I have slogged through all of this discussion and a lot of the stuff you posted in your issue on Github, but I am still mystified why you find the idea valuable. The code you have posted is all obscure and difficult to understand. What is the point of obscure and difficult to understand code? I just see no advantage to it. If feels like cleverness for its own sake.
The objects proposal on the other hand and the object literals described in issue 3087 seem immediately and obviously useful. It makes code that is more readable and understandable. It allows something close to OOP. A big win.
-Bob
Tucson AZ
On Sep 4, 2022, at 10:33, Andy Little via Discuss discuss@lists.openscad.org wrote:
Subject: [OpenSCAD] first class modules WIP
Date: September 4, 2022 at 10:33:05 MST
Reply-To: OpenSCAD general discussion discuss@lists.openscad.org
I Have now managed to get some actual openscad output using the first class feature into the CSG tree and am sure now this would be a very useful feature.
The example demonstrates putting modules in an array and returning from function.(Full code available to view here https://github.com/kwikius/openscad/blob/WIP-first-class-module/tests/data/scad/experimental/first_class_module/module_array.scad) ( pic of output attached)
// Example put modules in array and return modules from function
geometry = [
// [rotation , translation , module name ]
[[0,0,0], [0,0,0], module my_sphere],
[[0,45,0],[0,2.5 * rscale,0], module my_cylinder],
[[45,45,0],[0,-2.5 * rscale,0], module my_cube]
instantiate the modules defined in the geometry array
for ( i = [0 :1: 2]){
translate(get_translation(geometry,i)){
rotate(get_rotation(geometry,i)){
modalias = get_module(geometry,i); // module return from function
modalias(); // instantiate the module
The source code for the executable is on the WIP-first-class-module branch if you want to try it:w
https://github.com/kwikius/openscad/tree/WIP-first-class-module https://github.com/kwikius/openscad/tree/WIP-first-class-module
though it won’t use arguments yet, apart from in the way described belo
I found the following syntax useful
my_cube = module cube; // alias the builtin cube
Where there are no arguments, the arguments in the instantiation call are simply passed through to the module.
my_cube([1,2,3],center = true);
looking to implement parameters and arguments next.
<module_array.png>
I have to admit that I also find at least the literal definition
quite convenient syntax wise.
But I'm not saying we should toss out one of the proposals and
just look at the other one. There's information in both which
should be considered on how things will work. By looking at the
topic from various perspectives we hopefully will get something
that works in a sensible and teachable way.
