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Interpolation/internal 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Interpolation 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Intersections_2/internal 182 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Intersections_2 290 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Intersections_3/internal 365 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Intersections_3 306 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Kernel 352 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Kernel_d 106 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Mesh_2 63 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Mesh_3/experimental 1021 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Mesh_3 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Meshes 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Min_circle_2 44 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Min_ellipse_2 20 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Min_sphere_d 42 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Min_sphere_of_spheres_d 210 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Minkowski_sum_2 66 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Minkowski_sum_3 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Modular_arithmetic 333 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Nef_2 866 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Nef_3 372 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Nef_S2 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d/LA_eigen 42 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d/Types 62 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d/Vector 38 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d/Wrapper 369 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/NewKernel_d 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Number_types 52 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/OTR_2 32 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/OpenGR 53 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/OpenNL 32 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Optimal_bounding_box/internal 54 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Optimal_bounding_box 42 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Optimisation 222 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Partition_2 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Periodic_3_mesh_3/IO 129 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Periodic_3_mesh_3 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Point_set_3 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Point_set_processing_3/internal/Voronoi_covariance_3 50 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Point_set_processing_3/internal 50 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Point_set_processing_3 77 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_2 337 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Corefinement 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Hole_filling/experimental 62 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Hole_filling 72 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Isotropic_remeshing 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Polygon_mesh_slicer 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Side_of_triangle_mesh 47 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Smoothing 104 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal/Snapping 699 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing/internal 1812 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polygon_mesh_processing 39 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polyline_simplification_2 265 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Polynomial 415 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/QP_solver 173 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/RS 31 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Regularization 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Scale_space_reconstruction_3/internal 65 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Scale_space_reconstruction_3 451 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Segment_Delaunay_graph_2 659 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Segment_Delaunay_graph_Linf_2 25 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Set_movable_separability_2/Single_mold_translational_casting 20 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Set_movable_separability_2/internal 45 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Set_movable_separability_2 162 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Efficient_RANSAC 45 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Region_growing/Region_growing_on_point_set 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Region_growing/Region_growing_on_polygon_mesh 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Region_growing/internal 94 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/Region_growing 35 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection/deprecated 293 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Shape_detection 82 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Sqrt_extension 141 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Straight_skeleton_2 23 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Subdivision_method_3/internal 69 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Subdivision_method_3 26 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh/IO 165 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_approximation 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_parameterization/IO 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_parameterization/internal 341 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_parameterization 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_shortest_path/internal 166 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_shortest_path 36 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_simplification/Policies/Edge_collapse/internal 85 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_simplification/Policies/Edge_collapse 85 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_simplification/Policies 49 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_simplification/internal 142 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_simplification 167 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_topology/internal 167 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesh_topology 178 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_mesher 421 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Surface_sweep_2 224 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Tetrahedral_remeshing/internal 235 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Tetrahedral_remeshing 120 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Three 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Tools 103 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Triangulation_2/internal 107 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Triangulation_2 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Visibility_2 158 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/Voronoi_diagram_2 19 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/auto_link 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/bimap 18 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/graph/METIS 71 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/graph/internal 889 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/graph 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost/iterator 898 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/boost 81 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/constructions 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/export 39 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/AABB_tree 21 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/AFSR 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Mesh_3 195 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Static_filters 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Surface_mesh_deformation 108 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Surface_mesh_segmentation 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Surface_mesh_skeletonization 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/TDS_2 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/Triangulation 57 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/auxiliary 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal/boost 1300 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/internal 35 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/license/Polygon_mesh_processing 237 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/license 47 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/pointmatcher 94 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL/predicates 36348 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/CGAL 20 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/Math 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/Mesh 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/MeshExport 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/MeshImport 25 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/MeshInformation 20 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/OPC 84 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common/Platform 231 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Common 324 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/COM 83 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Classes 18 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader/BeamLattice1702 23 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader/Slice1507 44 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader/v093 51 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader/v100 165 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Reader 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Writer/v100 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model/Writer 602    /var/lib/snapd/snap/openscad-nightly/2576/usr/include/Model 0    /var/lib/snapd/snap/openscad-nightly/2576/usr/include/X11 37193    /var/lib/snapd/snap/openscad-nightly/2576/usr/include 0    /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/X11 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_DJ/LC_MESSAGES 315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_DJ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_DJ.utf8/LC_MESSAGES 2868 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_DJ.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ER/LC_MESSAGES 351 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ER 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ER@saaho/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ER@saaho 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ET/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/aa_ET 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/af_ZA/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/af_ZA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/af_ZA.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/af_ZA.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/agr_PE/LC_MESSAGES 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/agr_PE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ak_GH/LC_MESSAGES 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ak_GH 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/am_ET/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/am_ET 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/an_ES/LC_MESSAGES 316 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/an_ES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/an_ES.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/an_ES.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/anp_IN/LC_MESSAGES 343 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/anp_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_AE/LC_MESSAGES 312 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_AE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_AE.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_AE.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_BH/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_BH 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_BH.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_BH.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_DZ/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_DZ 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_DZ.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_DZ.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_EG/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_EG 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_EG.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_EG.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IN/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IQ/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IQ 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IQ.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_IQ.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_JO/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_JO 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_JO.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_JO.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_KW/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_KW 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_KW.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_KW.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LB/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LB 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LB.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LB.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LY/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LY 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LY.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_LY.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_MA/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_MA 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_MA.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_MA.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_OM/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_OM 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_OM.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_OM.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_QA/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_QA 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_QA.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_QA.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SA/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SA 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SA.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SA.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SD/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SD 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SD.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SD.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SS/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SS 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SY/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SY 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SY.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_SY.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_TN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_TN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_TN.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_TN.