Crash intersection() not
Thu, Oct 27, 2016 11:40 PM
I have a vague feeling this may have been reported?
http://forum.openscad.org/file/n18815/crash_intersection.jpg
!intersection() {
#translate([-29+60+35,0,50])
cube([96,100,37.5],true);
main();
} // t
module main() cube(5);
Crashes when you add a '#' before main() - inside the intersection.
Note the two do NOT intersect. Change the cube to 50, so they intersect, no
longer crashes.
Note below is what originally got the error using 2016.01.26 - may give
further clues?
http://forum.openscad.org/file/n18815/MinGW_Runtime_Assertion.jpg
Repeatable.
Both Retry & Ignore crash.
Occurred after I added the second # ie to main(), in the yellow highlight.
View this message in context: http://forum.openscad.org/Crash-intersection-not-tp18815.html
I have a vague feeling this may have been reported? <http://forum.openscad.org/file/n18815/crash_intersection.jpg> !intersection() { #translate([-29+60+35,0,50]) cube([96,100,37.5],true); main(); } // t module main() cube(5); Crashes when you add a '#' before main() - inside the intersection. Note the two do NOT intersect. Change the cube to 50, so they intersect, no longer crashes. Note below is what originally got the error using 2016.01.26 - may give further clues? <http://forum.openscad.org/file/n18815/MinGW_Runtime_Assertion.jpg> Repeatable. Both Retry & Ignore crash. Occurred after I added the second # ie to main(), in the yellow highlight. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Crash-intersection-not-tp18815.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Oct 27, 2016 11:46 PM
2015.03-2 doesn't crash.
View this message in context: http://forum.openscad.org/Crash-intersection-not-tp18815p18816.html
2015.03-2 doesn't crash. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Crash-intersection-not-tp18815p18816.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Fri, Oct 28, 2016 1:35 AM
longer crashes.
Thanks for the report!
I’ve opened a new issue: https://github.com/openscad/openscad/issues/1833
> On Oct 27, 2016, at 19:40, MichaelAtOz <oz.at.michael@gmail.com> wrote: > > I have a vague feeling this may have been reported? > Crashes when you add a '#' before main() - inside the intersection. > Note the two do NOT intersect. Change the cube to 50, so they intersect, no > longer crashes. > Thanks for the report! I’ve opened a new issue: https://github.com/openscad/openscad/issues/1833 -Marius
JL
Jean-Paul Louis
Sat, Oct 29, 2016 1:16 AM
It crashes on my MacBook with the latest OS X build
Process:              OpenSCAD [9192]
Path:                  /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD
Identifier:            org.openscad.OpenSCAD
Version:              2016.10 (2016.10.16)
Code Type:            X86-64 (Native)
Parent Process:        ??? [1]
Responsible:          OpenSCAD [9192]
User ID:              501
Date/Time:            2016-10-28 21:13:54.370 -0400
OS Version:            Mac OS X 10.12.1 (16B2555)
Report Version:        12
Anonymous UUID:        F083C7E2-3CB1-C884-21A3-0E601BD2B66D
Time Awake Since Boot: 19000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:      KERN_INVALID_ADDRESS at 0x0000000000000038
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:  exc handler [0]
VM Regions Near 0x38:
__TEXT                000000010234d000-0000000102878000 [ 5292K] r-x/rwx SM=COW  /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0  org.openscad.OpenSCAD        0x00000001023c4ea4 CSGTreeEvaluator::applyToChildren(State&, AbstractNode const&, OpenSCADOperator) + 1860
1  org.openscad.OpenSCAD        0x00000001023c5cad non-virtual thunk to CSGTreeEvaluator::visit(State&, CsgOpNode const&) + 45
2  org.openscad.OpenSCAD        0x00000001024144f5 NodeVisitor::traverse(AbstractNode const&, State const&) + 325
3  org.openscad.OpenSCAD        0x00000001023c442c CSGTreeEvaluator::buildCSGTree(AbstractNode const&) + 44
4  org.openscad.OpenSCAD        0x000000010250c23c MainWindow::compileCSG(bool) + 732
5  org.openscad.OpenSCAD        0x000000010251223f MainWindow::csgRender() + 47
6  org.qt-project.QtCore        0x00000001045cd504 QMetaMethod::invoke(QObject*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) const + 1348
7  org.qt-project.QtCore        0x00000001045cca44 QMetaObject::invokeMethod(QObject*, char const*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) + 2196
8  org.openscad.OpenSCAD        0x000000010250a5b7 MainWindow::compileDone(bool) + 343
9  org.openscad.OpenSCAD        0x00000001025094ae MainWindow::compile(bool, bool) + 1134
10  org.openscad.OpenSCAD        0x0000000102508cbc MainWindow::actionRenderPreview() + 172
11  org.qt-project.QtCore        0x00000001045f4923 QMetaObject::activate(QObject*, int, int, void**) + 883
12  org.qt-project.QtWidgets      0x00000001037c4e4f QAction::activate(QAction::ActionEvent) + 303
13  org.qt-project.QtWidgets      0x00000001038bc648 QAbstractButtonPrivate::click() + 88
14  org.qt-project.QtWidgets      0x00000001038bd7ae QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 270
15  org.qt-project.QtWidgets      0x000000010399293f QToolButton::mouseReleaseEvent(QMouseEvent*) + 15
16  org.qt-project.QtWidgets      0x000000010380dcc1 QWidget::event(QEvent*) + 1681
17  org.qt-project.QtWidgets      0x00000001038bd4ff QAbstractButton::event(QEvent*) + 175
18  org.qt-project.QtWidgets      0x0000000103992ef3 QToolButton::event(QEvent*) + 323
19  org.qt-project.QtWidgets      0x00000001037cdedd QApplicationPrivate::notify_helper(QObject*, QEvent*) + 269
20  org.qt-project.QtWidgets      0x00000001037d15f0 QApplication::notify(QObject*, QEvent*) + 9440
21  org.openscad.OpenSCAD        0x000000010252e5a2 OpenSCADApp::notify(QObject*, QEvent*) + 18
22  org.qt-project.QtCore        0x00000001045c3aa4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164
23  org.qt-project.QtWidgets      0x00000001037ce847 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 871
24  org.qt-project.QtWidgets      0x000000010382e52b QWidgetWindow::handleMouseEvent(QMouseEvent*) + 1387
25  org.qt-project.QtWidgets      0x000000010382d5bf QWidgetWindow::event(QEvent*) + 175
26  org.qt-project.QtWidgets      0x00000001037cdedd QApplicationPrivate::notify_helper(QObject*, QEvent*) + 269
27  org.qt-project.QtWidgets      0x00000001037d0822 QApplication::notify(QObject*, QEvent*) + 5906
28  org.openscad.OpenSCAD        0x000000010252e5a2 OpenSCADApp::notify(QObject*, QEvent*) + 18
29  org.qt-project.QtCore        0x00000001045c3aa4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164
30  org.qt-project.QtGui          0x0000000103ec6e0a QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 2794
31  org.qt-project.QtGui          0x0000000103eb05eb QWindowSystemInterface::sendWindowSystemEvents(QFlagsQEventLoop::ProcessEventsFlag) + 155
32  libqcocoa.dylib              0x0000000106410631 QCocoaEventDispatcherPrivate::postedEventsSourceCallback(void*) + 33
33  com.apple.CoreFoundation      0x00007fffb78784b1 CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION + 17
34  com.apple.CoreFoundation      0x00007fffb785961d __CFRunLoopDoSources0 + 557
35  com.apple.CoreFoundation      0x00007fffb7858b16 __CFRunLoopRun + 934
36  com.apple.CoreFoundation      0x00007fffb7858514 CFRunLoopRunSpecific + 420
37  com.apple.HIToolbox          0x00007fffb6df5fbc RunCurrentEventLoopInMode + 240
38  com.apple.HIToolbox          0x00007fffb6df5cf9 ReceiveNextEventCommon + 184
39  com.apple.HIToolbox          0x00007fffb6df5c26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
40  com.apple.AppKit              0x00007fffb54dfb79 _DPSNextEvent + 1093
41  com.apple.AppKit              0x00007fffb5bf51c3 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1637
42  com.apple.AppKit              0x00007fffb54d453d -[NSApplication run] + 926
43  libqcocoa.dylib              0x000000010640f53f QCocoaEventDispatcher::processEvents(QFlagsQEventLoop::ProcessEventsFlag) + 2191
44  org.qt-project.QtCore        0x00000001045bfeb1 QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 401
45  org.qt-project.QtCore        0x00000001045c4115 QCoreApplication::exec() + 341
46  org.openscad.OpenSCAD        0x00000001024f0b60 gui(std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >&, boost::filesystem::path const&, int, char**) + 2816
47  org.openscad.OpenSCAD        0x00000001024f386c main + 9308
48  libdyld.dylib                0x00007fffcc923255 start + 1
Thread 1:: OGL Profiler
0  libsystem_kernel.dylib        0x00007fffcca4a41a mach_msg_trap + 10
1  libsystem_kernel.dylib        0x00007fffcca49867 mach_msg + 55
2  com.apple.opengl              0x00007fffbc642d39 glcDebugListener + 302
3  libsystem_pthread.dylib      0x00007fffccb3aaab _pthread_body + 180
4  libsystem_pthread.dylib      0x00007fffccb3a9f7 _pthread_start + 286
5  libsystem_pthread.dylib      0x00007fffccb3a221 thread_start + 13
Thread 2:
0  libsystem_kernel.dylib        0x00007fffcca524e6 __workq_kernreturn + 10
1  libsystem_pthread.dylib      0x00007fffccb3a622 _pthread_wqthread + 1023
2  libsystem_pthread.dylib      0x00007fffccb3a211 start_wqthread + 13
Thread 3:
1  libsystem_pthread.dylib      0x00007fffccb3a7b5 _pthread_wqthread + 1426
Thread 4:: com.apple.NSEventThread
2  com.apple.CoreFoundation      0x00007fffb7859834 __CFRunLoopServiceMachPort + 212
3  com.apple.CoreFoundation      0x00007fffb7858cc1 __CFRunLoopRun + 1361
4  com.apple.CoreFoundation      0x00007fffb7858514 CFRunLoopRunSpecific + 420
5  com.apple.AppKit              0x00007fffb562c5a0 _NSEventThread + 205
6  libsystem_pthread.dylib      0x00007fffccb3aaab _pthread_body + 180
7  libsystem_pthread.dylib      0x00007fffccb3a9f7 _pthread_start + 286
8  libsystem_pthread.dylib      0x00007fffccb3a221 thread_start + 13
Thread 5:: com.apple.NSURLConnectionLoader
5  com.apple.CFNetwork          0x00007fffb6a29334 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6  com.apple.Foundation          0x00007fffb926630d NSThread__start + 1243
7  libsystem_pthread.dylib      0x00007fffccb3aaab _pthread_body + 180
8  libsystem_pthread.dylib      0x00007fffccb3a9f7 _pthread_start + 286
9  libsystem_pthread.dylib      0x00007fffccb3a221 thread_start + 13
Thread 6:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00006080001eb600  rbx: 0x00006080002248c0  rcx: 0x00006080001eb600  rdx: 0x00007fff5d8ade10
rdi: 0x0000608000423360  rsi: 0x0000000000000001  rbp: 0x00007fff5d8adec0  rsp: 0x00007fff5d8add60
r8: 0x0000000000000040  r9: 0x0000000000000000  r10: 0x00006080002655d0  r11: 0x0000000000000000
r12: 0x0000608000260928  r13: 0x00006080001e9d00  r14: 0x00006080004230a0  r15: 0x0000000000000000
rip: 0x00000001023c4ea4  rfl: 0x0000000000010202  cr2: 0x0000000000000038
Logical CPU:    2
Error Code:      0x00000006
Trap Number:    14
Binary Images:
0x10234d000 -        0x102877fff +org.openscad.OpenSCAD (2016.10 - 2016.10.16) <798865C6-FC78-315D-A258-3697BB28FD64> /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD
0x102a90000 -        0x102aaffff +libCGAL.dylib (0) <BB161E1E-1A02-3927-BD5C-E6CFC9DCFF65> /Applications/OpenSCAD.app/Contents/Frameworks/libCGAL.dylib
0x102ac0000 -        0x102b58ff7 +libmpfr.dylib (0) <84EA860F-1DB9-3CCD-90DB-4EA0F6D7D1AE> /Applications/OpenSCAD.app/Contents/Frameworks/libmpfr.dylib
0x102b6a000 -        0x102c14fff +libgmp.dylib (0) <AD00EEE9-9A5E-37CF-AC55-BEFC5095A552> /Applications/OpenSCAD.app/Contents/Frameworks/libgmp.dylib
0x102c22000 -        0x102c2fff7 +libopencsg.dylib (0) <7157C249-C096-3C92-9DB8-B48595685754> /Applications/OpenSCAD.app/Contents/Frameworks/libopencsg.dylib
0x102c3f000 -        0x102c6cfff +libGLEW.dylib (0) <B5752FBE-04A0-3AEE-99E2-0CFCC8215EAB> /Applications/OpenSCAD.app/Contents/Frameworks/libGLEW.dylib
0x102ca1000 -        0x102cb2fff +libboost_thread.dylib (0) <1BDE8682-7E38-376A-8311-E4F1A30647A7> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_thread.dylib
0x102cc6000 -        0x102d04ff7 +libboost_program_options.dylib (0) <30F50F11-56B3-30A2-A3D0-47FAE842DEFE> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_program_options.dylib
0x102d39000 -        0x102d48fff +libboost_filesystem.dylib (0) <74F720BD-7D42-3CC3-B46C-004C6D4F74E7> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_filesystem.dylib
0x102d55000 -        0x102d57fff +libboost_system.dylib (0) <9F8CAB71-D38E-3DDE-9C2A-2BE5902D2949> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_system.dylib
0x102d5b000 -        0x102dfffff +libboost_regex.dylib (0) <ABE85842-FE2B-3BE8-97CF-C6F336F00B4B> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_regex.dylib
