Becoming familiar with openscad
joea@acquisto.us
Mon, Mar 21, 2022 11:27 PM
I dabble in 3d printing and will download things from thingiverse.com, for example.
Some are "configurable" scad files and, to some degree, I can manage to configure them as I desire.
But, I am only "hacking", if it is not obvious from the authors comments or from what I can understand of the code, I grind to a halt.
Current project is a "knob" that I wish to use on valve actuator for the hydraulic jack on a press.  It has an axial hole, round, that I would like to modify to have two "flats" and to have an additional hole at right angle to it, perhaps all the way though, to allow installation of a "set screw" to hold the knob on the jack.
Don't really expect a hand holding session, especially without posting the code, but perhaps there are some good places for me to start looking?
Thanks.
I dabble in 3d printing and will download things from thingiverse.com, for example. Some are "configurable" scad files and, to some degree, I can manage to configure them as I desire. But, I am only "hacking", if it is not obvious from the authors comments or from what I can understand of the code, I grind to a halt. Current project is a "knob" that I wish to use on valve actuator for the hydraulic jack on a press. It has an axial hole, round, that I would like to modify to have two "flats" and to have an additional hole at right angle to it, perhaps all the way though, to allow installation of a "set screw" to hold the knob on the jack. Don't really expect a hand holding session, especially without posting the code, but perhaps there are some good places for me to start looking? Thanks.
Tue, Mar 22, 2022 12:05 AM
I guess the first thing is to install openscad. then click on the help
tab. look at the documentation for a while then try a simple script to
make a cube, say. Under the help tab is a cheat sheet, - click on the
cube (in the 3d section - it will open up a link to an explanation and
an example. In general, parts like knobs and brackets, can be built up
by union or difference of shapes such as cubes and cylinders.
If you want a you tube video - this will get you started
https://www.youtube.com/watch?v=Br6yvlL5I5w&t=217s
Best wishes,
Ray
for example.
Thanks.
I guess the first thing is to install openscad. then click on the help tab. look at the documentation for a while then try a simple script to make a cube, say. Under the help tab is a cheat sheet, - click on the cube (in the 3d section - it will open up a link to an explanation and an example. In general, parts like knobs and brackets, can be built up by union or difference of shapes such as cubes and cylinders. If you want a you tube video - this will get you started https://www.youtube.com/watch?v=Br6yvlL5I5w&t=217s Best wishes, Ray On 21/03/2022 23:27, joea@acquisto.us wrote: > > I dabble in 3d printing and will download things from thingiverse.com, > for example. > > Some are "configurable" scad files and, to some degree, I can manage > to configure them as I desire. > > But, I am only "hacking", if it is not obvious from the authors > comments or from what I can understand of the code, I grind to a halt. > > Current project is a "knob" that I wish to use on valve actuator for > the hydraulic jack on a press. It has an axial hole, round, that I > would like to modify to have two "flats" and to have an additional > hole at right angle to it, perhaps all the way though, to allow > installation of a "set screw" to hold the knob on the jack. > > Don't really expect a hand holding session, especially without posting > the code, but perhaps there are some good places for me to start looking? > > Thanks. > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Tue, Mar 22, 2022 12:48 AM
There's a tutorial at https://openscad.org/documentation.html that is a
good place to start.
There's a tutorial at https://openscad.org/documentation.html that is a good place to start.
Tue, Mar 22, 2022 12:56 AM
Here are some references that have arised in the forum.
Online tutorial:
https://learn.cadhub.xyz/docs/
Tutorial in video:
https://www.youtube.com/watch?v=dx06_gcdMck&list=PL3by7evD3F51u-17hoepe7IduGkfp2Fu6&ab_channel=John%27sBasement
Online book:
https://mastering-openscad.eu/
Em seg., 21 de mar. de 2022 às 23:28, joea@acquisto.us escreveu:
for example.
Thanks.