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_YE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_YE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_YE.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ar_YE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/as_IN/LC_MESSAGES 343 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/as_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ast_ES/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ast_ES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ast_ES.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ast_ES.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ayc_PE/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ayc_PE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/az_AZ/LC_MESSAGES 2739 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/az_AZ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/az_IR/LC_MESSAGES 2874 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/az_IR 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY/LC_MESSAGES 318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY@latin/LC_MESSAGES 298 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/be_BY@latin 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bem_ZM/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bem_ZM 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ber_DZ/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ber_DZ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ber_MA/LC_MESSAGES 2529 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ber_MA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bg_BG/LC_MESSAGES 31 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bg_BG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bg_BG.utf8/LC_MESSAGES 2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bg_BG.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bhb_IN.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bhb_IN.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bho_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bho_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bho_NP/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bho_NP 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bi_VU/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bi_VU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bn_BD/LC_MESSAGES 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bn_BD 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bn_IN/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bn_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bo_CN/LC_MESSAGES 2596 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bo_CN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bo_IN/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bo_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR/LC_MESSAGES 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR.utf8/LC_MESSAGES 2535 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR@euro/LC_MESSAGES 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/br_FR@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/brx_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/brx_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bs_BA/LC_MESSAGES 318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bs_BA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bs_BA.utf8/LC_MESSAGES 2535 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/bs_BA.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/byn_ER/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/byn_ER 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_AD/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_AD 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_AD.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_AD.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES/LC_MESSAGES 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES.utf8/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES@euro/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES@valencia/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_ES@valencia 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_FR/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_FR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_FR.utf8/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_FR.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_IT/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_IT 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_IT.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ca_IT.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ce_RU/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ce_RU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/chr_US/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/chr_US 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ckb_IQ/LC_MESSAGES 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ckb_IQ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cmn_TW/LC_MESSAGES 5036 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cmn_TW 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/crh_UA/LC_MESSAGES 2739 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/crh_UA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cs_CZ/LC_MESSAGES 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cs_CZ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cs_CZ.utf8/LC_MESSAGES 2535 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cs_CZ.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/csb_PL/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/csb_PL 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cv_RU/LC_MESSAGES 2531 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cv_RU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cy_GB/LC_MESSAGES 322 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cy_GB 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cy_GB.utf8/LC_MESSAGES 2537 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/cy_GB.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/da_DK/LC_MESSAGES 313 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/da_DK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/da_DK.utf8/LC_MESSAGES 2866 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/da_DK.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT/LC_MESSAGES 292 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT.utf8/LC_MESSAGES 340 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT@euro/LC_MESSAGES 314 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_AT@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE@euro/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_BE@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_CH/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_CH 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_CH.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_CH.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE@euro/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_DE@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_IT/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_IT 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_IT.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_IT.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LI.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LI.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU@euro/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/de_LU@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/doi_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/doi_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dsb_DE/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dsb_DE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dv_MV/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dv_MV 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dz_BT/LC_MESSAGES 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/dz_BT 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_CY/LC_MESSAGES 317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_CY 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_CY.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_CY.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR@euro/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/el_GR@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AG/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AU/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AU 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AU.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_AU.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_BW/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_BW 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_BW.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_BW.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_CA/LC_MESSAGES 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_CA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_CA.utf8/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_CA.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK.iso885915/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK.iso885915 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_DK.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB.iso885915/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB.iso885915 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_GB.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_HK/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_HK 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_HK.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_HK.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE@euro/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IE@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IL/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IL 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IN/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NG/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NG 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NZ/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NZ 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NZ.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_NZ.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_PH/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_PH 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_PH.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_PH.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SC.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SC.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SG/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SG 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SG.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_SG.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US.iso885915/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US.iso885915 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_US.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZA/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZA 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZA.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZA.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZM/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZM 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZW/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZW 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZW.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/en_ZW.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eo/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eo 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eo_US.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eo_US.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_AR/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_AR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_AR.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_AR.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_BO/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_BO 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_BO.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_BO.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CL/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CL 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CL.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CL.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CO/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CO 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CO.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CO.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CR/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CR.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CR.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CU/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_CU 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_DO/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_DO 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_DO.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_DO.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_EC/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_EC 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_EC.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_EC.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES@euro/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_ES@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_GT/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_GT 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_GT.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_GT.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_HN/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_HN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_HN.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_HN.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_MX/LC_MESSAGES 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_MX 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_MX.utf8/LC_MESSAGES 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_MX.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_NI/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_NI 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_NI.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_NI.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PA/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PA 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PA.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PA.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PE.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PE.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PR/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PR.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PR.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PY/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PY 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PY.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_PY.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_SV/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_SV 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_SV.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_SV.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_US/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_US 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_US.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_US.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_UY/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_UY 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_UY.