0x102e57000 -        0x102fd5ff7 +libglib-2.0.dylib (0) <75CB4D06-4CBE-3A31-8E62-98A5487ACA59> /Applications/OpenSCAD.app/Contents/Frameworks/libglib-2.0.dylib
0x103001000 -        0x10300fff7 +libintl.dylib (0) <8B0375AA-AC19-3568-92E0-7FA2697945BB> /Applications/OpenSCAD.app/Contents/Frameworks/libintl.dylib
0x103014000 -        0x1031daff7 +libxml2.dylib (0) <CF441BD1-044A-3FAC-A582-D881AC295DE0> /Applications/OpenSCAD.app/Contents/Frameworks/libxml2.dylib
0x103217000 -        0x103252fff +org.sparkle-project.Sparkle (1.13.1 git-2afc553 - 1.13.1) <40414915-A48C-3DBB-AACB-5C20BAAE6DA6> /Applications/OpenSCAD.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x103289000 -        0x103363ff7 +libharfbuzz.dylib (0) <952F418F-F934-3CDD-A327-CA8FC7FACE35> /Applications/OpenSCAD.app/Contents/Frameworks/libharfbuzz.dylib
0x1033ab000 -        0x103481fff +libfreetype.dylib (0) <E585D750-7702-390E-84B0-E938F545A7DC> /Applications/OpenSCAD.app/Contents/Frameworks/libfreetype.dylib
0x1034a3000 -        0x1034effff +libfontconfig.dylib (0) <7C3077D7-52E7-3C5D-BDA9-D762A31D30E2> /Applications/OpenSCAD.app/Contents/Frameworks/libfontconfig.dylib
0x103502000 -        0x1036eaff7 +libqscintilla2.dylib (0) <B53204B6-AEFD-3C53-9A6F-D597328D8278> /Applications/OpenSCAD.app/Contents/Frameworks/libqscintilla2.dylib
0x103761000 -        0x103794ff7 +org.qt-project.QtPrintSupport (5.7 - 5.7.0) <67BB0DB0-88B2-3802-92D5-7B326C90AFB0> /Applications/OpenSCAD.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
0x1037bc000 -        0x103cb5ff7 +org.qt-project.QtWidgets (5.7 - 5.7.0) <9029D91F-7F7E-3DE0-BD66-FC91DD8112C3> /Applications/OpenSCAD.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x103e9f000 -        0x10429fff7 +org.qt-project.QtGui (5.7 - 5.7.0) <65053079-A2E1-3D59-AE88-BEB242E05C97> /Applications/OpenSCAD.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
0x1043de000 -        0x1048f2ff7 +org.qt-project.QtCore (5.7 - 5.7.0) <91296610-5A00-30F7-9663-DDF7738C31FF> /Applications/OpenSCAD.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x104a0e000 -        0x104a17ff7 +org.qt-project.QtMacExtras (5.7 - 5.7.0) <8B3C4F7B-C98D-3A29-9858-DAF34F58768B> /Applications/OpenSCAD.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
0x104a1f000 -        0x104a23ff7 +org.qt-project.QtConcurrent (5.7 - 5.7.0) <AB461D07-E24C-3894-9E0C-DC3B8FCAFCC4> /Applications/OpenSCAD.app/Contents/Frameworks/QtConcurrent.framework/Versions/5/QtConcurrent
0x104a29000 -        0x104a2dffb  com.apple.agl (3.3.1 - AGL-3.3.1) <0B0E6527-C8E2-3162-BED1-DC2DD8DD2F95> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x104a38000 -        0x104a3aff7 +libboost_chrono.dylib (0) <5CEAEB01-4A14-3E20-998E-31877704C25A> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_chrono.dylib
0x1063e9000 -        0x10655afff +libqcocoa.dylib (0) <56AF80F9-6AAF-3A4E-97F4-109614288A77> /Applications/OpenSCAD.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x1065d0000 -        0x106637ff7 +org.qt-project.QtDBus (5.7 - 5.7.0) <A3B1C34A-7EBC-36D6-B053-9CEE4A3D14CE> /Applications/OpenSCAD.app/Contents/Frameworks/QtDBus.framework/Versions/5/QtDBus
0x106666000 -        0x10667dffb  libCGInterfaces.dylib (331.5) <5796C169-B449-33C8-B471-BD711BDCB898> /System/Library/Frameworks/Accelerate.framework/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x109013000 -        0x109017ff7 +libqtga.dylib (0) <576CF0ED-6C64-32C7-99BB-6468A1080D9F> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqtga.dylib
0x109477000 -        0x109481ff7 +libqdds.dylib (0) <C030C6EC-3611-3A8D-894F-071C96FB3031> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqdds.dylib
0x10948c000 -        0x109632fff  GLEngine (12.4.5) <A4E7F3A2-5025-3C7D-AAF5-6187601A8C00> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x109670000 -        0x1097e6ffb  libGLProgrammability.dylib (12.4.5) <6F6A4BA1-2DB2-3D22-9BEE-E45F6455BAE1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x109a9e000 -        0x10a00aff7  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.20.23 - 10.2.0) <937303A6-4DB6-324C-A0F9-4CA3EAA19830> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x10a21c000 -        0x10a246ffb  GLRendererFloat (12.4.5) <9C53418B-2B6F-3B16-AA50-EF8CD632B05F> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x10a264000 -        0x10a2dbff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.20.23 - 10.2.0) <2657569C-0E68-3078-97E4-0CCBE7052D14> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
0x10a3f3000 -        0x10a3faff7 +libqgif.dylib (0) <551D6575-9920-346E-BE76-3A835199CC08> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqgif.dylib
0x10a3ff000 -        0x10a403ff7 +libqwbmp.dylib (0) <9F5B0F44-0AF1-300C-88D2-7C2EE2C8F309> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqwbmp.dylib
0x10a788000 -        0x10a790fff +libqicns.dylib (0) <72F60B35-25FC-3478-A86D-6CC786A508C2> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqicns.dylib
0x10a796000 -        0x10a79cfff +libqico.dylib (0) <159201A7-AB7A-3174-A3F7-E3954A138C8F> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqico.dylib
0x10a7a1000 -        0x10a7e0fff +libqjpeg.dylib (0) <38A4D43B-CDF7-3867-95B6-C51AFCAFB512> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqjpeg.dylib
0x10a7ea000 -        0x10a7f0fff +libqmacjp2.dylib (0) <B2099559-AF1B-3680-B8FC-D0B08141A8ED> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqmacjp2.dylib
0x10a7f5000 -        0x10a859fff +libqtiff.dylib (0) <F086BC43-2567-3B23-B0FA-D458999803BB> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqtiff.dylib
0x10a867000 -        0x10a8e1fff +libqwebp.dylib (0) <E401A034-2209-3102-BA10-9E7F67BEA588> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqwebp.dylib
0x10ec86000 -        0x10ec8afff  libFontRegistryUI.dylib (196.2) <95FA58A8-CB9A-33A7-B2E9-B006404AFA2B> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x10ed6b000 -        0x10eda8287  dyld (421.2) <13A9466A-2576-3ABB-AD9D-D6BC16439B8F> /usr/lib/dyld
0x7fffb266b000 -    0x7fffb29a3fff  com.apple.RawCamera.bundle (7.00 - 874) <99AF1865-BCDD-3313-85BF-E246745201F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fffb2f9b000 -    0x7fffb37e7fff  com.apple.GeForceGLDriver (10.12.68 - 10.1.2) <576CB6F0-3BF6-34F6-9455-42C4A8B97004> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fffb37e8000 -    0x7fffb40b6ff3  libclh.dylib (4.0.3 - 4.0.3) <AFF52D6D-01CB-3695-8815-2BE30BCCBB77> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x7fffb40b7000 -    0x7fffb41c7ff7  com.apple.GeForceMTLDriver (10.12.68 - 10.1.2) <23ED1BB3-20F2-35C1-9A23-4623FDCD108A> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
0x7fffb44bf000 -    0x7fffb44bffff  com.apple.Accelerate (1.11 - Accelerate 1.11) <97EF9FB3-581F-3F19-84D0-E9262559A454> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fffb44d8000 -    0x7fffb49f1feb  com.apple.vImage (8.1 - ???) <A5DBF800-F768-3A61-8575-9B45FC32FEAB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffb49f2000 -    0x7fffb4b62ff3  libBLAS.dylib (1185) <C7E42BBE-2337-3AEF-9C45-A2F2CB1A5B3E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fffb4b63000 -    0x7fffb4b77ffb  libBNNS.dylib (14) <CFDEE88D-E002-347C-BC68-83099651585B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fffb4b78000 -    0x7fffb4f6efef  libLAPACK.dylib (1185) <2E8201CB-9A41-3D65-853E-841917FCE77B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fffb4f6f000 -    0x7fffb4f85fff  libLinearAlgebra.dylib (1185) <8CC29DE1-A231-3D5E-B5F1-DCC309036FE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fffb4f86000 -    0x7fffb4f8cfff  libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fffb4f8d000 -    0x7fffb4fa1ff7  libSparseBLAS.dylib (1185) <C35235B7-CFA6-39A7-BD6E-79F4D9CAFD36> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fffb4fa2000 -    0x7fffb5129fe7  libvDSP.dylib (600) <DF2860D3-1B2E-3DE0-8D8D-F567374398CB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fffb512a000 -    0x7fffb51dcffb  libvMisc.dylib (600) <5E006F98-FB5C-3AC4-B8B9-6D267B22AA72> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fffb51dd000 -    0x7fffb51ddfff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A395B521-8E54-30F2-B4FE-355D68900DAF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fffb5499000 -    0x7fffb6179ff3  com.apple.AppKit (6.9 - 1504.60) <5DA1E013-575C-34D5-A028-1639EB7B0040> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fffb618b000 -    0x7fffb618bfff  com.apple.ApplicationServices (48 - 48) <3E1395EA-C661-3318-9B87-9857BB81021B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fffb618c000 -    0x7fffb61faff7  com.apple.ApplicationServices.ATS (377 - 422.1) <FF4D9FCA-D799-3ED1-B5F8-3D81C29342D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fffb6294000 -    0x7fffb63c2ff7  libFontParser.dylib (194.2) <E29F233F-773A-3070-874A-83799BDF0B5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fffb63c3000 -    0x7fffb640dfff  libFontRegistry.dylib (196.2) <8AEE7F4E-60F0-33BB-99E4-5381EF1FEC6F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fffb646a000 -    0x7fffb649cfff  libTrueTypeScaler.dylib (194.2) <A8520109-5F65-3144-ABF7-E22B98A74287> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fffb6508000 -    0x7fffb65b2ff7  com.apple.ColorSync (4.12.0 - 502) <C86F8032-83DD-34EB-A4CB-87E96F25CF1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fffb65b3000 -    0x7fffb6603fff  com.apple.HIServices (1.22 - 590) <109A9893-313B-3467-9892-062F49D1FF0D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fffb6604000 -    0x7fffb6613ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fffb6614000 -    0x7fffb6661fff  com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fffb6662000 -    0x7fffb669dfff  com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fffb669e000 -    0x7fffb66a9ff7  com.apple.speech.synthesis.framework (6.0.15 - 6.0.15) <23EA6076-ECDF-3A50-81E7-3CE6451DC8C4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fffb66aa000 -    0x7fffb68b8ff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <BA73DBAD-A9D2-3BA7-BCDB-4790D6C8B460> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffb68b9000 -    0x7fffb68b9fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <C49668FF-2971-3E30-92BB-09E0720E74A5> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fffb6a22000 -    0x7fffb6da6ff7  com.apple.CFNetwork (807.1.3 - 807.1.3) <336BFAD9-1BAE-368E-8C48-B9F1CC251C67> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fffb6dc0000 -    0x7fffb6dc0fff  com.apple.Carbon (154 - 157) <AB71A31F-5B15-3BF5-8532-591EACD07B21> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fffb6dc1000 -    0x7fffb6dc4fff  com.apple.CommonPanels (1.2.6 - 98) <DDA2DF0B-86E7-34B6-B688-D7371DBC8A63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fffb6dc5000 -    0x7fffb70c9fff  com.apple.HIToolbox (2.1.1 - 856.6) <DAF74CE6-8B6B-3347-B299-FE860B517D38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fffb70ca000 -    0x7fffb70cdff7  com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fffb70ce000 -    0x7fffb70d3fff  com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fffb70d4000 -    0x7fffb716bff3  com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fffb716c000 -    0x7fffb7186fff  com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fffb7187000 -    0x7fffb7188ff3  com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fffb7189000 -    0x7fffb718bff7  com.apple.securityhi (9.0 - 55006) <FFB3F28C-B982-34EF-8510-8D6D10975404> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fffb718c000 -    0x7fffb7192ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fffb7272000 -    0x7fffb7272fff  com.apple.Cocoa (6.11 - 22) <5EEB0A26-F1C2-3D57-8441-52C0B80C2A6A> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fffb73a8000 -    0x7fffb7438ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <4082E8CC-568A-364A-9AF0-92F30F067D42> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fffb7439000 -    0x7fffb744cff3  com.apple.CoreBluetooth (1.0 - 1) <73A2B185-70E4-3535-A653-E1BC74584E55> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fffb744d000 -    0x7fffb7743ffb  com.apple.CoreData (120 - 752.2) <CCDCE896-CD36-3483-8E04-C513433BDDC5> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fffb7744000 -    0x7fffb77d0fff  com.apple.CoreDisplay (1.0 - 1) <ACA3B0B8-6900-3445-B202-C5C312421E44> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fffb77d1000 -    0x7fffb7c6aff7  com.apple.CoreFoundation (6.9 - 1348.15) <C25C6FB8-E934-349C-952C-26CF913BAC33> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fffb7c6b000 -    0x7fffb82e9fff  