Here are some references that have arised in the forum. Online tutorial: https://learn.cadhub.xyz/docs/ Tutorial in video: https://www.youtube.com/watch?v=dx06_gcdMck&list=PL3by7evD3F51u-17hoepe7IduGkfp2Fu6&ab_channel=John%27sBasement Online book: https://mastering-openscad.eu/ Em seg., 21 de mar. de 2022 às 23:28, <joea@acquisto.us> escreveu: > I dabble in 3d printing and will download things from thingiverse.com, > for example. > > Some are "configurable" scad files and, to some degree, I can manage to > configure them as I desire. > > But, I am only "hacking", if it is not obvious from the authors comments > or from what I can understand of the code, I grind to a halt. > > Current project is a "knob" that I wish to use on valve actuator for the > hydraulic jack on a press. It has an axial hole, round, that I would like > to modify to have two "flats" and to have an additional hole at right angle > to it, perhaps all the way though, to allow installation of a "set screw" > to hold the knob on the jack. > > Don't really expect a hand holding session, especially without posting the > code, but perhaps there are some good places for me to start looking? > > Thanks. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Tue, Mar 22, 2022 1:03 AM
and various other books at https://openscad.org/documentation-books.html
From: Ronaldo Persiano [mailto:rcmpersiano@gmail.com]
Sent: Tue, 22 Mar 2022 11:56
Subject: [OpenSCAD] Re: Becoming familiar with openscad
Online tutorial:
Tutorial in video:
https://www.youtube.com/watch?v=dx06_gcdMck https://www.youtube.com/watch?v=dx06_gcdMck&list=PL3by7evD3F51u-17hoepe7IduGkfp2Fu6&ab_channel=John%27sBasement &list=PL3by7evD3F51u-17hoepe7IduGkfp2Fu6&ab_channel=John%27sBasement
Online book:
Thanks.
and various other books at https://openscad.org/documentation-books.html _____ From: Ronaldo Persiano [mailto:rcmpersiano@gmail.com] Sent: Tue, 22 Mar 2022 11:56 To: OpenSCAD general discussion Subject: [OpenSCAD] Re: Becoming familiar with openscad Here are some references that have arised in the forum. Online tutorial: https://learn.cadhub.xyz/docs/ Tutorial in video: https://www.youtube.com/watch?v=dx06_gcdMck <https://www.youtube.com/watch?v=dx06_gcdMck&list=PL3by7evD3F51u-17hoepe7IduGkfp2Fu6&ab_channel=John%27sBasement> &list=PL3by7evD3F51u-17hoepe7IduGkfp2Fu6&ab_channel=John%27sBasement Online book: https://mastering-openscad.eu/ Em seg., 21 de mar. de 2022 às 23:28, <joea@acquisto.us> escreveu: I dabble in 3d printing and will download things from thingiverse.com, for example. Some are "configurable" scad files and, to some degree, I can manage to configure them as I desire. But, I am only "hacking", if it is not obvious from the authors comments or from what I can understand of the code, I grind to a halt. Current project is a "knob" that I wish to use on valve actuator for the hydraulic jack on a press. It has an axial hole, round, that I would like to modify to have two "flats" and to have an additional hole at right angle to it, perhaps all the way though, to allow installation of a "set screw" to hold the knob on the jack. Don't really expect a hand holding session, especially without posting the code, but perhaps there are some good places for me to start looking? Thanks. _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG. https://www.avg.com
SM
Sándor Megyeri
Tue, Mar 22, 2022 6:36 AM
I have started two years ago with this link:
http://www.tridimake.com/2014/09/how-to-use-openscad-tricks-and-tips-to.html
It works today, I' ve chekced it.
This is a short (59 pages) introductory, some very short explanation and
the basic forms.
You can build yout first objects after 10 minutes reading. I can really
suggest it.
The tutorials are also very useful, but first I neede some really basic
knowledge...
best regards
Sandor Megyeri
Jordan Brown openscad@jordan.maileater.net ezt írta (időpont: 2022. márc.
