snap looks for its own copies of system files within the file tree for
each snap.
I suggest
sudo apt install mlocate
sudo apt update
sudo locate ibQt5Core.so
and see what you see.
I don't have the OpenSCAD snap, but gravit designer is similar This is
how it looks on disk
/snap/gravit-designer/29/usr/lib/x86_64-linux-gnu/libQt5Core.so.5
/snap/gravit-designer/29/usr/lib/x86_64-linux-gnu/libQt5Core.so.5.5
/snap/gravit-designer/29/usr/lib/x86_64-linux-gnu/libQt5Core.so.5.5.1
And this is the links
-rw-r--r-- 1 root root 5052920 May 13 2017 libQt5Core.so.5.5.1
lrwxrwxrwx 1 root root 19 May 13 2017 libQt5DBus.so.5 ->
libQt5DBus.so.5.5.1
lrwxrwxrwx 1 root root 19 May 13 2017 libQt5DBus.so.5.5 ->
libQt5DBus.so.5.5.1
If say the links from libQt5DBus.so.5 to the actual file is missing you
would get your error
On 11/5/21 10:30 am, Ron Wheeler via Discuss wrote:
Jeremy
oops, I cut and pasted the wrong section of the listing. This is the
correct part
lrwxrwxrwx 1 root root 19 May 13 2017 libQt5Core.so.5 ->
libQt5Core.so.5.5.1
lrwxrwxrwx 1 root root 19 May 13 2017 libQt5Core.so.5.5 ->
libQt5Core.so.5.5.1
each snap.
I suggest
sudo apt update
libQt5DBus.so.5.5.1
libQt5DBus.so.5.5.1
you would get your error
Jeremy
