Super Secret Handshake for Examples - OpenSCAD 2015.03
U
unkerjay
Thu, Mar 9, 2017 12:18 PM
I'm using Linux Mint 18.1.
There's an OpenSCAD folder in /usr/share.
There's an OpenSCAD folder in .local/share.
I think there might even be one under .config.
I've copied the folders from /usr/share EVERYWHERE.
I've chmod the settings recursive 777.
Still NOTHING shows up in OpenSCAD.
So, what's the super secret handshake to make this work.
A suggestion:
Maybe either show the folder (such as with Libraries) or perhaps
better yet, allow the setting of the folder location from Preferences.
So far nothing I've seen or tried has worked.
So, what am I missing?
View this message in context: http://forum.openscad.org/Super-Secret-Handshake-for-Examples-OpenSCAD-2015-03-tp20827.html
I'm using Linux Mint 18.1. There's an OpenSCAD folder in /usr/share. There's an OpenSCAD folder in .local/share. I think there might even be one under .config. I've copied the folders from /usr/share EVERYWHERE. I've chmod the settings recursive 777. Still NOTHING shows up in OpenSCAD. So, what's the super secret handshake to make this work. A suggestion: Maybe either show the folder (such as with Libraries) or perhaps better yet, allow the setting of the folder location from Preferences. So far nothing I've seen or tried has worked. So, what am I missing? -- View this message in context: http://forum.openscad.org/Super-Secret-Handshake-for-Examples-OpenSCAD-2015-03-tp20827.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Mar 9, 2017 3:56 PM
Von: unkerjay unkerjay@centurylink.net
Where is the OpenSCAD package coming from? Is that
provided by some Mint repo?
Von: unkerjay <unkerjay@centurylink.net> > I'm using Linux Mint 18.1. > Where is the OpenSCAD package coming from? Is that provided by some Mint repo? ciao, Torsten.
FV
Frank van der Hulst
Thu, Mar 9, 2017 6:00 PM
Where are you looking for the examples?
When I open OpenSCAD, the "Welcome to OpenSCAD" splash screen shows
examples on the right-hand side. In the application itself, the File menu
has an entry for Examples.
Frank
Where are you looking for the examples? When I open OpenSCAD, the "Welcome to OpenSCAD" splash screen shows examples on the right-hand side. In the application itself, the File menu has an entry for Examples. Frank On Fri, Mar 10, 2017 at 4:56 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > Von: unkerjay <unkerjay@centurylink.net> > > I'm using Linux Mint 18.1. > > > Where is the OpenSCAD package coming from? Is that > provided by some Mint repo? > > ciao, > Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Thu, Mar 9, 2017 7:40 PM
The examples are normally (well, on Debian) installed in
/usr/share/openscad/examples/examples.json with that JSON
file being the main index and the actual examples in
subdirectories.
The examples are normally (well, on Debian) installed in /usr/share/openscad/examples/examples.json with that JSON file being the main index and the actual examples in subdirectories. ciao, Torsten.
U
unkerjay
Thu, Mar 9, 2017 9:43 PM
Yeah, I got it from "some Mint repo".
BIG mistake.
As an alternative, on two PCs tested now,
I used the instructions from the download page
for Ubuntu, including the add repository.
I, first, uninstalled, cleaned out my system and
purged files with:
sudo apt-get autoremove,
sudo apt-get autoclean,
and
sudo apt-get purge.
Then I added the other install commands, verbatim.
After that, openscad found the example files, no doubt,
via a more accurate install / update and they're all there
now, where I was expecting to find them and as indicated
here.
If only there weren't so many ways to get it wrong.
View this message in context: http://forum.openscad.org/Super-Secret-Handshake-for-Examples-OpenSCAD-2015-03-tp20827p20844.html
Yeah, I got it from "some Mint repo". BIG mistake. As an alternative, on two PCs tested now, I used the instructions from the download page for Ubuntu, including the add repository. I, first, uninstalled, cleaned out my system and purged files with: sudo apt-get autoremove, sudo apt-get autoclean, and sudo apt-get purge. Then I added the other install commands, verbatim. After that, openscad found the example files, no doubt, via a more accurate install / update and they're all there now, where I was expecting to find them and as indicated here. If only there weren't so many ways to get it wrong. -- View this message in context: http://forum.openscad.org/Super-Secret-Handshake-for-Examples-OpenSCAD-2015-03-tp20827p20844.html Sent from the OpenSCAD mailing list archive at Nabble.com.