com.apple.CoreGraphics (2.0 - 1070.8) <3F5B7647-8006-3738-9A5A-1AD2DF570992> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fffb82ea000 -    0x7fffb8529ff7  com.apple.CoreImage (12.0.0 - 451) <4A79760F-FD23-3055-9569-5F038818993F> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fffb8684000 -    0x7fffb8684fff  com.apple.CoreServices (775.8.2 - 775.8.2) <FE7B0765-C41F-3FD9-8FD7-094466AAD0EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fffb8685000 -    0x7fffb86d6ff7  com.apple.AE (712 - 712) <0EF17D7E-6BA4-3555-BC38-9BD0CC5B82A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fffb86d7000 -    0x7fffb89b2fff  com.apple.CoreServices.CarbonCore (1159 - 1159) <837B7ECF-7E62-3210-988C-63D7AB4EAA88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fffb89b3000 -    0x7fffb89e6fff  com.apple.DictionaryServices (1.2 - 274) <302B8678-D057-3CF8-ACA7-7424A4A6A00A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fffb89e7000 -    0x7fffb89efffb  com.apple.CoreServices.FSEvents (1230 - 1230) <8836E7D0-844F-36F9-9601-B630BB82336B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fffb89f0000 -    0x7fffb8b5bfff  com.apple.LaunchServices (775.8.2 - 775.8.2) <7389590A-0E30-3294-B39C-F179D237F6C4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fffb8b5c000 -    0x7fffb8c0cffb  com.apple.Metadata (10.7.0 - 1075.17) <40F7E6E2-B58B-34E1-B97B-26756ECDB947> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fffb8c0d000 -    0x7fffb8c6cfff  com.apple.CoreServices.OSServices (775.8.2 - 775.8.2) <C949CF81-3510-3987-AEB4-9A961B738DA2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fffb8c6d000 -    0x7fffb8cddfff  com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fffb8cde000 -    0x7fffb8d24ff7  com.apple.coreservices.SharedFileList (38 - 38) <6C5A3FBB-9502-3725-AC3A-AE7B1528BBD4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fffb8db1000 -    0x7fffb8efcffb  com.apple.CoreText (352.0 - 544.1) <3229A726-303B-3B09-A014-8708C3BEF2D1> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fffb8efd000 -    0x7fffb8f32fff  com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fffb8f33000 -    0x7fffb8fa4ffb  com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <0425CA71-50D9-32DC-8693-CAE6CB3B799D> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fffb909f000 -    0x7fffb90a4fff  com.apple.DiskArbitration (2.7 - 2.7) <566D5C06-13E8-3638-B2EC-2B834D5F04F1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fffb9233000 -    0x7fffb95daffb  com.apple.Foundation (6.9 - 1349) <08A463B1-296E-3AC1-B8D3-01A75B0785A8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffb9606000 -    0x7fffb9637fff  com.apple.GSS (4.0 - 2.0) <4F3C9982-457C-3731-85DB-8CE1A72621B0> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fffb96eb000 -    0x7fffb978efff  com.apple.Bluetooth (5.0.1 - 5.0.1f7) <406E3901-F5D3-3996-84F7-32975EBE8F86> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fffb978f000 -    0x7fffb9824ff7  com.apple.framework.IOKit (2.0.2 - 1324.21.1) <EEFE7FF0-CE41-326A-A571-8AA0B2E89271> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fffb9825000 -    0x7fffb982bffb  com.apple.IOSurface (153.1 - 153.1) <849B0928-3D37-3977-9670-19979DB4EE4D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffb987f000 -    0x7fffb99d5fef  com.apple.ImageIO.framework (3.3.0 - 1570.2) <1133B1CE-C702-3D66-80F3-6BB40D5D1178> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fffb99d6000 -    0x7fffb99dafff  libGIF.dylib (1570.2) <4AE8D51B-E26A-3CB0-9D53-58112F94E3CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fffb99db000 -    0x7fffb9acbfff  libJP2.dylib (1570.2) <9F56888C-28CD-3ED0-B7BB-FFB775EF9DE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fffb9acc000 -    0x7fffb9aefffb  libJPEG.dylib (1570.2) <BE6386AF-E7F7-3C26-8B9E-7682DA38F496> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fffb9af0000 -    0x7fffb9b17ff7  libPng.dylib (1570.2) <2BC453BB-5E15-3031-AFAE-912025F2674A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fffb9b18000 -    0x7fffb9b1aff3  libRadiance.dylib (1570.2) <0F2C81F9-2D74-36A6-BCC0-2366E60410C7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fffb9b1b000 -    0x7fffb9b74ff3  libTIFF.dylib (1570.2) <897EB69A-1C96-3BC2-A458-A21652249E71> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fffb9c94000 -    0x7fffba735ff7  com.apple.JavaScriptCore (12602 - 12602.2.14.0.5) <A9839022-B3BE-38E2-8956-B5ED9BE145FD> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fffba736000 -    0x7fffba74fff7  com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fffbaf36000 -    0x7fffbaf8dff7  com.apple.Metal (85.85 - 85.85) <EF221C0E-9638-312B-9455-FF3C69180C45> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fffbb6a3000 -    0x7fffbb6abfff  com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffbb87f000 -    0x7fffbb887ff7  libcldcpuengine.dylib (2.8.4) <B43FD148-4550-3EB1-9971-F5EFC0456CCE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fffbba50000 -    0x7fffbba9eff3  com.apple.opencl (2.8.6 - 2.8.6) <819DE36A-893E-3100-8430-EEB9D7023672> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fffbba9f000 -    0x7fffbbab8ffb  com.apple.CFOpenDirectory (10.12 - 194) <BDD22B3E-4149-366A-A974-942280861DD4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fffbbab9000 -    0x7fffbbac4ff7  com.apple.OpenDirectory (10.12 - 194) <E1125140-E42C-369C-8DC8-D0935767B275> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fffbbac5000 -    0x7fffbbac7fff  libCVMSPluginSupport.dylib (12.4.5) <AF349AF5-ACC9-32C8-98BE-1DC9523156C5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fffbbac8000 -    0x7fffbbacbff7  libCoreFSCache.dylib (150) <991F00EB-B1B4-3351-9D83-C11E4920C360> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fffbbacc000 -    0x7fffbbacffff  libCoreVMClient.dylib (150) <06276E05-1FB2-3748-A236-1F66468A1755> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fffbbad0000 -    0x7fffbbad8ffb  libGFXShared.dylib (12.4.5) <67ABA30E-DA8A-336C-8137-11CD0D455741> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fffbbad9000 -    0x7fffbbae4fff  libGL.dylib (12.4.5) <920D2CC5-D64F-35A5-8C54-4A5731AEC552> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fffbbae5000 -    0x7fffbbb21ff7  libGLImage.dylib (12.4.5) <BEDFA6BF-0D9C-35ED-9DDD-FDBB1F6AAF95> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fffbbc99000 -    0x7fffbbcd9ff3  libGLU.dylib (12.4.5) <79C811DC-7904-3A7D-A983-B3E8D5439336> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fffbc641000 -    0x7fffbc64ffff  com.apple.opengl (12.4.5 - 12.4.5) <B33F90DE-B86B-38E3-BCDB-5C8B4952D84B> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fffbd361000 -    0x7fffbd55bfff  com.apple.QuartzCore (1.11 - 449.39.5) <B1815529-31B4-3FD0-923D-C3E964F844FF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fffbdac1000 -    0x7fffbdddcff7  com.apple.security (7.0 - 57740.20.22) <7E95D13A-0D52-36A9-A1C4-C21EE26AB2AB> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fffbdddd000 -    0x7fffbde53ff7  com.apple.securityfoundation (6.0 - 55132.20.1) <8DDEA805-C6F7-3EF9-990F-136617DB942D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fffbde7d000 -    0x7fffbde80ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <A88DACDF-71A9-3974-8D8D-DAA2B64F2CA5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fffbe205000 -    0x7fffbe276ff7  com.apple.SystemConfiguration (1.14 - 1.14) <013957CA-2708-31F0-845D-11E271C96B94> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fffbe623000 -    0x7fffbf857ff3  com.apple.WebCore (12602 - 12602.2.14.0.5) <AA349DE2-73A3-32B2-8A1D-FEFFC468B87D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fffbf858000 -    0x7fffbf9bdfff  com.apple.WebKitLegacy (12602 - 12602.2.14.0.7) <3D4BAC77-370A-3D55-AD1A-68D4C489DAF1> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fffbf9be000 -    0x7fffbfd29ff7  com.apple.WebKit (12602 - 12602.2.14.0.7) <847FBE4F-06E5-315F-80FA-A58180B74608> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fffc08b8000 -    0x7fffc08daffb  com.apple.framework.Apple80211 (12.0 - 1200.37) <25299C0F-7A30-3BAA-9945-DB1515F68A2C> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffc08db000 -    0x7fffc08eafdb  com.apple.AppleFSCompression (88 - 1.0) <D3A6F5F9-2132-34B5-933F-DF5D6733DE8B> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffc09d3000 -    0x7fffc0a5e97f  com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffc0e7a000 -    0x7fffc0ef8ff7  com.apple.backup.framework (1.8.1 - 1.8.1) <792B4983-DE9A-377D-8338-93719706D12F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffc1b16000 -    0x7fffc1b3dffb  com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffc2464000 -    0x7fffc246dffb  com.apple.CommonAuth (4.0 - 2.0) <D561391D-80B8-35F8-9EFF-1ACC89895E38> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffc2b89000 -    0x7fffc2b9aff7  com.apple.CoreEmoji (1.0 - 39.1) <54432658-8481-3F33-ADED-B60684311E11> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffc2e7c000 -    0x7fffc2eacff3  com.apple.CoreServicesInternal (276 - 276) <CCB21255-89DC-3F53-A6D6-8FA8F693C837> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffc3135000 -    0x7fffc31bffff  com.apple.CoreSymbolication (61050) <15C4AF49-2F85-3265-B53F-4925616C746E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffc31c0000 -    0x7fffc32fefcf  com.apple.coreui (2.1 - 426.9.1) <A7672B5D-9972-34B8-968A-188D422083AE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffc32ff000 -    0x7fffc339effb  com.apple.CoreUtils (4.3 - 430.70) <946F5089-9F8D-3595-8208-AD945B26D267> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffc33ee000 -    0x7fffc3453ff3  com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <8DAD3903-9A77-3E50-99C4-3C5708FB25B1> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffc3454000 -    0x7fffc3461fff  com.apple.CrashReporterSupport (10.12 - 816) <BF292E0C-6CDB-3149-8177-4EF5DD72D544> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffc3507000 -    0x7fffc357eff3  com.apple.datadetectorscore (7.0 - 539) <AA02538E-706E-305B-AABA-FA9A6F4C1B8C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffc35b8000 -    0x7fffc35f7fff  com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffc35f8000 -    0x7fffc3709fff  com.apple.desktopservices (1.11.1 - 1.11.1) <03518A59-79B1-3B16-B923-52D6EFF04ADB> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffc39d5000 -    0x7fffc3e06ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffc5141000 -    0x7fffc5141fff  libmetal_timestamp.dylib (600.0.48.26) <681B9F09-0673-3C38-B636-9D77D338D1AF> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffc514e000 -    0x7fffc5159ff3  libGPUSupportMercury.dylib (12.4.5) <A08E7321-32C4-3008-97C3-870B6AB1E63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fffc540b000 -    0x7fffc5427ff7  com.apple.GenerationalStorage (2.0 - 259) <43D40063-BD46-3008-8992-FF092B7C9A58> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffc5b1d000 -    0x7fffc5b93ffb  com.apple.Heimdal (4.0 - 2.0) <418DD668-7288-3D33-BAFE-959DB96D0351> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffc61a6000 -    0x7fffc61adffb  com.apple.IOAccelerator (288.15 - 288.15) <DE5BC493-2F4E-3388-A887-DA5AD7BAD3F4> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffc61af000 -    0x7fffc61c3ff3  com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffc61c4000 -    0x7fffc61e6ff7  com.apple.IconServices (74.1 - 74.1) <F7B83970-4A72-3186-BBB3-90FA86C3E263> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffc62c8000 -    0x7fffc647cfff  com.apple.LanguageModeling (1.0 - 123) <10152D7F-C7C0-34AA-A295-D712D16C76E6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffc6d28000 -    0x7fffc6da0fef  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <EDE6F9AA-B863-3936-BA54-177B769080FD> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffc6f22000 -    0x7fffc6f4afff  com.apple.MultitouchSupport.framework (368.4 - 368.4) <18778258-70B1-31BF-845D-1FACBF280108> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffc6ff7000 -    0x7fffc7001fff  com.apple.NetAuth (6.0 - 6.0) <D57D5888-0290-3295-A1C4-D673D4DCB497> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffc77dd000 -    0x7fffc781eff7  com.apple.PerformanceAnalysis (1.145 - 145) <73A73364-EFB6-3D0A-A7EA-7F924359B3C9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffc7eb0000 -    0x7fffc7ecafff  com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffc7ee4000 -    0x7fffc7f07ff3  com.apple.RemoteViewServices (2.0 - 124) <280DB828-4613-3DF8-ACBA-C91989B64347> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffc8bcb000 -    0x7fffc8c47fff  com.apple.Sharing (671.15 - 671.15) <37C29D52-CA6E-3E30-9CCF-F7B4A8DE6B9B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffc8c68000 -    0x7fffc8ebafef  com.apple.SkyLight (1.600.0 - 108.11) <5D0C258E-0816-3FF2-AA3C-A7B9F2DEC19C> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffc9094000 -    0x7fffc90a0fff  com.apple.SpeechRecognitionCore (3.0.15 - 3.0.15) <BE386037-4B61-341F-80E2-5D8B5B50C8BC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffc9784000 -    0x7fffc97f0ff3  com.apple.Symbolication (61080.2) <8AB6B520-E8DE-392F-8B86-52098D2A2BA2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffc9be7000 -    0x7fffc9bedff7  com.apple.TCC (1.0 - 1) <787E8FD8-21A7-39E6-87D4-6AD09156C5A0> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffc9c79000 -    0x7fffc9e3aff3  com.apple.TextureIO (1.35 - 1.35) <63D75E50-F3C2-3E8E-A49B-F53531C24C54> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffc9eae000 -    0x7fffc9eaffff  com.apple.TrustEvaluationAgent (2.0 - 28) <6793B664-C4FC-3CD4-B0E7-25B9933391AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fffc9eb0000 -    0x7fffca03fffb  com.apple.UIFoundation (1.0 - 489) <0CD14719-FC52-3AC5-87EF-775437927990> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffcb03e000 -    0x7fffcb040ffb  com.apple.loginsupport (1.0 - 1) <03B57D6F-C210-32BC-B384-5B0E95660283> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffcb095000 -    0x7fffcb0b0ff7  libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
