On 11/5/2024 2:02 PM, Todd Allen via Discuss wrote:
Of these options
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_an_external_Editor_with_OpenSCAD
any thoughts for what I should try first or ones to be avoided? Any
good options not in that list?
Somewhat OT, but in looking at that page I see that it says that an
external editor allows you to better use a multi-monitor configuration,
putting the 3D view on one monitor while putting the editor and whatnot
on the other monitor. That advice is at best dated; undocking the
editor and other panes to separate windows lets you do the same with the
built-in editor. I removed those bits from the page.
I'm using VIM since I'm used to edit all my programs and text files with
this editor. I adapted the openscad code a little so when opening a file
from openscad it automatically opens the file in VIM. VIM has syntax
coloring code for openscad. Works pretty good.
Met vriendelijke groet,
Matthieu Hendriks
David Phillip Oster via Discuss schreef op 2024-11-05 23:09:
I use Xcode as my external editor for OpenSCAD, since I am already
using it for most of my other work.
On Tue, Nov 5, 2024 at 2:02 PM Todd Allen via Discuss
Of these options
On Tue, Nov 05, 2024 at 04:28:09PM -0600, Todd Allen via Discuss wrote:
I'm most interested in hearing about the integration and workflow with
OpenSCAD when using these external tools. For instance if one maintains
projects or sessions in an external editor with a large number of .scad
files what are the processes for preview, rendering, jumping to errors,
etc.?
I use Emacs for that. For each .scad I open a new instance of
openscad. I've set openscad to auto-preview. So I get error messages
in the openscad window the moment I hit "save". I then use goto-line
to find the offending error line. Yes I have to type the line number
manually.
This "works-for-me".
On Tue, Nov 5, 2024 at 4:09 PM David Phillip Oster <
davidphilliposter@gmail.com> wrote:
I use Xcode as my external editor for OpenSCAD, since I am already using
On Tue, Nov 5, 2024 at 2:02 PM Todd Allen via Discuss <
Of these options
any thoughts for what I should try first or ones to be avoided? Any good
** 'a' for accelleration.
I, also, would suggest trying Visual Studio Code with the Leathong
extension. It's not perfect, but it is quite helpful to me.
I tried and have continued using Kate which also supports LSP capabilities
via the Leathong server. I haven't yet tried VSCode and went with Kate
first because it has an .appimage distribution which is my preferred choice
for applications as I like to keep my work and work environment on a server
and access it from multiple computers without needing to install
applications on every computer. I have been satisfied with Kate providing
the main features I was looking for, especially named sessions which
maintain groups of opened files and the current position in each file with
split window editing of two or more files simultaneously. Kate has an
external commands plugin which allows me to define commands for multiple
versions of OpenSCAD such as the latest daily and stable versions each
bound to a single keystroke shortcut. I make a separate file to produce a
view of each part and assembly I might repeatedly look at within a project
and while editing I can open a preview or produce a rendering of any of
them with a keystroke or two. Less important to me but now nice to have
are features such as configurable formatting and color syntax highlighting
schemes/themes and the LSP features to chase definitions, references,
documentation, etc. In summary I'm glad I took a bit of time to look at
external editors and pleased to find integration with OpenSCAD exceeding my
expectations.
On Tue, Nov 5, 2024 at 5:45 PM Leonard Martin Struttmann via Discuss <
Len
On Tue, Nov 5, 2024 at 5:26 PM Todd Allen via Discuss <
Do any external tools communicate with OpenSCAD to open files, start a
render or interpret console output?
On Tue, Nov 5, 2024, 5:03 PM nop head via Discuss <
If you have a project that includes lots of other SCAD files then it
will generate a new preview if any of them change. If you want a render you
have to hit F6 in OpenSCAD.
On Tue, 5 Nov 2024 at 22:56, Harvey white via Discuss <
With Notepad++ you get no error feedback, but do get syntax recognition.
Typical workflow is to start the project (establish the file) in
OpenSCAD, then open that file in Notepad++. Make changes to the source
file in Notepad++, then save. That updates the screen. If you have
OpenSCAD editor open at the same time, it should show you syntax errors
and debugging information.
The advantage of Notepad++ is that you get color syntax highlighting,
and a wider selection of completion options, although they are not
linked to OpenSCAD but rather what you've typed already.
If you want, you can link one version of OpenSCAD to each source file.
Harvey
with
maintains projects or sessions in an external editor with a large
number of .scad files what are the processes for preview, rendering,
jumping to errors, etc.?
Of these options
avoided? Any good options not in that list?