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_UY.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_VE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_VE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_VE.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/es_VE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE/LC_MESSAGES 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE.iso885915/LC_MESSAGES 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE.iso885915 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/et_EE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES@euro/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_ES@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR.utf8/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR@euro/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/eu_FR@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fa_IR/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fa_IR 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ff_SN/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ff_SN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI/LC_MESSAGES 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI.utf8/LC_MESSAGES 2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI@euro/LC_MESSAGES 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fi_FI@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fil_PH/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fil_PH 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fo_FO/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fo_FO 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fo_FO.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fo_FO.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE@euro/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_BE@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CA/LC_MESSAGES 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CA.utf8/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CA.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CH/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CH 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CH.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_CH.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR/LC_MESSAGES 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR.utf8/LC_MESSAGES 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR@euro/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_FR@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU@euro/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fr_LU@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fur_IT/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fur_IT 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fy_DE/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fy_DE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fy_NL/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/fy_NL 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE@euro/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ga_IE@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gd_GB/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gd_GB 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gd_GB.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gd_GB.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ER/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ER 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ER@abegede/LC_MESSAGES 2528 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ER@abegede 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ET/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ET 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ET@abegede/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gez_ET@abegede 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES@euro/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gl_ES@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gu_IN/LC_MESSAGES 342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gu_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gv_GB/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gv_GB 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gv_GB.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/gv_GB.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ha_NG/LC_MESSAGES 2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ha_NG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hak_TW/LC_MESSAGES 299 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hak_TW 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/he_IL/LC_MESSAGES 314 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/he_IL 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/he_IL.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/he_IL.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hi_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hi_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hif_FJ/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hif_FJ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hne_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hne_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hr_HR/LC_MESSAGES 292 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hr_HR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hr_HR.utf8/LC_MESSAGES 339 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hr_HR.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hsb_DE/LC_MESSAGES 315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hsb_DE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hsb_DE.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hsb_DE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ht_HT/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ht_HT 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hu_HU/LC_MESSAGES 328 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hu_HU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hu_HU.utf8/LC_MESSAGES 2881 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hu_HU.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hy_AM/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hy_AM 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hy_AM.armscii8/LC_MESSAGES 315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/hy_AM.armscii8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ia_FR/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ia_FR 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/id_ID/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/id_ID 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/id_ID.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/id_ID.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ig_NG/LC_MESSAGES 2537 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ig_NG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ik_CA/LC_MESSAGES 2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ik_CA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/is_IS/LC_MESSAGES 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/is_IS 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/is_IS.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/is_IS.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_CH/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_CH 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_CH.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_CH.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT@euro/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/it_IT@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/iu_CA/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/iu_CA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ja_JP.eucjp/LC_MESSAGES 984 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ja_JP.eucjp 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ja_JP.utf8/LC_MESSAGES 1037 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ja_JP.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ka_GE/LC_MESSAGES 318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ka_GE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ka_GE.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ka_GE.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kab_DZ/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kab_DZ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ/LC_MESSAGES 317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ.rk1048/LC_MESSAGES 318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ.rk1048 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kk_KZ.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kl_GL/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kl_GL 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kl_GL.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kl_GL.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/km_KH/LC_MESSAGES 37 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/km_KH 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kn_IN/LC_MESSAGES 342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kn_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ko_KR.euckr/LC_MESSAGES 1139 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ko_KR.euckr 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ko_KR.utf8/LC_MESSAGES 1303 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ko_KR.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kok_IN/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kok_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ks_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ks_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ks_IN@devanagari/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ks_IN@devanagari 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ku_TR/LC_MESSAGES 199 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ku_TR 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ku_TR.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ku_TR.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kw_GB/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kw_GB 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kw_GB.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/kw_GB.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ky_KG/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ky_KG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lb_LU/LC_MESSAGES 339 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lb_LU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lg_UG/LC_MESSAGES 317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lg_UG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lg_UG.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lg_UG.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/li_BE/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/li_BE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/li_NL/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/li_NL 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lij_IT/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lij_IT 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ln_CD/LC_MESSAGES 2535 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ln_CD 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lo_LA/LC_MESSAGES 43 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lo_LA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lt_LT/LC_MESSAGES 317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lt_LT 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lt_LT.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lt_LT.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lv_LV/LC_MESSAGES 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lv_LV 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lv_LV.utf8/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lv_LV.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lzh_TW/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/lzh_TW 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mag_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mag_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mai_IN/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mai_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mai_NP/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mai_NP 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mfe_MU/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mfe_MU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mg_MG/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mg_MG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mg_MG.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mg_MG.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mhr_RU/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mhr_RU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mi_NZ/LC_MESSAGES 31 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mi_NZ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mi_NZ.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mi_NZ.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/miq_NI/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/miq_NI 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mjw_IN/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mjw_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mk_MK/LC_MESSAGES 315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mk_MK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mk_MK.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mk_MK.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ml_IN/LC_MESSAGES 2871 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ml_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mn_MN/LC_MESSAGES 344 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mn_MN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mni_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mni_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mnw_MM/LC_MESSAGES 304 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mnw_MM 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mr_IN/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mr_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ms_MY/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ms_MY 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ms_MY.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ms_MY.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mt_MT/LC_MESSAGES 317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mt_MT 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mt_MT.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/mt_MT.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/my_MM/LC_MESSAGES 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/my_MM 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nan_TW/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nan_TW 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nan_TW@latin/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nan_TW@latin 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nb_NO/LC_MESSAGES 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nb_NO 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nb_NO.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nb_NO.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nds_DE/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nds_DE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nds_NL/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nds_NL 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ne_NP/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ne_NP 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nhn_MX/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nhn_MX 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/niu_NU/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/niu_NU 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/niu_NZ/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/niu_NZ 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_AW/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_AW 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE@euro/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_BE@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL@euro/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nl_NL@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nn_NO/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nn_NO 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nn_NO.