In the OpenSCAD documentation for minkowski(), examples are given for 2
child objects, ref:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Transformations#minkowski
But what if you supply 3 or more, for example:
$fn=50;
minkowski()
cube([10,10,10]);
cylinder(r=2,h=10);
sphere(r=4);
This seems to be accepted, but it is not obvious what happens in this
case. It looks like the same as below?
$fn=50;
minkowski()
minkowski() {
cube([10,10,10]);
cylinder(r=2,h=10);
sphere(r=4);
In other words, when more than 2 child objects are supplied the child
objects are subject to a series of implicit minkowski operations until
the list is exhausted. Is this a correct interpretation?
I don't think the order matters does it? Basically the result is the set
with all combinations of points added together.
child objects, ref: https://en.wikibooks.org/wiki/
$fn=50;
minkowski()
cube([10,10,10]);
cylinder(r=2,h=10);
sphere(r=4);
$fn=50;
minkowski()
minkowski() {
cube([10,10,10]);
cylinder(r=2,h=10);
sphere(r=4);
objects are subject to a series of implicit minkowski operations until the
On Mar 18, 2018, at 7:41 AM, Carsten Arnholm arnholm@arnholm.org wrote:
In other words, when more than 2 child objects are supplied the child objects are subject to a series of implicit minkowski operations until the list is exhausted. Is this a correct interpretation?
Nophead is right: Minkowski sums are commutative, but they’re implemented by accumulating binary sums as you describe.
The exception is if all operators are convex. In that case we can exploit the fact that the "convex hulls of a minkowski sum” equals the “minkowski sum of convex hulls”. ..and simply collect vertices and calculate a single convex hull:
https://en.wikipedia.org/wiki/Minkowski_addition
Thanks, that makes it clearer. Perhaps the Wiki could mention minkowski
with more than 2 operators and that the order is not significant (i.e.
commutative).
Ok, I see that if all operators are convex then the minkowski sum is
convex as well, and the calculation becomes much simpler. Good point.
