OpenSCAD listed on Thingiverse's Jumpstart
http://www.thingiverse.com/jumpstart
Customizer is running 2015.03 (latest) [ref]
https://groups.google.com/forum/#!topic/thingiverse/88CVLy0andc . So
text() etc are available.
View this message in context: http://forum.openscad.org/In-case-you-missed-it-tp13811.html
Ahem...Quoting Jumpstart "Every model that OpenSCAD exports will be a high
quality, solid, watertight STL file that can be understood by 3D printer
software like MakerBot Desktop or other model slicers. Unlike programs like
Sculptris, OpenSCAD was written specifically to create 3D printable models,
and therefore it never exports bad or broken geometry."...
View this message in context: http://forum.openscad.org/In-case-you-missed-it-tp13811p13812.html
Lol.. reminds me of the old saying "Never say never..." As far as I
understand it, in theory the math model behind CGAL can guarantee "non
broken" geometry... (google for "regularized set operations", very rough
description is that it guarantees that if you start with two water-tight
objects, and perform an operation like union or difference, the result
will be a watertight object, which should propagate through the entire
object tree resulting in a water-tight overall model)
http://www.slideshare.net/hitesh915/presentation7-23624280
http://doc.cgal.org/latest/Nef_3/index.html#sectoinRegularized
But as I understand it, the theory gets a little messed up somewhere in
the thousands of lines of code in CGAL, OpenSCAD, binary floating point
conversion, re-conversion, ASCII decimal floating point conversion,
gcode, etc.
don bright
hmbright@fastmail.fm
high
like
models,
something stupid...
It works very well for me and I'm duly impressed. But you have to manage the
Delta overlaps between volumes when performing any boolean op as adjacency
is indeterminate.
IMHO this is where most people come unstuck making printable objects.
Another reason I love the # operator :) (and Wings3D :))
View this message in context: http://forum.openscad.org/In-case-you-missed-it-tp13811p13837.html