0x7fffcb0b1000 -    0x7fffcb0bcfff  libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
0x7fffcb14e000 -    0x7fffcb14fff3  libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffcb150000 -    0x7fffcb363fff  libFosl_dynamic.dylib (16.37) <D5551823-1E3D-3BDE-968C-BF022EE4958D> /usr/lib/libFosl_dynamic.dylib
0x7fffcb387000 -    0x7fffcb387fff  libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
0x7fffcb388000 -    0x7fffcb38bffb  libScreenReader.dylib (477.10.20) <B48924E9-5301-3141-9D62-ADA2852D5BAA> /usr/lib/libScreenReader.dylib
0x7fffcb38c000 -    0x7fffcb38dff3  libSystem.B.dylib (1238) <CFC3669C-FB44-3A51-8815-1E84A168F3C5> /usr/lib/libSystem.B.dylib
0x7fffcb3f9000 -    0x7fffcb424ffb  libarchive.2.dylib (41.20.1) <FC116AC3-EB4A-3252-821C-4E1703879C82> /usr/lib/libarchive.2.dylib
0x7fffcb425000 -    0x7fffcb499fff  libate.dylib (1.12.12) <DD989482-B873-3094-97BB-2B5AE8D3B544> /usr/lib/libate.dylib
0x7fffcb49d000 -    0x7fffcb49dff3  libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
0x7fffcb49e000 -    0x7fffcb4aeff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffcb4af000 -    0x7fffcb4bdff7  libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
0x7fffcb4be000 -    0x7fffcb514ff7  libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
0x7fffcb515000 -    0x7fffcb53ffff  libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
0x7fffcb540000 -    0x7fffcb550ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffcb551000 -    0x7fffcb566fc3  libcompression.dylib (34) <1691D6F2-46CD-3DA6-B44F-24CDD9BD0E4E> /usr/lib/libcompression.dylib
0x7fffcb567000 -    0x7fffcb567ff7  libcoretls.dylib (121.1.1) <F3BAB54C-DA82-37C3-A218-46FEB179D555> /usr/lib/libcoretls.dylib
0x7fffcb568000 -    0x7fffcb569ffb  libcoretls_cfhelpers.dylib (121.1.1) <D12709F3-BBE3-3CF7-9070-C2A0803F5526> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffcb623000 -    0x7fffcb707ff3  libcrypto.0.9.8.dylib (64) <4CB423CE-0B86-334A-9335-FEE75198024F> /usr/lib/libcrypto.0.9.8.dylib
0x7fffcb8a5000 -    0x7fffcb8f8ff7  libcups.2.dylib (450) <04CA1F55-4B70-3D65-B4B1-62F6C271A9EF> /usr/lib/libcups.2.dylib
0x7fffcb972000 -    0x7fffcb972fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fffcb982000 -    0x7fffcb987ff7  libheimdal-asn1.dylib (498.20.2) <C9B5464F-4A2E-3E3F-B514-B0911B5CB0DA> /usr/lib/libheimdal-asn1.dylib
0x7fffcb988000 -    0x7fffcba7aff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fffcba7b000 -    0x7fffcbca0fff  libicucore.A.dylib (57132.0.1) <C8176937-9271-3F0E-829D-F3BBB9DD44B5> /usr/lib/libicucore.A.dylib
0x7fffcbca6000 -    0x7fffcbca7fff  liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
0x7fffcbca8000 -    0x7fffcbcc1ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fffcbcc2000 -    0x7fffcbcd8ff7  libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
0x7fffcbcd9000 -    0x7fffcbf83fff  libmecabra.dylib (744.2.2) <C6C3EA2C-1DC7-3DCB-8A20-C645E38524AB> /usr/lib/libmecabra.dylib
0x7fffcbfb6000 -    0x7fffcc02fff3  libnetwork.dylib (856.20.4) <5012EFF3-8FF4-317D-B328-AB21E3B5CA8C> /usr/lib/libnetwork.dylib
0x7fffcc030000 -    0x7fffcc400d97  libobjc.A.dylib (706) <F9AFE665-A3A2-3285-9495-19803A565861> /usr/lib/libobjc.A.dylib
0x7fffcc403000 -    0x7fffcc407fff  libpam.2.dylib (21) <352F8FF6-2248-3594-B357-8D031DEFB06C> /usr/lib/libpam.2.dylib
0x7fffcc408000 -    0x7fffcc438ff7  libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
0x7fffcc456000 -    0x7fffcc472ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fffcc4c2000 -    0x7fffcc60afff  libsqlite3.dylib (252) <FCA29CD2-E8E4-3324-8E2C-19BDC11F0338> /usr/lib/libsqlite3.dylib
0x7fffcc6fc000 -    0x7fffcc709fff  libxar.1.dylib (354) <AAFCF321-8100-3622-880B-9661DCA35D69> /usr/lib/libxar.1.dylib
0x7fffcc70d000 -    0x7fffcc7fcffb  libxml2.2.dylib (30.11) <26676155-64CE-323F-B73C-AD77AF5982E8> /usr/lib/libxml2.2.dylib
0x7fffcc7fd000 -    0x7fffcc826fff  libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
0x7fffcc827000 -    0x7fffcc838ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fffcc847000 -    0x7fffcc84bff7  libcache.dylib (79) <84E55656-FDA9-3B29-9E4F-BE31B2C0AA3C> /usr/lib/system/libcache.dylib
0x7fffcc84c000 -    0x7fffcc856fff  libcommonCrypto.dylib (60092.20.1) <31040F10-5E57-3B9C-8D5B-33AD87D1BEE8> /usr/lib/system/libcommonCrypto.dylib
0x7fffcc857000 -    0x7fffcc85efff  libcompiler_rt.dylib (62) <486BDE52-81B4-3446-BD72-23977CAE556F> /usr/lib/system/libcompiler_rt.dylib
0x7fffcc85f000 -    0x7fffcc867fff  libcopyfile.dylib (138) <0DA49B77-56EC-362D-98FF-FA78CFD986D6> /usr/lib/system/libcopyfile.dylib
0x7fffcc868000 -    0x7fffcc8eafdb  libcorecrypto.dylib (442.20.2) <2684CC01-087E-33E2-8219-AAA3BBD9BFD7> /usr/lib/system/libcorecrypto.dylib
0x7fffcc8eb000 -    0x7fffcc91dfff  libdispatch.dylib (703.20.1) <877B505D-826C-3246-84F7-0F850636039E> /usr/lib/system/libdispatch.dylib
0x7fffcc91e000 -    0x7fffcc923ff3  libdyld.dylib (421.2) <7BFA3476-6210-3BCB-8CE8-9B952F87BD84> /usr/lib/system/libdyld.dylib
0x7fffcc924000 -    0x7fffcc924ffb  libkeymgr.dylib (28) <09CD7CA6-46D2-3A9F-B9F1-7C4CA5CA0D68> /usr/lib/system/libkeymgr.dylib
0x7fffcc925000 -    0x7fffcc931ffb  libkxld.dylib (3789.21.3) <F12B5274-44AD-3268-A793-31EF351A4BD9> /usr/lib/system/libkxld.dylib
0x7fffcc932000 -    0x7fffcc932fff  liblaunch.dylib (972.20.3) <7AB2E2EA-8B47-3420-87CE-5EE18A4EEE49> /usr/lib/system/liblaunch.dylib
0x7fffcc933000 -    0x7fffcc938fff  libmacho.dylib (894) <1EAE5ADD-490C-3B1F-9F97-447BA8E0E90F> /usr/lib/system/libmacho.dylib
0x7fffcc939000 -    0x7fffcc93bff3  libquarantine.dylib (85) <F3E47D7C-8776-327C-9426-DD7DEB30DBDD> /usr/lib/system/libquarantine.dylib
0x7fffcc93c000 -    0x7fffcc93dffb  libremovefile.dylib (45) <C4FC07FF-ED86-382E-B06F-33C34718080C> /usr/lib/system/libremovefile.dylib
0x7fffcc93e000 -    0x7fffcc956ff7  libsystem_asl.dylib (349.1.1) <F0987490-8427-367F-B302-A05A7D61FEBF> /usr/lib/system/libsystem_asl.dylib
0x7fffcc957000 -    0x7fffcc957ff7  libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
0x7fffcc958000 -    0x7fffcc9e5fef  libsystem_c.dylib (1158.20.4) <5F9531F5-EDA3-3D25-A827-3E0FD6B392BA> /usr/lib/system/libsystem_c.dylib
0x7fffcc9e6000 -    0x7fffcc9e9ffb  libsystem_configuration.dylib (888.20.5) <CDC55FCB-C1FC-350D-A919-5DBCFC835B63> /usr/lib/system/libsystem_configuration.dylib
0x7fffcc9ea000 -    0x7fffcc9edfff  libsystem_coreservices.dylib (41.2) <5DE691C6-7EE6-3210-895D-9EA3ECBC09B4> /usr/lib/system/libsystem_coreservices.dylib
0x7fffcc9ee000 -    0x7fffcca06ffb  libsystem_coretls.dylib (121.1.1) <8F7E9B12-400D-3276-A9C5-4546B0258554> /usr/lib/system/libsystem_coretls.dylib
0x7fffcca07000 -    0x7fffcca0dfff  libsystem_dnssd.dylib (765.20.4) <28E52C39-DF10-340F-A3EC-C0119AF6361F> /usr/lib/system/libsystem_dnssd.dylib
0x7fffcca0e000 -    0x7fffcca37fff  libsystem_info.dylib (503) <C686B834-5E7D-382C-AF6E-44AB78EE83E2> /usr/lib/system/libsystem_info.dylib
0x7fffcca38000 -    0x7fffcca5aff7  libsystem_kernel.dylib (3789.21.3) <EC53F92A-0DFA-3027-A220-414A01F17B2E> /usr/lib/system/libsystem_kernel.dylib
0x7fffcca5b000 -    0x7fffccaa2fe7  libsystem_m.dylib (3121.4) <7F86C291-B105-31C1-9923-90EBAB22B73F> /usr/lib/system/libsystem_m.dylib
0x7fffccaa3000 -    0x7fffccac1ff7  libsystem_malloc.dylib (116) <F9840080-4C2C-3F3B-8087-7C738F12A1C7> /usr/lib/system/libsystem_malloc.dylib
0x7fffccac2000 -    0x7fffccb19ff3  libsystem_network.dylib (856.20.4) <2BAFB24F-999C-3148-BDD8-F28E05F716F7> /usr/lib/system/libsystem_network.dylib
0x7fffccb1a000 -    0x7fffccb23ff3  libsystem_networkextension.dylib (563.20.3) <971DD3AD-D17A-32FF-95DE-0A5A979E68AE> /usr/lib/system/libsystem_networkextension.dylib
0x7fffccb24000 -    0x7fffccb2dff3  libsystem_notify.dylib (165.20.1) <EAD023A2-AD3F-31C8-9489-274B9A42DA61> /usr/lib/system/libsystem_notify.dylib
0x7fffccb2e000 -    0x7fffccb36fe7  libsystem_platform.dylib (126.1.2) <2F2D6A81-C36C-353D-B27B-A6643A32375E> /usr/lib/system/libsystem_platform.dylib
0x7fffccb37000 -    0x7fffccb41ff7  libsystem_pthread.dylib (218.20.1) <46375095-4731-3034-9D87-396DE95FC697> /usr/lib/system/libsystem_pthread.dylib
0x7fffccb42000 -    0x7fffccb45ff7  libsystem_sandbox.dylib (592.21.2) <2D42A2BF-A7AF-352A-A821-D8F6E85A63AC> /usr/lib/system/libsystem_sandbox.dylib
0x7fffccb46000 -    0x7fffccb47fff  libsystem_secinit.dylib (24) <A54B8FEF-E792-3C54-8E0B-E80A376662F2> /usr/lib/system/libsystem_secinit.dylib
0x7fffccb48000 -    0x7fffccb4ffff  libsystem_symptoms.dylib (532.1.1) <8FB7CA37-79EF-3651-B5B9-B5E1E0947067> /usr/lib/system/libsystem_symptoms.dylib
0x7fffccb50000 -    0x7fffccb70ff7  libsystem_trace.dylib (518.20.8) <C029B910-A65F-35F6-B194-B933B454EAB4> /usr/lib/system/libsystem_trace.dylib
0x7fffccb71000 -    0x7fffccb76ffb  libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
0x7fffccb77000 -    0x7fffccba0ff7  libxpc.dylib (972.20.3) <85EB25FD-218F-38EE-9E69-391CC8EBE6C5> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 10247
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=343.0M resident=0K(0%) swapped_out_or_unallocated=343.0M(100%)
Writable regions: Total=375.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=375.6M(100%)
                            VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework              256K        3
Activity Tracing                  256K        2
CG backing stores                38.6M      10
CG image                          1144K      12
CoreAnimation                      96K        9
CoreUI image data                2240K      13
CoreUI image file                  156K        4
Kernel Alloc Once                    8K        2
MALLOC                          305.6M      51
MALLOC guard page                  48K      10
Memory Tag 242                      12K        2
Memory Tag 251                      16K        2
OpenGL GLSL                        256K        4
SQLite page cache                  64K        2
STACK GUARD                      56.0M        8
Stack                            11.0M        8
VM_ALLOCATE                        468K      31
__DATA                            34.8M      266
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                      122.3M      49
__TEXT                          220.7M      259
__UNICODE                          556K        2
mapped file                      55.9M      18
shared memory                    16.4M      16
TOTAL                            869.9M      762
Model: MacBookPro11,3, BootROM MBP112.0138.B17, 4 processors, Intel Core i7, 2.3 GHz, 16 GB, SMC 2.19f12
Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe, 2048 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, -
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, -
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.21.171.47.1a8)
Bluetooth: Version 5.0.1f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: Parallels Host-Only #1, Ethernet, vnic1
Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
USB Device: USB 3.0 Bus
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: USB Receiver
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
Jean-Paul
N1JPL
longer crashes.