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nn_NO.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nr_ZA/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nr_ZA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nso_ZA/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/nso_ZA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/oc_FR/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/oc_FR 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/oc_FR.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/oc_FR.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_ET/LC_MESSAGES 2536 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_ET 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_KE/LC_MESSAGES 31 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_KE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_KE.utf8/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/om_KE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/or_IN/LC_MESSAGES 363 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/or_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/os_RU/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/os_RU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pa_IN/LC_MESSAGES 341 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pa_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pa_PK/LC_MESSAGES 339 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pa_PK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pap_AW/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pap_AW 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pap_CW/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pap_CW 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pl_PL/LC_MESSAGES 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pl_PL 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pl_PL.utf8/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pl_PL.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ps_AF/LC_MESSAGES 2830 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ps_AF 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_BR/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_BR 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_BR.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_BR.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT@euro/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/pt_PT@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/quz_PE/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/quz_PE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/raj_IN/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/raj_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ro_RO/LC_MESSAGES 315 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ro_RO 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ro_RO.utf8/LC_MESSAGES 2866 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ro_RO.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.cp1251/LC_MESSAGES 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.cp1251 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.koi8r/LC_MESSAGES 318 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.koi8r 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_RU.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_UA/LC_MESSAGES 319 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_UA 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_UA.utf8/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ru_UA.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/rw_RW/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/rw_RW 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sa_IN/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sa_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sah_RU/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sah_RU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sat_IN/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sat_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sc_IT/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sc_IT 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_IN@devanagari/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_IN@devanagari 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_PK/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sd_PK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/se_NO/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/se_NO 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sgs_LT/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sgs_LT 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/shn_MM/LC_MESSAGES 346 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/shn_MM 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/shs_CA/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/shs_CA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/si_LK/LC_MESSAGES 2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/si_LK 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sid_ET/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sid_ET 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sk_SK/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sk_SK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sk_SK.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sk_SK.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sl_SI/LC_MESSAGES 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sl_SI 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sl_SI.utf8/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sl_SI.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sm_WS/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sm_WS 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_DJ/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_DJ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_DJ.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_DJ.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_ET/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_ET 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_KE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_KE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_KE.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_KE.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_SO/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_SO 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_SO.utf8/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/so_SO.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_AL/LC_MESSAGES 32 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_AL 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_AL.utf8/LC_MESSAGES 2537 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_AL.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_MK/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sq_MK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_ME/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_ME 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_RS/LC_MESSAGES 341 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_RS 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_RS@latin/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sr_RS@latin 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ss_ZA/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ss_ZA 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/st_ZA/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/st_ZA 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/st_ZA.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/st_ZA.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI/LC_MESSAGES 26 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI.utf8/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI@euro/LC_MESSAGES 313 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_FI@euro 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE.iso885915/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE.iso885915 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sv_SE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sw_KE/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sw_KE 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sw_TZ/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/sw_TZ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/szl_PL/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/szl_PL 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ta_IN/LC_MESSAGES 342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ta_IN 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ta_LK/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ta_LK 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tcy_IN.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tcy_IN.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/te_IN/LC_MESSAGES 342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/te_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tg_TJ/LC_MESSAGES 316 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tg_TJ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tg_TJ.utf8/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tg_TJ.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/th_TH/LC_MESSAGES 335 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/th_TH 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/th_TH.utf8/LC_MESSAGES 50 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/th_TH.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/the_NP/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/the_NP 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ti_ER/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ti_ER 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ti_ET/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ti_ET 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tig_ER/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tig_ER 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tk_TM/LC_MESSAGES 2868 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tk_TM 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tl_PH/LC_MESSAGES 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tl_PH 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tl_PH.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tl_PH.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tn_ZA/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tn_ZA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/to_TO/LC_MESSAGES 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/to_TO 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tpi_PG/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tpi_PG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_CY/LC_MESSAGES 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_CY 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_CY.utf8/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_CY.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_TR/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_TR 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_TR.utf8/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tr_TR.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ts_ZA/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ts_ZA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tt_RU/LC_MESSAGES 2532 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tt_RU 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tt_RU@iqtelif/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/tt_RU@iqtelif 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ug_CN/LC_MESSAGES 2533 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ug_CN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ug_CN@latin/LC_MESSAGES 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ug_CN@latin 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uk_UA/LC_MESSAGES 280 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uk_UA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uk_UA.utf8/LC_MESSAGES 2827 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uk_UA.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/unm_US/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/unm_US 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ur_IN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ur_IN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ur_PK/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ur_PK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ/LC_MESSAGES 317 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ.utf8/LC_MESSAGES 2870 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ@cyrillic/LC_MESSAGES 341 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/uz_UZ@cyrillic 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ve_ZA/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/ve_ZA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/vi_VN/LC_MESSAGES 2867 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/vi_VN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE/LC_MESSAGES 291 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE.utf8/LC_MESSAGES 339 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE@euro/LC_MESSAGES 291 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wa_BE@euro 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wae_CH/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wae_CH 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wal_ET/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wal_ET 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wo_SN/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/wo_SN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/xh_ZA/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/xh_ZA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/xh_ZA.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/xh_ZA.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yi_US/LC_MESSAGES 319 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yi_US 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yi_US.utf8/LC_MESSAGES 2867 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yi_US.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yo_NG/LC_MESSAGES 2534 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yo_NG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yue_HK/LC_MESSAGES 338 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yue_HK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yuw_PG/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/yuw_PG 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN/LC_MESSAGES 743 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.gb18030/LC_MESSAGES 2809 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.gb18030 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.gbk/LC_MESSAGES 1167 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.gbk 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.utf8/LC_MESSAGES 2741 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_CN.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_HK/LC_MESSAGES 1092 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_HK 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_HK.