windmill blades.
Roger Whiteley
Mon, Jun 26, 2023 8:14 PM
Roger  - a follow-up..
These are my notes from a successful STL repair process.. this worked
for me, N.B. I use Ubuntu Linux, so I don't have access to the 3D tools
on a Windows 10 machine.
Stumbling around trying to fix a long broken STL model…
https://formlabs.com/blog/best-stl-file-repair-software-tools/
I used MESHLAB 2022
Load the STL, Enable Display of Boundary Edges, Boundary Faces, No-Manif
Verts, No-Manif Edges, Texture Border.
Then follow the guide in the link above, but this is the report..
Apply Filter Merge Close Vertices
Apply Filter Repair non Manifold Edges
Apply Filter Repair non Manifold Vertices by splitting.
Tried filter Simplification: Quadric Edge Collapse Decimation - failed -
the input mesh isn't watertight…
Apply filter Merge Close Vertices.
Apply filter Close Holes.. ….. …. result!.
Hope this helps..
R.
Roger  - a follow-up.. These are my notes from a successful STL repair process.. this worked for me, N.B. I use Ubuntu Linux, so I don't have access to the 3D tools on a Windows 10 machine. Stumbling around trying to fix a long broken STL model… https://formlabs.com/blog/best-stl-file-repair-software-tools/ <https://formlabs.com/blog/best-stl-file-repair-software-tools/> *I used MESHLAB 2022* Load the STL, Enable Display of Boundary Edges, Boundary Faces, No-Manif Verts, No-Manif Edges, Texture Border. Then follow the guide in the link above, but this is the report.. Apply Filter Merge Close Vertices Apply Filter Repair non Manifold Edges Apply Filter Repair non Manifold Vertices by splitting. Tried filter Simplification: Quadric Edge Collapse Decimation - failed - the input mesh isn't watertight… Apply filter Merge Close Vertices. Apply filter Close Holes.. ….. …. result!. Hope this helps.. R.