22., K, 1:49):
I have started two years ago with this link: http://www.tridimake.com/2014/09/how-to-use-openscad-tricks-and-tips-to.html It works today, I' ve chekced it. This is a short (59 pages) introductory, some very short explanation and the basic forms. You can build yout first objects after 10 minutes reading. I can really suggest it. The tutorials are also very useful, but first I neede some really basic knowledge... best regards Sandor Megyeri Jordan Brown <openscad@jordan.maileater.net> ezt írta (időpont: 2022. márc. 22., K, 1:49): > There's a tutorial at https://openscad.org/documentation.html that is a > good place to start. > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
WF
William F. Adams
Tue, Mar 22, 2022 12:46 PM
While I started w/ OpenSCAD, I find typing and managing syntax a tedious burden, so instead do my work visually using BlockSCAD:
https://www.blockscad3d.com
once a project is done, I export it to OpenSCAD to set up for the Customizer and to add the projection() command to flatten things out to cut on a CNC.
https://willadams.gitbook.io/design-into-3d/3d-project
While I started w/ OpenSCAD, I find typing and managing syntax a tedious burden, so instead do my work visually using BlockSCAD: https://www.blockscad3d.com once a project is done, I export it to OpenSCAD to set up for the Customizer and to add the projection() command to flatten things out to cut on a CNC. https://willadams.gitbook.io/design-into-3d/3d-project William
Terry
Tue, Mar 22, 2022 2:21 PM
Thanks.
I'm a relative novice too. After help here and much experiment (fun) I recently
printed a possibly relevant knob myself. When you've decided your design
requirement let me know if you'd like to see my code.
Meanwhile it might be helpful to see the various design options I considered for
the inner cylinder, containing the spindle hole:
#1. Simple flat plus screw hole.
#2. Flat with some flexibility, for tight fit, no screw.
#3. Improvement on #2, with bevelled top for easier insertion.
#4. Slot to hold flexible or springy metal strip (like original).
#5. Flat, solid, no screw, optimum fit via trial/error; my final choice.
Illustration attached, or here:
https://www.dropbox.com/s/gtas7yvp367nn4a/FinishedAll.jpg?raw=1
Terry
On Mon, 21 Mar 2022 23:27:48 +0000, you wrote: >I dabble in 3d printing and will download things from thingiverse.com, for example. > >Some are "configurable" scad files and, to some degree, I can manage to configure them as I desire. > >But, I am only "hacking", if it is not obvious from the authors comments or from what I can understand of the code, I grind to a halt. > >Current project is a "knob" that I wish to use on valve actuator for the hydraulic jack on a press. It has an axial hole, round, that I would like to modify to have two "flats" and to have an additional hole at right angle to it, perhaps all the way though, to allow installation of a "set screw" to hold the knob on the jack. > >Don't really expect a hand holding session, especially without posting the code, but perhaps there are some good places for me to start looking? > >Thanks. I'm a relative novice too. After help here and much experiment (fun) I recently printed a possibly relevant knob myself. When you've decided your design requirement let me know if you'd like to see my code. Meanwhile it might be helpful to see the various design options I considered for the inner cylinder, containing the spindle hole: #1. Simple flat plus screw hole. #2. Flat with some flexibility, for tight fit, no screw. #3. Improvement on #2, with bevelled top for easier insertion. #4. Slot to hold flexible or springy metal strip (like original). #5. Flat, solid, no screw, optimum fit via trial/error; my final choice. Illustration attached, or here: https://www.dropbox.com/s/gtas7yvp367nn4a/FinishedAll.jpg?raw=1 Terry
JL
joea-lists@j4computers.com
Tue, Mar 22, 2022 10:59 PM
Thanks for all the links.  I accomplished my immediate task, and expect I will slowly become more familiar with openscad, which I find substantially easier and less frustrating to use for my needs than freecad or Solidworks.  But then, I am not a “designer” by trade.  Or nature perhaps.
In any event, I have unsubscribed at this email address and subscribed under one I dedicated to list use.
joe a.
Thanks for all the links. I accomplished my immediate task, and expect I will slowly become more familiar with openscad, which I find substantially easier and less frustrating to use for my needs than freecad or Solidworks. But then, I am not a “designer” by trade. Or nature perhaps. In any event, I have unsubscribed at this email address and subscribed under one I dedicated to list use. joe a.
