Wrong Opengl version detected - preview fails
Joculus
Tue, Jul 7, 2020 7:50 PM
Hello,
it's the first time that I will put a question to a forum. So please be
forgiving if i do not fully comply with the netiquette.
My problem is that the prewiew fails (has errors). I know that the problem
is caused by the opengl version and I know the work around with "% and #". I
have an old SONY Vaio laptop with Win 10 with HD 3000 GPU. Natively there is
no W10 driver but I installed (found the possibliity in the internet) the
Intel driver 9.17.10.4459. This driver supports opengl 3.1. But I get on
startup this warning:
http://forum.openscad.org/file/t2875/Waring.jpg
Here OpenGL version is mentioned with 1.1.0 Why is this so? See
VersionInfo.txt http://forum.openscad.org/file/t2875/VersionInfo.txt  for
more. Here The opengl version is 1.1.0, too. But I am nearly sure to have
OpenGL version > 2.0. The CAPS viewer output is :
http://forum.openscad.org/file/t2875/Caps_Viewer.jpg
And I can run the Open GL 3.x - Illuminated Torus demo without a problem.
All other demos 2.x are also running. The open GL extension viewer also says
OpenGL 3.1.
What could I do that OpenSCAD gets the right (?) OpenGL version and the
preview running correct? And where gets OpenSCAD the version info from?
I am happy for your suggestions and I am sorry for ma bad English. If more
information is needed - please write what I could do.
Hello, it's the first time that I will put a question to a forum. So please be forgiving if i do not fully comply with the netiquette. My problem is that the prewiew fails (has errors). I know that the problem is caused by the opengl version and I know the work around with "% and #". I have an old SONY Vaio laptop with Win 10 with HD 3000 GPU. Natively there is no W10 driver but I installed (found the possibliity in the internet) the Intel driver 9.17.10.4459. This driver supports opengl 3.1. But I get on startup this warning: <http://forum.openscad.org/file/t2875/Waring.jpg> Here OpenGL version is mentioned with 1.1.0 Why is this so? See VersionInfo.txt <http://forum.openscad.org/file/t2875/VersionInfo.txt> for more. Here The opengl version is 1.1.0, too. But I am nearly sure to have OpenGL version > 2.0. The CAPS viewer output is : <http://forum.openscad.org/file/t2875/Caps_Viewer.jpg> And I can run the Open GL 3.x - Illuminated Torus demo without a problem. All other demos 2.x are also running. The open GL extension viewer also says OpenGL 3.1. What could I do that OpenSCAD gets the right (?) OpenGL version and the preview running correct? And where gets OpenSCAD the version info from? I am happy for your suggestions and I am sorry for ma bad English. If more information is needed - please write what I could do. -- Sent from: http://forum.openscad.org/
Tue, Jul 7, 2020 9:49 PM
No solution, but maybe I'm encountering the same problem.
When you start OpenSCAD up, do you get a yellowish preview pane with
axes, or do you get an empty white box?
Maybe 1/3 of the time I end up with an OpenGL warning and an empty white
box.  If I try again a few times it'll usually usually eventually
succeed.  This may be correlated to which of my two monitors (with
different display adapters) the window initially comes up on, but I
haven't found anything that reliably controls whether or not it works.
Once it's up and working it continues to work on either monitor.
No solution, but maybe I'm encountering the same problem. When you start OpenSCAD up, do you get a yellowish preview pane with axes, or do you get an empty white box? Maybe 1/3 of the time I end up with an OpenGL warning and an empty white box.  If I try again a few times it'll usually usually eventually succeed.  This may be correlated to which of my two monitors (with different display adapters) the window initially comes up on, but I haven't found anything that reliably controls whether or not it works.  Once it's up and working it continues to work on either monitor.
arnholm@arnholm.org
Wed, Jul 8, 2020 8:04 AM
I have the same problem after upgrading my Win7 computer to Win10. It is
not clear how to fix it. Windows claims all drivers are up to date. IT
seems to be a Win10 issue since the same computer did not see this
problem under Win7.
Craten Arnholm
On 2020-07-07 21:50, Joculus wrote: > But I get on startup this warning: > http://forum.openscad.org/file/t2875/Waring.jpg I have the same problem after upgrading my Win7 computer to Win10. It is not clear how to fix it. Windows claims all drivers are up to date. IT seems to be a Win10 issue since the same computer did not see this problem under Win7. Craten Arnholm
Joculus
Tue, Jul 28, 2020 12:23 PM
Thanks to JordanBrown and cacb for their pity. Now I know I'm not alone ...I
hoped get so much replies like "Polyhedron generation from two parallel
polygones?" Is there someone of the programmers who could tell me how QT(?)
gets the openGL version?Is there any possibility to override the version
checking? Any suggestion is very welcome. I love OpenSCAD, but it is very
hard to model something in partial blind flight.
Thanks to JordanBrown and cacb for their pity. Now I know I'm not alone ...I hoped get so much replies like "Polyhedron generation from two parallel polygones?" Is there someone of the programmers who could tell me how QT(?) gets the openGL version?Is there any possibility to override the version checking? Any suggestion is very welcome. I love OpenSCAD, but it is very hard to model something in partial blind flight. -- Sent from: http://forum.openscad.org/
Tue, Jul 28, 2020 2:07 PM
I don't know why it would fail to detect the driver but
according to https://doc.qt.io/qt-5/windows-requirements.html
you could try setting the environment variable:
QT_OPENGL=desktop
or try
QT_OPENGL=software
If that does not change anything, another option could be
adding the Mesa Software driver to the OpenSCAD folder:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows#OpenGL_(Optional)
While switching to software rendering might slow down
things a little bit, it should not have a huge impact as
OpenSCAD does not make much use of GPU side rendering
currently.
I don't know why it would fail to detect the driver but according to https://doc.qt.io/qt-5/windows-requirements.html you could try setting the environment variable: QT_OPENGL=desktop or try QT_OPENGL=software If that does not change anything, another option could be adding the Mesa Software driver to the OpenSCAD folder: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows#OpenGL_(Optional) While switching to software rendering might slow down things a little bit, it should not have a huge impact as OpenSCAD does not make much use of GPU side rendering currently. ciao, Torsten.
Joculus
Wed, Jul 29, 2020 9:37 PM
Thank you Torsten!
Your last hint was the solution. Setting the environment variable QT_OPENGL
made no difference but putting the Mesa OpenGL32.dll into OpenSCAD dir
worked. First I had some problems finding the dll for Win 64. At the end I
found the dll created by Federico Dossena. This works well with the
"goldfeather algorithm" checked. Without this the preview had some errors.
Now everything is displayed perfectly and the speed is very high. I am happy
to get rid of the "%" and "#" before the most of the lines...
Thank you and all the others for the perfect support.
Thank you Torsten! Your last hint was the solution. Setting the environment variable QT_OPENGL made no difference but putting the Mesa OpenGL32.dll into OpenSCAD dir worked. First I had some problems finding the dll for Win 64. At the end I found the dll created by Federico Dossena. This works well with the "goldfeather algorithm" checked. Without this the preview had some errors. Now everything is displayed perfectly and the speed is very high. I am happy to get rid of the "%" and "#" before the most of the lines... Thank you and all the others for the perfect support. -- Sent from: http://forum.openscad.org/
