Ray West
Mon, Nov 1, 2021 12:24 PM
I'm trying to generate a cylinder, with the radius throughout its length
varying as a sine wave. Here is the profile
module profile(){
for(i=[0:7212.5])
translate([i5,0,0])
square([6,(cos(i*5)31)+31+(20100)]);
I need to rotate the section around the x-axis to generate the cylinder.
it appears that rotate_extrude is limited to the z axis, and a 2d
drawing is limited to the x/y plane. Any solutions welcomed. From an
example, it seems that if I could generate a 2d polygon of the profile,
then that can be rotated into the y/z plane, and then it can be rotated,
but programmatically generating the polygon in openscad has me stumped.
I think there must be a better way than stacking a thousand or so 1mm
thick discs.
Best wishes,
Ray
module profile(){
for(i=[0:72*12.5])
translate([i*5,0,0])
square([6,(cos(i*5)*31)+31+(20*100)]);
thick discs.
Best wishes,
Ray
D
dpa
Mon, Nov 1, 2021 1:40 PM
rotate([0,90,0]) rotate_extrude(convexity=10) rotate (90) profile();
like this?
Am Mo., 1. Nov. 2021 um 13:24 Uhr schrieb Ray West raywest@raywest.com:
module profile(){
for(i=[0:7212.5])
translate([i5,0,0])
thick discs.
Best wishes,
Ray
like this?
Am Mo., 1. Nov. 2021 um 13:24 Uhr schrieb Ray West <raywest@raywest.com>:
> Hi,
> module profile(){
> for(i=[0:72*12.5])
> thick discs.
> Best wishes,
> Ray
Mon, Nov 1, 2021 1:42 PM
Is that what you want?
rotate_extrude(convexity=10) rotate(90) profile();
Note that 2d objects like squares and circles live in the plane XY. You are
allowed to rotate them in an axis other than z or translate them off the XY
plane and get a preview image. But that is misleading because render will
keep them in the XY plane despite the transforms. The rule of thumb is
never transform 2d objects off the XY plane. linear_extrude and
rotate_extrude operate on objects in the XY plane. After extrude you may
transform the shape as you want.
Em seg., 1 de nov. de 2021 às 13:24, Ray West raywest@raywest.com
escreveu:
module profile(){
for(i=[0:7212.5])
translate([i5,0,0])
thick discs.
Best wishes,
Ray
Em seg., 1 de nov. de 2021 às 13:24, Ray West <raywest@raywest.com>
escreveu:
> Hi,
> module profile(){
> for(i=[0:72*12.5])
> thick discs.
> Best wishes,
> Ray
Michael Möller
Mon, Nov 1, 2021 1:56 PM
This does not generate thousands of little squares or little disks:
Vector=[for( i = [0:7212.5]) [i5,(cos(i5)31)+31+(20100) ] ] ; // your
formula
Poly=[for(L=[[[0,200]], Vector, [[7212.5*5,200]]], a=L) a]; // add the
end points
polygon(Poly);//echo(Poly) ; // verify the flat shape
rotate_extrude() rotate(90) polygon(Poly) ; // and there it is ?
are allowed to rotate them in an axis other than z or translate them off
the XY plane and get a preview image. But that is misleading because render
will keep them in the XY plane despite the transforms. The rule of thumb is
escreveu:
module profile(){
for(i=[0:7212.5])
translate([i5,0,0])
thick discs.
Best wishes,
Ray
Vector=[for( i = [0:72*12.5]) [i*5,(cos(i*5)*31)+31+(20*100) ] ] ; // your
formula
Poly=[for(L=[[[0,200]], Vector, [[72*12.5*5,200]]], a=L) a]; // add the
end points
> escreveu:
>> Hi,
>> module profile(){
>> for(i=[0:72*12.5])
>> thick discs.
