Re: offset_extrude()
YV
Yuri Volodin
Tue, Sep 29, 2026 7:24 AM
translate([0,0,rise>0 ? rise+s0.5 : rise-s0.5]) cube([s,s,s],
correct please.
translate(\[0,0,rise>0 ? rise+s*0.5 : rise-s*0.5\]) cube(\[s,s,s\], ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\ correct please.
Tue, Sep 29, 2026 7:40 AM
On 9/29/2026 1:24 AM, Yuri Volodin via Discuss wrote:
translate([0,0,rise>0 ? rise+s/0.5 : rise-s/0.5]) cube([s,s,s],
correct please.
Looks like the copy you looked at somehow got fed through a MarkDown
processor.  That's never healthy for sources.
Let's try this, putting it in "preformat" form:
         translate([0,0,rise>0 ? rise+s*0.5 : rise-s*0.5]) cube([s,s,s], center=true);
Here is Todd's entire module, in preformat form:
module conditional_zflip_z(condition, z=0) {
if (condition)
scale([1,1,-1]) translate([0,0,-z]) children();
else children();
module conditional_offset(condition, delta) {
if (condition)
offset(delta=delta) children();
else children();
// generates an extrusion from z=0 cropped at z=rise.
// extrusion tapers inward with positive run and outward with negative run
module roofrr(rise=1, run=1, s=100, convexity=10) {
assert(rise != 0, "rise can not be zero.")
assert(s != 0, "s can not be zero.")
if (run) {
conditional_zflip_z(run<0, z=rise)
scale([1,1,rise/abs(run)]) roof(convexity=convexity) conditional_offset(run<0, delta=-run) children();
translate([0,0,rise>0 ? rise+s0.5 : rise-s0.5]) cube([s,s,s], center=true);
else {
conditional_zflip_z(rise<0) linear_extrude(height=abs(rise), convexity=convexity) children();
module offset_extrude(
height,
bottom=[],
top=[],
h, l, length,
offset="round", r=0, steps=16,
extra=0,
cut=undef, chamfer_width=undef, chamfer_height=undef,
joint=undef, k=0.75, angle=45,
convexity=10, thickness = 1/1024, s=100
req_children($children);
argspec = [
["for", ""],
["r",r],
["extra",extra],
["type","circle"],
["steps",steps],
["offset",offset],
["chamfer_width",chamfer_width],
["chamfer_height",chamfer_height],
["angle",angle],
["cut",cut],
["joint",joint],
["k", k],
["points", []],
top = struct_set(argspec, top, grow=false);
bottom = struct_set(argspec, bottom, grow=false);
 offsets_bot = _rounding_offsets(bottom, -1);
 offsets_top = _rounding_offsets(top, 1);
 // "Extra" height enlarges the result beyond the requested height, so subtract it
 bottom_height = len(offsets_bot)==0 ? 0 : abs(last(offsets_bot)[1]) - struct_val(bottom,"extra");
 top_height = len(offsets_top)==0 ? 0 : abs(last(offsets_top)[1]) - struct_val(top,"extra");
 height = one_defined([l,h,height,length], "l,h,height,length", dflt=u_add(bottom_height,top_height));
 middle = height-bottom_height-top_height;
 check =
     assert(height>=0, "Height must be nonnegative")
     assert(middle>=0, str(
                         "Specified end treatments (bottom height = ",bottom_height,
                         " top_height = ",top_height,") are too large for extrusion height (",height,")"
 // The entry r[i] is [radius,z] for a given layer
 r = move([0,bottom_height],p=concat(
                     reverse(offsets_bot), [[0,0], [0,middle]], move([0,middle], p=offsets_top)));
 dochamfer = offset=="chamfer";
 attachable(){
     last = len(r)-2;
     for(i=[0:last]) {
         overlap = /* i<last ? thickness : */ 0;
         for(j=[0:$children-1]) {
             run = r[i][0] - r[i+1][0];
             rise = r[i+1][1] - r[i][1];
             up(r[i][1]) // +layers[i][0]
             roofrr(rise=rise+overlap, run=run, s=s, convexity=convexity)
                 if (offset=="round")
                     offset(r=r[i][0])
                     children(j);
                 else
                     offset(delta=r[i][0],chamfer = dochamfer)
                     children(j);
     union();