It crashes on my MacBook with the latest OS X build Process: OpenSCAD [9192] Path: /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD Identifier: org.openscad.OpenSCAD Version: 2016.10 (2016.10.16) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: OpenSCAD [9192] User ID: 501 Date/Time: 2016-10-28 21:13:54.370 -0400 OS Version: Mac OS X 10.12.1 (16B2555) Report Version: 12 Anonymous UUID: F083C7E2-3CB1-C884-21A3-0E601BD2B66D Time Awake Since Boot: 19000 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000038 Exception Note: EXC_CORPSE_NOTIFY Termination Signal: Segmentation fault: 11 Termination Reason: Namespace SIGNAL, Code 0xb Terminating Process: exc handler [0] VM Regions Near 0x38: --> __TEXT 000000010234d000-0000000102878000 [ 5292K] r-x/rwx SM=COW /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 org.openscad.OpenSCAD 0x00000001023c4ea4 CSGTreeEvaluator::applyToChildren(State&, AbstractNode const&, OpenSCADOperator) + 1860 1 org.openscad.OpenSCAD 0x00000001023c5cad non-virtual thunk to CSGTreeEvaluator::visit(State&, CsgOpNode const&) + 45 2 org.openscad.OpenSCAD 0x00000001024144f5 NodeVisitor::traverse(AbstractNode const&, State const&) + 325 3 org.openscad.OpenSCAD 0x00000001023c442c CSGTreeEvaluator::buildCSGTree(AbstractNode const&) + 44 4 org.openscad.OpenSCAD 0x000000010250c23c MainWindow::compileCSG(bool) + 732 5 org.openscad.OpenSCAD 0x000000010251223f MainWindow::csgRender() + 47 6 org.qt-project.QtCore 0x00000001045cd504 QMetaMethod::invoke(QObject*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) const + 1348 7 org.qt-project.QtCore 0x00000001045cca44 QMetaObject::invokeMethod(QObject*, char const*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) + 2196 8 org.openscad.OpenSCAD 0x000000010250a5b7 MainWindow::compileDone(bool) + 343 9 org.openscad.OpenSCAD 0x00000001025094ae MainWindow::compile(bool, bool) + 1134 10 org.openscad.OpenSCAD 0x0000000102508cbc MainWindow::actionRenderPreview() + 172 11 org.qt-project.QtCore 0x00000001045f4923 QMetaObject::activate(QObject*, int, int, void**) + 883 12 org.qt-project.QtWidgets 0x00000001037c4e4f QAction::activate(QAction::ActionEvent) + 303 13 org.qt-project.QtWidgets 0x00000001038bc648 QAbstractButtonPrivate::click() + 88 14 org.qt-project.QtWidgets 0x00000001038bd7ae QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 270 15 org.qt-project.QtWidgets 0x000000010399293f QToolButton::mouseReleaseEvent(QMouseEvent*) + 15 16 org.qt-project.QtWidgets 0x000000010380dcc1 QWidget::event(QEvent*) + 1681 17 org.qt-project.QtWidgets 0x00000001038bd4ff QAbstractButton::event(QEvent*) + 175 18 org.qt-project.QtWidgets 0x0000000103992ef3 QToolButton::event(QEvent*) + 323 19 org.qt-project.QtWidgets 0x00000001037cdedd QApplicationPrivate::notify_helper(QObject*, QEvent*) + 269 20 org.qt-project.QtWidgets 0x00000001037d15f0 QApplication::notify(QObject*, QEvent*) + 9440 21 org.openscad.OpenSCAD 0x000000010252e5a2 OpenSCADApp::notify(QObject*, QEvent*) + 18 22 org.qt-project.QtCore 0x00000001045c3aa4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164 23 org.qt-project.QtWidgets 0x00000001037ce847 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 871 24 org.qt-project.QtWidgets 0x000000010382e52b QWidgetWindow::handleMouseEvent(QMouseEvent*) + 1387 25 org.qt-project.QtWidgets 0x000000010382d5bf QWidgetWindow::event(QEvent*) + 175 26 org.qt-project.QtWidgets 0x00000001037cdedd QApplicationPrivate::notify_helper(QObject*, QEvent*) + 269 27 org.qt-project.QtWidgets 0x00000001037d0822 QApplication::notify(QObject*, QEvent*) + 5906 28 org.openscad.OpenSCAD 0x000000010252e5a2 OpenSCADApp::notify(QObject*, QEvent*) + 18 29 org.qt-project.QtCore 0x00000001045c3aa4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164 30 org.qt-project.QtGui 0x0000000103ec6e0a QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 2794 31 org.qt-project.QtGui 0x0000000103eb05eb QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 155 32 libqcocoa.dylib 0x0000000106410631 QCocoaEventDispatcherPrivate::postedEventsSourceCallback(void*) + 33 33 com.apple.CoreFoundation 0x00007fffb78784b1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17 34 com.apple.CoreFoundation 0x00007fffb785961d __CFRunLoopDoSources0 + 557 35 com.apple.CoreFoundation 0x00007fffb7858b16 __CFRunLoopRun + 934 36 com.apple.CoreFoundation 0x00007fffb7858514 CFRunLoopRunSpecific + 420 37 com.apple.HIToolbox 0x00007fffb6df5fbc RunCurrentEventLoopInMode + 240 38 com.apple.HIToolbox 0x00007fffb6df5cf9 ReceiveNextEventCommon + 184 39 com.apple.HIToolbox 0x00007fffb6df5c26 _BlockUntilNextEventMatchingListInModeWithFilter + 71 40 com.apple.AppKit 0x00007fffb54dfb79 _DPSNextEvent + 1093 41 com.apple.AppKit 0x00007fffb5bf51c3 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1637 42 com.apple.AppKit 0x00007fffb54d453d -[NSApplication run] + 926 43 libqcocoa.dylib 0x000000010640f53f QCocoaEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 2191 44 org.qt-project.QtCore 0x00000001045bfeb1 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 401 45 org.qt-project.QtCore 0x00000001045c4115 QCoreApplication::exec() + 341 46 org.openscad.OpenSCAD 0x00000001024f0b60 gui(std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >&, boost::filesystem::path const&, int, char**) + 2816 47 org.openscad.OpenSCAD 0x00000001024f386c main + 9308 48 libdyld.dylib 0x00007fffcc923255 start + 1 Thread 1:: OGL Profiler 0 libsystem_kernel.dylib 0x00007fffcca4a41a mach_msg_trap + 10 1 libsystem_kernel.dylib 0x00007fffcca49867 mach_msg + 55 2 com.apple.opengl 0x00007fffbc642d39 glcDebugListener + 302 3 libsystem_pthread.dylib 0x00007fffccb3aaab _pthread_body + 180 4 libsystem_pthread.dylib 0x00007fffccb3a9f7 _pthread_start + 286 5 libsystem_pthread.dylib 0x00007fffccb3a221 thread_start + 13 Thread 2: 0 libsystem_kernel.dylib 0x00007fffcca524e6 __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fffccb3a622 _pthread_wqthread + 1023 2 libsystem_pthread.dylib 0x00007fffccb3a211 start_wqthread + 13 Thread 3: 0 libsystem_kernel.dylib 0x00007fffcca524e6 __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fffccb3a7b5 _pthread_wqthread + 1426 2 libsystem_pthread.dylib 0x00007fffccb3a211 start_wqthread + 13 Thread 4:: com.apple.NSEventThread 0 libsystem_kernel.dylib 0x00007fffcca4a41a mach_msg_trap + 10 1 libsystem_kernel.dylib 0x00007fffcca49867 mach_msg + 55 2 com.apple.CoreFoundation 0x00007fffb7859834 __CFRunLoopServiceMachPort + 212 3 com.apple.CoreFoundation 0x00007fffb7858cc1 __CFRunLoopRun + 1361 4 com.apple.CoreFoundation 0x00007fffb7858514 CFRunLoopRunSpecific + 420 5 com.apple.AppKit 0x00007fffb562c5a0 _NSEventThread + 205 6 libsystem_pthread.dylib 0x00007fffccb3aaab _pthread_body + 180 7 libsystem_pthread.dylib 0x00007fffccb3a9f7 _pthread_start + 286 8 libsystem_pthread.dylib 0x00007fffccb3a221 thread_start + 13 Thread 5:: com.apple.NSURLConnectionLoader 0 libsystem_kernel.dylib 0x00007fffcca4a41a mach_msg_trap + 10 1 libsystem_kernel.dylib 0x00007fffcca49867 mach_msg + 55 2 com.apple.CoreFoundation 0x00007fffb7859834 __CFRunLoopServiceMachPort + 212 3 com.apple.CoreFoundation 0x00007fffb7858cc1 __CFRunLoopRun + 1361 4 com.apple.CoreFoundation 0x00007fffb7858514 CFRunLoopRunSpecific + 420 5 com.apple.CFNetwork 0x00007fffb6a29334 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 6 com.apple.Foundation 0x00007fffb926630d __NSThread__start__ + 1243 7 libsystem_pthread.dylib 0x00007fffccb3aaab _pthread_body + 180 8 libsystem_pthread.dylib 0x00007fffccb3a9f7 _pthread_start + 286 9 libsystem_pthread.dylib 0x00007fffccb3a221 thread_start + 13 Thread 6: 0 libsystem_kernel.dylib 0x00007fffcca524e6 __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fffccb3a7b5 _pthread_wqthread + 1426 2 libsystem_pthread.dylib 0x00007fffccb3a211 start_wqthread + 13 Thread 0 crashed with X86 Thread State (64-bit): rax: 0x00006080001eb600 rbx: 0x00006080002248c0 rcx: 0x00006080001eb600 rdx: 0x00007fff5d8ade10 rdi: 0x0000608000423360 rsi: 0x0000000000000001 rbp: 0x00007fff5d8adec0 rsp: 0x00007fff5d8add60 r8: 0x0000000000000040 r9: 0x0000000000000000 r10: 0x00006080002655d0 r11: 0x0000000000000000 r12: 0x0000608000260928 r13: 0x00006080001e9d00 r14: 0x00006080004230a0 r15: 0x0000000000000000 rip: 0x00000001023c4ea4 rfl: 0x0000000000010202 cr2: 0x0000000000000038 Logical CPU: 2 Error Code: 0x00000006 Trap Number: 14 Binary Images: 0x10234d000 - 0x102877fff +org.openscad.OpenSCAD (2016.10 - 2016.10.16) <798865C6-FC78-315D-A258-3697BB28FD64> /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD 0x102a90000 - 0x102aaffff +libCGAL.dylib (0) <BB161E1E-1A02-3927-BD5C-E6CFC9DCFF65> /Applications/OpenSCAD.app/Contents/Frameworks/libCGAL.dylib 0x102ac0000 - 0x102b58ff7 +libmpfr.dylib (0) <84EA860F-1DB9-3CCD-90DB-4EA0F6D7D1AE> /Applications/OpenSCAD.app/Contents/Frameworks/libmpfr.dylib 0x102b6a000 - 0x102c14fff +libgmp.dylib (0) <AD00EEE9-9A5E-37CF-AC55-BEFC5095A552> /Applications/OpenSCAD.app/Contents/Frameworks/libgmp.dylib 0x102c22000 - 0x102c2fff7 +libopencsg.dylib (0) <7157C249-C096-3C92-9DB8-B48595685754> /Applications/OpenSCAD.app/Contents/Frameworks/libopencsg.dylib 0x102c3f000 - 0x102c6cfff +libGLEW.dylib (0) <B5752FBE-04A0-3AEE-99E2-0CFCC8215EAB> /Applications/OpenSCAD.app/Contents/Frameworks/libGLEW.dylib 0x102ca1000 - 0x102cb2fff +libboost_thread.dylib (0) <1BDE8682-7E38-376A-8311-E4F1A30647A7> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_thread.dylib 0x102cc6000 - 0x102d04ff7 +libboost_program_options.dylib (0) <30F50F11-56B3-30A2-A3D0-47FAE842DEFE> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_program_options.dylib 0x102d39000 - 0x102d48fff +libboost_filesystem.dylib (0) <74F720BD-7D42-3CC3-B46C-004C6D4F74E7> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_filesystem.dylib 0x102d55000 - 0x102d57fff +libboost_system.dylib (0) <9F8CAB71-D38E-3DDE-9C2A-2BE5902D2949> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_system.dylib 0x102d5b000 - 0x102dfffff +libboost_regex.dylib (0) <ABE85842-FE2B-3BE8-97CF-C6F336F00B4B> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_regex.dylib 0x102e57000 - 0x102fd5ff7 +libglib-2.0.dylib (0) <75CB4D06-4CBE-3A31-8E62-98A5487ACA59> /Applications/OpenSCAD.app/Contents/Frameworks/libglib-2.0.dylib 0x103001000 - 0x10300fff7 +libintl.dylib (0) <8B0375AA-AC19-3568-92E0-7FA2697945BB> /Applications/OpenSCAD.app/Contents/Frameworks/libintl.dylib 0x103014000 - 0x1031daff7 +libxml2.dylib (0) <CF441BD1-044A-3FAC-A582-D881AC295DE0> /Applications/OpenSCAD.app/Contents/Frameworks/libxml2.dylib 0x103217000 - 0x103252fff +org.sparkle-project.Sparkle (1.13.1 git-2afc553 - 1.13.1) <40414915-A48C-3DBB-AACB-5C20BAAE6DA6> /Applications/OpenSCAD.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle 0x103289000 - 0x103363ff7 +libharfbuzz.dylib (0) <952F418F-F934-3CDD-A327-CA8FC7FACE35> /Applications/OpenSCAD.app/Contents/Frameworks/libharfbuzz.dylib 0x1033ab000 - 0x103481fff +libfreetype.dylib (0) <E585D750-7702-390E-84B0-E938F545A7DC> /Applications/OpenSCAD.app/Contents/Frameworks/libfreetype.dylib 0x1034a3000 - 0x1034effff +libfontconfig.dylib (0) <7C3077D7-52E7-3C5D-BDA9-D762A31D30E2> /Applications/OpenSCAD.app/Contents/Frameworks/libfontconfig.dylib 0x103502000 - 0x1036eaff7 +libqscintilla2.dylib (0) <B53204B6-AEFD-3C53-9A6F-D597328D8278> /Applications/OpenSCAD.app/Contents/Frameworks/libqscintilla2.dylib 0x103761000 - 0x103794ff7 +org.qt-project.QtPrintSupport (5.7 - 5.7.0) <67BB0DB0-88B2-3802-92D5-7B326C90AFB0> /Applications/OpenSCAD.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport 0x1037bc000 - 0x103cb5ff7 +org.qt-project.QtWidgets (5.7 - 5.7.0) <9029D91F-7F7E-3DE0-BD66-FC91DD8112C3> /Applications/OpenSCAD.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets 0x103e9f000 - 0x10429fff7 +org.qt-project.QtGui (5.7 - 5.7.0) <65053079-A2E1-3D59-AE88-BEB242E05C97> /Applications/OpenSCAD.