Why does the attached NOT give me a 16x14 plate with 3mm rounded corners
JS
Jon S
Thu, Oct 15, 2026 8:56 AM
hull(){
cylinder(h=5,d=6,$fn=100);
translate(10,0)
translate(10,8)
  translate(0,8)
Please advise when you folks get a moment.
Thanks,
JonS
hull(){ cylinder(h=5,d=6,$fn=100); translate(10,0) cylinder(h=5,d=6,$fn=100); translate(10,8) cylinder(h=5,d=6,$fn=100); translate(0,8) cylinder(h=5,d=6,$fn=100); } Please advise when you folks get a moment. Thanks, JonS
GS
Guenther Sohler
Thu, Oct 15, 2026 9:00 AM
you need to place the translations in [] brackets like:
translate([10,8,0])
Guenther
On Thu, Oct 15, 2026 at 10:56 AM Jon S via Discuss <
hull(){
translate(10,0)
translate(10,8)
translate(0,8)
Thanks,
JonS
you need to place the translations in [] brackets like: translate([10,8,0]) Guenther On Thu, Oct 15, 2026 at 10:56 AM Jon S via Discuss < discuss@lists.openscad.org> wrote: > hull(){ > > cylinder(h=5,d=6,$fn=100); > > translate(10,0) > > cylinder(h=5,d=6,$fn=100); > > translate(10,8) > > cylinder(h=5,d=6,$fn=100); > > translate(0,8) > > cylinder(h=5,d=6,$fn=100); > > } > > Please advise when you folks get a moment. > > Thanks, > > JonS > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
JS
Jon Sumpter
Thu, Oct 15, 2026 3:53 PM
Guenther,
Thank you.
JonS
From: Guenther Sohler via Discuss discuss@lists.openscad.org
Sent: Thursday, October 15, 2026 2:00 AM
Cc: Guenther Sohler guenther.sohler@gmail.com
Subject: [OpenSCAD] Re: Why does the attached NOT give me a 16x14 plate with 3mm rounded corners
translate([10,8,0])
Guenther
On Thu, Oct 15, 2026 at 10:56 AM Jon S via Discuss <discuss@lists.openscad.orgmailto:discuss@lists.openscad.org> wrote:
hull(){
translate(10,0)
translate(10,8)
translate(0,8)
Thanks,
JonS
Guenther, Thank you. JonS ________________________________ From: Guenther Sohler via Discuss <discuss@lists.openscad.org> Sent: Thursday, October 15, 2026 2:00 AM To: OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org> Cc: Guenther Sohler <guenther.sohler@gmail.com> Subject: [OpenSCAD] Re: Why does the attached NOT give me a 16x14 plate with 3mm rounded corners you need to place the translations in [] brackets like: translate([10,8,0]) Guenther On Thu, Oct 15, 2026 at 10:56 AM Jon S via Discuss <discuss@lists.openscad.org<mailto:discuss@lists.openscad.org>> wrote: hull(){ cylinder(h=5,d=6,$fn=100); translate(10,0) cylinder(h=5,d=6,$fn=100); translate(10,8) cylinder(h=5,d=6,$fn=100); translate(0,8) cylinder(h=5,d=6,$fn=100); } Please advise when you folks get a moment. Thanks, JonS _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org<mailto:discuss-leave@lists.openscad.org>
Thu, Oct 15, 2026 4:15 PM
As Guenter said, the one argument to translate is a single list of two
or three numbers, not two or three plain numbers.  That is:
translate([10,0]) ...
not
translate(10,0) ...
Note: It's not correct to say that the argument to translate() needs to
be in brackets, because it might be a variable or result from an
expression, e.g.:
pos = [10, 0];
translate(pos) something();
translate(pos + [5,5]) somethingElse();
You will see this same pattern in many places throughout the program:
cube(), square(), translate(), rotate(), et cetera.  Some of them can
also take a single number - cube(10), for instance, is equivalent to
cube([10,10,10]) - but their 2D or 3D form always takes a list of
coordinates as a single argument.
But you should have gotten warnings in the console:
WARNING: Too many unnamed arguments supplied in file ., line 5
WARNING: Unable to convert translate(10) parameter to a vec3 or vec2 of numbers in file ., line 5
WARNING: Too many unnamed arguments supplied in file ., line 9
WARNING: Unable to convert translate(10) parameter to a vec3 or vec2 of numbers in file ., line 9
WARNING: Too many unnamed arguments supplied in file ., line 13
WARNING: Unable to convert translate(0) parameter to a vec3 or vec2 of numbers in file ., line 13
and in the Error Log pane:
and even if you've hidden those, you should have gotten an alert at the
top of the 3D view:
If you've hidden the console and the error log, and you've turned off
the warnings and errors in 3D view... don't do that.
Also:  DO turn on "Stop on the first warning" in
Edit/Preferences/Advanced/OpenSCAD Language Features/Warnings.  If
you've got a warning, you need to fix it.
As Guenter said, the one argument to translate is a single list of two or three numbers, not two or three plain numbers.  That is: translate([10,0]) ... not translate(10,0) ... Note: It's not correct to say that the argument to translate() needs to be in brackets, because it might be a variable or result from an expression, e.g.: pos = [10, 0]; translate(pos) something(); translate(pos + [5,5]) somethingElse(); You will see this same pattern in many places throughout the program:  cube(), square(), translate(), rotate(), et cetera.  Some of them can *also* take a single number - cube(10), for instance, is equivalent to cube([10,10,10]) - but their 2D or 3D form always takes a list of coordinates as a single argument. But you should have gotten warnings in the console: WARNING: Too many unnamed arguments supplied in file ., line 5 WARNING: Unable to convert translate(10) parameter to a vec3 or vec2 of numbers in file ., line 5 WARNING: Too many unnamed arguments supplied in file ., line 9 WARNING: Unable to convert translate(10) parameter to a vec3 or vec2 of numbers in file ., line 9 WARNING: Too many unnamed arguments supplied in file ., line 13 WARNING: Unable to convert translate(0) parameter to a vec3 or vec2 of numbers in file ., line 13 and in the Error Log pane: and even if you've hidden those, you should have gotten an alert at the top of the 3D view: If you've hidden the console and the error log, and you've turned off the warnings and errors in 3D view... don't do that. Also:  DO turn on "Stop on the first warning" in Edit/Preferences/Advanced/OpenSCAD Language Features/Warnings.  If you've got a warning, you need to fix it.