On 9/29/2026 1:24 AM, Yuri Volodin via Discuss wrote: > > translate([0,0,rise>0 ? rise+s/0.5 : rise-s/0.5]) cube([s,s,s], > > ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ > correct please. > Looks like the copy you looked at somehow got fed through a MarkDown processor.  That's never healthy for sources. Let's try this, putting it in "preformat" form: translate([0,0,rise>0 ? rise+s*0.5 : rise-s*0.5]) cube([s,s,s], center=true); Here is Todd's entire module, in preformat form: module conditional_zflip_z(condition, z=0) { if (condition) scale([1,1,-1]) translate([0,0,-z]) children(); else children(); } module conditional_offset(condition, delta) { if (condition) offset(delta=delta) children(); else children(); } // generates an extrusion from z=0 cropped at z=rise. // extrusion tapers inward with positive run and outward with negative run module roofrr(rise=1, run=1, s=100, convexity=10) { assert(rise != 0, "rise can not be zero.") assert(s != 0, "s can not be zero.") if (run) { conditional_zflip_z(run<0, z=rise) difference() { scale([1,1,rise/abs(run)]) roof(convexity=convexity) conditional_offset(run<0, delta=-run) children(); translate([0,0,rise>0 ? rise+s*0.5 : rise-s*0.5]) cube([s,s,s], center=true); } } else { conditional_zflip_z(rise<0) linear_extrude(height=abs(rise), convexity=convexity) children(); } } module offset_extrude( height, bottom=[], top=[], h, l, length, offset="round", r=0, steps=16, extra=0, cut=undef, chamfer_width=undef, chamfer_height=undef, joint=undef, k=0.75, angle=45, convexity=10, thickness = 1/1024, s=100 ) { req_children($children); argspec = [ ["for", ""], ["r",r], ["extra",extra], ["type","circle"], ["steps",steps], ["offset",offset], ["chamfer_width",chamfer_width], ["chamfer_height",chamfer_height], ["angle",angle], ["cut",cut], ["joint",joint], ["k", k], ["points", []], ]; top = struct_set(argspec, top, grow=false); bottom = struct_set(argspec, bottom, grow=false); offsets_bot = _rounding_offsets(bottom, -1); offsets_top = _rounding_offsets(top, 1); // "Extra" height enlarges the result beyond the requested height, so subtract it bottom_height = len(offsets_bot)==0 ? 0 : abs(last(offsets_bot)[1]) - struct_val(bottom,"extra"); top_height = len(offsets_top)==0 ? 0 : abs(last(offsets_top)[1]) - struct_val(top,"extra"); height = one_defined([l,h,height,length], "l,h,height,length", dflt=u_add(bottom_height,top_height)); middle = height-bottom_height-top_height; check = assert(height>=0, "Height must be nonnegative") assert(middle>=0, str( "Specified end treatments (bottom height = ",bottom_height, " top_height = ",top_height,") are too large for extrusion height (",height,")" ) ); // The entry r[i] is [radius,z] for a given layer r = move([0,bottom_height],p=concat( reverse(offsets_bot), [[0,0], [0,middle]], move([0,middle], p=offsets_top))); dochamfer = offset=="chamfer"; attachable(){ last = len(r)-2; for(i=[0:last]) { overlap = /* i<last ? thickness : */ 0; for(j=[0:$children-1]) { run = r[i][0] - r[i+1][0]; rise = r[i+1][1] - r[i][1]; up(r[i][1]) // +layers[i][0] roofrr(rise=rise+overlap, run=run, s=s, convexity=convexity) if (offset=="round") offset(r=r[i][0]) children(j); else offset(delta=r[i][0],chamfer = dochamfer) children(j); } } union(); } }
Tue, Sep 29, 2026 7:46 AM
Interestingly, the text/plain version of your message had the *s intact,
but added backslashes before the brackets:
I suggest that you find a different mail client, or be very very careful
about what you do with source text.
Interestingly, the text/plain version of your message had the *s intact, but added backslashes before the brackets: translate(\[0,0,rise>0 ? rise+s*0.5 : rise-s*0.5\]) cube(\[s,s,s\], I suggest that you find a different mail client, or be very very careful about what you do with source text.
