I don't have time right this moment to investigate, but generally "one
object works, but disappears as soon as you add another object" means
that the object is malformed. With only one object CGAL (the fancy
geometry processor) doesn't get involved, but with two it does and it
doesn't like malformed objects.
If you have such a malformed object, adding in even something simple
like a cube will demonstrate the problem.
Module structure - what is in a module and what is not - does not affect
the situation. What matters is the 3D shapes and how they are combined.
Note that once you get past this it looks like you will have preview
rendering problems. Parts will be transparent. Your object is not
convex and you have not said "convexity=xxx" in your linear_extrude
call. Just set convexity to 10 or so.
