Gene Heskett
Tue, Jun 22, 2021 7:07 PM
On Tuesday 22 June 2021 12:56:50 Ray West wrote:
view-thrown together helps, too.
Unforch, not in this case, Ray. The preview shows it but neither the
render or the print gets it into plastic. So I'm confused. Have I
triggered a bug?
On 22/06/2021 16:19, Gene Heskett wrote:
Greetings all;
I have composed this script to cap the output side of a harmonic
drive: But the bearing module is totally ignored. As seperate code
elsewhere in this drive it works great.
// new output disk to contain 62 tooth spline
// and incorporate for space savings the output shaft bearings
/hakespear, what am I doing wrong?
Thanks all.
Cheers, Gene Heskett
-Ed Howdershelt (Author)
triggered a bug?
> > Greetings all;
Thanks all.
- Louis D. Brandeis
Tue, Jun 22, 2021 7:08 PM
That appears to be because the final square() extends beyond the top and
bottom of the rings. The final square does not intersect with anything.
To see this, comment out the cap, and use #bearing()
On Tue, Jun 22, 2021 at 1:41 PM Gene Heskett gheskett@shentel.net wrote:
On Tuesday 22 June 2021 11:32:05 Leonard Martin Struttmann wrote:
Put a "#" in front of the bearing() call, i.e.,
#bearing();
That worked fine, and I've made that difference into a union and added
another item to make a thin break between the two parts, makiing a
bearing channel in the middle of that thick rim, but when I take the #
away for a normal render, the break is the cap disappears from the
render, as if the 3rd argument to the union is beiing ignored. How many
items can be combined in one union() {...} statement?
With the #bearing(); I can see the break thru the top disk even at a .1mm
gap, too narrow to render but its not there in the render, so I'm
rendering to see if it is present with the # and a .5mm gap. And no,
that gap is not there in the render. The bearing race channal is there
but not the third argument. And it won't work without it.
So I'm bumfuzzled. This is the new version:
// and a timing belt pulley for output coupling.
// turn upside down to print so no supports needed
// will superglue timing pulley in center hole, and make bearing race
// addition later after verifying fit.
IDofspl=67.99;// to fit OD of 60 or 62 tooth spline
splsocht=6.00;// height of cup for spline
ODofCup=IDofspl+splsocht*2;// incorporate bearing in space
echo(11,ODofCup);
bb=4.36;// crosman bb dia plus clearance
//instclr=.4100;
// need some data for rotate_extrude
ctr_ht=splsocht/2;// center bb groove vertically
innr=ODofCup-splsocht/2;// get radius of bb groove
bbofs=splsocht/2;// might be useful
$fn=360;
translate([0,0,splsocht/2])
// builds inner|outer walls of splined ring socket
cylinder(h=splsocht,d=ODofCup,center=true);// outer
cylinder(h=splsocht+1,d=IDofspl,center=true);//inner,1st subtract
#bearing();
};// ends difference from line 20
// now cap it, this works! turn upside down to render
translate([0,0,splsocht+1.5]) // looks good
cylinder(h=splsocht/2,d=ODofCup,center=true);// make hole in center
cylinder(h=splsocht,d=20,center=true);
module bearing() {
rotate_extrude()
translate([ODofCup/2.16,1.0]) // below main gfx so can see
union()
circle(d=bb);
square([.40splsocht, 1.35splsocht],center=true);
square([.5,14],center=true);
The preview looks great, but the render does not show the last square
statements effect. And a test print doesn't show it either, so I stopped
it.
Thanks for some insight.
> > #bearing();
> echo(11,ODofCup);
> //instclr=.4100;
> $fn=360;
> difference() {
> #bearing();
> difference() {
> module bearing() {
> rotate_extrude()
> union()
> circle(d=bb);
> square([.40*splsocht, 1.35*splsocht],center=true);
> it.
> - Louis D. Brandeis
Tue, Jun 22, 2021 7:17 PM
The difference subtracts the bearing successfully but the cap fills it in
again.
On Tue, 22 Jun 2021 at 20:09, Leonard Martin Struttmann <
#bearing();
echo(11,ODofCup);
//instclr=.4100;
$fn=360;
#bearing();
module bearing() {
rotate_extrude()
union()
circle(d=bb);
it.
again.
>> > #bearing();
>> echo(11,ODofCup);
>> //instclr=.4100;
>> $fn=360;
>> difference() {
>> #bearing();
>> difference() {
>> module bearing() {
>> rotate_extrude()
>> union()
>> circle(d=bb);
>> it.
>> - Louis D. Brandeis
Gene Heskett
Tue, Jun 22, 2021 7:22 PM
and bottom of the rings. The final square does not intersect with
anything.
yes it does, its superimposed on the first 2 items and extends thru both
the top and bottoms of them.
