Preview glitch
E
Endre
Wed, Apr 12, 2017 10:48 PM
There is an axis:
http://forum.openscad.org/file/n21214/axis.png
And a ring:
http://forum.openscad.org/file/n21214/ring.png
When they are union()-ed together the preview is ugly:
http://forum.openscad.org/file/n21214/union.png
Is there a workaround for this?
Ugly, script generated code is  here https://pastebin.com/98JytRMr  .
View this message in context: http://forum.openscad.org/Preview-glitch-tp21214.html
There is an axis: <http://forum.openscad.org/file/n21214/axis.png> And a ring: <http://forum.openscad.org/file/n21214/ring.png> When they are union()-ed together the preview is ugly: <http://forum.openscad.org/file/n21214/union.png> Is there a workaround for this? Ugly, script generated code is here <https://pastebin.com/98JytRMr> . -- View this message in context: http://forum.openscad.org/Preview-glitch-tp21214.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Apr 12, 2017 11:12 PM
Yes, either make sure there are no coincident faces, e.g. make one slightly
longer than the other, or put render() just after your color() statements.
On 12 April 2017 at 23:48, Endre ebak32@gmail.com wrote:
There is an axis:
And a ring:
Yes, either make sure there are no coincident faces, e.g. make one slightly longer than the other, or put render() just after your color() statements. On 12 April 2017 at 23:48, Endre <ebak32@gmail.com> wrote: > There is an axis: > <http://forum.openscad.org/file/n21214/axis.png> > > And a ring: > <http://forum.openscad.org/file/n21214/ring.png> > > When they are union()-ed together the preview is ugly: > <http://forum.openscad.org/file/n21214/union.png> > > Is there a workaround for this? > > > Ugly, script generated code is here <https://pastebin.com/98JytRMr> . > > > > -- > View this message in context: http://forum.openscad.org/ > Preview-glitch-tp21214.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Apr 12, 2017 11:16 PM
There is an axis:
And a ring:
Z-fighting <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Print_version#Chapter_8_--_Frequently_Asked_Questions> 2017-04-12 19:48 GMT-03:00 Endre <ebak32@gmail.com>: > There is an axis: > <http://forum.openscad.org/file/n21214/axis.png> > > And a ring: > <http://forum.openscad.org/file/n21214/ring.png> > > When they are union()-ed together the preview is ugly: > <http://forum.openscad.org/file/n21214/union.png> > > Is there a workaround for this? > > > Ugly, script generated code is here <https://pastebin.com/98JytRMr> . > > > > -- > View this message in context: http://forum.openscad.org/ > Preview-glitch-tp21214.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
E
Endre
Thu, Apr 13, 2017 8:37 AM
Thanks! The render() solved it :)
View this message in context: http://forum.openscad.org/Preview-glitch-tp21214p21225.html
Thanks! The render() solved it :) -- View this message in context: http://forum.openscad.org/Preview-glitch-tp21214p21225.html Sent from the OpenSCAD mailing list archive at Nabble.com.