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui 0x1043de000 - 0x1048f2ff7 +org.qt-project.QtCore (5.7 - 5.7.0) <91296610-5A00-30F7-9663-DDF7738C31FF> /Applications/OpenSCAD.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore 0x104a0e000 - 0x104a17ff7 +org.qt-project.QtMacExtras (5.7 - 5.7.0) <8B3C4F7B-C98D-3A29-9858-DAF34F58768B> /Applications/OpenSCAD.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras 0x104a1f000 - 0x104a23ff7 +org.qt-project.QtConcurrent (5.7 - 5.7.0) <AB461D07-E24C-3894-9E0C-DC3B8FCAFCC4> /Applications/OpenSCAD.app/Contents/Frameworks/QtConcurrent.framework/Versions/5/QtConcurrent 0x104a29000 - 0x104a2dffb com.apple.agl (3.3.1 - AGL-3.3.1) <0B0E6527-C8E2-3162-BED1-DC2DD8DD2F95> /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x104a38000 - 0x104a3aff7 +libboost_chrono.dylib (0) <5CEAEB01-4A14-3E20-998E-31877704C25A> /Applications/OpenSCAD.app/Contents/Frameworks/libboost_chrono.dylib 0x1063e9000 - 0x10655afff +libqcocoa.dylib (0) <56AF80F9-6AAF-3A4E-97F4-109614288A77> /Applications/OpenSCAD.app/Contents/PlugIns/platforms/libqcocoa.dylib 0x1065d0000 - 0x106637ff7 +org.qt-project.QtDBus (5.7 - 5.7.0) <A3B1C34A-7EBC-36D6-B053-9CEE4A3D14CE> /Applications/OpenSCAD.app/Contents/Frameworks/QtDBus.framework/Versions/5/QtDBus 0x106666000 - 0x10667dffb libCGInterfaces.dylib (331.5) <5796C169-B449-33C8-B471-BD711BDCB898> /System/Library/Frameworks/Accelerate.framework/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib 0x109013000 - 0x109017ff7 +libqtga.dylib (0) <576CF0ED-6C64-32C7-99BB-6468A1080D9F> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqtga.dylib 0x109477000 - 0x109481ff7 +libqdds.dylib (0) <C030C6EC-3611-3A8D-894F-071C96FB3031> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqdds.dylib 0x10948c000 - 0x109632fff GLEngine (12.4.5) <A4E7F3A2-5025-3C7D-AAF5-6187601A8C00> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine 0x109670000 - 0x1097e6ffb libGLProgrammability.dylib (12.4.5) <6F6A4BA1-2DB2-3D22-9BEE-E45F6455BAE1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x109a9e000 - 0x10a00aff7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.20.23 - 10.2.0) <937303A6-4DB6-324C-A0F9-4CA3EAA19830> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver 0x10a21c000 - 0x10a246ffb GLRendererFloat (12.4.5) <9C53418B-2B6F-3B16-AA50-EF8CD632B05F> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat 0x10a264000 - 0x10a2dbff7 com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.20.23 - 10.2.0) <2657569C-0E68-3078-97E4-0CCBE7052D14> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver 0x10a3f3000 - 0x10a3faff7 +libqgif.dylib (0) <551D6575-9920-346E-BE76-3A835199CC08> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqgif.dylib 0x10a3ff000 - 0x10a403ff7 +libqwbmp.dylib (0) <9F5B0F44-0AF1-300C-88D2-7C2EE2C8F309> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqwbmp.dylib 0x10a788000 - 0x10a790fff +libqicns.dylib (0) <72F60B35-25FC-3478-A86D-6CC786A508C2> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqicns.dylib 0x10a796000 - 0x10a79cfff +libqico.dylib (0) <159201A7-AB7A-3174-A3F7-E3954A138C8F> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqico.dylib 0x10a7a1000 - 0x10a7e0fff +libqjpeg.dylib (0) <38A4D43B-CDF7-3867-95B6-C51AFCAFB512> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqjpeg.dylib 0x10a7ea000 - 0x10a7f0fff +libqmacjp2.dylib (0) <B2099559-AF1B-3680-B8FC-D0B08141A8ED> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqmacjp2.dylib 0x10a7f5000 - 0x10a859fff +libqtiff.dylib (0) <F086BC43-2567-3B23-B0FA-D458999803BB> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqtiff.dylib 0x10a867000 - 0x10a8e1fff +libqwebp.dylib (0) <E401A034-2209-3102-BA10-9E7F67BEA588> /Applications/OpenSCAD.app/Contents/PlugIns/imageformats/libqwebp.dylib 0x10ec86000 - 0x10ec8afff libFontRegistryUI.dylib (196.2) <95FA58A8-CB9A-33A7-B2E9-B006404AFA2B> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib 0x10ed6b000 - 0x10eda8287 dyld (421.2) <13A9466A-2576-3ABB-AD9D-D6BC16439B8F> /usr/lib/dyld 0x7fffb266b000 - 0x7fffb29a3fff com.apple.RawCamera.bundle (7.00 - 874) <99AF1865-BCDD-3313-85BF-E246745201F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera 0x7fffb2f9b000 - 0x7fffb37e7fff com.apple.GeForceGLDriver (10.12.68 - 10.1.2) <576CB6F0-3BF6-34F6-9455-42C4A8B97004> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver 0x7fffb37e8000 - 0x7fffb40b6ff3 libclh.dylib (4.0.3 - 4.0.3) <AFF52D6D-01CB-3695-8815-2BE30BCCBB77> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib 0x7fffb40b7000 - 0x7fffb41c7ff7 com.apple.GeForceMTLDriver (10.12.68 - 10.1.2) <23ED1BB3-20F2-35C1-9A23-4623FDCD108A> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver 0x7fffb44bf000 - 0x7fffb44bffff com.apple.Accelerate (1.11 - Accelerate 1.11) <97EF9FB3-581F-3F19-84D0-E9262559A454> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fffb44d8000 - 0x7fffb49f1feb com.apple.vImage (8.1 - ???) <A5DBF800-F768-3A61-8575-9B45FC32FEAB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fffb49f2000 - 0x7fffb4b62ff3 libBLAS.dylib (1185) <C7E42BBE-2337-3AEF-9C45-A2F2CB1A5B3E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fffb4b63000 - 0x7fffb4b77ffb libBNNS.dylib (14) <CFDEE88D-E002-347C-BC68-83099651585B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib 0x7fffb4b78000 - 0x7fffb4f6efef libLAPACK.dylib (1185) <2E8201CB-9A41-3D65-853E-841917FCE77B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fffb4f6f000 - 0x7fffb4f85fff libLinearAlgebra.dylib (1185) <8CC29DE1-A231-3D5E-B5F1-DCC309036FE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fffb4f86000 - 0x7fffb4f8cfff libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib 0x7fffb4f8d000 - 0x7fffb4fa1ff7 libSparseBLAS.dylib (1185) <C35235B7-CFA6-39A7-BD6E-79F4D9CAFD36> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x7fffb4fa2000 - 0x7fffb5129fe7 libvDSP.dylib (600) <DF2860D3-1B2E-3DE0-8D8D-F567374398CB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fffb512a000 - 0x7fffb51dcffb libvMisc.dylib (600) <5E006F98-FB5C-3AC4-B8B9-6D267B22AA72> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fffb51dd000 - 0x7fffb51ddfff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A395B521-8E54-30F2-B4FE-355D68900DAF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fffb5499000 - 0x7fffb6179ff3 com.apple.AppKit (6.9 - 1504.60) <5DA1E013-575C-34D5-A028-1639EB7B0040> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fffb618b000 - 0x7fffb618bfff com.apple.ApplicationServices (48 - 48) <3E1395EA-C661-3318-9B87-9857BB81021B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fffb618c000 - 0x7fffb61faff7 com.apple.ApplicationServices.ATS (377 - 422.1) <FF4D9FCA-D799-3ED1-B5F8-3D81C29342D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fffb6294000 - 0x7fffb63c2ff7 libFontParser.dylib (194.2) <E29F233F-773A-3070-874A-83799BDF0B5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fffb63c3000 - 0x7fffb640dfff libFontRegistry.dylib (196.2) <8AEE7F4E-60F0-33BB-99E4-5381EF1FEC6F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fffb646a000 - 0x7fffb649cfff libTrueTypeScaler.dylib (194.2) <A8520109-5F65-3144-ABF7-E22B98A74287> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib 0x7fffb6508000 - 0x7fffb65b2ff7 com.apple.ColorSync (4.12.0 - 502) <C86F8032-83DD-34EB-A4CB-87E96F25CF1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fffb65b3000 - 0x7fffb6603fff com.apple.HIServices (1.22 - 590) <109A9893-313B-3467-9892-062F49D1FF0D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fffb6604000 - 0x7fffb6613ff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fffb6614000 - 0x7fffb6661fff com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fffb6662000 - 0x7fffb669dfff com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fffb669e000 - 0x7fffb66a9ff7 com.apple.speech.synthesis.framework (6.0.15 - 6.0.15) <23EA6076-ECDF-3A50-81E7-3CE6451DC8C4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fffb66aa000 - 0x7fffb68b8ff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <BA73DBAD-A9D2-3BA7-BCDB-4790D6C8B460> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fffb68b9000 - 0x7fffb68b9fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <C49668FF-2971-3E30-92BB-09E0720E74A5> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x7fffb6a22000 - 0x7fffb6da6ff7 com.apple.CFNetwork (807.1.3 - 807.1.3) <336BFAD9-1BAE-368E-8C48-B9F1CC251C67> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fffb6dc0000 - 0x7fffb6dc0fff com.apple.Carbon (154 - 157) <AB71A31F-5B15-3BF5-8532-591EACD07B21> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fffb6dc1000 - 0x7fffb6dc4fff com.apple.CommonPanels (1.2.6 - 98) <DDA2DF0B-86E7-34B6-B688-D7371DBC8A63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x7fffb6dc5000 - 0x7fffb70c9fff com.apple.HIToolbox (2.1.1 - 856.6) <DAF74CE6-8B6B-3347-B299-FE860B517D38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fffb70ca000 - 0x7fffb70cdff7 com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x7fffb70ce000 - 0x7fffb70d3fff com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x7fffb70d4000 - 0x7fffb716bff3 com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x7fffb716c000 - 0x7fffb7186fff com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x7fffb7187000 - 0x7fffb7188ff3 com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x7fffb7189000 - 0x7fffb718bff7 com.apple.securityhi (9.0 - 55006) <FFB3F28C-B982-34EF-8510-8D6D10975404> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x7fffb718c000 - 0x7fffb7192ff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fffb7272000 - 0x7fffb7272fff com.apple.Cocoa (6.11 - 22) <5EEB0A26-F1C2-3D57-8441-52C0B80C2A6A> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fffb73a8000 - 0x7fffb7438ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <4082E8CC-568A-364A-9AF0-92F30F067D42> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fffb7439000 - 0x7fffb744cff3 com.apple.CoreBluetooth (1.0 - 1) <73A2B185-70E4-3535-A653-E1BC74584E55> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth 0x7fffb744d000 - 0x7fffb7743ffb com.apple.CoreData (120 - 752.2) <CCDCE896-CD36-3483-8E04-C513433BDDC5> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fffb7744000 - 0x7fffb77d0fff com.apple.CoreDisplay (1.0 - 1) <ACA3B0B8-6900-3445-B202-C5C312421E44> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay 0x7fffb77d1000 - 0x7fffb7c6aff7 com.apple.CoreFoundation (6.9 - 1348.15) <C25C6FB8-E934-349C-952C-26CF913BAC33> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fffb7c6b000 - 0x7fffb82e9fff com.apple.CoreGraphics (2.0 - 1070.8) <3F5B7647-8006-3738-9A5A-1AD2DF570992> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fffb82ea000 - 0x7fffb8529ff7 com.apple.CoreImage (12.0.0 - 451) <4A79760F-FD23-3055-9569-5F038818993F> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x7fffb8684000 - 0x7fffb8684fff com.apple.CoreServices (775.8.2 - 775.8.2) <FE7B0765-C41F-3FD9-8FD7-094466AAD0EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fffb8685000 - 0x7fffb86d6ff7 com.apple.AE (712 - 712) <0EF17D7E-6BA4-3555-BC38-9BD0CC5B82A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fffb86d7000 - 0x7fffb89b2fff com.apple.CoreServices.CarbonCore (1159 - 1159) <837B7ECF-7E62-3210-988C-63D7AB4EAA88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fffb89b3000 - 0x7fffb89e6fff com.apple.DictionaryServices (1.2 - 274) <302B8678-D057-3CF8-ACA7-7424A4A6A00A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fffb89e7000 - 0x7fffb89efffb com.apple.CoreServices.FSEvents (1230 - 1230) <8836E7D0-844F-36F9-9601-B630BB82336B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fffb89f0000 - 0x7fffb8b5bfff com.apple.LaunchServices (775.8.2 - 775.8.2) <7389590A-0E30-3294-B39C-F179D237F6C4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fffb8b5c000 - 0x7fffb8c0cffb com.apple.Metadata (10.7.0 - 1075.17) <40F7E6E2-B58B-34E1-B97B-26756ECDB947> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fffb8c0d000 - 0x7fffb8c6cfff com.apple.CoreServices.OSServices (775.8.2 - 775.8.2) <C949CF81-3510-3987-AEB4-9A961B738DA2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fffb8c6d000 - 0x7fffb8cddfff com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fffb8cde000 - 0x7fffb8d24ff7 com.apple.coreservices.SharedFileList (38 - 38) <6C5A3FBB-9502-3725-AC3A-AE7B1528BBD4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x7fffb8db1000 - 0x7fffb8efcffb com.apple.CoreText (352.0 - 544.1) <3229A726-303B-3B09-A014-8708C3BEF2D1> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fffb8efd000 - 0x7fffb8f32fff com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fffb8f33000 - 0x7fffb8fa4ffb com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <0425CA71-50D9-32DC-8693-CAE6CB3B799D> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN 0x7fffb909f000 - 0x7fffb90a4fff com.apple.DiskArbitration (2.7 - 2.7) <566D5C06-13E8-3638-B2EC-2B834D5F04F1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fffb9233000 - 0x7fffb95daffb com.apple.Foundation (6.9 - 1349) <08A463B1-296E-3AC1-B8D3-01A75B0785A8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fffb9606000 - 0x7fffb9637fff com.apple.GSS (4.0 - 2.0) <4F3C9982-457C-3731-85DB-8CE1A72621B0> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fffb96eb000 - 0x7fffb978efff com.apple.Bluetooth (5.0.1 - 5.0.1f7) <406E3901-F5D3-3996-84F7-32975EBE8F86> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth 0x7fffb978f000 - 0x7fffb9824ff7 com.apple.framework.IOKit (2.0.2 - 1324.21.1) <EEFE7FF0-CE41-326A-A571-8AA0B2E89271> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fffb9825000 - 0x7fffb982bffb com.apple.IOSurface (153.1 - 153.1) <849B0928-3D37-3977-9670-19979DB4EE4D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fffb987f000 - 0x7fffb99d5fef com.apple.ImageIO.framework (3.3.0 - 1570.2) <1133B1CE-C702-3D66-80F3-6BB40D5D1178> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fffb99d6000 - 0x7fffb99dafff libGIF.dylib (1570.2) <4AE8D51B-E26A-3CB0-9D53-58112F94E3CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fffb99db000 - 0x7fffb9acbfff libJP2.dylib (1570.2) <9F56888C-28CD-3ED0-B7BB-FFB775EF9DE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fffb9acc000 - 0x7fffb9aefffb libJPEG.dylib (1570.2) <BE6386AF-E7F7-3C26-8B9E-7682DA38F496> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fffb9af0000 - 0x7fffb9b17ff7 libPng.dylib (1570.2) <2BC453BB-5E15-3031-AFAE-912025F2674A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fffb9b18000 - 0x7fffb9b1aff3 libRadiance.dylib (1570.2) <0F2C81F9-2D74-36A6-BCC0-2366E60410C7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fffb9b1b000 - 0x7fffb9b74ff3 libTIFF.dylib (1570.2) <897EB69A-1C96-3BC2-A458-A21652249E71> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x7fffb9c94000 - 0x7fffba735ff7 com.apple.JavaScriptCore (12602 - 12602.2.14.0.5) <A9839022-B3BE-38E2-8956-B5ED9BE145FD> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fffba736000 - 0x7fffba74fff7 com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fffbaf36000 - 0x7fffbaf8dff7 com.apple.Metal (85.85 - 85.85) <EF221C0E-9638-312B-9455-FF3C69180C45> /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x7fffbb6a3000 - 0x7fffbb6abfff com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fffbb87f000 - 0x7fffbb887ff7 libcldcpuengine.dylib (2.8.4) <B43FD148-4550-3EB1-9971-F5EFC0456CCE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib 0x7fffbba50000 - 0x7fffbba9eff3 com.apple.opencl (2.8.6 - 2.8.6) <819DE36A-893E-3100-8430-EEB9D7023672> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fffbba9f000 - 0x7fffbbab8ffb com.apple.CFOpenDirectory (10.12 - 194) <BDD22B3E-4149-366A-A974-942280861DD4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fffbbab9000 - 0x7fffbbac4ff7 com.apple.OpenDirectory (10.12 - 194) <E1125140-E42C-369C-8DC8-D0935767B275> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fffbbac5000 - 0x7fffbbac7fff libCVMSPluginSupport.dylib (12.4.5) <AF349AF5-ACC9-32C8-98BE-1DC9523156C5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fffbbac8000 - 0x7fffbbacbff7 libCoreFSCache.dylib (150) <991F00EB-B1B4-3351-9D83-C11E4920C360> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x7fffbbacc000 - 0x7fffbbacffff libCoreVMClient.dylib (150) <06276E05-1FB2-3748-A236-1F66468A1755> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fffbbad0000 - 0x7fffbbad8ffb libGFXShared.dylib (12.4.5) <67ABA30E-DA8A-336C-8137-11CD0D455741> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fffbbad9000 - 0x7fffbbae4fff libGL.dylib (12.4.5) <920D2CC5-D64F-35A5-8C54-4A5731AEC552> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fffbbae5000 - 0x7fffbbb21ff7 libGLImage.dylib (12.4.5) <BEDFA6BF-0D9C-35ED-9DDD-FDBB1F6AAF95> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fffbbc99000 - 0x7fffbbcd9ff3 libGLU.dylib (12.4.5) <79C811DC-7904-3A7D-A983-B3E8D5439336> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fffbc641000 - 0x7fffbc64ffff com.apple.opengl (12.4.5 - 12.4.5) <B33F90DE-B86B-38E3-BCDB-5C8B4952D84B> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fffbd361000 - 0x7fffbd55bfff com.apple.QuartzCore (1.11 - 449.39.5) <B1815529-31B4-3FD0-923D-C3E964F844FF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fffbdac1000 - 0x7fffbdddcff7 com.apple.security (7.0 - 57740.20.22) <7E95D13A-0D52-36A9-A1C4-C21EE26AB2AB> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fffbdddd000 - 0x7fffbde53ff7 com.apple.securityfoundation (6.0 - 55132.20.1) <8DDEA805-C6F7-3EF9-990F-136617DB942D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fffbde7d000 - 0x7fffbde80ff3 com.apple.xpc.ServiceManagement (1.0 - 1) <A88DACDF-71A9-3974-8D8D-DAA2B64F2CA5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fffbe205000 - 0x7fffbe276ff7 com.apple.SystemConfiguration (1.14 - 1.14) <013957CA-2708-31F0-845D-11E271C96B94> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fffbe623000 - 0x7fffbf857ff3 com.apple.WebCore (12602 - 12602.2.14.0.5) <AA349DE2-73A3-32B2-8A1D-FEFFC468B87D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore 0x7fffbf858000 - 0x7fffbf9bdfff com.apple.WebKitLegacy (12602 - 12602.2.14.0.7) <3D4BAC77-370A-3D55-AD1A-68D4C489DAF1> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy 0x7fffbf9be000 - 0x7fffbfd29ff7 com.apple.WebKit (12602 - 12602.2.14.0.7) <847FBE4F-06E5-315F-80FA-A58180B74608> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit 0x7fffc08b8000 - 0x7fffc08daffb com.apple.framework.Apple80211 (12.0 - 1200.37) <25299C0F-7A30-3BAA-9945-DB1515F68A2C> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 0x7fffc08db000 - 0x7fffc08eafdb com.apple.AppleFSCompression (88 - 1.0) <D3A6F5F9-2132-34B5-933F-DF5D6733DE8B> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x7fffc09d3000 - 0x7fffc0a5e97f com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x7fffc0e7a000 - 0x7fffc0ef8ff7 com.apple.backup.framework (1.8.1 - 1.8.1) <792B4983-DE9A-377D-8338-93719706D12F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x7fffc1b16000 - 0x7fffc1b3dffb com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary 0x7fffc2464000 - 0x7fffc246dffb com.apple.CommonAuth (4.0 - 2.0) <D561391D-80B8-35F8-9EFF-1ACC89895E38> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fffc2b89000 - 0x7fffc2b9aff7 com.apple.CoreEmoji (1.0 - 39.1) <54432658-8481-3F33-ADED-B60684311E11> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji 0x7fffc2e7c000 - 0x7fffc2eacff3 com.apple.CoreServicesInternal (276 - 276) <CCB21255-89DC-3F53-A6D6-8FA8F693C837> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x7fffc3135000 - 0x7fffc31bffff com.apple.CoreSymbolication (61050) <15C4AF49-2F85-3265-B53F-4925616C746E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fffc31c0000 - 0x7fffc32fefcf com.apple.coreui (2.1 - 426.9.1) <A7672B5D-9972-34B8-968A-188D422083AE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x7fffc32ff000 - 0x7fffc339effb com.apple.CoreUtils (4.3 - 430.70) <946F5089-9F8D-3595-8208-AD945B26D267> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils 0x7fffc33ee000 - 0x7fffc3453ff3 com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <8DAD3903-9A77-3E50-99C4-3C5708FB25B1> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi 0x7fffc3454000 - 0x7fffc3461fff com.apple.CrashReporterSupport (10.12 - 816) <BF292E0C-6CDB-3149-8177-4EF5DD72D544> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0x7fffc3507000 - 0x7fffc357eff3 com.apple.datadetectorscore (7.0 - 539) <AA02538E-706E-305B-AABA-FA9A6F4C1B8C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x7fffc35b8000 - 0x7fffc35f7fff com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x7fffc35f8000 - 0x7fffc3709fff com.apple.desktopservices (1.11.1 - 1.11.1) <03518A59-79B1-3B16-B923-52D6EFF04ADB> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fffc39d5000 - 0x7fffc3e06ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x7fffc5141000 - 0x7fffc5141fff libmetal_timestamp.dylib (600.0.48.26) <681B9F09-0673-3C38-B636-9D77D338D1AF> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib 0x7fffc514e000 - 0x7fffc5159ff3 libGPUSupportMercury.dylib (12.4.5) <A08E7321-32C4-3008-97C3-870B6AB1E63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib 0x7fffc540b000 - 0x7fffc5427ff7 com.apple.GenerationalStorage (2.0 - 259) <43D40063-BD46-3008-8992-FF092B7C9A58> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x7fffc5b1d000 - 0x7fffc5b93ffb com.apple.Heimdal (4.0 - 2.0) <418DD668-7288-3D33-BAFE-959DB96D0351> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fffc61a6000 - 0x7fffc61adffb com.apple.IOAccelerator (288.15 - 288.15) <DE5BC493-2F4E-3388-A887-DA5AD7BAD3F4> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x7fffc61af000 - 0x7fffc61c3ff3 com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment 0x7fffc61c4000 - 0x7fffc61e6ff7 com.apple.IconServices (74.1 - 74.1) <F7B83970-4A72-3186-BBB3-90FA86C3E263> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x7fffc62c8000 - 0x7fffc647cfff com.apple.LanguageModeling (1.0 - 123) <10152D7F-C7C0-34AA-A295-D712D16C76E6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fffc6d28000 - 0x7fffc6da0fef com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <EDE6F9AA-B863-3936-BA54-177B769080FD> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders 0x7fffc6f22000 - 0x7fffc6f4afff com.apple.MultitouchSupport.framework (368.4 - 368.4) <18778258-70B1-31BF-845D-1FACBF280108> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fffc6ff7000 - 0x7fffc7001fff com.apple.NetAuth (6.0 - 6.0) <D57D5888-0290-3295-A1C4-D673D4DCB497> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fffc77dd000 - 0x7fffc781eff7 com.apple.PerformanceAnalysis (1.145 - 145) <73A73364-EFB6-3D0A-A7EA-7F924359B3C9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x7fffc7eb0000 - 0x7fffc7ecafff com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer 0x7fffc7ee4000 - 0x7fffc7f07ff3 com.apple.RemoteViewServices (2.0 - 124) <280DB828-4613-3DF8-ACBA-C91989B64347> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x7fffc8bcb000 - 0x7fffc8c47fff com.apple.Sharing (671.15 - 671.15) <37C29D52-CA6E-3E30-9CCF-F7B4A8DE6B9B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x7fffc8c68000 - 0x7fffc8ebafef com.apple.SkyLight (1.600.0 - 108.11) <5D0C258E-0816-3FF2-AA3C-A7B9F2DEC19C> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight 0x7fffc9094000 - 0x7fffc90a0fff com.apple.SpeechRecognitionCore (3.0.15 - 3.0.15) <BE386037-4B61-341F-80E2-5D8B5B50C8BC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore 0x7fffc9784000 - 0x7fffc97f0ff3 com.apple.Symbolication (61080.2) <8AB6B520-E8DE-392F-8B86-52098D2A2BA2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0x7fffc9be7000 - 0x7fffc9bedff7 com.apple.TCC (1.0 - 