I am working on adding gears to my OpenSCAD model (specifically 1 flat & 1 round to create a sliding structure). I am trying to figure out how to use the modules in the MCAD\involute_gears.scad library. Are there any good detailed tutorials on this library? I don't plan on creating a fancy gearbox or any other complex structure, just a sliding platform moved by a rotating gear. The involute_gears.scad library had a lot of variables/parameters (not to say they aren't necessary, but I still need to know what they are), so I am looking for a good reference and/or tutorial. But one thing I did notice is that some of the modules have parameters with default values that are of the wrong type. For example, the rack(…) module has parameters named circular_pitch & diametral_pitch with default values of false, which causes a warning. I will probably end up specifying most of these parameters anyway (once I learn what they all are), but it makes me wonder why default values would be specified as the wrong type? Any, back to the main question, is there any good documentation or tutorials for this library? Thanks!
Nathan Sokalski
My suggestion is that you use a different gear library. I personally
wouldn't recommend MCAD for any purpose.
Try going here for an explanation of how gears work and a well documented
library to make them:
https://github.com/BelfrySCAD/BOSL2/wiki/gears.scad#section-quick-introduction-to-gears
Note, however, that worm gears are broken. (If anybody knows how to make a
correct enveloping worm gear, get in touch.)
On Thu, May 2, 2024, 14:27 Nathan Sokalski via Discuss <
library? Thanks!
Nathan Sokalski
Thank you for that response, I'll try to take a look at that ASAP.
Nathan Sokalski
From: Adrian Mariano via Discuss discuss@lists.openscad.org
Sent: Thursday, May 2, 2024 4:41 PM
Cc: Adrian Mariano avm4@cornell.edu
Subject: [OpenSCAD] Re: Using MCAD\involute_gears.scad
My suggestion is that you use a different gear library. I personally wouldn't recommend MCAD for any purpose.
Try going here for an explanation of how gears work and a well documented library to make them:
Note, however, that worm gears are broken. (If anybody knows how to make a correct enveloping worm gear, get in touch.)
On Thu, May 2, 2024, 14:27 Nathan Sokalski via Discuss <discuss@lists.openscad.orgmailto:discuss@lists.openscad.org> wrote:
Nathan Sokalski
When I was making gears in OpenScad, I found this library to be very useful:
https://github.com/dpellegr/PolyGear
On Thu, May 2, 2024 at 3:48 PM Nathan Sokalski via Discuss <
To: OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org
library? Thanks!
Nathan Sokalski
I’ve used the BOSL2 gears a little bit and they worked well. The parameters were a little quirky because specifying gears is quirky as it turns out. I had the naive idea you could specify a diameter and number teeth, but no. I had to specify pitch and one or two other things, then I could get the various measurement info back from some other functions.
Good luck!
-Bob
On May 2, 2024, at 11:27, Nathan Sokalski via Discuss discuss@lists.openscad.org wrote:
Nathan Sokalski
njsokalski@hotmail.com mailto:njsokalski@hotmail.com
I'm not sure quirky is exactly how I'd characterize the issue. If you
specify number of teeth and diameter then you've constrained tooth size.
Gears can only mesh if they are the same tooth size (among other things),
so that means if you specify gears that way, you'll be unlikely to ever get
two that can mesh. So you necessarily have to start with tooth size, which
is most naturally (due to how gear math works) given as the "module" of the
gear. At this point if you specify a number of teeth that determines the
radius. Or you could pick a radius and that will determine the number of
teeth. You can tweak the radius with profile shifting or by making helical
gears at different angles. The whole business of gears is about 10x more
complicated than I realized before got sucked into debugging the gear
code.
On Fri, May 3, 2024 at 6:11 PM Bob Carlson via Discuss <
Good luck!
-Bob
On May 2, 2024, at 11:27, Nathan Sokalski via Discuss <
library? Thanks!
Nathan Sokalski
Yeah, if you don’t like quirky, pick your adjective. Intuitive it is not. It makes sense once you spend some time looking into it, but you really do have to invest the time. And thanks for debugging it. And I just came across and used catenary which apparently did not exist a couple of months ago. Handy.
-Bob
On May 3, 2024, at 15:32, Adrian Mariano via Discuss discuss@lists.openscad.org wrote:
I'm not sure quirky is exactly how I'd characterize the issue. If you specify number of teeth and diameter then you've constrained tooth size. Gears can only mesh if they are the same tooth size (among other things), so that means if you specify gears that way, you'll be unlikely to ever get two that can mesh. So you necessarily have to start with tooth size, which is most naturally (due to how gear math works) given as the "module" of the gear. At this point if you specify a number of teeth that determines the radius. Or you could pick a radius and that will determine the number of teeth. You can tweak the radius with profile shifting or by making helical gears at different angles. The whole business of gears is about 10x more complicated than I realized before got sucked into debugging the gear code.
On Fri, May 3, 2024 at 6:11 PM Bob Carlson via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
Good luck!
-Bob
On May 2, 2024, at 11:27, Nathan Sokalski via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
Nathan Sokalski