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_HK.utf8 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG/LC_MESSAGES 426 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG.gbk/LC_MESSAGES 878 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG.gbk 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG.utf8/LC_MESSAGES 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_SG.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW/LC_MESSAGES 924 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW.euctw/LC_MESSAGES 1197 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW.euctw 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW.utf8/LC_MESSAGES 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zh_TW.utf8 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zu_ZA/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zu_ZA 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zu_ZA.utf8/LC_MESSAGES 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale/zu_ZA.utf8 215940    /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/locale 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/avahi 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/Help 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/config/support 18 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/config/testfiles 47 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/config 35 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/demo/icons 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/demo/resources 63 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL/demo 394 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake/CGAL 394 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/cmake 36042 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/dri 454 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/fcitx 327 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders 327 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0 342 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0 316 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines 316 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0 316 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/gtk-2.0 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/pkgconfig 515 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/pulseaudio 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt-default/qtchooser 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt-default 580 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer 399 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/egldeviceintegrations 96 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/gamepads 422 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/generic 40 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/iconengines 141 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats 359 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts 1544 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms 88 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/printsupport 36 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/wayland-decoration-client 250 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/wayland-graphics-integration-client 436 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/wayland-graphics-integration-server 301 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/wayland-shell-integration 156 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins/xcbglintegrations 4844 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/plugins 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/qml/QtQml 66 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5/qml 4910 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu/qt5 229052 /var/lib/snapd/snap/openscad-nightly/2576/usr/lib/x86_64-linux-gnu 451481    /var/lib/snapd/snap/openscad-nightly/2576/usr/lib 1    /var/lib/snapd/snap/openscad-nightly/2576/usr/sbin 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/C 17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/am_ET.UTF-8 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/armscii-8 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/cs_CZ.UTF-8 123 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/el_GR.UTF-8 566 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/en_US.UTF-8 36 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/fi_FI.UTF-8 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/georgian-academy 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/georgian-ps 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ibm-cp1133 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iscii-dev 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/isiri-3342 22 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-1 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-10 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-11 23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-13 23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-14 21 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-15 25 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-2 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-3 18 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-4 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-5 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-6 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-7 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-8 23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-9 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/iso8859-9e 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ja 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ja.JIS 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ja.SJIS 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ja_JP.UTF-8 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/km_KH.UTF-8 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ko 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ko_KR.UTF-8 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/koi8-c 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/koi8-r 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/koi8-u 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/microsoft-cp1251 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/microsoft-cp1255 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/microsoft-cp1256 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/mulelao-1 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/nokhchi-1 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/pt_BR.UTF-8 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/pt_PT.UTF-8 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/ru_RU.UTF-8 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/sr_CS.UTF-8 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/tatar-cyr 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/th_TH 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/th_TH.UTF-8 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/tscii-0 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/vi_VN.tcvn 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/vi_VN.viscii 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_CN 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_CN.UTF-8 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_CN.gb18030 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_CN.gbk 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_HK.UTF-8 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_HK.big5 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_HK.big5hkscs 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_TW 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_TW.UTF-8 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale/zh_TW.big5 1260 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/locale 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/compat 39 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/geometry/digital_vndr 41 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/geometry/sgi_vndr 350 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/geometry 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/keycodes/digital_vndr 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/keycodes/sgi_vndr 76 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/keycodes 716 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/rules 25 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/digital_vndr 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/fujitsu_vndr 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/hp_vndr 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/jolla_vndr 49 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/macintosh_vndr 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/nec_vndr 113 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/nokia_vndr 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/sgi_vndr 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/sharp_vndr 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/sony_vndr 161 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/sun_vndr 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols/xfree68_vndr 2022 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/symbols 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb/types 3218 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11/xkb 4520    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/X11 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/applications 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/apport/package-hooks 5    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/apport 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libegl-mesa0 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libegl1 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libgbm1 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libgl1 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libgl1-mesa-dri 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libglapi-mesa 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libglvnd0 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libglx-mesa0 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libglx0 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug/libopengl0 8    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/bug 292 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/CGAL 93 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/adwaita-icon-theme 23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/dmz-cursor-theme 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fcitx-frontend-qt5 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fcitx-module-dbus 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fcitx-modules 174 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fontconfig 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fontconfig-config 73 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fonts-dejavu-core 41 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/fonts-ubuntu 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gnome-themes-extra 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gnome-themes-extra-data 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gnome-themes-standard 41 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gtk-update-icon-cache 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gtk2-engines-murrine 17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/gtk2-engines-pixbuf 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/hicolor-icon-theme 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/humanity-icon-theme 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libasyncns0 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libavahi-client3 22 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libavahi-common-data 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libavahi-common3 1921 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libboost-filesystem1.71.0 1921 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libboost-program-options1.71.0 1921 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libboost-regex1.71.0 1921 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libboost-system1.71.0 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libcairo-gobject2 133 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libcairo2 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libcups2/examples 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libcups2 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdatrie1 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdouble-conversion3 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-amdgpu1 17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-common 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-intel1 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-nouveau2 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm-radeon1 17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libdrm2 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libegl-mesa0 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libegl1 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libevdev2 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libflac8 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libfontconfig1 37 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libfreetype6 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libfribidi0 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgbm1 19 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgdk-pixbuf2.0-0 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgdk-pixbuf2.0-common 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgl1 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgl1-mesa-dri 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglapi-mesa 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglew2.1 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglu1-mesa 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglvnd0 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglx-mesa0 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libglx0 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgraphite2-3 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libgudev-1.0-0 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libharfbuzz0b 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libice6 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libicu66 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libinput-bin 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libinput10 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libjbig0 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libjpeg-turbo8 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libjpeg8 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libllvm11 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libmpfr6 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libmtdev1 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libogg0 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libopengl0 56 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpango-1.0-0 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpangocairo-1.0-0 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpangoft2-1.0-0 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpciaccess0 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpcre2-16-0 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpixman-1-0 92 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpng16-16 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpresage-data 32 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpresage1v5 32 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libpulse0 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqscintilla2-qt5-15 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqscintilla2-qt5-l10n 127 