1) <787E8FD8-21A7-39E6-87D4-6AD09156C5A0> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fffc9c79000 - 0x7fffc9e3aff3 com.apple.TextureIO (1.35 - 1.35) <63D75E50-F3C2-3E8E-A49B-F53531C24C54> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO 0x7fffc9eae000 - 0x7fffc9eaffff com.apple.TrustEvaluationAgent (2.0 - 28) <6793B664-C4FC-3CD4-B0E7-25B9933391AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x7fffc9eb0000 - 0x7fffca03fffb com.apple.UIFoundation (1.0 - 489) <0CD14719-FC52-3AC5-87EF-775437927990> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation 0x7fffcb03e000 - 0x7fffcb040ffb com.apple.loginsupport (1.0 - 1) <03B57D6F-C210-32BC-B384-5B0E95660283> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x7fffcb095000 - 0x7fffcb0b0ff7 libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib 0x7fffcb0b1000 - 0x7fffcb0bcfff libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib 0x7fffcb14e000 - 0x7fffcb14fff3 libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib 0x7fffcb150000 - 0x7fffcb363fff libFosl_dynamic.dylib (16.37) <D5551823-1E3D-3BDE-968C-BF022EE4958D> /usr/lib/libFosl_dynamic.dylib 0x7fffcb387000 - 0x7fffcb387fff libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib 0x7fffcb388000 - 0x7fffcb38bffb libScreenReader.dylib (477.10.20) <B48924E9-5301-3141-9D62-ADA2852D5BAA> /usr/lib/libScreenReader.dylib 0x7fffcb38c000 - 0x7fffcb38dff3 libSystem.B.dylib (1238) <CFC3669C-FB44-3A51-8815-1E84A168F3C5> /usr/lib/libSystem.B.dylib 0x7fffcb3f9000 - 0x7fffcb424ffb libarchive.2.dylib (41.20.1) <FC116AC3-EB4A-3252-821C-4E1703879C82> /usr/lib/libarchive.2.dylib 0x7fffcb425000 - 0x7fffcb499fff libate.dylib (1.12.12) <DD989482-B873-3094-97BB-2B5AE8D3B544> /usr/lib/libate.dylib 0x7fffcb49d000 - 0x7fffcb49dff3 libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib 0x7fffcb49e000 - 0x7fffcb4aeff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib 0x7fffcb4af000 - 0x7fffcb4bdff7 libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib 0x7fffcb4be000 - 0x7fffcb514ff7 libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib 0x7fffcb515000 - 0x7fffcb53ffff libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib 0x7fffcb540000 - 0x7fffcb550ffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib 0x7fffcb551000 - 0x7fffcb566fc3 libcompression.dylib (34) <1691D6F2-46CD-3DA6-B44F-24CDD9BD0E4E> /usr/lib/libcompression.dylib 0x7fffcb567000 - 0x7fffcb567ff7 libcoretls.dylib (121.1.1) <F3BAB54C-DA82-37C3-A218-46FEB179D555> /usr/lib/libcoretls.dylib 0x7fffcb568000 - 0x7fffcb569ffb libcoretls_cfhelpers.dylib (121.1.1) <D12709F3-BBE3-3CF7-9070-C2A0803F5526> /usr/lib/libcoretls_cfhelpers.dylib 0x7fffcb623000 - 0x7fffcb707ff3 libcrypto.0.9.8.dylib (64) <4CB423CE-0B86-334A-9335-FEE75198024F> /usr/lib/libcrypto.0.9.8.dylib 0x7fffcb8a5000 - 0x7fffcb8f8ff7 libcups.2.dylib (450) <04CA1F55-4B70-3D65-B4B1-62F6C271A9EF> /usr/lib/libcups.2.dylib 0x7fffcb972000 - 0x7fffcb972fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib 0x7fffcb982000 - 0x7fffcb987ff7 libheimdal-asn1.dylib (498.20.2) <C9B5464F-4A2E-3E3F-B514-B0911B5CB0DA> /usr/lib/libheimdal-asn1.dylib 0x7fffcb988000 - 0x7fffcba7aff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib 0x7fffcba7b000 - 0x7fffcbca0fff libicucore.A.dylib (57132.0.1) <C8176937-9271-3F0E-829D-F3BBB9DD44B5> /usr/lib/libicucore.A.dylib 0x7fffcbca6000 - 0x7fffcbca7fff liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib 0x7fffcbca8000 - 0x7fffcbcc1ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib 0x7fffcbcc2000 - 0x7fffcbcd8ff7 libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib 0x7fffcbcd9000 - 0x7fffcbf83fff libmecabra.dylib (744.2.2) <C6C3EA2C-1DC7-3DCB-8A20-C645E38524AB> /usr/lib/libmecabra.dylib 0x7fffcbfb6000 - 0x7fffcc02fff3 libnetwork.dylib (856.20.4) <5012EFF3-8FF4-317D-B328-AB21E3B5CA8C> /usr/lib/libnetwork.dylib 0x7fffcc030000 - 0x7fffcc400d97 libobjc.A.dylib (706) <F9AFE665-A3A2-3285-9495-19803A565861> /usr/lib/libobjc.A.dylib 0x7fffcc403000 - 0x7fffcc407fff libpam.2.dylib (21) <352F8FF6-2248-3594-B357-8D031DEFB06C> /usr/lib/libpam.2.dylib 0x7fffcc408000 - 0x7fffcc438ff7 libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib 0x7fffcc456000 - 0x7fffcc472ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib 0x7fffcc4c2000 - 0x7fffcc60afff libsqlite3.dylib (252) <FCA29CD2-E8E4-3324-8E2C-19BDC11F0338> /usr/lib/libsqlite3.dylib 0x7fffcc6fc000 - 0x7fffcc709fff libxar.1.dylib (354) <AAFCF321-8100-3622-880B-9661DCA35D69> /usr/lib/libxar.1.dylib 0x7fffcc70d000 - 0x7fffcc7fcffb libxml2.2.dylib (30.11) <26676155-64CE-323F-B73C-AD77AF5982E8> /usr/lib/libxml2.2.dylib 0x7fffcc7fd000 - 0x7fffcc826fff libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib 0x7fffcc827000 - 0x7fffcc838ff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib 0x7fffcc847000 - 0x7fffcc84bff7 libcache.dylib (79) <84E55656-FDA9-3B29-9E4F-BE31B2C0AA3C> /usr/lib/system/libcache.dylib 0x7fffcc84c000 - 0x7fffcc856fff libcommonCrypto.dylib (60092.20.1) <31040F10-5E57-3B9C-8D5B-33AD87D1BEE8> /usr/lib/system/libcommonCrypto.dylib 0x7fffcc857000 - 0x7fffcc85efff libcompiler_rt.dylib (62) <486BDE52-81B4-3446-BD72-23977CAE556F> /usr/lib/system/libcompiler_rt.dylib 0x7fffcc85f000 - 0x7fffcc867fff libcopyfile.dylib (138) <0DA49B77-56EC-362D-98FF-FA78CFD986D6> /usr/lib/system/libcopyfile.dylib 0x7fffcc868000 - 0x7fffcc8eafdb libcorecrypto.dylib (442.20.2) <2684CC01-087E-33E2-8219-AAA3BBD9BFD7> /usr/lib/system/libcorecrypto.dylib 0x7fffcc8eb000 - 0x7fffcc91dfff libdispatch.dylib (703.20.1) <877B505D-826C-3246-84F7-0F850636039E> /usr/lib/system/libdispatch.dylib 0x7fffcc91e000 - 0x7fffcc923ff3 libdyld.dylib (421.2) <7BFA3476-6210-3BCB-8CE8-9B952F87BD84> /usr/lib/system/libdyld.dylib 0x7fffcc924000 - 0x7fffcc924ffb libkeymgr.dylib (28) <09CD7CA6-46D2-3A9F-B9F1-7C4CA5CA0D68> /usr/lib/system/libkeymgr.dylib 0x7fffcc925000 - 0x7fffcc931ffb libkxld.dylib (3789.21.3) <F12B5274-44AD-3268-A793-31EF351A4BD9> /usr/lib/system/libkxld.dylib 0x7fffcc932000 - 0x7fffcc932fff liblaunch.dylib (972.20.3) <7AB2E2EA-8B47-3420-87CE-5EE18A4EEE49> /usr/lib/system/liblaunch.dylib 0x7fffcc933000 - 0x7fffcc938fff libmacho.dylib (894) <1EAE5ADD-490C-3B1F-9F97-447BA8E0E90F> /usr/lib/system/libmacho.dylib 0x7fffcc939000 - 0x7fffcc93bff3 libquarantine.dylib (85) <F3E47D7C-8776-327C-9426-DD7DEB30DBDD> /usr/lib/system/libquarantine.dylib 0x7fffcc93c000 - 0x7fffcc93dffb libremovefile.dylib (45) <C4FC07FF-ED86-382E-B06F-33C34718080C> /usr/lib/system/libremovefile.dylib 0x7fffcc93e000 - 0x7fffcc956ff7 libsystem_asl.dylib (349.1.1) <F0987490-8427-367F-B302-A05A7D61FEBF> /usr/lib/system/libsystem_asl.dylib 0x7fffcc957000 - 0x7fffcc957ff7 libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib 0x7fffcc958000 - 0x7fffcc9e5fef libsystem_c.dylib (1158.20.4) <5F9531F5-EDA3-3D25-A827-3E0FD6B392BA> /usr/lib/system/libsystem_c.dylib 0x7fffcc9e6000 - 0x7fffcc9e9ffb libsystem_configuration.dylib (888.20.5) <CDC55FCB-C1FC-350D-A919-5DBCFC835B63> /usr/lib/system/libsystem_configuration.dylib 0x7fffcc9ea000 - 0x7fffcc9edfff libsystem_coreservices.dylib (41.2) <5DE691C6-7EE6-3210-895D-9EA3ECBC09B4> /usr/lib/system/libsystem_coreservices.dylib 0x7fffcc9ee000 - 0x7fffcca06ffb libsystem_coretls.dylib (121.1.1) <8F7E9B12-400D-3276-A9C5-4546B0258554> /usr/lib/system/libsystem_coretls.dylib 0x7fffcca07000 - 0x7fffcca0dfff libsystem_dnssd.dylib (765.20.4) <28E52C39-DF10-340F-A3EC-C0119AF6361F> /usr/lib/system/libsystem_dnssd.dylib 0x7fffcca0e000 - 0x7fffcca37fff libsystem_info.dylib (503) <C686B834-5E7D-382C-AF6E-44AB78EE83E2> /usr/lib/system/libsystem_info.dylib 0x7fffcca38000 - 0x7fffcca5aff7 libsystem_kernel.dylib (3789.21.3) <EC53F92A-0DFA-3027-A220-414A01F17B2E> /usr/lib/system/libsystem_kernel.dylib 0x7fffcca5b000 - 0x7fffccaa2fe7 libsystem_m.dylib (3121.4) <7F86C291-B105-31C1-9923-90EBAB22B73F> /usr/lib/system/libsystem_m.dylib 0x7fffccaa3000 - 0x7fffccac1ff7 libsystem_malloc.dylib (116) <F9840080-4C2C-3F3B-8087-7C738F12A1C7> /usr/lib/system/libsystem_malloc.dylib 0x7fffccac2000 - 0x7fffccb19ff3 libsystem_network.dylib (856.20.4) <2BAFB24F-999C-3148-BDD8-F28E05F716F7> /usr/lib/system/libsystem_network.dylib 0x7fffccb1a000 - 0x7fffccb23ff3 libsystem_networkextension.dylib (563.20.3) <971DD3AD-D17A-32FF-95DE-0A5A979E68AE> /usr/lib/system/libsystem_networkextension.dylib 0x7fffccb24000 - 0x7fffccb2dff3 libsystem_notify.dylib (165.20.1) <EAD023A2-AD3F-31C8-9489-274B9A42DA61> /usr/lib/system/libsystem_notify.dylib 0x7fffccb2e000 - 0x7fffccb36fe7 libsystem_platform.dylib (126.1.2) <2F2D6A81-C36C-353D-B27B-A6643A32375E> /usr/lib/system/libsystem_platform.dylib 0x7fffccb37000 - 0x7fffccb41ff7 libsystem_pthread.dylib (218.20.1) <46375095-4731-3034-9D87-396DE95FC697> /usr/lib/system/libsystem_pthread.dylib 0x7fffccb42000 - 0x7fffccb45ff7 libsystem_sandbox.dylib (592.21.2) <2D42A2BF-A7AF-352A-A821-D8F6E85A63AC> /usr/lib/system/libsystem_sandbox.dylib 0x7fffccb46000 - 0x7fffccb47fff libsystem_secinit.dylib (24) <A54B8FEF-E792-3C54-8E0B-E80A376662F2> /usr/lib/system/libsystem_secinit.dylib 0x7fffccb48000 - 0x7fffccb4ffff libsystem_symptoms.dylib (532.1.1) <8FB7CA37-79EF-3651-B5B9-B5E1E0947067> /usr/lib/system/libsystem_symptoms.dylib 0x7fffccb50000 - 0x7fffccb70ff7 libsystem_trace.dylib (518.20.8) <C029B910-A65F-35F6-B194-B933B454EAB4> /usr/lib/system/libsystem_trace.dylib 0x7fffccb71000 - 0x7fffccb76ffb libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib 0x7fffccb77000 - 0x7fffccba0ff7 libxpc.dylib (972.20.3) <85EB25FD-218F-38EE-9E69-391CC8EBE6C5> /usr/lib/system/libxpc.dylib External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 10247 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=343.0M resident=0K(0%) swapped_out_or_unallocated=343.0M(100%) Writable regions: Total=375.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=375.6M(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Accelerate framework 256K 3 Activity Tracing 256K 2 CG backing stores 38.6M 10 CG image 1144K 12 CoreAnimation 96K 9 CoreUI image data 2240K 13 CoreUI image file 156K 4 Kernel Alloc Once 8K 2 MALLOC 305.6M 51 MALLOC guard page 48K 10 Memory Tag 242 12K 2 Memory Tag 251 16K 2 OpenGL GLSL 256K 4 SQLite page cache 64K 2 STACK GUARD 56.0M 8 Stack 11.0M 8 VM_ALLOCATE 468K 31 __DATA 34.8M 266 __GLSLBUILTINS 2588K 2 __IMAGE 528K 2 __LINKEDIT 122.3M 49 __TEXT 220.7M 259 __UNICODE 556K 2 mapped file 55.9M 18 shared memory 16.4M 16 =========== ======= ======= TOTAL 869.9M 762 Model: MacBookPro11,3, BootROM MBP112.0138.B17, 4 processors, Intel Core i7, 2.3 GHz, 16 GB, SMC 2.19f12 Graphics: Intel Iris Pro, Intel Iris Pro, Built-In Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe, 2048 MB Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, - Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, - AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.21.171.47.1a8) Bluetooth: Version 5.0.1f7, 3 services, 27 devices, 1 incoming serial ports Network Service: Wi-Fi, AirPort, en0 Network Service: Parallels Host-Only #1, Ethernet, vnic1 Serial ATA Device: APPLE SSD SM0512F, 500.28 GB USB Device: USB 3.0 Bus USB Device: Hub USB Device: Apple Internal Keyboard / Trackpad USB Device: BRCM20702 Hub USB Device: Bluetooth USB Host Controller USB Device: Hub USB Device: USB Receiver Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1 Jean-Paul N1JPL > On Oct 27, 2016, at 9:35 PM, Marius Kintel <marius@kintel.net> wrote: > > >> On Oct 27, 2016, at 19:40, MichaelAtOz <oz.at.michael@gmail.com> wrote: >> >> I have a vague feeling this may have been reported? >> Crashes when you add a '#' before main() - inside the intersection. >> Note the two do NOT intersect. Change the cube to 50, so they intersect, no >> longer crashes. >> > Thanks for the report! > I’ve opened a new issue: https://github.com/openscad/openscad/issues/1833 > > -Marius > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
