This is, what I mean by "prone to faulty output" and "kamikaze".
If you know, what you do, the result will pay off your effort, e.g. sweep().
But if you don't, you mess up everything and start to curse into the wrong
direction, ignoring the wellknow fact that there is no free lunch.
polyhedron() and polygon() are currently kamikaze operations. Plugging this
holes will be a lot effort and slow things down significantly. Ignoring them
is more or less a thumbs-up for lazy_union().
View this message in context: http://forum.openscad.org/rendering-for-paper-assembly-manual-tp20108p20145.html
Ronaldo,
OpenSCAD is single threaded. So RAM size can play an import role, when
scaling up a problem.
You are right about the similarities. That's why I noted "The implementation
has some similarities with your sweep interface". A lazy_union() over a set
of polyhedron() calls could even do away with it and just merge the points
and faces into a single call. This would open the door to composing 3D
objects by a set of surfaces ... Also your approach, and your desire, I
know.
I am using this lazy_union technique to be able to compose and render gear
systems with a large amount of teeth that have been 3D shape optimized by a
separate process, similar to my simplified 2D gear cutter project
http://www.thingiverse.com/thing:636119 . Currently I am using this path
to include scad-converted versions of my stls, which consumes time, memory
and is the work-around for a work-around of a work-around of
lazy_union() forN(r=radius, N=numteeth) mytooth();
Concerning the merge with "C-style for": First I had an old recursive
version in my lib, which I could tweak by faktor ~5 employing "each" and
"C-for". So there is progress in OpenSCAD with every new build.
View this message in context: http://forum.openscad.org/rendering-for-paper-assembly-manual-tp20108p20146.html
On 01/17/2017 12:26 PM, Parkinbot wrote:
Beyond time, since the whole workflow is defined for linux
being on Windows it doesn't seem viable to me to branch out
an own version and just implement it.
We don't have anyone who did get it running via VisualStudio,
but a dev environment on Windows should work via MSYS2 and
QtCreator as IDE:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows
I don't know when this was used last, so there is a chance
a library is missing, but otherwise there were not that much
changes regarding the build system I think.
@Parkinbot and @Ronaldo
https://en.wiktionary.org/wiki/if_all_you_have_is_a_hammer,_everything_looks_like_a_nail
Yes, I understand wonderful things are possible with triangles, and you have
a hammer which works with triangular nails.
But when you have a circle()'ular peg you cannot hammer it into a square()
hole.
Will you please stop side tracking threads.
View this message in context: http://forum.openscad.org/rendering-for-paper-assembly-manual-tp20108p20155.html
View this message in context: http://forum.openscad.org/rendering-for-paper-assembly-manual-tp20108p20157.html