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5core5a 125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5dbus5 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5gamepad5 125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5gui5 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5multimedia5 125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5network5 125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5printsupport5 61 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5qml5 59 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5quick5 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5svg5 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5waylandclient5 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5waylandcompositor5 125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libqt5widgets5 43 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/librsvg2-2 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/librsvg2-common 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libsensors-config 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libsensors5 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libsm6 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libsndfile1 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libthai-data 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libthai0 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libtiff5 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libtinyxml2.6.2v5 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libvorbis0a 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libvorbisenc2 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libvulkan1 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwacom-common 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwacom2 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwayland-client0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwayland-cursor0 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwayland-egl1 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwayland-server0 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libwebp6 53 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libx11-6 48 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libx11-data 48 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libx11-xcb1 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxau6 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-dri2-0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-dri3-0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-glx0 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-icccm4 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-image0 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-keysyms1 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-present0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-randr0 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-render-util0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-render0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-shape0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-shm0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-sync1 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-util1 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-xfixes0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-xinerama0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-xinput0 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb-xkb1 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcb1 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxcomposite1 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxdamage1 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxdmcp6 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxext6 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxfixes3 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxkbcommon-x11-0 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxkbcommon0 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxml2 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxrender1 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxshmfence1 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libxxf86vm1 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/libzip5 17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/light-themes 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/locales-all 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/qtwayland5 59 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/shared-mime-info/shared-mime-info-spec.html 228 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/shared-mime-info 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/ttf-ubuntu-font-family 19 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/ubuntu-mono 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/x11-common 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/xdg-user-dirs 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc/xkb-data 11094    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc 3    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/doc-base 35    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/drirc.d 21 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/addon 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/configdesc 46 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/data/quickphrase.d 3816 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/data 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/dbus 1368 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx/spell 5215    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fcitx 2806 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fonts/truetype/dejavu 4279 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fonts/truetype/ubuntu 7085 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fonts/truetype 7085    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/fonts 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/glvnd/egl_vendor.d 1    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/glvnd 63 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/gtk-engines 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/actions 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/apps 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/devices 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/emblems 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/emotes 89 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/legacy 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/mimetypes 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/status 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16/ui 147 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/16x16 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/devices 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/emblems 125 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/legacy 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/mimetypes 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22/status 135 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/22x22 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/actions 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/apps 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/devices 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/emblems 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/emotes 123 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/legacy 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/mimetypes 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/status 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24/ui 183 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/24x24 2053 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/256x256/legacy 2053 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/256x256 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/actions 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/apps 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/devices 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/emblems 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/emotes 195 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/legacy 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/mimetypes 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/status 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32/ui 259 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/32x32 18 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/actions 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/apps 18 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/devices 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/emblems 23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/emotes 306 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/legacy 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/mimetypes 14 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/status 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48/ui 398 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/48x48 130 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/devices 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/emblems 46 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/legacy 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/mimetypes 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512/status 229 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/512x512 20 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/actions 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/apps 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/devices 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/emblems 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/emotes 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/legacy 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/mimetypes 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/status 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64/ui 90 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/64x64 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/8x8/emblems 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/8x8/legacy 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/8x8 26 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/actions 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/apps 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/devices 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/emblems 37 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/emotes 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/legacy 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/mimetypes 21 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/status 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96/ui 121 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/96x96 163 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/actions 61 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/apps 26 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/categories 67 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/devices 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/emblems 22 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/emotes 17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/legacy 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/mimetypes 18 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/places 264 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/status 22 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable/ui 696 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable-up-to-32/status 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita/scalable-up-to-32 4321 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Adwaita 1699 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/DMZ-Black/cursors 1701 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/DMZ-Black 1699 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/DMZ-White/cursors 1701 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/DMZ-White 100 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/128 341 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/16 445 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/22 548 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/24 132 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/32 486 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/48 80 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/64 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions/symbolic 2133 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/actions 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/16 45 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/22 47 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/24 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/32 168 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations/48 270 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/animations 147 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/128 231 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/16 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/192 405 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/22 767 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/24 313 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/32 766 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/48 126 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps/64 2757 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/apps 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/128 43 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/16 56 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/22 210 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/24 139 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/32 782 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/48 178 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories/64 1416 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/categories 42 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/128 82 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/16 100 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/22 159 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/24 58 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/32 462 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/48 57 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices/64 960 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/devices 45 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/16 43 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/22 66 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/24 106 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/32 152 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems/48 410 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/emblems 272 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/128 148 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/16 203 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/22 245 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/24 246 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/256 149 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/32 765 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/48 35 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes/64 2062 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/mimes 25 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/128 127 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/16 254 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/22 285 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/24 218 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/32 294 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/48 