To answer the question you asked: concat() accepts N arrays,
concatenates them, and returns the result.
Nophead gave you the solution to your problem: list comprehension or
recursion.
But to respond to some of the behaviors that you asked about:
Concat does not assign or reassign anything. It is a pure function: it
accepts inputs, and returns an output.
In OpenSCAD, it is not possible to assign a new value to an existing
name. There are a few cases that look sort of like you're doing that,
but you're not - you're assigning a new value to a new name, and when
that new name goes out of scope the old name and its value will reappear.
x = concat(x, y);
probably does not do what you want, but that has nothing to do with
concat. It is that you cannot assign a new value to the existing name.
This is exactly the same case as:
x = x + 1;
and is a close variation on this:
x = 1;
if (something) {
x = 2;
