On Mar 25, 2012 Whosawhatsis wrote:
It would be nice if OpenSCAD allowed you to select whether or not to
center squares and cubes on each axis independently. Here's the syntax I
suggest:
cube(10, center = [true, true, false]);
This should create a 10mm cube sitting on the center of the X/Y plane. I
know there are ways to do this using translate, but it would make the
code more elegant and easier to edit.
Hi!
I second this (old) proposition; I rarely need a cube centered on its 3
axes, and always have to use translate() to move, which is pretty annoying.
Especially when using global consts (for parametric code), it leads to
XXX/2, YYY/2...
Thanks,
PS : sphere is also not consistant with cylinder/cube, as it is always
centered...
Frédéric
You can implement features of this kind easily as your own library and
include it into you projects.
Have a look at: http://www.thingiverse.com/thing:644830
Rudolf
View this message in context: http://forum.openscad.org/Centering-cube-axes-independently-tp15128p15130.html
Sure, but:
is there any reason not to put it as a native feature?
what about perfs? I guess it would be much faster if native...
Frédéric
Well, your proposal is in principle not bad. I also often missed this
feature.
@Kintel
In my eyes one would be better off having an automatically included
standard library, where stuff like that is rewritable without having to put
further burden to the dev team. If there was also a qualified naming scheme
in OpenSCAD, the implementation could even be made fully transparent. This
would also be the perfect place to put in other customizations, like
includes for other libraries.
@fma
Be assured, you won't notice any increase in execution time with code like
this:
module yourcube(size = [1,1,1], center = false)
sz = (len(size) == 3)?size:[size,size,size];
if (len(center) == 1)
cube(size, center);
else
translate([center[0]?-sz[0]/2:0,center[1]?-sz[1]/2:0,center[2]?-sz[2]/2:0])
cube(size);
yourcube([6, 10, 12], [true, true, false]); // testing it
View this message in context: http://forum.openscad.org/Centering-cube-axes-independently-tp15128p15145.html
I guess there's full agreement on that. The issue list already contains
a number of things that would be nice and simple candidates for inclusion
e.g.:
https://github.com/openscad/openscad/issues/1517
https://github.com/openscad/openscad/issues/821
(Hmm, one of the 821 related issues might need to be reopened?!)
The challenges are "only":
There is a feature requests open for this feature on github, from 2013
https://github.com/openscad/openscad/issues/265
And a pull request from 2014, so it has been implemented, but not accepted
into the tree yet.
https://github.com/openscad/openscad/pull/753
Sure, but:
Frédéric