286 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/64 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places/scalable 1494 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/places 22 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/128 223 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/16 291 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/22 304 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/24 37 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/32 530 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/48 21 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/64 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status/scalable 1427 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/status 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/16 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/22 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/24 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/32 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock/48 95 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity/stock 13051 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/actions/16 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/actions/22 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/actions/24 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/actions 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps/16 134 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps/22 121 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps/24 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps/48 265 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/apps 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/devices/16 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/devices/22 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/devices/24 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/devices 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/16 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/22 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/24 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/32 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/48 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places/64 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/places 160 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status/16 205 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status/22 211 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status/24 438 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status/48 1013 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark/status 1316 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/Humanity-Dark 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/16 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/22 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/24 27 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/48 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps/64 98 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons/apps 98 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/LoginIcons 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/default 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/animations 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128/stock 16 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/128x128 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/16x16 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/192x192 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/22x22 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/24x24 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/animations 44 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256/stock 44 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/256x256 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/32x32 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/36x36 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/animations 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48/stock 11 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/48x48 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/animations 103 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512/stock 103 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/512x512 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/animations 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64/stock 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/64x64 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/72x72 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/96x96 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/actions 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/animations 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/categories 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/devices 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/emblems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/emotes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/filesystems 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/intl 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/mimetypes 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/places 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/chart 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/code 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/data 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/form 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/image 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/io 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/media 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/navigation 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/net 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/object 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/table 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock/text 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable/stock 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/scalable 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/symbolic/apps 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor/symbolic 234 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/hicolor 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/actions/16 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/actions/22 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/actions/24 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/actions 72 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/animations/22 72 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/animations/24 143 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/animations 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps/16 39 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps/22 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps/24 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps/48 84 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/apps 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/categories/22 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/categories/24 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/categories 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/mimes/16 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/mimes/22 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/mimes/24 22 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/mimes 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/16 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/22 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/24 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/32 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/48 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places/64 38 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/places 483 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/status/16 572 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/status/22 301 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/status/24 1355 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/128 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/16 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/22 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/24 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/32 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/48 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock/64 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark/stock 1678 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-dark 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/actions/16 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/actions/22 6 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/actions/24 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/actions 72 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/animations/22 72 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/animations/24 143 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/animations 12 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps/16 39 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps/22 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps/24 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps/48 84 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/apps 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/categories/22 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/categories/24 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/categories 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/mimes/16 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/mimes/22 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/mimes/24 22 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/mimes 5 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/16 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/22 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/24 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/32 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/48 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places/64 38 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/places 499 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/status/16 844 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/status/22 544 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/status/24 1886 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/status 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/128 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/16 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/22 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/24 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/32 0 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/48 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock/64 4 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light/stock 2210 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons/ubuntu-mono-light 26309    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/icons 8    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libdrm 33    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libinput 566    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libthai 299 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libwacom/layouts 502 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/libwacom 17 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/lintian/overrides 17    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/lintian 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/aa/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/aa 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ace/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ace 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/af/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/af 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/am/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/am 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/an/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/an 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ar/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ar 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/as/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/as 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ast/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ast 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/az/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/az 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/be/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/be 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/be@latin/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/be@latin 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bg/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bg 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bn/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bn 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bn_IN/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bn_IN 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bo/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bo 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/br/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/br 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bs/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/bs 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ca/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ca 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ca@valencia/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ca@valencia 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ce/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ce 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/chr/LC_MESSAGES 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/chr 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ckb/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ckb 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/crh/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/crh 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cs/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cs 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/csb/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/csb 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cv/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cv 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cy/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/cy 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/da/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/da 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/de/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/de 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/dv/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/dv 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/el/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/el 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_AU/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_AU 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_CA/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_CA 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_GB/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/en_GB 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/eo/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/eo 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/es/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/es 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/et/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/et 