Dear all,
I am making an animation with OpenScad, and I generate frame images with the
'Dump image' option. However, the images are very low quality, see the
example
attached http://forum.openscad.org/file/t2203/frame00001.png .
Do you know how to increase the image resolution?
Thank you.
I think the only option is to make the window as big as possible.
From the command line you can set the size of dumped images with ---imgsize
but I don't think you can do animation from the command line. You could
dump images one at a time using -D$t=n but it would be slow.
On 12 April 2018 at 10:10, Aleandro michele.roma@hotmail.it wrote:
Dear all,
example
Thank you.
Yeah, sometimes I also missed a full screen or viewport only view.
If I check all view/hide options, the biggest dump I can do on Windows @
1920x1200 screen size is 1924x1132 with no taskbar shown. On my two monitor
system, each @ 1920x1200, I reach up to 3836x1132.
