Hi all,
I am trying to wrap my head around this:
Since OpenScad doesn't support units, how do you print a correctly-sized
model? I am trying to make some feet for a food processor and they need to
fit into the 1/4 inch (sorry, its easier for me to think in inches) hole.
I am using Cura slicer and Repetier.
thanks in advance for your help
I've just always assumed the measure in OpenSCAD was millimeters and exports have always matched up dimensionally on that basis --- should that not work?
So, 3.175 radius and 6.35 diameter (but see the discussions about making holes match based on orientation and so forth)
Openscad is unitless, so whatever numbers you put in the scad file go into
the STL file. STL is also unitless but slicers default to interpreting the
numbers as mm.
On Sun, 23 Aug 2020 at 16:18, William F. Adams via Discuss <
to
not work?
You then have:
inch=25.4;
holeDiameter=0.25inch; // or =1/4inch if you prefer
IMHO better than trying to get your toolchain into imperial.
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of jordanthompson
Sent: Mon, 24 Aug 2020 01:12
Subject: [OpenSCAD] scaling with OpenScad, Cura, and Repetier
Hi all,
That is what I wound up doing but it surprised me that literally EVERYWHERE I
read, OpenScad was unit-less.
In fact (at least with Cura and Repetier on my modified Davinci 1.0a) 1 unit
= 1 mm. So to convert to inches:
2.54 in/cm *10 mm/cm = 25.4 mm/in
I now have:
2.54 * 10 = inches;
// 1/4 in sphere:
sphere(r=1/4*inches);
thanks for helping me clear this up!
Openscad only has one output format, stl, which is unitless. It is worth
noting that it works in geometric shapes, which are also unitless...
EVERYWHERE I
unit
I now have:
2.54 * 10 = inches;
// 1/4 in sphere:
I just read this and it is exactly what I wound up doing earlier. Thanks
very much for your help
Openscad only has one output format, stl, which is unitless. It is worth noting that it works in geometric shapes, which are also unitless...
OpenSCAD has many output formats.
For STL export, there is no way to specify units of measurement. Some people say that STL is unitless, but the defacto standard is to interpret the units as millimeters.
For 3MF export, if you don't specify a unit of measurement, it defaults to millimeters. Therefore, OpenSCAD uses millimeters when exporting to 3MF.
For SVG export, OpenSCAD explicitly sets the unit of measurement to be millimeters, even though specifying the unit of measurement is optional.
I now have:
2.54 * 10 = inches;
// 1/4 in sphere:
You could always just build your model as if the units are inches, and
then perform one single "scale" operation at the end when you
instantiate the model:
module my_model() {
// definite geometry here with 1" units
// scale up for slicer compatibility
scale(inches) my_model();
This removes the need to repeatedly use "* inches" throughout the model.
Ray