>> Best wishes,
>> Ray
Ray West
Mon, Nov 1, 2021 2:29 PM
Yes, exactly. I tried a single rotate rotate_extrude(convexity=10)
rotate ([0,90,0]) profile(); and it gives a <WARNING: Scaling a 2D
object with 0 - removing object>
I didn't realise it would know which axis to rotate with just the single
value, so never tried the two rotates.
Thanks
Thanks
D
dpa
Mon, Nov 1, 2021 2:39 PM
Well.. You can also use the "full" vector specification, but you need
to turn the 2D profile() by Z-axis.
rotate_extrude() rotate ([0,0,90]) profile();
which, admittedly, is a bit confusing, but it wokrs
Am Mo., 1. Nov. 2021 um 15:30 Uhr schrieb Ray West raywest@raywest.com:
Thanks
to turn the 2D profile() by *Z*-axis.
rotate_extrude() rotate (*[0,0,90]*) profile();
Am Mo., 1. Nov. 2021 um 15:30 Uhr schrieb Ray West <raywest@raywest.com>:
> Thanks
Mon, Nov 1, 2021 5:47 PM
your formula
the end points
I don't see why you offset the base +200 in Y.
The lists can be a bit simpler.
Simplest is probably to build the whole polygon in one shot:
Poly=[
[ 0, 0 ],
for( i = [0:72*12.5]) [i*5, (cos(i*5)*31)+31+(20*100) ],
[ 72*12.5*5, 0 ]
] ; // your formula
but if you want to maintain the pattern of generating the curve
separately, you can use concat:
Poly=concat([[72*12.5*5, 0], [0, 0]], Vector ); // add the end points
or you could use the "each" list comprehension operator:
Poly=[
[ 0, 0 ],
each Vector,
[ 72*12.5*5, 0 ]
] ; // your formula
But the first lesson, that I'm kind of surprised that nobody has
explicitly mentioned, is that when you're planning to do a
rotate_extrude, you need to design your 2D model with the intended
radius in +X and the intended Z in Y. I guess that you can put the
shape entirely in -X, but I wouldn't.
The sine wave should be drawn as x = f(y) to avoid the need for the
initial rotate.
Poly=[
[ 0, 0 ],
for( i = [0:72*12.5]) [ (cos(i*5)*31)+31+(20*100), i*5 ],
[ 0, 72*12.5*5 ]
] ; // your formula
rotate_extrude() polygon(Poly);
Note that I transposed the coordinates rather than rotating, so the
figure is in +X / +Y.
> your formula
> the end points
Poly=[
[ 0, 0 ],
[ 72*12.5*5, 0 ]
] ; // your formula
Poly=[
[ 0, 0 ],
each Vector,
[ 72*12.5*5, 0 ]
] ; // your formula
initial rotate.
Poly=[
[ 0, 0 ],
[ 0, 72*12.5*5 ]
] ; // your formula
Ray West
Mon, Nov 1, 2021 8:34 PM
Thanks. All done and dusted now. Printing as I type. The offset was to
show the sort of radius I was aiming for. I couldn't find out how to set
it up for programmatically generating the polygon, so thanks for the
explanation.
// your formula
the end points
Poly=[
[ 0, 0 ],
[ 72*12.5*5, 0 ]
] ; // your formula
Poly=[
[ 0, 0 ],
each Vector,
[ 72*12.5*5, 0 ]
] ; // your formula
initial rotate.
Poly=[
[ 0, 0 ],
[ 0, 72*12.5*5 ]
] ; // your formula
explanation.
>> // your formula
>> the end points
> Poly=[
> [ 0, 0 ],
> [ 72*12.5*5, 0 ]
> ] ; // your formula
> Poly=[
> [ 0, 0 ],
> each Vector,
> [ 72*12.5*5, 0 ]
> ] ; // your formula
> initial rotate.
> Poly=[
> [ 0, 0 ],
> [ 0, 72*12.5*5 ]
> ] ; // your formula
