Intersection with only one argument returns that argument. Previously a
second argument guarded by a false if was ignored but with the latest
snapshot it seems to be counted as and empty argument giving an empty
result.
cube();
if(false)
sphere();
I.e. this gives a cube with the last release but the latest snapshot gives
nothing. Again this has broken my library as I made use of it. For example
this code:
module shape()
hull() {
circle(boss_r);
translate([boss_r + extension - eps, 0])
square([eps, 2 * boss_r], center = true);
if(corner_r)
translate([boss_r + extension - corner_r, 0])
rotate(-45)
quadrant(w = 100, r = corner_r - eps, center =
true);
Now has to be written like this:
module shape() {
module _shape()
hull() {
circle(boss_r);
if(corner_r)
_shape();
rotate(-45)
true);
else
_shape();
Again is this an intentional change? Should a false if be treated as
nothing at all or an empty object?
I do this a lot with difference but that still works because no second
argument is the same as an empty second argument with difference.
treated as nothing at all or an empty object?
So that's probably due to the fix for
https://github.com/openscad/openscad/issues/3312
I'm not sure there's a way to fix the bug and also keep the
behavior with if(false).
I think cube(0) and a non-overlapping intersection or any other csg
operation that results in an empty object is different from a false
if, which is no object at all.
other csg operation that results in an empty object is
different from a false if, which is no object at all.
Right, it sounds sensible that if(false) would remove the
object completely. I guess we have to see if that would
affect anything where the if is used as first part of a
difference().
Is intersection not a logical AND operation? So what should you expect
if you say 1 AND 0 ?
If the second operand is empty geometry I expect an empty result.
If the second object is missing I expect the first object, as it has always
done, just as difference() with one child. Intersection still does that.
What has changed is if(false) now produces an empty() node equivalent to
empty geometry, whereas before it returned an empty group() node, which
must have been ignored by intersection().
should you expect if you say 1 AND 0 ?
That's not the point, the question is if this:
cube();
if (false) sphere();
is equal to
cube();
=> result expectation is a cube
or
cube();
empty-geometry
=> result expectation is empty geometry
cube();
is equal to
cube();
or
cube();
empty-geometry
All I am pointing out is that the "old" result has been wrong all along,
in spite of how many are used to it working that way. Something AND
nothing, no matter how you name "nothing", should always be nothing. Try
doing a VEN diagram...
regards,
Bill
to empty geometry, whereas before it returned an empty group() node,
which must have been ignored by intersection().
what is the significance between a "group()" node that is empty and an
"empty()" node that is empty?
One may also ask what is the significance between a "group()" that
contains something and a "union()" that contains something?
Carsten Arholm
Yes an intersection between two operands works like that but what about an
intersection with one operand? There is no such thing in maths but the
OpenSCAD has had the convention of being a NOP in that case and so is union
and difference.
cube();
is equal to
cube();
or
cube();
empty-geometry
regards,
Bill