But, and this may be a clue, I want the .2mm break line to extend thru
the cap too, which it does in the preview. Do I need to reorder the code
to make cap part of the rim somehow, then use the difference to do the
cut?
#bearing();
added another item to make a thin break between the two parts,
makiing a bearing channel in the middle of that thick rim, but when
I take the # away for a normal render, the break is the cap
disappears from the render, as if the 3rd argument to the union is
beiing ignored. How many items can be combined in one union() {...}
statement?
.1mm gap, too narrow to render but its not there in the render, so
I'm rendering to see if it is present with the # and a .5mm gap.
And no, that gap is not there in the render. The bearing race
channal is there but not the third argument. And it won't work
without it.
race // addition later after verifying fit.
echo(11,ODofCup);
//instclr=.4100;
$fn=360;
subtract #bearing();
center cylinder(h=splsocht,d=20,center=true);
module bearing() {
rotate_extrude()
union()
circle(d=bb);
square statements effect. And a test print doesn't show it either,
so I stopped it.
Still looking for a solution that renders.
Thanks Leonard.
> anything.
cut?
> > > #bearing();
> > statement?
> > without it.
> > echo(11,ODofCup);
> > //instclr=.4100;
> > $fn=360;
> > difference() {
> > difference() {
> > module bearing() {
> > rotate_extrude()
> > union()
> > circle(d=bb);
> > so I stopped it.
Thanks Leonard.
- Louis D. Brandeis
Tue, Jun 22, 2021 7:46 PM
Yep. The cap needs to be unioned with the rings before subtracting the
bearing.
anything.
cut?
#bearing();
statement?
without it.
echo(11,ODofCup);
//instclr=.4100;
$fn=360;
module bearing() {
rotate_extrude()
union()
circle(d=bb);
so I stopped it.
Thanks Leonard.
bearing.
> > anything.
> cut?
> > > > #bearing();
> > > statement?
> > > without it.
> > > echo(11,ODofCup);
> > > //instclr=.4100;
> > > $fn=360;
> > > difference() {
> > > difference() {
> > > module bearing() {
> > > rotate_extrude()
> > > union()
> > > circle(d=bb);
> > > so I stopped it.
> Thanks Leonard.
> - Louis D. Brandeis
Tue, Jun 22, 2021 8:26 PM
Yes the bearing shows up above the ring when highlighted but it never shows
a cut in the preview.
On Tue, 22 Jun 2021 at 20:47, Leonard Martin Struttmann <
bearing.
anything.
cut?
#bearing();
statement?
without it.
echo(11,ODofCup);
//instclr=.4100;
$fn=360;
module bearing() {
rotate_extrude()
union()
circle(d=bb);
so I stopped it.
Thanks Leonard.
> bearing.
>> > anything.
>> cut?
>> > > > #bearing();
>> > > statement?
>> > > without it.
>> > > echo(11,ODofCup);
>> > > //instclr=.4100;
>> > > $fn=360;
>> > > difference() {
>> > > difference() {
>> > > module bearing() {
>> > > rotate_extrude()
>> > > union()
>> > > circle(d=bb);
>> > > so I stopped it.
>> Thanks Leonard.
>> - Louis D. Brandeis
Gene Heskett
Tue, Jun 22, 2021 8:32 PM
in again.
Another aha! moment.
Hmmmmm.
So I should make the bearing 6mm thick as it is now and 9mm tall, at the
speced id, and put the cap inside it instead of on top. I can do that I
think. Done and printing with a .2mm gap. In this particular instance
every fraction of a mm of height I can get rid of will help. Same
height, built right side up for cura this time. Looks like .2mm isn't
enough gap but we'll see if it breaks in the right place as I put in the
bearings. It should.
Thank you very much, nop head. That was the magic phrase, like the song
Rosanne Cash made a few $ with on 16th Avenue in Nashville many years
ago.
anything.
#bearing();
statement?
a .1mm gap, too narrow to render but its not there in the render,
so I'm rendering to see if it is present with the # and a .5mm gap.
without it.
echo(11,ODofCup);
//instclr=.4100;
$fn=360;
module bearing() {
rotate_extrude()
union()
circle(d=bb);
so I stopped it.
respectable. - Louis D. Brandeis
Genes Web page http://geneslinuxbox.net:6309/gene
> in again.
Hmmmmm.
ago.
> > anything.
> >> > #bearing();
> >> statement?
> >> without it.
> >> echo(11,ODofCup);
> >> //instclr=.4100;
> >> $fn=360;
> >> difference() {
> >> difference() {
> >> module bearing() {
> >> rotate_extrude()
> >> union()
> >> circle(d=bb);
> >> so I stopped it.
- Louis D. Brandeis