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/eu/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/eu 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fa/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fa 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fi/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fi 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fo/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fo 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fr/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fr 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fr_CA/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fr_CA 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fur/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fur 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fy/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/fy 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ga/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ga 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gd/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gd 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gl/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gl 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gu/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/gu 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/he/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/he 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hi/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hi 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hr/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hr 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ht/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ht 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hu/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hu 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hy/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/hy 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ia/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ia 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/id/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/id 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/is/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/is 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/it/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/it 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ja/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ja 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/jv/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/jv 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ka/LC_MESSAGES 3    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ka 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kk/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kk 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/km/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/km 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kn/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kn 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ko/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ko 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ku/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ku 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kw/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/kw 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ky/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ky 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ln/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ln 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/lt/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/lt 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/lv/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/lv 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mi/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mi 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mk/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mk 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ml/LC_MESSAGES 1    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ml 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mr/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/mr 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ms/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ms 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/my/LC_MESSAGES 3    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/my 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nb/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nb 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nds/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nds 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ne/LC_MESSAGES 3    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ne 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nl/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nl 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nn/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/nn 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/oc/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/oc 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/om/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/om 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/or/LC_MESSAGES 3    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/or 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pa/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pa 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pl/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pl 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ps/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ps 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pt/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pt 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pt_BR/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/pt_BR 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ro/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ro 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ru/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ru 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sa/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sa 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sd/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sd 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/se/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/se 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/shn/LC_MESSAGES 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/shn 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/si/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/si 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sk/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sk 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sl/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sl 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sq/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sq 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sr/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sr 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sr@Latn/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sr@Latn 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sv/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sv 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sw/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/sw 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ta/LC_MESSAGES 3    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ta 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ta_LK/LC_MESSAGES 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ta_LK 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/te/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/te 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/tg/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/tg 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/th/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/th 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/tr/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/tr 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ug/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ug 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/uk/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/uk 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ur/LC_MESSAGES 1    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/ur 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/vec/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/vec 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/vi/LC_MESSAGES 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/vi 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_CN/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_CN 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_HK/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_HK 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_TW/LC_MESSAGES 2 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale/zh_TW 218    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/locale 23    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man/man1 24    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man/man5 12    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man/man7 1    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man/man8 59    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/man 4    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/metainfo 2251 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/mime/packages 2251    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/mime 13 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/color-schemes/editor 10 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/color-schemes/render 24 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/color-schemes 20 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Advanced 732 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Basics 9 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Functions 167 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Old 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples/Parametric 943 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/examples 3981 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/fonts/Liberation-2.00.1/ttf 3990 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/fonts/Liberation-2.00.1 3991 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/fonts 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/libraries/MCAD/bitmap 243 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/libraries/MCAD 243 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/libraries 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/cs/LC_MESSAGES 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/cs 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/de/LC_MESSAGES 34 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/de 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/es/LC_MESSAGES 15 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/es 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/fr/LC_MESSAGES 30 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/fr 35 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/hy/LC_MESSAGES 35 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/hy 25 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/pl/LC_MESSAGES 25 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/pl 35 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/ru/LC_MESSAGES 35 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/ru 26 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/uk/LC_MESSAGES 26 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/uk 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/zh_CN/LC_MESSAGES 29 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/zh_CN 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/zh_TW/LC_MESSAGES 28 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale/zh_TW 270 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/locale 3 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly/templates 5472 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/openscad-nightly 2    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/pkgconfig 12162 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/presage 303 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/qt5/translations 303    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/qt5 87 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita/gtk-2.0/assets 153 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita/gtk-2.0 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita/gtk-3.0 158 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita 87 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita-dark/gtk-2.0/assets 153 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita-dark/gtk-2.0 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita-dark/gtk-3.0 157 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Adwaita-dark 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-2.0/apps 26 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-2.0 40 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-3.0/apps 15725 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-3.0/assets 15867 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-3.0 41 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-3.20/apps 197 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/gtk-3.20 62 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/metacity-1 295 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance/unity 16446 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Ambiance 7 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-2.0/apps 26 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-2.0 23 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-3.0/apps 134 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-3.0 25 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-3.20/apps 189 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/gtk-3.20 62 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/metacity-1 256 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance/unity 666 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes/Radiance 17426 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/themes 1 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/thumbnailers 8 /var/lib/snapd/snap/openscad-nightly/2576/usr/share/xml/fontconfig 8    /var/lib/snapd/snap/openscad-nightly/2576/usr/share/xml 93364    /var/lib/snapd/snap/openscad-nightly/2576/usr/share 592524    /var/lib/snapd/snap/openscad-nightly/2576/usr 592937    /var/lib/snapd/snap/openscad-nightly/2576 592937    /var/lib/snapd/snap/openscad-nightly/ On 2021-05-08 9:18 p.m., Torsten Paul wrote: >> $ openscad-nightly >> /snap/openscad-nightly/2576/usr/bin/openscad-nightly: error while >> loading shared libraries: libQt5Core.so.5: cannot open shared >> object file: No such file or directory > I don't know what's going on, but that's not how snaps should > start. Those need to run inside the container which brings > everything including the matching Qt library. > > Try starting via /snap/bin/openscad-nightly that should bring > up the application running inside the snap environment. > > ciao, > Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- Ron Wheeler Artifact Software 438-345-3369 rwheeler@artifact-software.com
